Inserting large amount of records in loop
Oct 5, 2011 6:10 PM
I have a loop that goes from current date to the end of the year and inserts a record for each day up to the end of the year
The question is, is there a better way to do this without having to loop..insert...loop..insert so many times!
Here's the code -->
<!--- OFFSET FOR TIME DIFFERENCE ON SERVER TO LOCAL TIME --->
<CFSET timedifference="2">
<CFSET TestAffUID = "1234">
<CFSET StartDate = #Now()#>
<CFSET EndDate = "01/01/2012">
<CFSET NumberOfDays = #datediff('d',StartDate,EndDate)#>
<CFLOOP INDEX="DateCounter" FROM="0" TO="#NumberOfDays#">
<!--- CREATE THE DATE --->
<CFSET DateToAdd = DateAdd( "d", Datecounter, StartDate )>
<!--- INSERT THE DATE INTO DBASE --->
<CFQUERY NAME="InsertDate" DATASOURCE="#datasource#">
INSERT INTO impressions
imp_aff_uid,
imp_date,
imp_counter
VALUES
#TestAffUID#,
#createodbcdate(dateadd('h',timedifference,DateToAdd))#,
</CFQUERY>
</CFLOOP>
    Oct 6, 2011 2:52 AM   in reply to ACS LLC
    You can insert all records in a single query, something like this:
    insert into table (field1, field2, ...)
    select 'field1value1', 'field2value', ...
    union all
    select 'field1value2', 'field2value2', ...
    union all
    Mack
    Oct 6, 2011 5:39 AM   in reply to mack_
    If you go with mack_'s method, you will have to do something to escape the extra "union" keyword generated in your loop.
    If you have records from last year, you can use and sql dateadd function to do everything in one query.  If you go with this approach, you will have to figure out what to do about leap years.
    Oct 6, 2011 9:37 AM   in reply to ACS LLC
    You currently have your query inside a loop.  You can also put loops inside queries to achieve the syntax mack_ suggested.
    Oct 6, 2011 12:06 PM   in reply to ACS LLC
    You can have SQL Server do the work, less database connections:
    DECLARE @Start int,
            @End int,
            @NextYear varchar(20),
            @ImpDate smalldatetime
    SET @Start = 0
    SET @NextYear = CONVERT(varchar(4), year(DATEADD(yyyy, 1, GETDATE() ))) + '-01-01 00:00:00'
    SET @End = (SELECT DATEDIFF (d , GETDATE(),  @NextYear ))
    WHILE (@Start < @End)
    BEGIN
        SET @ImpDate = (    SELECT DateAdd( hh, 2, DateAdd( d, @Start, getDate() ))    ) /*this is what you intended with the #createodbcdate(dateadd('h',timedifference,DateToAdd))# except that createodbcdate() does not capture the time, you really need createodbcdatetime() */
        /* SET @ImpDate = (    SELECT DateAdd( d, @Start, CONVERT(date, getDate(), 101) )    ) --if you want the time to be 00:00:00 */
        /* Print(@ImpDate) */
        INSERT INTO impressions ([imp_aff_uid], [imp_date], [imp_counter])
        VALUES (1234, @ImpDate, 0)
        SET @Start = @Start +1
    END
    </CFQUERY>
