Hi!
I'm making an installer(.msi) for my program with the help of visual studio 2005 tools (in Win 7 64 bit system and Win xp - 32 bit). What is the best way to detect if flash player is installed or not ? I tried doing that with the help of the registry key but it didn't work. Maybe I was not detecting the right key. Can someone give some general guidelines on detecting flash player ?
Hi Varunvp,
You can detect if Flash Player is installed by using the following registry keys:
32-bit Flash Player on 32-bit Windows: HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia
32-bit Flash Player on 64-bit Windows: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia
64-bit Flash Player on 64-bit Windows: HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia
Note the following:
1. It is usually sufficient to detect the 32-bit Flash Player, since the installer for 64-bit is installing both 32-bit and 64-bit Flash Players.
2
...Copy link to clipboard
Hi Varunvp,
Note the following:
2. There are subkeys for both ActiveX (Internet Explorer) and Plugin (Mozilla-based browsers) Flash Players at the locations given above. You can detect a specific type of Flash Player by using these keys, if necessary.
For instructions on how to access the registry, please refer to http://msdn.microsoft.com/
Stephen
Thanks for that Stephen. That helped.
