AE Interleave compression check box?
Oct 18, 2011 6:52 PM
Tags: #exporting #compression #lossless
Is there an interleave compression check box for After Effects. I remember a tutorial saying to check a check box during export; otherwise, the file will be huge. Problem is I forgot and can't find that check box.
    Oct 18, 2011 8:14 PM   in reply to ryanjohnsond
    "interleave"?
    Are you referring to interlacing? You can use the Field Render option in the render settings to make interlaced video.
    It seems that you are asking a general question about compression. Start here, and come back if you have questions.
    Oct 20, 2011 2:18 AM   in reply to ryanjohnsond
    There has never been a dedicated audio interleave checkbox in AE and even if there were, it would have no effect on file size - interleaved PCM data is just as big as the separate WAV/ AIFF file. In order to reduce file size, you would have to use a compressed audio CoDec, but that's very much a specific output format setting and has nothing to do with AE as such.
    Mylenium
