Here is a function to read preview images from active catalog
Oct 4, 2011 8:08 AM
--- Get a preview image corresponding to specified photo, at the specified level, if possible.
--  @param photo (LrPhoto or table of param, required)     specified photo or table of named parameters same as below including photo=lr-photo:
--  @param photoPath (string, optional)     photo-path if available, otherwise will be pulled from raw-metadata.
--  @param previewFile (string, default=unique-temp-path)     target path to store jpeg - if non-vil value passed and file is pre-existing, it will be overwritten.
--  @param level (number, required)      appx sizes + intended use:
--      <br>     1 - 80x60     small thumb
--      <br>     2 - 160x120   medium thumb
--      <br>     3 - 320x240   large thumb
--      <br>     4 - 640x480   small image
--      <br>     5 - 1280x960  medium image
--      <br>     6 - 2560x1920 large image
--      <br>     7 - 1:1       full-res
--  @param minLevel (number, default=1) minimum acceptable level.
--  @usage file, errm, level = cat:getPreview{ photo=catalog:getTargetPhoto(), level=5 }
--  @usage file, errm, level = cat:getPreview( catalog:getTargetPhoto(), nil, nil, 5 )
--  @return file (string, or nil) path to file containing requested preview (may be the same as preview-file passed in).
--  @return errm (string, or nil) error message if unable to obtain requested preview (includes path(s)).
--  @return level (number, or nil) actual level read, which may be different than requested level if min-level passed in.
function Catalog:getPreview( photo, photoPath, previewFile, level, minLevel )
    if photo == nil then
        app:callingError( "no photo" )
    end
    if not photo.catalog then -- not lr-photo
        photoPath = photo.photoPath
        previewFile = photo.previewFile
        -- assert( photo.level, "no level in param table" )
        level = photo.level
        minLevel = photo.minLevel
        photo = photo.photo
        -- assert( photo and photo.catalog, "no lr-photo in param table" )
    end
    if level == nil then
        app:callingError( "no level" )
    end
    if level > 7 then
        app:logWarning( "Max level is 7" )
        level = 7
    end
    if photoPath == nil then
        photoPath = photo:getRawMetadata( 'path' )
    end
    local photoFilename = LrPathUtils.leafName( photoPath )
    local _previewFile
    if previewFile == nil then
        _previewFile = LrPathUtils.child( LrPathUtils.getStandardFilePath( 'temp' ), str:fmt( "^1.lrPreview.jpg", photoFilename ) ) -- include extension, since there are separate previews for each file-type.
    else
        if fso:existsAsFile( previewFile ) then
            app:logVerbose( "preview path passed is to existing file to be overwritten" )
        end
        _previewFile = previewFile
    end
    local imageId
    local s = tostring( photo ) -- THIS IS WHAT ALLOWS IT TO WORK DESPITE LOCKED DATABASE (id is output by to-string method).
    local p1, p2 = s:find( 'id "' )
    if p1 then
        s = s:sub( p2 + 1 )
        p1, p2 = s:find( '" )' )
        if p1 then
            imageId = s:sub( 1, p1-1 )
        end
    end
    if imageId == nil then
        return nil, "bad id"
    end
    local cp = catalog:getPath()
    local fn = LrPathUtils.leafName( cp )
    local n = LrPathUtils.removeExtension( fn )
    local cd = LrPathUtils.parent( cp )
    local pn = n .. " Previews.lrdata"
    local d = LrPathUtils.child( cd, pn )
    local pdb = LrPathUtils.child( d, 'previews.db' )
    assert( fso:existsAsFile( pdb ), "nope" )
    --Debug.pause( pdb )
    local exe = app:getPref( 'sqlite3' )
    if not str:is( exe ) then
        if WIN_ENV then
            exe = LrPathUtils.child( _PLUGIN.path, "sqlite3.exe" )
        else
            exe = LrPathUtils.child( _PLUGIN.path, "sqlite3" )
        end
        app:logVerbose( "Using sqlite executable included with plugin: ^1", exe )
    else
        app:logVerbose( "Using custom sqlite executable: ^1", exe )
    end
    local param = '"' .. pdb .. '"'
    local targ = str:fmt( "select uuid, digest from ImageCacheEntry where imageId=^1", imageId )
    local r1, r2, r3 = app:executeCommand( exe, param, { targ }, nil, 'del' )
    local uuid -- of preview
    local digest -- of preview
    if r1 then
        if r3 then
            local c = str:split( r3, '|' )
            if #c >= 2 then
                -- good
                uuid = c[1]
                digest = c[2]
            else
                return nil, "bad split"
            end
        else
            return nil, "no content"
        end
    else
        return nil, r2
    end
    local previewSubdir = str:getFirstChar( uuid )
    local pDir = LrPathUtils.child( d, previewSubdir )
    if fso:existsAsDir( pDir ) then
        -- good
    else
        return nil, "preview letter dir does not exist: " .. pDir
    end
    previewSubdir = uuid:sub( 1, 4 )
    pDir = LrPathUtils.child( pDir, previewSubdir )
        -- good
    else
        return nil, "preview 4-some dir does not exist: " .. pDir
    end
    local previewFilename = uuid .. '-' .. digest .. ".lrprev"
    local previewPath = LrPathUtils.child( pDir, previewFilename )
    if fso:existsAsFile( previewPath ) then
        app:logVerbose( "Found preview file at ^1", previewPath )
    else
        return nil, str:fmt( "No preview file corresponding to ^1 at ^2", photo:getRawMetadata( 'photoPath' ), previewPath )
    end
    -- this could be modified to return image data instead of file if need be.
    local content
    local function getImageFile()
        local p1, p2 = content:find( "level_" .. str:to( level ) )
        if p1 then
            local start = p2 + 2 -- jump over level_n\0
            local p3 = content:find( "AgHg", start )
            local stop
            if p3 then
                stop = start + p3 - 1
            else
                stop = content:len() - 1
            end
            local data = content:sub( start, stop )
            if previewFile ~= nil then -- user passed file
                app:logVerbose( "Writing preview into user file: ^1", _previewFile )
            else
                -- rename file to include level.
                local base = LrPathUtils.removeExtension( _previewFile ) .. '_' .. level
                _previewFile = base .. ".jpg"
                app:logVerbose( "Writing preview into default-named file: ^1", _previewFile )
            end
            local s, m = fso:writeFile( _previewFile, data )
            if s then
                app:logVerbose( "Wrote preview file: ^1", _previewFile )
                return _previewFile
            else
                return nil, m
            end
        else
            return nil -- no real error, just no preview at that level.
        end
    end
    minLevel = minLevel or 1
    local status
    status, content = LrTasks.pcall( LrFileUtils.readFile, previewPath )
    if status and content then
        repeat
            local file, errm = getImageFile() -- at level
            if file then
                return file, nil, level
            elseif errm then
                return nil, errm
            elseif level > minLevel then
                level = level - 1
            else
                return nil, str:fmt( "No preview for ^1 at any acceptable level", photoPath )
            end
        until level <= 0
        return nil, str:fmt( "Unable to obtain preview for ^1", photoPath )
    else
        return nil, str:fmt( "Unable to read preview source file at ^1, error message: ^2", previewPath, content )
    end
end
This function is working great so far, but as of 2011-09-29 it has not been rigorously tested, so it may have a bug or two...
It is based on the elare plugin framework available here (including source code): https://www.assembla.com/spaces/lrdevplugin/
You will need sqlite3 executable from here: http://www.sqlite.org/sqlite.html
- put it in lr(dev)plugin dir
Note: view-factory's picture component will accept a path as resource id, so to use:
local pictureFile, errm = cat:getPreview( photo, nil, nil, 4 )
if pictureFile then
   items[#items + 1] = vf:picture {
       value = pictureFile,
end
Note: the above code is intended for "sample/example" only -
MUST DO:
- Handle portrait orientation properly...
MAYBE DO:
- Handle AdobeRGB profile assignment - not needed for thumbs, but maybe for the biggies...
- Optimize for multi-photo use.
- Change detection for sake of caching for repeated access (like scrolling thumbnails).
@2011-10-04, the code at Assembla.com (see link above) takes care of all these things, and then some...;-)
Rob
    Oct 5, 2011 9:21 AM   in reply to Rob Cole
    There's also undocumented view control:
    LrPhotoPictureView.makePhotoPictureView({
              width=400,
              height=400,
    Should give you a nice view of the currently selected photo if you add this to your view
    Jarno
    Oct 5, 2011 9:43 AM   in reply to jarnoh
    Excellent.  How did you learn about this?  (It's good to learn how to fish, rather than be just given fish.)
    Oct 5, 2011 10:09 AM   in reply to John R. Ellis
    In Mac version there's a file called Contents/PlugIns/MultipleMonitor.lrmodule/Contents/Resources/LrPhotoP ictureView.lua
    Simple strings command on this gives a lot of clues and the rest is just trying it out.
    Jarno
    Oct 5, 2011 10:24 AM   in reply to jarnoh
    Excellent tip, thanks.
    Oct 5, 2011 11:25 AM   in reply to John R. Ellis
    Using the technique of grepping for suspect strings, I found the following additional importable modules. LrRemoteCommunication might be of particular interest to Rob, if he can figure out how to use it:
    LrPhotoPictureView
    {--table: 1
        makePhotoPictureView = function: 0000000015836630}
    {--table: 1
        closeNamedConnection = function: 00000000114B3570,
        pollForMessage = function: 00000000159251F0,
        spawnTaskAndConnect = function: 0000000013EF8610,
        sendMessageToServer = function: 00000000114B3660,
        launchApplicationWithPath = function: 0000000015A592D0}
    LrTableUtils
    {--table: 1
        debugDumpTable = function: 0000000000589430}
    LrUUID
    {--table: 1
        generateUUID = function: 0000000005B75140}
    Oct 7, 2011 10:15 AM   in reply to jarnoh
              width=400,
              height=400,
    Cool. Alas, it appears that width, height cannot be bound to an observable table. I suppose this sort of makes sense, as you wouldn't want the photo jumping around in the container.
    But as a trick for making invisible objects not take up any space, setting this to 0 when a view is first brought up would be nice.
    Duh. I should learn how to use  LrView.conditionalItem() shouldn't I?
    Message was edited by: clvrmnky
    Jan 14, 2012 11:57 AM   in reply to jarnoh
    I did some digging, and it looks like LR4 beta has new view component, viewFactory:catalog_photo.  API seems to work just like LrPhotoPictureView.
    Jan 14, 2012 1:50 PM   in reply to jarnoh
    Neat, thanks.
