I've tried the steps mutliple times with the same error each time. I create a new Experience Service project, enable the Composite Application Framework, delete the default Application file that gets created, add a new CAF Tile (I've tried module and non-module), add a label (with text "Hello World" of course) and a DataGrid. Then I create a New Composite Application, add the newly created tile and then go to Run Configurations... and create a new run config for the experience server and click Run. The browser opens up and I get the standard CAF login box. I login successfully and then receive the error (I've attached a screenshot for reference).
Any help here would be greatly appreciated. (One last item of note, there is not internet access on our developer workstations)
The graphic indicates that its failing on a SWZ for flex 4.5.1. Please note that 4.5.1 is not yet supported by the CAF that is released – that support is coming very soon in a service pack. If you recompile your tiles using Flex 4.5.0, they’ll reference SWZ files that are already available in the ADEP server, and you shouldn’t see this failure.
Don
