I want to load a mesh, and use its shape in order to create a rigidbody. Is there a solution to pass a vertex array for example to create a shape. If so, what class I need to use ? (com.adobe.pellet.collision.shape.bt... )
I can use a primitive shape for my rigidBody, but I want my object stands on its own faces.
I got the reference of SceneNode and now using createRigidBody, I want to convert it to rigidbody - so that I can apply mass.
But, I am not able to grip the third parameter which says -
public function createRigidBody( obj:SceneNode, mass:Number, shape:btCollisionShape ):btRigidBody
// I've reached till here...
var tree:SceneNode = new SceneNode( "PalmTrees" );
var rigidTree:PelletRigidBody = mPellet.createRigidBody(tree, 0, WHAT_GOES_HERE??);
Any idea? ![]()
Finally, its done !!!
Here is the code to extract the mesh data from loaded model and apply rigidBody to it.
I used "TestPhysicsStaticMesh.as" class from Proscenium Samples folder to get this done. ![]()
_modelLoader = new OBJLoader( "../res/content/PalmTrees/PalmTrees.obj" );
_modelLoader.addEventListener( Event.COMPLETE, loadComplete);
protected function loadComplete( event:Event ):void
var manifest:ModelManifest = _modelLoader.model.addTo( tree );
var scale:Number = 2;
for each (var boatMesh:SceneMesh in manifest.meshes)
var indices:Vector.<uint> = new Vector.<uint>;
var vertices:Vector.<Number> = new Vector.<Number>;
var indexVertexArray:btTriangleIndexVertexArray;
var shape:btBvhTriangleMeshShape;
var boatCollision:SceneNode;
var rbody:btRigidBody;
boatMesh.getIndexVertexArrayCopyForAllElements( indices, vertices );
indexVertexArray = new btTriangleIndexVertexArray( indices.length/3, indices, vertices.length/3, vertices );
shape = new btBvhTriangleMeshShape(indexVertexArray,false);
boatCollision = new SceneNode;
boatMesh.addChild( boatCollision );
rbody = mPellet.createRigidBody(boatCollision, 0, shape);
shape.setLocalScaling(scale,scale,scale);
rbody.worldTransform.origin.setValue(10,0,-20);
boatCollision.physicsObject.collisionFlags |= btCollisionObject.CF_STATIC_OBJECT;
boatMesh.appendScale(scale,scale,scale);
boatMesh.appendTranslation(10,0,-20);
scene.addChild( boatMesh );
