Can somebody point me to an example of a process that can handle mutiple barcodes in a single document ?
I have created a form in designer with a QR barcode, saved to a tif file. I am able to extract the data to xml using Barcode Forms decoder followed by extract to xml. When adding a second barcode it fails with java.lang.ArrayIndexOutOfBoundsException,
how should I change the process to handle multiple barcodes ?
thanks
Steve
Solved! Go to Solution.
Total Likes
Hi Steve,
I sent an .lca in response to your email. For others I have attached the .lca for the process that looks like this....
It does not use a watched folder but rather reads the .tiff file from the application in the repository directly.
Steve
Total Likes
Steve,
What kind of value encoding are you using? XML, tab-delimited, custom,..?
If you can share the form (stwalker.adobe@gmail.com) I can take a look.
Steve
Total Likes
I am using tab delimited, with field names , and auto filling the barcode
I can manually scan both barcodes on the tif file and see the data - but the process fails on the decode step when dropping it into the watched folder. As mentioned the form with the single barcode works fine
I have sent you the forms.
many thanks for looking at this
Steve
Total Likes
Hi Steve,
Steve
Total Likes
hi steve,
I tried this and it works perfectly, exactly the help I was looking for, I can now apply these changes to my form and process and get moving again !
many thanks
Steve
Total Likes
