I have tried to install FMG on linux as per instructions. It installs successfully. But it is not starting up? There no logs created? Anyone having the issues? I have tested on Centos 5.5 32bit, Ubuntu 32bit, and Ubuntu 64bit. Same situation....
I had installed it on Ubuntu and it started but can't register any sip profiles... M trying to register a sip profile on a local asterisk server.
Any help would be higly apprecited. Thanks..
Core log files..
#Start-Date: 2011-10-12 13:03:13
#Software: Flash Media Gateway 4.5.0.0 release
#Fields: DATE LEVEL TYPE THREAD COMMENT
2011-10-12::13:03:13.090 INFO 1073742997 CORE 20058 Reading server configurations
2011-10-12::13:03:13.090 ERROR 1073742997 CORE 20058 License Key is not valid; activating Developer Edition limits.
2011-10-12::13:03:13.090 DEBUG 1073742997 CORE 20058 Log Level Initialzed at 1
2011-10-12::13:03:13.093 DEBUG 1073742997 CORE 20058 Loading Plugins.
2011-10-12::13:03:13.094 ERROR 1073742997 CORE 20058 Error Loading plugin /opt/adobe/fmg/mod/libcodech264.so, Cannot locate the symbol registerPlugins
2011-10-12::13:03:13.105 DEBUG 1073742997 CORE 20058 FMG Started.
It seems to be some network/firewall problem if you can stop firewall temporarily please try doing that and then run Flash Media Gateway again.
If that doesn’t work I will suggest you to run wireshark on the machine where Flash Media Gateway is running and restart then send back wireshark capture, conf files and log files. All these information together can help us move further.
In case running wireshark is not possible set debugSIP tag as true and then restart Flash Media Gateway and send back complete log folder and conf folder file.
Hi shbansal,
Please find below log files..
Sip.xml
<Profile>
<profileID> sipGateway </profileID>
<userName> TestProfile </userName>
<!-- SIP username used inside Authentication header. This tag is optional and defaults to <userName> -->
<authUserName> sip_username </authUserName>
<password> sip_password </password>
<displayName> TestProfile </displayName>
<!-- this is the Ip address of remote server where FMG registers -->
<remoteSipHost> xxx.xxx.xxx.xxx </remoteSipHost>
<!-- Indicates FMG registers at remote server -->
<doRegister> 1 </doRegister>
<context> sipGatewayContext </context>
<supportedCodecs>
<codecID> G711u </codecID>
</supportedCodecs>
</Profile>
Note:- xxx.xxx.xxx.xxx is my local Ip address also FMG and Asterisk are running on same machine.
Core logs
#Start-Date: 2011-10-12 14:55:57
2011-10-12::14:55:57.428 INFO 1073742997 CORE 2028 Reading server configurations
2011-10-12::14:55:57.428 ERROR 1073742997 CORE 2028 License Key is not valid; activating Developer Edition limits.
2011-10-12::14:55:57.432 DEBUG 1073742997 CORE 2028 Log Level Initialzed at 1
2011-10-12::14:55:57.456 DEBUG 1073742997 CORE 2028 Loading Plugins.
2011-10-12::14:55:57.457 ERROR 1073742997 CORE 2028 Error Loading plugin /opt/adobe/fmg/mod/libcodech264.so, Cannot locate the symbol registerPlugins
2011-10-12::14:55:57.824 DEBUG 1073742997 CORE 2028 FMG Started.
2011-10-12::14:55:57.826 DEBUG 1073742997 RTMP 2028 Received onStatus <NetConnection.Connect.Closed> code <status> classType <(null)> description <(null)> details
2011-10-12::14:55:57.826 DEBUG 1073742997 SIP 2028 Adding Interface address - xxx.xxx.xxx.xxx
2011-10-12::14:55:57.827 DEBUG 1073742997 SIP 2028 Loading quality level config for device=Tandberg990MXP from /opt/adobe/fmg/conf/videoqualitylevels.xml
2011-10-12::14:55:57.827 DEBUG 1073742997 SIP 2028 Loading quality level config for device=TandbergEdge95MXP from /opt/adobe/fmg/conf/videoqualitylevels.xml
2011-10-12::14:55:57.827 DEBUG 1073742997 SIP 2028 Loading quality level config for device=GenericVtcDevice from /opt/adobe/fmg/conf/videoqualitylevels.xml
2011-10-12::14:55:57.828 DEBUG 1073742997 SIP 2028 registration field not set for profile sipPhone ..setting default to -->Reg to Gib<--
2011-10-12::14:55:57.829 DEBUG 1073742997 RTMP 2028 Received onStatus <NetConnection.Connect.Closed> code <status> classType <(null)> description <(null)> details
2011-10-12::14:55:57.847 INFO 1073742997 RTMP 2028 Connection Failed: Registry Connection to rtmp://localhost/registry/telephony_control
2011-10-12::14:55:57.855 DEBUG 1073742997 SIP 2028 Error : could not resolve the address (sip-phone-ip:5060) error no. :
2011-10-12::14:55:57.855 DEBUG 1073742997 SIP 2028 sip Domain address not set...
2011-10-12::14:55:57.855 DEBUG 1073742997 SIP 2028 registration field not set for profile sipPhone2 ..setting default to -->Reg to Gib<--
2011-10-12::14:55:57.855 DEBUG 1073742997 SIP 2028 Could not get Local Interface addr - default MG Address : xxx.xxx.xxx.xxx is used
2011-10-12::14:55:57.868 WARNING 1073742997 CONTROL 2028 No remote HTTP host or pass specified in fmsmg.xml, exiting discoverHttp
2011-10-12::14:55:57.872 INFO 1073742997 FMS detected IPv6 protocol stack!
2011-10-12::14:55:57.873 INFO 1073742997 FMS config <NetworkingIPv6 enable=false>
2011-10-12::14:55:57.873 INFO 1073742997 FMS running in IPv4 protocol stack mode!
2011-10-12::14:55:57.873 INFO 1073742997 Host: ubuntu IPv4: 127.0.0.1
2011-10-12::14:55:57.874 DEBUG 1073742997 SIP 2028 Error : could not resolve the address (sip-gw-ip:5060) error no. :
2011-10-12::14:55:57.874 DEBUG 1073742997 SIP 2028 Could not get Local Interface addr - default MG Address : xxx.xxx.xxx.xxx is used
2011-10-12::14:55:57.874 DEBUG 1073742997 SIP 2028 sip Domain address not set...
2011-10-12::14:55:57.874 DEBUG 1073742997 SIP 2028 registration field not set for profile sipVideoPhone ..setting default to -->Reg to Gib<--
2011-10-12::14:55:57.926 ERROR 1073742997 SIP 2028 Error : Sip stack could not be constructed : -1
2011-10-12::14:55:58.875 INFO 1073742935 /opt/adobe/fmg/conf/http.xml
2011-10-12::14:56:07.847 DEBUG 1073742997 RTMP 2028 Received onStatus <NetConnection.Connect.Closed> code <status> classType <(null)> description <(null)> details
2011-10-12::14:56:07.847 INFO 1073742997 RTMP 2028 Connection Failed: Registry Connection to rtmp://localhost/registry/telephony
2011-10-12::15:09:57.238 DEBUG 1073742997 RTMP 2028 Received onStatus <NetConnection.Connect.Closed> code <status> classType <(null)> description <(null)> details
2011-10-12::15:09:57.238 INFO 1073742997 RTMP 2028 Connection Failed: Registry Connection to rtmp://localhost/registry/telephony
2011-10-12::15:09:57.238 INFO 1073742997 RTMP 2028 Connection Failed: Registry Connection to rtmp://localhost/registry/telephony_control
2011-10-12::15:09:57.239 DEBUG 1073742997 RTMP 2028 Received onStatus <NetConnection.Connect.Closed> code <status> classType <(null)> description <(null)> details
2011-10-12::15:09:57.239 INFO 1073742997 RTMP 2028 Connection Failed: Registry Connection to rtmp://localhost/registry/telephony_control
2011-10-12::15:10:07.239 DEBUG 1073742997 RTMP 2028 Received onStatus <NetConnection.Connect.Closed> code <status> classType <(null)> description <(null)> details
2011-10-12::15:10:07.239 INFO 1073742997 RTMP 2028 Connection Failed: Registry Connection to rtmp://localhost/registry/telephony
2011-10-12::15:10:07.239 INFO 1073742997 RTMP 2028 Connection Failed: Registry Connection to rtmp://localhost/registry/telephony_control
2011-10-12::15:10:07.240 DEBUG 1073742997 RTMP 2028 Received onStatus <NetConnection.Connect.Closed> code <status> classType <(null)> description <(null)> details
2011-10-12::15:10:07.240 INFO 1073742997 RTMP 2028 Connection Failed: Registry Connection to rtmp://localhost/registry/telephony
2011-10-12::15:10:07.240 INFO 1073742997 RTMP 2028 Connection Failed: Registry Connection to rtmp://localhost/registry/telephony_control
SIp Logs
14:55:57.907 -INFO- STACK - ConstructStackLog - Log was initialized successfully
14:55:57.908 -INFO- STACK - Common Core version 1.4.9 (Release)
14:55:57.908 -INFO- STACK - OS=Linux ES
14:55:57.908 -INFO- STACK - Compiler=GNU-4.1
14:55:57.908 -INFO- STACK - Architecture=Little Endian, 64bit
14:55:57.908 -INFO- STACK - TIME: Timestamp=Posix, Clock=Linux, Tm=Posix
14:55:57.908 -INFO- STACK - THREADS: Semaphore=Posix, Lock=Posix, Mutex=Posix, Thread=Posix
14:55:57.908 -INFO- STACK - MEMORY: OsMem=Malloc
14:55:57.908 -INFO- STACK - NETWORK: Host=Posix, Select=select(), Socket=BSD, PortRange=Fast, DNS=Ares, TLS=None
14:55:57.908 -INFO- STACK - ANSI: 64Ascii=Standard, Assert=Ansi, StdIo=Ansi, LogListener=File&Term
14:55:57.908 -INFO- STACK - CHECKS: NULL=on, Range=on, Other=on
14:55:57.908 -INFO- STACK - USR_CONFIG: EnableIpv6Tos=no, UseFakedIpv6TClass=no, IpsecEnabled=no
14:55:57.908 -INFO- STACK - USR_CONFIG: DnsUsesHosts=yes, DnsUsesCaching=yes, DnsCacheSanity=no
14:55:57.908 -INFO- STACK - USR_CONFIG: UsePosixTimestamps=yes, UseRdtscTimestamps=yes, SelectKqueueGroups=no
14:55:57.908 -INFO- STACK - USR_CONFIG: EhdHostFile=none, QueueType=standard
14:55:57.908 -DEBUG - STACK - CalculateConfigParams - maxTransmitters - default value 100 was taken instead of -1
14:55:57.908 -DEBUG - STACK - CalculateConfigParams - messagePoolNumofPages - default value 150 was taken
14:55:57.908 -DEBUG - STACK - CalculateConfigParams - generalPoolNumofPages - default value 224 was taken
14:55:57.908 -DEBUG - STACK - CalculateConfigParams - numOfReadBuffers - default value 50 was taken
14:55:57.908 -DEBUG - STACK - CalculateConfigParams - elementPoolNumofPages - default value 80 was taken
14:55:57.908 -INFO- STACK - RvSipStackConstruct - RADVISION SIP stack - version 5.5.0.6 - Constructing...
14:55:57.908 -INFO- RA - RA_ConstructFrom - (ElementSize=1568,NumOfElements=150,pLogMgr=0x0x7f86c8052c68,name=Mes sagePool)
14:55:57.908 -INFO- RA - RA_Clear - (raH=0x0x7f86cc0be040(MessagePool))
14:55:57.908 -INFO- RPOOL - RPOOL_CoreConstruct - (elemSize=1536,maxNumOfBlocks=150,allocEmptyBlocks=1,name=MessagePool )=0x0x7f86cc0be020
14:55:57.908 -INFO- RA - RA_ConstructFrom - (ElementSize=1056,NumOfElements=224,pLogMgr=0x0x7f86c8052c68,name=Gen eralPool)
14:55:57.908 -INFO- RA - RA_Clear - (raH=0x0x7f86cc084040(GeneralPool))
14:55:57.908 -INFO- RPOOL - RPOOL_CoreConstruct - (elemSize=1024,maxNumOfBlocks=224,allocEmptyBlocks=1,name=GeneralPool )=0x0x7f86cc084020
14:55:57.908 -INFO- RA - RA_ConstructFrom - (ElementSize=288,NumOfElements=236,pLogMgr=0x0x7f86c8052c68,name=Elem entPool)
14:55:57.908 -INFO- RA - RA_Clear - (raH=0x0x7f86c8058980(ElementPool))
14:55:57.908 -INFO- RPOOL - RPOOL_CoreConstruct - (elemSize=256,maxNumOfBlocks=236,allocEmptyBlocks=1,name=ElementPool) =0x0x7f86c8058960
14:55:57.908 -INFO- STACK - StackAllocateMemoryPools - Memory pools were allocated successfully
14:55:57.909 -INFO- MEMORY - RvMemoryAlloc(block allocated=0x7f86c80588a0)
14:55:57.909 -DEBUG - STACK - StackConstructParserModule - parser module constructed
14:55:57.909 -INFO- MEMORY - RvMemoryAlloc(block allocated=0x7f86c804f9b0)
14:55:57.909 -INFO- MESSAGE- SipMessageMgrConstruct - Message Manager was constructed successfully.
14:55:57.909 -DEBUG - STACK - StackConstructMessageModule - message module constructed
14:55:57.923 -INFO- TRANSPORT - SipTransportConstruct - Constructing the Transport module
14:55:57.923 -INFO- MEMORY - RvMemoryAlloc(block allocated=0x7f86c8010ee0)
14:55:57.923 -DEBUG - TRANSPORT - TransportMgrInitialize - max num of sockets for the stack is: 28
14:55:57.923 -INFO- MEMORY - RvMemoryAlloc(block allocated=0x7f86c801ba90)
14:55:57.923 -DEBUG - THREAD - RvThreadConstructFromUserThread(thread=0x7f86c801ba90) - thread was constructed.
14:55:57.923 -INFO- MEMORY - RvMemoryAlloc(block allocated=0x7f86c8011680)
14:55:57.923 -INFO- MEMORY - RvMemoryAlloc(block allocated=0x7f86c800d3a0)
14:55:57.923 -INFO- MEMORY - RvMemoryAlloc(block allocated=0x7f86c80588e0)
14:55:57.923 -INFO- RLIST - RLIST_PoolListConstruct - (TotalNumberOfUserElements=285,TotalNumberOfLists=1,UserDataRecSize=8 ,name=OORPool)
14:55:57.923 -INFO- RA - RA_ConstructFrom - (ElementSize=16,NumOfElements=1,pLogMgr=0x0x7f86c8052c68,name=OORPool )
14:55:57.923 -INFO- RA - RA_Clear - (raH=0x0x7f86c8002330(OORPool))
14:55:57.923 -INFO- RA - RA_ConstructFrom - (ElementSize=32,NumOfElements=285,pLogMgr=0x0x7f86c8052c68,name=OORPo ol)
14:55:57.923 -INFO- RA - RA_Clear - (raH=0x0x7f86c8054f80(OORPool))
14:55:57.923 -INFO- RLIST - RLIST_PoolListConstruct - (TotalNumberOfUserElements=285,TotalNumberOfLists=1,UserDataRecSize=8 ,name=OORPool)=0x0x7f86c804f9f0
14:55:57.923 -INFO- RLIST - RLIST_ListConstruct - (pListPool=0x0x7f86c804f9f0)
14:55:57.923 -INFO- RA - RA_ConstructFrom - (ElementSize=4096,NumOfElements=1,pLogMgr=0x0x7f86c8052c68,name=SendB uffer)
14:55:57.924 -INFO- RA - RA_Clear - (raH=0x0x7f86c8017d70(SendBuffer))
14:55:57.924 -INFO- RA - RA_ConstructFrom - (ElementSize=4096,NumOfElements=1,pLogMgr=0x0x7f86c8052c68,name=RecvB uffer)
14:55:57.924 -INFO- RA - RA_Clear - (raH=0x0x7f86c80166e0(RecvBuffer))
14:55:57.924 -INFO- MEMORY - RvMemoryAlloc(block allocated=0x7f86c800bc80)
14:55:57.924 -INFO- RLIST - RLIST_PoolListConstruct - (TotalNumberOfUserElements=3,TotalNumberOfLists=1,UserDataRecSize=240 ,name=LocalAddressesPool)
14:55:57.924 -INFO- RA - RA_ConstructFrom - (ElementSize=16,NumOfElements=1,pLogMgr=0x0x7f86c8052c68,name=LocalAd dressesPool)
14:55:57.924 -INFO- RA - RA_Clear - (raH=0x0x7f86c80013b0(LocalAddressesPool))
14:55:57.924 -INFO- RA - RA_ConstructFrom - (ElementSize=264,NumOfElements=3,pLogMgr=0x0x7f86c8052c68,name=LocalA ddressesPool)
14:55:57.924 -INFO- RA - RA_Clear - (raH=0x0x7f86c8018e40(LocalAddressesPool))
14:55:57.924 -INFO- RLIST - RLIST_PoolListConstruct - (TotalNumberOfUserElements=3,TotalNumberOfLists=1,UserDataRecSize=240 ,name=LocalAddressesPool)=0x0x7f86c8011440
14:55:57.924 -INFO- RLIST - RLIST_ListConstruct - (pListPool=0x0x7f86c8011440)
14:55:57.924 -INFO- TRANSPORT - TransportMgrAddLocalAddressToList - UDP Local Address xxx.xxx.xxx.xxx:5060 (0x0x7f86c8018f00) was added to list
14:55:57.924 -INFO- TRANSPORT - TransportMgrAddLocalAddressToList - UDP Local Address 127.0.0.1:5060 (0x0x7f86c8019008) was added to list
14:55:57.924 -ERROR - SOCKET - RvSocketBind(sock=36,addr=xxx.xxx.xxx.xxx:5060,scopeId=-1,range=(nil) ,useRange=0,errno=98)=-2145371137
14:55:57.924 -ERROR - TRANSPORT - TransportUDPOpen (Local Address 0x0x7f86c8018f00): can't bind UDP socket -1 (crv=-2145371137,rv=-1:UNKNOWN)
14:55:57.924 -ERROR - TRANSPORT - LocalAddressOpen - Failed to open local UDP address xxx.xxx.xxx.xxx:5060 (0x0x7f86c8018f00). rv=-1
14:55:57.924 -ERROR - TRANSPORT - OpenLocalAddressesFromList - Failed to open local UDP address xxx.xxx.xxx.xxx:5060 (0x0x7f86c8018f00). rv=-1
14:55:57.924 -ERROR - TRANSPORT - OpenLocalAddresses - Failed to open UDP addresses (rv=-1)
14:55:57.924 -ERROR - TRANSPORT - TransportMgrInitialize - Failed to open local addresses
14:55:57.924 -ERROR - TRANSPORT - SipTransportConstruct - Failed - destructing the module
14:55:57.924 -DEBUG - TRANSPORT - TransportMgrDestruct - Destructing the transport manager
14:55:57.924 -INFO- RLIST - RLIST_PoolListDestruct - (pListPool=0x0x7f86c8011440)
14:55:57.924 -INFO- RA - RA_Destruct - (raH=0x0x7f86c8018e40(LocalAddressesPool))
14:55:57.924 -INFO- RA - RA_Destruct - (raH=0x0x7f86c80013b0(LocalAddressesPool))
14:55:57.924 -INFO- RA - RA_Destruct - (raH=0x0x7f86c8017d70(SendBuffer))
14:55:57.924 -INFO- RA - RA_Destruct - (raH=0x0x7f86c80166e0(RecvBuffer))
14:55:57.924 -INFO- RLIST - RLIST_PoolListDestruct - (pListPool=0x0x7f86c804f9f0)
14:55:57.924 -INFO- RA - RA_Destruct - (raH=0x0x7f86c8054f80(OORPool))
14:55:57.924 -INFO- RA - RA_Destruct - (raH=0x0x7f86c8002330(OORPool))
14:55:57.924 -ERROR - STACK - StackConstructTransportModule - The transport module couldn't be constructed
14:55:57.924 -ERROR - STACK - StackConstructModules - The Transport module couldn't be constructed, rv=-1
14:55:57.924 -ERROR - STACK - RvSipStackConstruct - Failed to construct stack modules. The supplied configuration was:
14:55:57.924 -INFO- STACK - [======Compilation Parameters=========]
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - RELEASE = on
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - RV_SIP_SUBS_ON = on
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - RV_SIP_AUTH_ON = on
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - RV_SIP_HIGHAVAL_ON = on
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - RV_SIP_TEL_URI_SUPPORT = on
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - RV_SIP_OTHER_URI_SUPPORT = on
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - RV_THREADNESS_TYPE = RV_THREADNESS_MULTI
14:55:57.924 -INFO- STACK - [======Stack objects allocation=========]
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - maxCallLegs = 30
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - maxTransactions = 60
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - maxTransmitters = 100
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - maxRegClients = 20
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - maxPubClients = 2
14:55:57.924 -INFO- STACK - [=======Memory pools allocation=========]
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - messagePoolNumofPages = 150
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - messagePoolPageSize = 1536
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - generalPoolNumofPages = 224
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - generalPoolPageSize = 1024
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - elementPoolNumofPages = 236
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - elementPoolPageSize = 256
14:55:57.924 -INFO- STACK - [=======Network parameters==============]
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - bIgnoreLocalAddresses = 0
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - maxNumOfLocalAddresses = 3
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - localUdpAddress = xxx.xxx.xxx.xxx
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - localUdpPort = 5060
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - numOfExtraUdpAddresses = 1
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - tcpEnabled = 0
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - localTcpAddress = 0.0.0.0
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - localTcpPort = 5060
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - numOfExtraTcpAddresses = 0
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - maxConnections = 20
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - ePersistencyLevel = -1
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - connectionCapacityPercent = 0
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - serverConnectionTimeout = -1
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - DLAEnabled = 1
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - outboundProxyIpAddress =
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - outboundProxyHostName = None
14:55:57.924 -INFO- STACK - PrintConfigParamsToLog - outboundProxyPort = 5060
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - eOutboundProxyTransport = -1
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - sendReceiveBufferSize = 4096
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - socketSendReceiveBufferSize = 32768
14:55:57.925 -INFO- STACK - [======Transaction behavior=============]
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - bUseRportParamInVia = 0
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - bDynamicInviteHandling = 0
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - enableServerAuth = 1
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - maxAuthObj = 156
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - bDisableMerging = 0
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - bOldInviteHandling = 0
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - bResolveTelUrls = 0
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - strDialPlanSuffix = NULL
14:55:57.925 -INFO- STACK - [======Call-Leg behavior================]
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - manualAckOn2xx = 0
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - manualPrack = 0
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - bEnableForking = 0
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - forkedAckTrxTimeout = 32000
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - forked1xxTimerTimeout = -1
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - manualBehavior = 0
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - enableInviteProceedingTimeoutState = 1
14:55:57.925 -INFO- STACK - [======Multi-Threaded parameters========]
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - numberOfProcessingThreads = 0
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - processingQueueSize = 100
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - numOfReadBuffers = 50
14:55:57.925 -INFO- STACK - [======Timers configuration=============]
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - retransmissionT1 = 500
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - retransmissionT2 = 4000
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - generalLingerTimer = 8000
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - inviteLingerTimer = 8000
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - provisionalTimer = 180000
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - retransmissionT4 = 5000
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - cancelGeneralNoResponseTimer = -1
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - cancelInviteNoResponseTimer = -1
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - generalRequestTimeoutTimer = -1
14:55:57.925 -INFO- STACK - [======Proxy Timers configuration========]
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - isProxy = 0
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - proxy2xxRcvdTimer = 32000
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - proxy2xxSentTimer = 0
14:55:57.925 -INFO- STACK - [======DNS parameters====================]
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - maxElementsInSingleDnsList = 0
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - maxDnsDomains = 30
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - maxDnsServers = 30
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - maxDnsBuffLen = 4096
14:55:57.925 -INFO- STACK - [======Extension support=================]
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - rejectUnsupportedExtensions = 0
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - addSupportedListToMsg = 1
14:55:57.925 -INFO- STACK - [======Session Timer behavior============]
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - sessionExpires = 1800
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - minSE = -1
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - manualSessionTimer = 0
14:55:57.925 -INFO- STACK - [======Subscription behavior=============]
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - maxSubscriptions = 0
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - subsAlertTimer = 5000
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - subsNoNotifyTimer = 32000
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - subsAutoRefresh = 0
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - bDisableRefer3515Behavior = 0
14:55:57.925 -INFO- STACK - PrintConfigParamsToLog - enableSubsForking = 0
14:55:57.925 -INFO- STACK - [================General Log Filters===================]
14:55:57.925 -INFO- STACK - General Filters - default Filter = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - General Filters - core Filter =
14:55:57.925 -INFO- STACK - General Filters - ads Filter =
14:55:57.925 -INFO- STACK - [================Modules Log Filters===================]
14:55:57.925 -INFO- STACK - Module Filters - CALL= INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - TRANSACTION = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - MESSAGE= INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - TRANSPORT = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - TRANSPORTIMER = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - PARSER = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - STACK = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - MSGBUILDER= INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - AUTH= INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - TRANSC_CLIENT = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - REG_CLIENT= INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - PUB_CLIENT= INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - SUBS= INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - COMPARTMENT = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - RESOLVER = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - TRANSMITTER = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - SECURITY = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - SEC AGREE = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - RLIST = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - RA = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - RPOOL = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - HASH= INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - PQUEUE = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - SEMA4 = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - MUTEX = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - LOCK= INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - MEMORY = INFO,DEBUG,WARN,ERROR,EXCEP
14:55:57.925 -INFO- STACK - Module Filters - THREAD = INFO,DEBUG,WARN,ERROR,EXCEP
