dondematias
Premiere cs5 shows yellow line above avchd file, why?
May 18, 2010 8:57 AM
I have recently upgraded to premiere cs5. I was using premiere  cs4 and there was no yellow line above my timeline, the project preset I'm using is exactly the same one an yet it shows differently. Why is this happening? Why does cs4 show no line at all and cs5 does? Even the playback in cs4 is better than in the new cs5! I have tried all the avchd presets and they all show this yellow line.
    May 18, 2010 8:59 AM   in reply to dondematias
    May 18, 2010 9:29 AM   in reply to dondematias
    If a question is not fully answered THERE, don't ask a duplicate question
    Say it was not fully answered, and WHY it was not fully answered, or what you do not understand... THERE
    Keep the discussion in the original message so anyone who may want to try and answer can see what has already been said, rather than starting over
    Any Mod... please lock this discussion so the Q & A may proceed where there is a (partial) answer
    There are 4 possible indicators.
    1. Nothing, in which case no rendering is required.
    2. Red, in which case rendering is required for the most fluid playback.
    3. Yellow, in which case rendering is likely not necessary for playback, but is required on export
    3. Green, in which case the timeline is rendered.
    May 18, 2010 12:06 PM   in reply to dondematias
    Could be that your settings does not match your footage entirely.
    There is this new feature: drag a file into the New Item Icon in the Project Window (just like AE) to make a sequence that matches your footage.
    See if the yellow line has gone.
    May 18, 2010 5:34 PM   in reply to dondematias
    I don't know how did you make it without yellow line in CS4 - with AVC-HD!!! I always had it there!!!
    And had to render files after importing into Timeline cause it was jittering....
    Now, it CS5 i still get the yellow line over some files (those in HDSLR presets), but they play smoothly in FULL RESOLUTION QUALITY!!!!
    No way that playback was better in CS4 - for me, of course - that is only thing I enjoy about CS5 actually - its speed!!!!
    Maybe that is your problem with playback - right click on your Program Monitor and choose lower Viewing quality (choose 1/2 res) - that is also the default value in cs5, if I am not mistaking!
    What is your config? (do you have enough RAM??? I had to switch from 4 to 8 GB of RAM to have CS5 work really smoothly with great, FULL RES. playback, even with unredered effects . like color correction and others - and I don't own CUDA VGA - so WIN7 64bit and PPRO does it's job very well in that part (I still get those yellow lines above CANON 5D footage - and they are showing up to warn you that something in that file isn't exactly matching the Preset's settings - although, I don't know what, cause it is HDSLR preset, exaclty for that kind of h.264 AVC-HD ---- It won't hurt your playback, but it will render when rendering entire sequence or exporting finished project file!
    May 23, 2010 6:10 AM   in reply to dondematias
    I join that.
    I'm trying to edit footage from SANYO Xacti HD1010
    I used to open these type of files in CS4 with the AVCHD 1080i 60fps preset
    with gray line and with smooth playback (no need for render)
    and now in CS5 it opens with a yellow line and with a jerky playback.
    May 23, 2010 6:28 AM   in reply to dondematias
    lol, 5 minutes after my previous post I found the solution for this issue.
    Premiere CS5 is set by default to playback resolution = 1/2 quality
    (you can change it in the output submenu under the monitors).
    I changed it to full and it fixed the jerky playback.
    and now it is smooth like butter.
    though the yellow line is still there but it works great without render...
    I guess because those kind of camera's output is so compressed that  playing it in 1/2 quality
    gives you a very bad preview.
    I hope this will help others..
    - Uri
    Oct 5, 2011 10:48 AM   in reply to Harm Millaard
    How do you get rid of the yellow line? I'm having some issues with export errors. I'm brand new to Premiere not to editing. I assume there is a button to push when you exsport that will render the yellow line. Is there a way you can control the destination of the file as well?
    Oct 5, 2011 11:10 AM   in reply to scott_mo
    Don't worry about the yellow line--at least, not in regard to any export errors you're receiving. Read here for information on the render bars: Red, yellow, and green render bars and what they mean « Premiere Pro work area
    If you're having problems exporting, start a new thread with all relevant details about your sequence, source footage, export settings, and hardware/software setup.
    Aug 3, 2012 9:28 PM   in reply to dondematias
    you can get rid of the yellow by setting the start and end points and then under Sequence click render entire work area
