Looking to replace a Flash Slideshow/Banner with something more universal
Oct 13, 2011 8:25 PM
This site has a Flash Slideshow banner thingie -
http://www.ddbikes.com/
- that I wouls like to replace with something jQuery or other AJAXie solution for the obvious reasons of cross-platform compatibility. I've seen a few sites, well, many many sites that do this i some fashion or another and my next step is to go digging through the code to see what's being used and how. But I thought I'd start here first to maybe get a head start if anyone can point me to any scripts or solutions.
The requirements are pretty basic, but they are requirements. From experience, I know that a lot of these scripts can maybe do 3 out of 4 things out of the box, but that 4th thing can end up being troublesome. So it needs to -
  • Rotate through a set of images with the ability to set the time between transitions
  • Transitions can be simple fades, the blurring effect is optionsl
  • Optional place links on images
  • Some way to manually advance to another image - thumgnmail, other image, whatever.
  • Toolyiip on rollover of these advance buttons/images
  • AND - somewhat easy to update. The person doing the updating has no trouble with getting into the code view and updating image names and links, etc.
Anyone have any favorite solutions for this?  Thanks!
Lon
    Oct 14, 2011 6:44 AM   in reply to Lon Winters
    If you haven't already, investigate Project Seven, which has several solutions and is a solid source. www.projectseven.com
    Chris
    www.cdeatherage.net
    Oct 14, 2011 9:29 AM   in reply to cdeatherage
    Well, here is a link to the jquery slideshow I like. My requirements are not the same as yours, so you will have to take a look to see if it meets your needs.
    It is really easy to update. Just change the images in the directory.
    http://jquery.malsup.com/cycle/
    Oct 14, 2011 10:25 AM   in reply to Lon Winters
    I use this jQuery slidebox on my site (customized to my requirements).
    http://manos.malihu.gr/slidebox-jquery-banner-rotator
    Adobe Widget Exchange has Spry Content Slideshow
    http://alt-web.com/sandbox/Spry-test.html
    Nancy O.
    Alt-Web Design & Publishing
    Web | Graphics | Print | Media  Specialists
    http://alt-web.com/
    http://twitter.com/altweb
    Apr 14, 2012 11:09 AM   in reply to Lon Winters
    Lon, you can use multiple Dreamweaver plugins and multiple "Widgets" on the same page.
    Here's a pseudo-code example:
    (within the <head> section):
    <script type="text/javascript" src="js/jquery-1.5.1.min.js"></script>
    <script type="text/javascript" src="js/widget1.js"></script>
    <script type="text/javascript" src="js/widget2.js"></script>…
    Then, to the extent your widgets call styles, place the links to stylesheets below that.
    </head>
    <body>
    place your widgets in the body as divs, either as a Class or an ID and don't forget to close the tags.
    </body>
    </html>
    Apr 14, 2012 11:20 AM   in reply to Lon Winters
    You can have multiple Spry widgets on the same page however it works best if you use the same Spry UI version for all.
    This working demo shows one page with:
    • Spry Menu 2.0,
    • Spry Tabbed Panels 2.0
    • Spry Content Slideshow
    View the source code to see which Spry support files are common to all widgets and which are specific to each widget.
    http://alt-web.com/DEMOS/Spry-test.html
    Nancy O.
    http://alt-web.com/
