Can somebody point me to an example of a process that can handle mutiple barcodes in a single document ?
I have created a form in designer with a QR barcode, saved to a tif file. I am able to extract the data to xml using Barcode Forms decoder followed by extract to xml. When adding a second barcode it fails with java.lang.ArrayIndexOutOfBoundsException,
how should I change the process to handle multiple barcodes ?
thanks
Steve
Steve,
What kind of value encoding are you using? XML, tab-delimited, custom,..?
If you can share the form (stwalker.adobe@gmail.com) I can take a look.
Steve
I am using tab delimited, with field names , and auto filling the barcode
I can manually scan both barcodes on the tif file and see the data - but the process fails on the decode step when dropping it into the watched folder. As mentioned the form with the single barcode works fine
I have sent you the forms.
many thanks for looking at this
Steve
