Using a PDF I downloaded online, I inserted comments using both Adobe Acrobat Pro and Nuance PDF Converter Pro.
In both the Acrobat and Nuance applications I can print the PDF with the comments just fine.
When I opened the document in Adobe Reader 9.4.0 it would not print the comments by default.
I hunted around the File > Print & Edit > Preferences dialog boxes but found no such option in Reader 9.4. It either does not exist, or I'm not looking in the proper place(s).
I opened the same document in Adobe Reader X and I did have the option to print the comments as outlined in the instructions here (http://kb2.adobe.com/cps/897/cpsid_89733.html).
On that same page however it says a comment printing options should be on both the Edit > Preferences and File > Print dialog boxed in Reader 9 but it is not. The instructions above appear to be inaccurate.
I've tested this on multiple systems (same base OS & configuration) but the problem persists: How does one print comments in Adobe Reader 9.4.0? (Upgrading is not an option at this time.)
Thanks for the response. Please refer to my screenshot above.
As you can see its already set to 'Document and Markups' but in the mini-preview (thumbnail preview) of the document, it does not show the comment I have on that page. When I actually print the document, the comments do not show up. Conversely in Reader X when its set to 'Document and Markups' it shows the comments in the mini-preview.
Thanks for the speedy response!
