Hello all, I typically work in Illustrator whenever I need to do some print work but decided to use Photoshop this time around as I was going for more realism.
I have used some effects(linear burn, overlay, screen etc...) but tried to respect the print colors as much as possible.
Could someone please tell me how I should now save/export the image for the most accurate print results?
Do I simply flatten image and then change color mode to CMYK?
Any help appreciated!
Image > Mode > CMYK would use the settings and target space as defined under Edit > Color Settings.
These may not fit the actual printing needs, so if the image is indeed going to be printed (offset or other process) better ask the printer which ICC-profile they recommend in this case.
Edit:
Saving a pdf As a Copy from Photoshop can be used to create a file that maintains Vector Masks and type as vector data (not Vector Smart Objects, though, mind you).
Thank you for the help guys.
I ended up saving the image as a high res jpeg and importing it into Illustrator as the background image.
Then I saved the file as an EPS and sent the EPS over to the printer.
This would mean that he/she can set it up as they need for print right?
P.S. Im pretty sure it is offset.
