I have made modifications to one image that is in a series that all need, more or less, the same modifications made to them. Is it possible to save settings given to an image and then apply those to another image? How is this done?
TIA,
Ken
LR3 / Macbook Pro / Canon camera RAW image
Selecting all the images you want to apply the setting, then hit SYNC... choose the setting you want to copy over and hit ok.
Another way, right click on the photo you edit, then go to Developing Settings -> Copy Setting, choose setting you want to copy. Then select images you want, right click and Developing Settings -> Paste Setting.
Do I need to do this for each setting then? I have several settings for the image I want to apply all modifications from to other similar images. Is this not possible?
Since I am new to this, I have not been able to find a 'Sync' setting in the pull-down menus, so I assume it is available through some other means. The right click, which is control-click on a Mac gives a menu but not with 'Sync' but it does have develop settings, which when I choose that gives me a menu for choices which I then click on apply but nothing happens. I have a target image selected for this first trial run. How does the program know what the source image is? I get no menus alluding to a source image.
I guess I need a little more basic steps to this.
Using LR 3.5 on a Mac with Lion OSX.
PS, I assume that I am also supposed to be in 'Library' mode because it has the capability of selecting multiple images where 'Develop' just shows one image at a time.
The source is the most selected image (i don't know if I use the correct LR term). When you select multiple images, there is one image in that selection with brighter gray and it is your source image. Most of the time, it would be the first image you selected. But you can change the source image without deselect them all.
