BoozyMondango
Cannot get OSMF to play AkamaiHD stream from SMIL file
Oct 12, 2011 12:14 PM
Tags: #video #player #osmf #smil #akamai
I have built a player that can play using this smil file fine using the akamaiHDCore library, but I cannot get OSMF to work with it.  You can see the video with the test player below.
http://mediapm.edgesuite.net/edgeflash/public/debug/HDPlayer.html?url= http://mediapm.edgesuite.net/edgeflash/public/debug/assets/smil/earth2 .smil
I am using the sample app SimplePlugin that has been modified to load the smil, and akamaibasicstreaming plugin.
Can someone elighten me as to what might be wrong?  It loads the smil file fine as well as the plugins, but then just does nothing.  No debug output at all.  Code Below:
public class WT08_SimplePlugin extends MovieClip
        //DECLARATIONS
        // Plugin path
        private static const SMIL_PLUGIN:String = "org.osmf.smil.SMILPluginInfo";
        private static const BASIC_STREAMING_PLUGIN:String = "com.akamai.osmf.AkamaiBasicStreamingPluginInfo";
        // Media paths
        public static const MEDIA_PATH:String = "http://mediapm.edgesuite.net/jawyllie/edgeflash_benchmark.smil";
        public var player:MediaPlayer;
        public var container:MediaContainer;
        public var mediaFactory:MediaFactory;
        private var t:int = 0;
        //CONSTRUCTOR
        public function WT08_SimplePlugin()
            stage.scaleMode = StageScaleMode.NO_SCALE;
            stage.align = StageAlign.TOP_LEFT;
            AkamaiBasicStreamingPluginInfo;
            SMILPluginInfo;
            initPlayer();
        protected function initPlayer():void
            // Create a mediafactory instance
            mediaFactory = new MediaFactory();
            //Marker 1: Add the listeners for the plugin load call
            mediaFactory.addEventListener( MediaFactoryEvent.PLUGIN_LOAD, onPluginLoaded );
            mediaFactory.addEventListener( MediaFactoryEvent.PLUGIN_LOAD_ERROR, onPluginLoadFailed );
            //the simplified api controller for media
            player = new MediaPlayer();
            player.autoDynamicStreamSwitch = true;
            //the container (sprite) for managing display and layout
            container = new MediaContainer();
            //Adds the container to the stage
            this.addChild( container );
            //Marker 2: Load the plugin
            loadPlugin( BASIC_STREAMING_PLUGIN );
            loadPlugin( SMIL_PLUGIN );
            //this.loadMedia();
        private function loadPlugin( source:String ):void
            //Marker 3: Create the plugin resource using a static plugin
            var pluginResource:MediaResourceBase;
            var pluginInfoClass:Class = getDefinitionByName( source ) as Class;
            pluginResource = new PluginInfoResource( new pluginInfoClass() );
            //Marker 4: Load the plugin
            mediaFactory.loadPlugin( pluginResource );
        protected function onPluginLoaded( event:MediaFactoryEvent ):void
            trace( "onPluginLoaded()" );
            if(this.t == 1){
                loadMedia();
            }else{
                this.t = 1;
        protected function onPluginLoadFailed( event:MediaFactoryEvent ):void{
            trace( "onPluginFailedLoad()" );
        protected function removeMediaFactoryEventListeners():void
            mediaFactory.removeEventListener( MediaFactoryEvent.PLUGIN_LOAD, onPluginLoaded );
            mediaFactory.removeEventListener( MediaFactoryEvent.PLUGIN_LOAD_ERROR, onPluginLoadFailed );
        protected function loadMedia():void
            //Marker 6: The pointer to the media
            var resource:URLResource = new URLResource( MEDIA_PATH );
            var element:MediaElement = mediaFactory.createMediaElement( resource );
            // Add the media element
            player.media = element;
            container.addMediaElement( element );
    Oct 13, 2011 3:41 AM   in reply to BoozyMondango
    Please set player.autoPlay=true before adding the element to start playback.
    Can you test with another smil? Like http://mediapm.edgesuite.net/osmf/content/test/smil/elephants_dream.sm il .
    S.
