NA770
FTP Fails in Dreamweaver MX, Same Config Works in CS5
Oct 16, 2011 5:37 PM
I've been using Dreamweaver MX for about 5 years and have been using FTP throughout that period.  About a week ago FTP started failing with the error message "An FTP error occurred - cannot make connection to host."  My FTP log is blank, as if it did not attempt to make an FTP connection.  If I save my site config and using that same site config in Dreamweaver CS5, then I can connect and use FTP without issue.  I can also connect with other FTP programs, such as Filezilla. This confirms that I am using correct login information, and FTP is available for the website.  Switching to passive FTP did not help.  Removing and re-installing Dreamweaver MX did not help.  Turning off all my firewalls did not help.  Searching around the web, one person mentioned a similar issue being caused by the server that maintains the website changing their SSH host key changing and were able to resolve that by deleting Dreamweaver's ssh host file.  For him the file was at ~/Library/Application Support/Dreamweaver 8/Configuration/ssh_hosts.  However, it seems to be in a different location for Dreamweaver MX on my Widows 7 computer.  Any ideas on what might be causing this or what I could try?
    Oct 16, 2011 8:52 PM   in reply to NA770
    I would recheck the configurations all over again.  In fact, the best thing is to delete the current configurations and then re-enter them again very carefully.  99% of the time people always make mistakes when re-entering the info.  Also, it is a good idea to print the e-mail you might have received from your host and keep it in front of you when you are re-entering the FTP info.
    If this fails, then you need to try using FileZilla, WS-FTP or something else to check whether your host hasn't messed up your account in some material way.  They do all the time because they like poking their noses in almost anything when they don't have anything to do.
    hth
    Oct 17, 2011 5:07 AM   in reply to NA770
    If you have both CS5 and MX, why not just uninstall MX?  It's outdated and the error could be a conflict with an OS that postdates DW MX by over 7 years.  Adobe has no announced plans to support MX and seeing how they released CS5.5 after CS5, I don't foresee them going backwards to fix the problem.
    Oct 17, 2011 2:41 PM   in reply to NA770
    How about if you take a gamble and reinstall your DW MX?  It could solve the problem. IMHO
    Oct 17, 2011 5:59 PM   in reply to BarakObi
    Well - this is a very good suggestion but what puzzles me is why should a software that worked for 5 years suddenly stopped working.  This is completely beyond any sensible reasons.
    I think the MX was initially working in either Windows 2000 or Windows XP and now the NA770 decided to install the same product in Windows 7.  If this is so then it looks like it must be a question of rights attached to that user.  The OP should, perhaps try using as an ADMINISTRATOR or a USER account with those privileges to see if it is anything to do with the rights/security issues of Windows 7.
    We don't know if the product is still running on the old operating system/machine.  5 years ago we didn't have Windows 7 and MX was released well before XP was released.
    I am reluctant to suggest to reformat the HD and clear any bugs that might have entered the system but it is up to the OP to decide now.
    There is no solution to this problem assuming all the configuration settings are correct as claimed in this thread.
    Oct 17, 2011 6:55 PM   in reply to NA770
    Have you tried creating a new site definition and uploading a test page (one page will do) to see if it works in the new site?  As far as I know, DW keeps all configurations for different sites separate from each other.
    Just a try.
    Oct 17, 2011 7:25 PM   in reply to mytaxsite.co.uk
    Your FTP client (be it Dreamweaver or Filezilla) is only 50% of the equation. There was probably a server side change that CS5 can handle and MX can't. Check with your host.
    If they have updated something that makes MX obsolete for connecting, then it's yet another reason to finally let go of seven year old software.
