Javascript/ Batch Processing - Query (Please assist/advice)
Sep 19, 2011 11:23 PM
  Latest reply: alienA2, Oct 4, 2011 11:32 PM
Replies 1 2 Previous Next
    Oct 4, 2011 1:29 AM   in reply to alienA2
    If you used the code I provided then that's not true... It will work if the
    word "apple" is anywhere in the file's name.
    However, it is case-sensitive, so if the file is called Apple_1234.pdf it
    will not work.
    To make it case insensitive, change the code to:
    /apple/i.test(this.documentFileName)
    Oct 4, 2011 1:38 AM   in reply to alienA2
    Not sure what you mean by "add description for "apple""? Do you mean that
    you want to edit the meta-data of the file?
    Oct 4, 2011 2:02 AM   in reply to alienA2
    But which field in the meta-data?
    Let's say it's "Title". In that case, you use the same if-statement, and
    then add:
    this.info.Title = "Apple"
    Oct 4, 2011 2:14 AM   in reply to alienA2
    Correct.
    Oct 4, 2011 2:41 AM   in reply to alienA2
    I wrote to you in an earlier post how to get the file name (without the
    extension). Simply apply that to this.info.Title.
    Oct 4, 2011 4:17 AM   in reply to alienA2
    this.documentFileName.replace(/\.pdf$/i,"") gives you the current file's name minus the extension. Think how you can incorporate that in the code you already have...
1 2 Previous Next
Actions
