I noticed that there is a Logger class within the Gravity classes: http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/com /adobe/gravity/utility/logging/Logger.html
Is it possible to use this logging from within CAF? I added a "normal" logger and it does not work for me when debugging a CAF project - none of my messages are sent to the console. I noticed that the Mosaic classes do not have any logging utilities but the Gravity classes do.
Yes, Gravity logging APIs can be used in Mosaic as-is. To view the log output:
1. Open CRXDE lite in a browser and log in
2. Navigate to /libs/mosaic/components/index/index.jsp
3. Locate the line in the file that initializes the flashvars variable. In 10.0 this should be on line 65
4. After that line, add a new line:
flashvars.mdebug = true;
5. Click the “Save All” button to save the changes
Then, when a new application is launched, a debug window will appear with a “Log Viewer” tab. Note that the debug window will appear in the upper left corner of the browser in a layer that will be behind html or pdf content, so if your application’s layout has html or pdf content in the upper left region you may not be able to see the debug window.
If you have any difficulties with using the gravity logging within mosaic, the CAF (Mosaic) forum http://forums.adobe.com/community/adep/capabilities/composite-applicat ion-framework will be another source of help.
Don
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
