Software Monkey
Cannot Install Air on Windows 7
Aug 14, 2011 2:57 AM
I
am unable to install Adobe Air on my Hp Pavilion laptop which is
running Windows 7 x64. I have tried many of the suggestions in this forum but nothing has helped so far. I have listed the log file and MSI log in case anyone can see what is going wrong. There are errors reported in both log files but I dont know what I nee to do to fix them.
AIR Install log file...
[2011-08-14:10:27:36] Runtime Installer begin with version 2.7.1.19610 on Windows 7 x86
[2011-08-14:10:27:36] Commandline is:
[2011-08-14:10:27:36] No installed runtime detected
[2011-08-14:10:27:39] Relaunching with elevation
[2011-08-14:10:27:39] Launching subprocess with commandline c:\users\pauline\appdata\local\temp\airc83e.tmp\adobe air installer.exe -ei
[2011-08-14:10:27:39] Runtime Installer begin with version 2.7.1.19610 on Windows 7 x86
[2011-08-14:10:27:39] Commandline is: -stdio \\.\pipe\AIR_5380_0 -ei
[2011-08-14:10:27:39] No installed runtime detected
[2011-08-14:10:27:39] Starting silent runtime install. Installing runtime version 2.7.1.19610
[2011-08-14:10:27:39] Installing msi at c:\users\pauline\appdata\local\temp\airc83e.tmp\setup.msi with guid {FDB3B167-F4FA-461D-976F-286304A57B2A}
[2011-08-14:10:27:40] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
[2011-08-14:10:27:40] Rolling back install of c:\users\pauline\appdata\local\temp\airc83e.tmp\setup.msi
[2011-08-14:10:27:40] Rollback complete
[2011-08-14:10:27:40] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
[2011-08-14:10:27:40] Runtime Installer end with exit code 7
[2011-08-14:10:27:43] Runtime Installer end with exit code 7
[2011-08-14:10:33:19] Runtime Installer begin with version 2.7.1.19610 on Windows 7 x86
[2011-08-14:10:33:19] Commandline is:
[2011-08-14:10:33:19] No installed runtime detected
[2011-08-14:10:33:21] Relaunching with elevation
[2011-08-14:10:33:21] Launching subprocess with commandline c:\users\pauline\appdata\local\temp\air80b.tmp\adobe air installer.exe -ei
[2011-08-14:10:33:21] Runtime Installer begin with version 2.7.1.19610 on Windows 7 x86
[2011-08-14:10:33:21] Commandline is: -stdio \\.\pipe\AIR_6488_0 -ei
[2011-08-14:10:33:21] No installed runtime detected
[2011-08-14:10:33:22] Starting silent runtime install. Installing runtime version 2.7.1.19610
[2011-08-14:10:33:22] Installing msi at c:\users\pauline\appdata\local\temp\air80b.tmp\setup.msi with guid {FDB3B167-F4FA-461D-976F-286304A57B2A}
[2011-08-14:10:33:22] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
[2011-08-14:10:33:22] Rolling back install of c:\users\pauline\appdata\local\temp\air80b.tmp\setup.msi
[2011-08-14:10:33:22] Rollback complete
[2011-08-14:10:33:22] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
[2011-08-14:10:33:22] Runtime Installer end with exit code 7
[2011-08-14:10:33:24] Runtime Installer end with exit code 7
MSI Log...
=== Verbose logging started: 14/08/2011  10:33:22  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Users\Pauline\appdata\local\temp\air80b.tmp\adobe air installer.exe ===
MSI (c) (94:80) [10:33:22:090]: Resetting cached policy values
MSI (c) (94:80) [10:33:22:090]: Machine policy value 'Debug' is 0
MSI (c) (94:80) [10:33:22:090]: ******* RunEngine:
           ******* Product: c:\users\pauline\appdata\local\temp\air80b.tmp\setup.msi
           ******* Action:
           ******* CommandLine: **********
MSI (c) (94:80) [10:33:22:090]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (94:80) [10:33:22:090]: Grabbed execution mutex.
MSI (c) (94:80) [10:33:22:100]: Cloaking enabled.
MSI (c) (94:80) [10:33:22:100]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (94:80) [10:33:22:100]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (14:F0) [10:33:22:110]: Running installation inside multi-package transaction c:\users\pauline\appdata\local\temp\air80b.tmp\setup.msi
MSI (s) (14:F0) [10:33:22:110]: Grabbed execution mutex.
MSI (s) (14:D4) [10:33:22:110]: Resetting cached policy values
MSI (s) (14:D4) [10:33:22:110]: Machine policy value 'Debug' is 0
MSI (s) (14:D4) [10:33:22:110]: ******* RunEngine:
           ******* Action:
MSI (s) (14:D4) [10:33:22:110]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: User non-assigned for product: 2E27C1FFC30259E4D8423715692DE940
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: User non-assigned for product: 2E27C1FFC30259E4D8423715692DE940
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 000021599B0090400100000000F01FEC
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 000021599B0090400100000000F01FEC
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 00004109500200000000000000F01FEC
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 00004109500200000000000000F01FEC
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 032440EF5AC97F34B985A55C2AA8F133
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 032440EF5AC97F34B985A55C2AA8F133
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 0694AF70830BBE9498B1F95939A05A44
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 0694AF70830BBE9498B1F95939A05A44
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 076CFAAAB965F2A4284B2449E5D03EFE
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 076CFAAAB965F2A4284B2449E5D03EFE
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 08C1B278CE8313A42AC5898002959300
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 08C1B278CE8313A42AC5898002959300
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 0D756077321A70C3E844C138CE981581
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 0D756077321A70C3E844C138CE981581
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 1007C6B46D7C017319E3B52CF3EC196E
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 1007C6B46D7C017319E3B52CF3EC196E
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 1A74D29ED72DA0343886B0FA9D6505D7
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 1A74D29ED72DA0343886B0FA9D6505D7
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 1D034B0FAA6BD374B960AAD30DF10D8B
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 1D034B0FAA6BD374B960AAD30DF10D8B
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 2350B7483E55FAA4D8B73E1A7ADC715E
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 2350B7483E55FAA4D8B73E1A7ADC715E
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 26ABA8B10F47DE741BC84A13825E198B
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 26ABA8B10F47DE741BC84A13825E198B
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 26CEF00243C306D4C98ECE73E2100CF8
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 26CEF00243C306D4C98ECE73E2100CF8
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 2C1A65825C073CE4FA7F5E5BE155032A
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 2C1A65825C073CE4FA7F5E5BE155032A
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 389F20921C4BAB448BD5C5D6252E4C14
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 389F20921C4BAB448BD5C5D6252E4C14
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 38E1FB04BE028D11795C00905C206085
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 38E1FB04BE028D11795C00905C206085
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 3D04254D3B6B9FF42B3445CE3E1E0066
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 3D04254D3B6B9FF42B3445CE3E1E0066
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 42C6FBF1DF1C10144AB2C065F4E9E897
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 42C6FBF1DF1C10144AB2C065F4E9E897
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 4314AE291D01A814191EA5403531A183
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 4314AE291D01A814191EA5403531A183
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 45B438B3B4CE2E84FB6C30FFD50AF626
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 45B438B3B4CE2E84FB6C30FFD50AF626
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 4A4869755DDD3AC4E98AB77E9D95D34B
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 4A4869755DDD3AC4E98AB77E9D95D34B
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 4A9D4F432C248434EB4F5E358C54947E
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 4A9D4F432C248434EB4F5E358C54947E
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 4E42866C3BBC1584BBF38EFC6D539032
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 4E42866C3BBC1584BBF38EFC6D539032
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120622FF
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120622FF
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 4EA42A62D9304AC4784BF268140622FF
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 4EA42A62D9304AC4784BF268140622FF
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 4EE8B9B9BDE22C14FAE2367ED573DCFD
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 4EE8B9B9BDE22C14FAE2367ED573DCFD
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 52744B0D6663D294EB6F85A741DBB99D
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 52744B0D6663D294EB6F85A741DBB99D
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 53A4D966B6414134981FA13C7D8B3876
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 53A4D966B6414134981FA13C7D8B3876
MSI (s) (14:D4) [10:33:22:110]: Setting cached product context: machine assigned for product: 55565908215A0914C9DA0B003CD6B6B6
MSI (s) (14:D4) [10:33:22:110]: Using cached product context: machine assigned for product: 55565908215A0914C9DA0B003CD6B6B6
MSI (s) (14:D4) [10:33:22:120]: Setting cached product context: machine assigned for product: 5E16A70DC95AC334CBDB2220F52A82B7
MSI (s) (14:D4) [10:33:22:120]: Using cached product context: machine assigned for product: 5E16A70DC95AC334CBDB2220F52A82B7
MSI (s) (14:D4) [10:33:22:120]: Setting cached product context: machine assigned for product: 60EA627A3AAA1D34783E075F0113F440
MSI (s) (14:D4) [10:33:22:120]: Using cached product context: machine assigned for product: 60EA627A3AAA1D34783E075F0113F440
MSI (s) (14:D4) [10:33:22:120]: Setting cached product context: machine assigned for product: 6116D6C8427B0184F8D20D746E7B6DE8
MSI (s) (14:D4) [10:33:22:120]: Using cached product context: machine assigned for product: 6116D6C8427B0184F8D20D746E7B6DE8
MSI (s) (14:D4) [10:33:22:120]: Setting cached product context: machine assigned for product: 67D6ECF5CD5FBA732B8B22BAC8DE1B4D
MSI (s) (14:D4) [10:33:22:120]: Using cached product context: machine assigned for product: 67D6ECF5CD5FBA732B8B22BAC8DE1B4D
MSI (s) (14:D4) [10:33:22:120]: Setting cached product context: machine assigned for product: 68AB67CA7DA7FFFFB7449A0100000010
MSI (s) (14:D4) [10:33:22:120]: Using cached product context: machine assigned for product: 68AB67CA7DA7FFFFB7449A0100000010
MSI (s) (14:D4) [10:33:22:120]: Setting cached product context: machine assigned for product: 692203C692165214F96D1288CE8D18E4
MSI (s) (14:D4) [10:33:22:120]: Using cached product context: machine assigned for product: 692203C692165214F96D1288CE8D18E4
MSI (s) (14:D4) [10:33:22:120]: Setting cached product context: machine assigned for product: 6E815EB96CCE9A53884E7857C57002F0
MSI (s) (14:D4) [10:33:22:120]: Using cached product context: machine assigned for product: 6E815EB96CCE9A53884E7857C57002F0
MSI (s) (14:D4) [10:33:22:120]: Setting cached product context: machine assigned for product: 761B3BDFAF4FD16479F68236405AB7A2
MSI (s) (14:D4) [10:33:22:120]: Using cached product context: machine assigned for product: 761B3BDFAF4FD16479F68236405AB7A2
MSI (s) (14:D4) [10:33:22:120]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (14:D4) [10:33:22:120]: User policy value 'DisableMedia' is 0
MSI (s) (14:D4) [10:33:22:120]: Machine policy value 'AllowLockdownMedia' is 1
MSI (s) (14:D4) [10:33:22:120]: SOURCEMGMT: Looking for sourcelist for product {FDB3B167-F4FA-461D-976F-286304A57B2A}
MSI (s) (14:D4) [10:33:22:120]: SOURCEMGMT: Adding {FDB3B167-F4FA-461D-976F-286304A57B2A}; to potential sourcelist list (pcode;disk;relpath).
MSI (s) (14:D4) [10:33:22:120]: SOURCEMGMT: Now checking product {FDB3B167-F4FA-461D-976F-286304A57B2A}
MSI (s) (14:D4) [10:33:22:120]: SOURCEMGMT: Attempting to use LastUsedSource from source list.
MSI (s) (14:D4) [10:33:22:120]: SOURCEMGMT: Trying source c:\users\pauline\appdata\local\temp\airbf96.tmp\.
MSI (s) (14:D4) [10:33:22:120]: Note: 1: 2203 2: c:\users\pauline\appdata\local\temp\airbf96.tmp\setup.msi 3: -2147287037
MSI (s) (14:D4) [10:33:22:120]: SOURCEMGMT: Source is invalid due to missing/inaccessible package.
MSI (s) (14:D4) [10:33:22:120]: Note: 1: 1706 2: -2147483647 3: setup.msi
MSI (s) (14:D4) [10:33:22:120]: SOURCEMGMT: Processing net source list.
MSI (s) (14:D4) [10:33:22:120]: SOURCEMGMT: Processing media source list.
MSI (s) (14:D4) [10:33:22:120]: Note: 1: 2203 2:  3: -2147287037
MSI (s) (14:D4) [10:33:22:120]: SOURCEMGMT: Processing URL source list.
MSI (s) (14:D4) [10:33:22:120]: Note: 1: 1402 2: UNKNOWN\URL 3: 2
MSI (s) (14:D4) [10:33:22:120]: Note: 1: 1706 2:  3: setup.msi
MSI (s) (14:D4) [10:33:22:120]: SOURCEMGMT: Failed to resolve source
MSI (s) (14:D4) [10:33:22:120]: MainEngineThread is returning 1612
MSI (s) (14:F0) [10:33:22:130]: User policy value 'DisableRollback' is 0
MSI (s) (14:F0) [10:33:22:130]: Machine policy value 'DisableRollback' is 0
MSI (s) (14:F0) [10:33:22:130]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (14:F0) [10:33:22:130]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installe r\Rollback\Scripts 3: 2
MSI (s) (14:F0) [10:33:22:130]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installe r\InProgress 3: 2
MSI (s) (14:F0) [10:33:22:130]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
MSI (s) (14:F0) [10:33:22:130]: Restoring environment variables
MSI (c) (94:80) [10:33:22:130]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
MSI (c) (94:80) [10:33:22:130]: MainEngineThread is returning 1612
=== Verbose logging stopped: 14/08/2011  10:33:22 ===
Tony
  • Chris Campbell
    May 4, 2010
    Aug 15, 2011 1:03 PM   in reply to Software Monkey
    Hi Tony,
    Thank you for providing both logs, this is exaclty what we need when we are trying to troubleshoot AIR installer issues.
    Microsoft has just released a brand new tool that should help you resolve this problem.  I'm very curious to get your feedback on it.  Would you mind giving it a try and let us know how it works for you?
    http://support.microsoft.com/mats/Program_Install_and_Uninstall/en-us
    Chris
    Oct 11, 2011 6:46 PM   in reply to Chris Campbell
    You need to make this much, much better known, put it on your download page, put it on the product page.
    I have been developing flash for almost 15 years, and I have not been able to upgrade my Air suite for months - sorry Chris, but that is so bad I can not tell you.
    Basically what is being said is - we cant install flash.
    It is clearly a registry key issue - clearly needs information to be supplied to customers and users right at the download and installation source.
    Oct 11, 2011 9:32 PM   in reply to zx3cv1zx30vzx23c01v3zxc21
    On the other hand, other's (such as myself) have not experienced any problem installing AIR. I've installed it (a number of versions) on both Mac (Lion) and Win7 without any issue.
    That said, putting known fixes to known problems on the product page is a good idea.
    Also an explanation of what the problem is/was would be good. Was it previous versions of AIR failing to uninstall correctly - or current versions of AIR failing to uninstall previous versions correctly. Was it a problem with a version of Windows7?  It all helps to settle one's nerves.
    Carl
