I need to share a folio with a number of employees. This wasn't an issue last week but this week it seems folios with HTMLResources.zip files added will not donwload into content viewer from the Acrobat servers and display an error message shortly after the the free folio is actioned to download. To get around this I simply published it through the distribution service, set to private initially, and I was able to download the whole thing (and without sash) with no problems. Is it possible to get the distribution copy of the folio to other peoples content viewers without having to sign in on every one as me?
Going through the Distro Service was only a workaround for the root problem of not being able to download folios to the iPad CV that have HTMLResources.zip files attached to them, by following normal procedures. (see the original thread here)
This hasnt been (to my knowledge) addressed.
Perhaps one of the Bobs...?
Private publishing requires that the user log in with the same credentials as the person that published. So, no...there is no way to share without handing out the credentials.
Sorry, what is the best way to sharing a folio (that is update every 2/4 days) with other 2 designers/editors and also with a client?
The client should see only the final result on ipad at every update. This work could have a long development for the zero number (30-40 days - is there a time limit for private publishing?)
1- the designers should login with the same adobe id? It's necessary.
2- to show the preview to the client the better solution is private publishing? (updated every xx days).
It could be a problem if the customer use the same login of the designers (but this is required for private publishing...).
What is the best and simple solution to work in a young-poor international team?
Many thanks.
f
