Keyboard shortcuts
Oct 6, 2011 7:55 AM
Tags: #shortcuts
Hi, all;
I appreciate that several people have put together keyboard shortcut lists, but I still find myself looking for several that I haven't seen documented anywhere.  I know that not all of these may even have shortcuts, but I figure it wouldn't hurt to ask.
Bring stage object forward
Bring stage object to front
Send stage object backward
Send stage object to back
Switch focus from object on stage to object on timeline
Select next/previous object (on stage, like you can do with arrows on timeline)
Move playhead to beginning of slide timeline
Snap end of object timeline to playhead (the opposite of Ctrl-L).
Move slide up in filmstrip
Move slide down in filmstrip
Thanks in advance for any help on this!
Amy
    Oct 6, 2011 8:39 AM   in reply to Amy Blankenship
    Hi Amy,
    Not much to add for concerning shortcuts:
    Shortcuts for Arrangement (back/forward..) are listed in the menu Arrange all with brackets, but I'm not using them because they are only functional on a QWERTY (I'm on AZERTY)
    No way to switch focus from object on stage to timeline AFAIK, and if I want to move through selecting objects I'm doing it on the timeline, where you already discovered the arrows. On stage you can use the TAB-key but it will start from the bottom of the stack on the timeline.
    Move playhead to start timeline (when timeline is in focus): Home
    No snap end of object timeline to playhead, have introduced already multiple times a feature request about that.
    Move slide up/down in filmstip (or even sometimes no need for focus on filmstrip): PageUp/PageDown
    I told you I'm a shortcut freak
    Lilybiri
    Oct 6, 2011 9:02 AM   in reply to Amy Blankenship
    Bring Forward    CTRL+]
    Send Backward    CTRL+[
    Bring to Front    SHIFT+CTRL+]
    Send to Back    SHIFT+CTRL+[
    I'm on CP 5.5
    No shortcuts for moving, but in that case I would not duplicate, but copy, move to the correct place and paste there. Or make the filmstrip floating and expand its size, or use the Branching view
    Lilybiri
