My computer is only 2 months old (WIndows 7) and was working fine. Then I updated adobe flash to the latest (which I believe is 11.0) and now when I play a video (on you tube... but it happens on other sites that uses flash), the video will play for about 3 seconds and then a terrible sound happens and it goes to the blue crash screen. This is consistant, every time the same thing. I reverted back to the system before the update, but it continued to do the same thing. I uninstalled the new flash, reinstalled it and the same thing.
I did see someone with a similar problem, and we both have the NVIDIA GEForce video card. Also, on the blue screen, I did see a message that there was a time out when accessing the NVIDIA, so I'm guessing it has someting to do with that.
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Any ideas?
Here's an update:
I was looking (some more) thru this forum and found this advice:
Re: Cannot view videos with flash player 11
I was having the same problem and this is how I solved it. This worked for me—it may not work for you.
First go to http://get.adobe.com/flashplayer/ and install Adobe Flash Player for your computer.
Click to open Internet Explorer.
marv70"
Even tho my problem was a litte different, I tried it. The only thing was that both the flash and active x were enabled already. So I toggled it (disabled and then enabled) and closed. Then I tried a youtube video and it worked! We'll see if it stays that way...
If that doesn't help also try to update your graphics card driver. This sounds like a driver crash.
That was my next thing to try, but since the computer is new, all the software is updated... but you never know. The crashes started immediately after updating to the new Adobe Flash. Anyway, it's working now.
I'm having the same issue, but it was not resolved by toggling the flash add-on in IE8. Specifically, when I run movies on hulu.com on XP SP3 in IE8, Firefox(7.0.1), or Chrome(14.0.835.202) with flash 11.0.1.152 and the latest nvidia geforce 9400 GT driver v280.26 (latest), the tab takes up at least 200,000 K of Memory, and sooner than later freezes my computer. Sometimes I get the blue screen with the following error: "STOP 0x0000008e (0xe0000001, 0xf8908925, 0xb79ee880, 0x00000000)". Sometimes Chrome will say that the plug-in is unresponsive, but the computer will completely freeze if I try to stop the plug-in. For some reason, hulu.com crashes sooner when I'm logged in. I reintalled firefox & chrome (but didn't delete the dir in the programs folder) and reinstalled flash for both IE and non-IE browsers. I tried running Chrome with just its native flash plugin, but I had the same issues. I have few-to-none add-ons in the browsers, norton safety minder, and ClamWin AV. Not sure what to try next...
Have you tried disabling Hardware Acceleration?
That helps. Thank you.
