Tim RG
Audition CS5.5 Crashes Immediately After Start-Up.
Jun 30, 2011 2:00 PM
Hello,
I'm running Audition off a MacBook Pro Version 10.6.6 -- immediately after attempted start-up and I receive a message informing me that the application has quit unexpectedly. I attempt to reopen the application but to no avail. Any suggestions?
    Jun 30, 2011 2:41 PM   in reply to Tim RG
    Rename the following folder to something else (e.g. "4.0_backup").   This will simulate clearing your preferences
    ~/Library/Preferences/Adobe/Audition/4.0
    Launch Audition, and then post what is in the "Audition Log.txt" file that is created in the new 4.0 folder that will be created the next time you launch Audition.
    You also didn't mention if this has always happened since you installed and activated the product, or if it started after something else.
    Jul 1, 2011 8:03 AM   in reply to Tim RG
    Glad to hear you're up and running again.   The method I outlined above is sort of an all or nothing sledgehammer move.   In the future, you may wish to hold the [ Shift ] key while starting Audition as that will "ignore" any previous preferences upon startup.
    However, if it does happen again, I'd like to work with you to figure out the actual cause, because if we can narrow it down, we can figure out some other behavior in the future than whatever is crashing it right now.   Be sure to send in those crash logs with comments...
    Oct 16, 2011 6:29 AM   in reply to Charles VW
    Hello. My Audition can not start. Please help me
    Here is the log file
    Log file created: 10/16/2011 8:24:39 PM
    Ticks = 0      <4132> <AuLog.Startup> <5> Application: Audition
    Ticks = 0      <4132> <AuLog.Startup> <5> Version 4.0
    Ticks = 16      <4132> <AuLog.Startup> <5> Build: 1815
    Ticks = 218      <4132> <AuLog.Startup> <5> AuUI initialization sequence started...
    Ticks = 218      <4132> <AuLog.Startup> <5> Initializing Crash Recovery
    Ticks = 234      <4132> <AuLog.Startup> <5> Initializing AuDSP
    Ticks = 250      <4132> <AuLog.Startup> <5> Initializing AuBackEnd
    Ticks = 312      <4132> <AuLog.Startup> <5> Initializing AuApplication
    Ticks = 312      <4132> <AuLog.Startup> <5> AuApplication initialization sequence started...
    Ticks = 312      <4132> <AuLog.Startup> <5> Initializing XML Loader
    Ticks = 359      <4132> <AuLog.Startup> <5> Initializing Application Settings
    Ticks = 359      <4132> <AuLog.Startup> <5> Intializing dva unit test and console
    Ticks = 359      <4132> <AuLog.Startup> <5> Initializing Audio Device
    Ticks = 452      <4132> <AuLog.Startup> <5> Initializing XMP System
    Ticks = 468      <4132> <AuLog.Startup> <5> Initializing AMIO Host
    Ticks = 468      <4132> <AuLog.Startup> <5> AMIO Host initialization sequence started...
    Ticks = 484      <4132> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioAiff
    Ticks = 515      <4132> <AuLog.Plug-in> <5> Audition AIFF Amio plug-in. ID: 775c126d-5387-4af8-aa44-2209d40b102a
    Ticks = 530      <4132> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioLSF
    Ticks = 593      <4132> <AuLog.Plug-in.AmioLSF> <5> Loading libsndfile...
    Ticks = 640      <4132> <AuLog.Plug-in.AmioLSF> <5> libsndfile version detected: libsndfile-1.0.23
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00020000  AIFF (Apple/SGI) aiff
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020001      Signed 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020003      Signed 24 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020004      Signed 32 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020005      Unsigned 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020006      32 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020007      64 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020010      U-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020011      A-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020012      IMA ADPCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020020      GSM 6.10
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020040      12 bit DWVW
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020041      16 bit DWVW
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020042      24 bit DWVW
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00030000  AU (Sun/NeXT) au
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030001      Signed 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030003      Signed 24 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030004      Signed 32 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030006      32 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030007      64 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030010      U-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030011      A-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030030      32kbs G721 ADPCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030031      24kbs G723 ADPCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00120000  AVR (Audio Visual Research) avr
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00120001      Signed 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00120002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00120005      Unsigned 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00180000  CAF (Apple Core Audio File) caf
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180001      Signed 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180003      Signed 24 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180004      Signed 32 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180006      32 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180007      64 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180010      U-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180011      A-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00170000  FLAC (FLAC Lossless Audio Codec) flac
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00170001      Signed 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00170002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00170003      Signed 24 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00100000  HTK (HMM Tool Kit) htk
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00100002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00060000  IFF (Amiga IFF/SVX8/SV16) iff
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00060001      Signed 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00060002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000c0000  MAT4 (GNU Octave 2.0 / Matlab 4.2) mat
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000c0002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000c0004      Signed 32 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000c0006      32 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000c0007      64 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000d0000  MAT5 (GNU Octave 2.1 / Matlab 5.0) mat
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0004      Signed 32 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0005      Unsigned 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0006      32 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0007      64 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00210000  MPC (Akai MPC 2k) mpc
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00210002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00200000  OGG (OGG Container format) oga
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00200060      Vorbis
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00050000  PAF (Ensoniq PARIS) paf
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00050001      Signed 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00050002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00050003      Signed 24 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00050004      Signed 32 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000e0000  PVF (Portable Voice Format) pvf
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000e0001      Signed 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000e0002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000e0004      Signed 32 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00040000  RAW (header-less) raw
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040001      Signed 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040003      Signed 24 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040004      Signed 32 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040005      Unsigned 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040006      32 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040007      64 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040010      U-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040011      A-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040020      GSM 6.10
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040040      12 bit DWVW
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040041      16 bit DWVW
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040042      24 bit DWVW
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040021      VOX ADPCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00220000  RF64 (RIFF 64) rf64
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220003      Signed 24 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220004      Signed 32 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220005      Unsigned 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220006      32 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220007      64 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220010      U-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220011      A-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00160000  SD2 (Sound Designer II) sd2
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00160001      Signed 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00160002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00160003      Signed 24 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00110000  SDS (Midi Sample Dump Standard) sds
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00110001      Signed 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00110002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00110003      Signed 24 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000a0000  SF (Berkeley/IRCAM/CARL) sf
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0003      Signed 24 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0004      Signed 32 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0006      32 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0010      U-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0011      A-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00080000  VOC (Creative Labs) voc
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00080002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00080005      Unsigned 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00080010      U-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00080011      A-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000b0000  W64 (SoundFoundry WAVE 64) w64
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0003      Signed 24 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0004      Signed 32 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0005      Unsigned 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0006      32 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0007      64 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0010      U-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0011      A-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0012      IMA ADPCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0013      Microsoft ADPCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0020      GSM 6.10
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00010000  WAV (Microsoft) wav
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010002      Signed 16 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010003      Signed 24 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010004      Signed 32 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010005      Unsigned 8 bit PCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010006      32 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010007      64 bit float
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010010      U-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010011      A-Law
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010012      IMA ADPCM
    Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010013      Microsoft ADPCM
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010020      GSM 6.10
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010030      32kbs G721 ADPCM
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00070000  WAV (NIST Sphere) wav
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070001      Signed 8 bit PCM
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070002      Signed 16 bit PCM
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070003      Signed 24 bit PCM
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070004      Signed 32 bit PCM
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070010      U-Law
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070011      A-Law
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00130000  WAVEX (Microsoft) wav
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130002      Signed 16 bit PCM
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130003      Signed 24 bit PCM
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130004      Signed 32 bit PCM
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130005      Unsigned 8 bit PCM
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130006      32 bit float
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130007      64 bit float
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130010      U-Law
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130011      A-Law
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130012      IMA ADPCM
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130013      Microsoft ADPCM
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130020      GSM 6.10
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130030      32kbs G721 ADPCM
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00190000  WVE (Psion Series 3) wve
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00190011      A-Law
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000f0000  XI (FastTracker 2) xi
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000f0051      16 bit DPCM
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000f0050      8 bit DPCM
    Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> libsndfile version detected: libsndfile-1.0.23
    Ticks = 671      <4132> <AuLog.Plug-in> <5> Audition libsndfile Amio plug-in. ID: caf0f3de-96be-4e2f-85a7-ac6e61310fcb
    Ticks = 671      <4132> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioMp3
    Ticks = 796      <4132> <AuLog.Plug-in> <5> Audition Mp3 Amio plug-in. ID: ea4740a7-e67e-4070-bed8-3bd3727779db
    Ticks = 811      <4132> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioQT
    Ticks = 811      <4132> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioWav
    Ticks = 827      <4132> <AuLog.Plug-in> <5> Audition Wave Amio plug-in. ID: 60df8553-00c8-4fd7-8a07-6f25e30ab79c
    Ticks = 827      <4132> <AuLog.Startup> <5> AMIO Host initialization sequence complete.
    Ticks = 842      <4132> <AuLog.Startup> <5> Session Host initialization sequence started...
    Ticks = 858      <4132> <AuLog.Plug-in> <5> Loading Session plug-in: FinalCutXML
    Ticks = 967      <4132> <AuLog.Plug-in> <5> FCP XML session plug-in. ID: 611577b8-4c4f-4253-a29d-f01516cdeb90
    Ticks = 967      <4132> <AuLog.Plug-in> <5> Loading Session plug-in: LegacyXML
    Ticks = 1045      <4132> <AuLog.Plug-in> <5> Audition 3.0 XML session plug-in. ID: da4b6774-0370-4c6d-912b-bd0e3a763ef8
    Ticks = 1045      <4132> <AuLog.Plug-in> <5> Loading Session plug-in: OmfSession
    Ticks = 1154      <4132> <AuLog.Plug-in> <5> DQ OMF PLug-In. ID: 94debb27-326b-4457-92ba-84d6e6f75567
    Ticks = 1170      <4132> <AuLog.Plug-in> <5> Loading Session plug-in: PremiereProInterchange
    Ticks = 1217      <4132> <AuLog.Plug-in> <5> Adobe Premiere Pro to Audition XML session interchange plug-in. ID: d22d3d0c-2f52-4651-bd94-f73eb80b7e2c
    Ticks = 1217      <4132> <AuLog.Plug-in> <5> Loading Session plug-in: SesxNative
    Ticks = 1279      <4132> <AuLog.Plug-in> <5> Audition Sesx plug-in. ID: e4fe4447-02d0-44c6-90c8-89d5083fcd26
    Ticks = 1279      <4132> <AuLog.Startup> <5> Session Host initialization sequence complete.
    Ticks = 1310      <4132> <AuLog.Startup> <5> Initializing Clipboard Manager
    Ticks = 1310      <4132> <AuLog.Startup> <5> Initializing Preset Manager
    Ticks = 1310      <4132> <AuLog.Startup> <5> Initializing Favorites Manager
    Ticks = 1310      <4132> <AuLog.Startup> <5> AuApplication initialization sequence complete.
    Ticks = 1310      <4132> <AuLog.Startup> <5> Initializing AsyncQueueManager
    Ticks = 1310      <4132> <AuLog.Startup> <5> Initializing AuUI
    Ticks = 1732      <4132> <AuLog.Startup> <5> Initializing AuScripting
    Ticks = 1747      <4132> <AuLog.Startup> <5> Setting up temp directories
    Ticks = 2184      <4132> <AuLog.Startup> <5> AuUI initialization sequence complete.
    Oct 16, 2011 6:32 AM   in reply to HIeuLQ
    I use Window 64 bit and this is Audition CS5, slash window appear and program die immediately.
    Oct 16, 2011 11:45 AM   in reply to HIeuLQ
    Did you try the advice given above to ignore or remove your preferences?
    %USERPROFILE%\AppData\Roaming\Adobe\Audition\4.0
    Alternatively, try the methods in this FAQ to provide more context.
    Oct 19, 2011 7:50 AM   in reply to Charles VW
    Yup, I tried this. But then it still crash.   I just did nothing. Install trial version, open it and it stop immediately.
    Oct 19, 2011 9:20 AM   in reply to HIeuLQ
    Oct 23, 2011 9:37 PM   in reply to Tim RG
    Audition crashes upon startup ever since I installed it.  Tried above methods and the alternative FAQ, but nothing has worked.
    Here is the log.
    Log file created: 10/24/2011 12:32:40 AM
    Ticks = 15      <2584> <AuLog.Startup> <5> Application: Audition
    Ticks = 15      <2584> <AuLog.Startup> <5> Version 4.0
    Ticks = 15      <2584> <AuLog.Startup> <5> Build: 1815
    Ticks = 140      <2584> <AuLog.Startup> <5> AuUI initialization sequence started...
    Ticks = 140      <2584> <AuLog.Startup> <5> Initializing Crash Recovery
    Ticks = 140      <2584> <AuLog.Startup> <5> Initializing AuDSP
    Ticks = 140      <2584> <AuLog.Startup> <5> Initializing AuBackEnd
    Ticks = 218      <2584> <AuLog.Startup> <5> Initializing AuApplication
    Ticks = 218      <2584> <AuLog.Startup> <5> AuApplication initialization sequence started...
    Ticks = 218      <2584> <AuLog.Startup> <5> Initializing XML Loader
    Ticks = 234      <2584> <AuLog.Startup> <5> Initializing Application Settings
    Ticks = 234      <2584> <AuLog.Startup> <5> Intializing dva unit test and console
    Ticks = 234      <2584> <AuLog.Startup> <5> Initializing Audio Device
    Ticks = 359      <2584> <AuLog.Startup> <5> Initializing XMP System
    Ticks = 359      <2584> <AuLog.Startup> <5> Initializing AMIO Host
    Ticks = 359      <2584> <AuLog.Startup> <5> AMIO Host initialization sequence started...
    Ticks = 374      <2584> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioAiff
    Ticks = 374      <2584> <AuLog.Plug-in> <5> Audition AIFF Amio plug-in. ID: 775c126d-5387-4af8-aa44-2209d40b102a
    Ticks = 374      <2584> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioLSF
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Loading libsndfile...
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> libsndfile version detected: libsndfile-1.0.23
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00020000  AIFF (Apple/SGI) aiff
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020001      Signed 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020003      Signed 24 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020004      Signed 32 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020005      Unsigned 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020006      32 bit float
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020007      64 bit float
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020010      U-Law
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020011      A-Law
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020012      IMA ADPCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020020      GSM 6.10
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020040      12 bit DWVW
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020041      16 bit DWVW
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020042      24 bit DWVW
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00030000  AU (Sun/NeXT) au
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030001      Signed 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030003      Signed 24 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030004      Signed 32 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030006      32 bit float
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030007      64 bit float
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030010      U-Law
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030011      A-Law
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030030      32kbs G721 ADPCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030031      24kbs G723 ADPCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00120000  AVR (Audio Visual Research) avr
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00120001      Signed 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00120002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00120005      Unsigned 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00180000  CAF (Apple Core Audio File) caf
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180001      Signed 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180003      Signed 24 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180004      Signed 32 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180006      32 bit float
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180007      64 bit float
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180010      U-Law
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180011      A-Law
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00170000  FLAC (FLAC Lossless Audio Codec) flac
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00170001      Signed 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00170002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00170003      Signed 24 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00100000  HTK (HMM Tool Kit) htk
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00100002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00060000  IFF (Amiga IFF/SVX8/SV16) iff
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00060001      Signed 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00060002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000c0000  MAT4 (GNU Octave 2.0 / Matlab 4.2) mat
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000c0002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000c0004      Signed 32 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000c0006      32 bit float
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000c0007      64 bit float
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000d0000  MAT5 (GNU Octave 2.1 / Matlab 5.0) mat
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0004      Signed 32 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0005      Unsigned 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0006      32 bit float
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0007      64 bit float
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00210000  MPC (Akai MPC 2k) mpc
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00210002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00200000  OGG (OGG Container format) oga
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00200060      Vorbis
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00050000  PAF (Ensoniq PARIS) paf
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00050001      Signed 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00050002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00050003      Signed 24 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00050004      Signed 32 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000e0000  PVF (Portable Voice Format) pvf
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000e0001      Signed 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000e0002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000e0004      Signed 32 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00040000  RAW (header-less) raw
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040001      Signed 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040003      Signed 24 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040004      Signed 32 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040005      Unsigned 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040006      32 bit float
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040007      64 bit float
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040010      U-Law
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040011      A-Law
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040020      GSM 6.10
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040040      12 bit DWVW
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040041      16 bit DWVW
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040042      24 bit DWVW
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040021      VOX ADPCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00220000  RF64 (RIFF 64) rf64
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220003      Signed 24 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220004      Signed 32 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220005      Unsigned 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220006      32 bit float
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220007      64 bit float
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220010      U-Law
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220011      A-Law
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00160000  SD2 (Sound Designer II) sd2
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00160001      Signed 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00160002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00160003      Signed 24 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00110000  SDS (Midi Sample Dump Standard) sds
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00110001      Signed 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00110002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00110003      Signed 24 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000a0000  SF (Berkeley/IRCAM/CARL) sf
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0003      Signed 24 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0004      Signed 32 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0006      32 bit float
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0010      U-Law
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0011      A-Law
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00080000  VOC (Creative Labs) voc
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00080002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00080005      Unsigned 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00080010      U-Law
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00080011      A-Law
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000b0000  W64 (SoundFoundry WAVE 64) w64
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0002      Signed 16 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0003      Signed 24 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0004      Signed 32 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0005      Unsigned 8 bit PCM
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0006      32 bit float
    Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0007      64 bit float
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0010      U-Law
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0011      A-Law
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0012      IMA ADPCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0013      Microsoft ADPCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0020      GSM 6.10
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00010000  WAV (Microsoft) wav
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010002      Signed 16 bit PCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010003      Signed 24 bit PCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010004      Signed 32 bit PCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010005      Unsigned 8 bit PCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010006      32 bit float
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010007      64 bit float
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010010      U-Law
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010011      A-Law
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010012      IMA ADPCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010013      Microsoft ADPCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010020      GSM 6.10
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010030      32kbs G721 ADPCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00070000  WAV (NIST Sphere) wav
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070001      Signed 8 bit PCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070002      Signed 16 bit PCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070003      Signed 24 bit PCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070004      Signed 32 bit PCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070010      U-Law
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070011      A-Law
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00130000  WAVEX (Microsoft) wav
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130002      Signed 16 bit PCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130003      Signed 24 bit PCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130004      Signed 32 bit PCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130005      Unsigned 8 bit PCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130006      32 bit float
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130007      64 bit float
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130010      U-Law
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130011      A-Law
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130012      IMA ADPCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130013      Microsoft ADPCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130020      GSM 6.10
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130030      32kbs G721 ADPCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00190000  WVE (Psion Series 3) wve
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00190011      A-Law
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000f0000  XI (FastTracker 2) xi
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000f0051      16 bit DPCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000f0050      8 bit DPCM
    Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> libsndfile version detected: libsndfile-1.0.23
    Ticks = 390      <2584> <AuLog.Plug-in> <5> Audition libsndfile Amio plug-in. ID: caf0f3de-96be-4e2f-85a7-ac6e61310fcb
    Ticks = 390      <2584> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioMp3
    Ticks = 390      <2584> <AuLog.Plug-in> <5> Audition Mp3 Amio plug-in. ID: ea4740a7-e67e-4070-bed8-3bd3727779db
    Ticks = 390      <2584> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioQT
    Ticks = 827      <2584> <AuLog.Plug-in> <5> Quicktime version detected: 0x07698000 7.6.9
    Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: smi
    Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/smil
    Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mpegurl
    Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-mpegurl
    Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime extension: smi,smil,sml
    Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime extension: m3u,m3url
    Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: wav
    Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/wav
    Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-wav
    Ticks = 873      <2584> <AuLog.Plug-in> <5> Quicktime extension: wav,bwf
    Ticks = 873      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: 3gp2
    Ticks = 873      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/3gpp2
    Ticks = 873      <2584> <AuLog.Plug-in> <5> Quicktime extension: 3g2
    Ticks = 873      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: 3gpp
    Ticks = 873      <2584> <AuLog.Plug-in> <5> Quicktime extension: 3gp
    Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: aifc
    Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/aiff
    Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-aiff
    Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime extension: aiff,aif,aifc,cdda
    Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: aiff
    Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: fli
    Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/flc
    Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime extension: flc,fli
    Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: giff
    Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/gif
    Ticks = 905      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: gsm
    Ticks = 905      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-gsm
    Ticks = 905      <2584> <AuLog.Plug-in> <5> Quicktime extension: gsm
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: mpeg
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/mpeg
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/x-mpeg
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mpeg
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-mpeg
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime extension: mpeg,mpg,m1s,m1v,m1a,m75,m15,mpm,mpv,mpa
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime extension: mpeg,mpg,m1s,m1a,mpm,mpa
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: midi
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/midi
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-midi
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime extension: midi,mid,smf,kar
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: mp3
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mp3
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-mp3
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mpeg3
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-mpeg3
    Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime extension: mp3
    Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: pict
    Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/pict
    Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-pict
    Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: smil
    Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/smil
    Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mpegurl
    Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-mpegurl
    Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime extension: smi,smil,sml
    Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime extension: m3u,m3url
    Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: sd2f
    Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-sd2
    Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime extension: sd2
    Ticks = 951      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: text
    Ticks = 951      <2584> <AuLog.Plug-in> <5> Quicktime mime type: text/plain
    Ticks = 951      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: ulaw
    Ticks = 951      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/basic
    Ticks = 951      <2584> <AuLog.Plug-in> <5> Quicktime extension: au,snd,ulw
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: vfw
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/x-msvideo
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/avi
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/msvideo
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime extension: avi,vfw
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: wave
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/wav
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-wav
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime extension: wav,bwf
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: ac3
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/ac3
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-ac3
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime extension: ac3
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: adts
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/aac
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-aac
    Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime extension: aac
    Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: amc
    Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/x-mpeg
    Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: amr
    Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/AMR
    Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime extension: amr
    Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: caff
    Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-caf
    Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime extension: caf
    Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: cdda
    Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/aiff
    Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-aiff
    Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime extension: aiff,aif,aifc,cdda
    Ticks = 998      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: celp
    Ticks = 998      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/vnd.qcelp
    Ticks = 998      <2584> <AuLog.Plug-in> <5> Quicktime extension: qcp
    Ticks = 998      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: dvc
    Ticks = 998      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/x-dv
    Ticks = 998      <2584> <AuLog.Plug-in> <5> Quicktime extension: dv,dif
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: grip
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-sgi
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-photoshop
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-bmp
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/vnd.fpx
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/gif
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/jpeg2000-image
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-jpeg2000-image
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/jp2
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/pjpeg
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-macpaint
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/pict
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-pict
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/png
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-png
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-quicktime
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-targa
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/tiff
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-tiff
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: mpg4
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/mp4
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mp4
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime extension: mp4,mpg4
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: qhtm
    Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: text/x-html-insertion
    Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: rtsp
    Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/x-rtsp
    Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: sdp
    Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/sdp
    Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/x-sdp
    Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: sdv
    Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/3gpp
    Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime extension: 3gp
    Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: utxt
    Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime mime type: text/plain
    Ticks = 1107      <2584> <AuLog.Plug-in> <5> Audition QuickTime Amio plug-in. ID: 01914214-f044-47f7-a43b-5e98267fafd0
    Ticks = 1107      <2584> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioWav
    Ticks = 1107      <2584> <AuLog.Plug-in> <5> Audition Wave Amio plug-in. ID: 60df8553-00c8-4fd7-8a07-6f25e30ab79c
    Ticks = 1107      <2584> <AuLog.Startup> <5> AMIO Host initialization sequence complete.
    Ticks = 1123      <2584> <AuLog.Startup> <5> Session Host initialization sequence started...
    Ticks = 1139      <2584> <AuLog.Plug-in> <5> Loading Session plug-in: FinalCutXML
    Ticks = 1139      <2584> <AuLog.Plug-in> <5> FCP XML session plug-in. ID: 611577b8-4c4f-4253-a29d-f01516cdeb90
    Ticks = 1139      <2584> <AuLog.Plug-in> <5> Loading Session plug-in: LegacyXML
    Ticks = 1139      <2584> <AuLog.Plug-in> <5> Audition 3.0 XML session plug-in. ID: da4b6774-0370-4c6d-912b-bd0e3a763ef8
    Ticks = 1139      <2584> <AuLog.Plug-in> <5> Loading Session plug-in: OmfSession
    Ticks = 1139      <2584> <AuLog.Plug-in> <5> DQ OMF PLug-In. ID: 94debb27-326b-4457-92ba-84d6e6f75567
    Ticks = 1154      <2584> <AuLog.Plug-in> <5> Loading Session plug-in: PremiereProInterchange
    Ticks = 1154      <2584> <AuLog.Plug-in> <5> Adobe Premiere Pro to Audition XML session interchange plug-in. ID: d22d3d0c-2f52-4651-bd94-f73eb80b7e2c
    Ticks = 1154      <2584> <AuLog.Plug-in> <5> Loading Session plug-in: SesxNative
    Ticks = 1154      <2584> <AuLog.Plug-in> <5> Audition Sesx plug-in. ID: e4fe4447-02d0-44c6-90c8-89d5083fcd26
    Ticks = 1154      <2584> <AuLog.Startup> <5> Session Host initialization sequence complete.
    Ticks = 1154      <2584> <AuLog.Startup> <5> Initializing Clipboard Manager
    Ticks = 1154      <2584> <AuLog.Startup> <5> Initializing Preset Manager
    Ticks = 1154      <2584> <AuLog.Startup> <5> Initializing Favorites Manager
    Ticks = 1154      <2584> <AuLog.Startup> <5> AuApplication initialization sequence complete.
    Ticks = 1154      <2584> <AuLog.Startup> <5> Initializing AsyncQueueManager
    Ticks = 1170      <2584> <AuLog.Startup> <5> Initializing AuUI
    Ticks = 1388      <2584> <AuLog.Startup> <5> Initializing AuScripting
    Ticks = 1388      <2584> <AuLog.Startup> <5> Setting up temp directories
    Oct 24, 2011 9:18 AM   in reply to rossnano
    Here is the log.
    I don't think you tried what was requested in the FAQ, because you've not posted the crash dump or system information that was requested in the FAQ.  Instead, you posted the Audition Log file, which is usually helpful, but not in this situation.  Also, the steps mentioned in the FAQ won't stop your crash, it will only help you get us the information we need to figure out what the crash is.  I'd first try to delete your preferences folder.
    Oct 24, 2011 9:32 AM   in reply to Charles VW
    hello, please help me, i dont know how to solve this problem. Audition CS5.5 crashes to after start-up.
    system information
    Hardware Overview:
      Model Name:          MacBook
      Model Identifier:          MacBook6,1
      Processor Name:          Intel Core 2 Duo
      Processor Speed:          2.26 GHz
      Number of Processors:          1
      Total Number of Cores:          2
      L2 Cache:          3 MB
      Memory:          4 GB
      Bus Speed:          1.07 GHz
      Boot ROM Version:          MB61.00C8.B00
      SMC Version (system):          1.51f53
      Serial Number (system):          45012Q3H8PW
      Hardware UUID:          83B15CC5-50FA-53F9-ABB2-9F4CDF9BE254
      Sudden Motion Sensor:
      State:          Enabled
    problem detail and system configration
    Process:         Adobe Audition [3829]
    Path:            /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/MacOS/Adobe Audition
    Identifier:      com.adobe.Audition.4.0
    Version:         4.0x1815 (4.0)
    Code Type:       X86 (Native)
    Parent Process:  launchd [156]
    Date/Time:       2011-10-25 00:28:01.532 +0800
    OS Version:      Mac OS X 10.7.2 (11C74)
    Report Version:  9
    Interval Since Last Report:          199872 sec
    Crashes Since Last Report:           71
    Per-App Interval Since Last Report:  168 sec
    Per-App Crashes Since Last Report:   40
    Anonymous UUID:                      913EA101-2C51-460B-A86C-99F2C6F9883B
    Crashed Thread:  0  Dispatch queue: com.apple.main-thread
    Exception Type:  EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
    VM Regions Near 0:
    --> __PAGEZERO             0000000000000000-0000000000001000 [    4K] ---/--- SM=NUL  /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/MacOS/Adobe Audition
        __TEXT                 0000000000001000-0000000000003000 [    8K] r-x/rwx SM=COW  /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/MacOS/Adobe Audition
    Application Specific Information:
    objc[3829]: garbage collection is OFF
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0   org.perian                              0x0f3686cc 0xf226000 + 1320652
    1   com.apple.CoreServices.CarbonCore          0x950fb5f5 CallComponent + 223
    2   com.apple.CoreServices.CarbonCore          0x950fb63e CallComponentDispatch + 29
    3   com.apple.CoreServices.CarbonCore          0x95167898 CallComponentOpen + 43
    4   com.apple.CoreServices.CarbonCore          0x950fa2b4 OpenAComponent + 426
    5   com.apple.CoreServices.CarbonCore          0x950fa334 OpenComponent + 24
    6   com.apple.CoreServices.CarbonCore          0x950fb57c CallComponent + 102
    7   com.apple.CoreServices.CarbonCore          0x950fb63e CallComponentDispatch + 29
    8   com.apple.QuickTime                     0x9af104a0 MovieImportGetMIMETypeList + 43
    9   com.adobe.AmioQT.bundle                 0x0b8a593b amio::qt::QueryExtensions(std::list<std::string, std::allocator<std::string> >&, std::list<std::string, std::allocator<std::string> > const*, bool, ComponentDescription) + 283
    10  com.adobe.AmioQT.bundle                 0x0b8a677b amio::qt::QueryImportExtensions(std::list<std::string, std::allocator<std::string> >&, std::list<std::string, std::allocator<std::string> >*, bool) + 107
    11  com.adobe.AmioQT.bundle                 0x0b89ba0e amio::AmioQTInterface::GetAmioInfo(amio::AmioGetAmioInfoInterface&) + 398
    12  com.adobe.AmioQT.bundle                 0x0b896b1a amio::AmioInterfaceTemplate<amio::qt::Source, amio::qt::Source>::EntryPoint(int, void*, void*) + 218
    13  com.adobe.AmioQT.bundle                 0x0b895e69 AmioInterface + 57
    14  com.adobe.aubackend.framework           0x01fe2c82 abe::AmioPlugin::LoadModule(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 482
    15  com.adobe.aubackend.framework           0x01fdcb40 abe::AmioHost::Impl::LoadModule(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 576
    16  com.adobe.aubackend.framework           0x01fe035f abe::AmioHost::Impl::Initialize(std::list<abe::AmioInfo, std::allocator<abe::AmioInfo> > const*, boost::function<void ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >)>&) + 2351
    17  com.adobe.aubackend.framework           0x01fda611 abe::AmioHost::Initialize(std::list<abe::AmioInfo, std::allocator<abe::AmioInfo> > const*, boost::function<void ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >)>) + 33
    18  AuApplication                           0x028c4f4a app::Initializer::Initialize(bool, boost::function<void ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >)>) + 3306
    19  AuUI                                    0x03b56440 aui::ApplicationInitializer::Impl::Initialize(dvaworkspace::workspace ::Workspace*) + 2768
    20  AuUI                                    0x03b4bc3c aui::ApplicationInitializer::Initialize(dvaworkspace::workspace::Work space*) + 28
    21  AuUI                                    0x0353d6d7 aui::Application::InitApplication(exo::app::AppInitArgs&) + 3943
    22  com.adobe.exo.framework                 0x0194cdf9 exo::app::AppBase::Initialize(exo::app::AppInitArgs&) + 729
    23  AuUI                                    0x0353243e aui::Application::Initialize(exo::app::AppInitArgs&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 158
    24  AuUI                                    0x03555c0f AudMacMain(int, char**) + 415
    25  com.adobe.Audition.4.0                  0x00002ecd main + 93
    26  com.adobe.Audition.4.0                  0x00002c66 start + 54
    Thread 1:: Dispatch queue: com.apple.libdispatch-manager
    0   libsystem_kernel.dylib                  0x91a6890a kevent + 10
    1   libdispatch.dylib                       0x9a3f1c58 _dispatch_mgr_invoke + 969
    2   libdispatch.dylib                       0x9a3f06a7 _dispatch_mgr_thread + 53
    Thread 2:
    0   libsystem_kernel.dylib                  0x91a6802e __workq_kernreturn + 10
    1   libsystem_c.dylib                       0x90266ccf _pthread_wqthread + 773
    2   libsystem_c.dylib                       0x902686fe start_wqthread + 30
    Thread 3:
    Thread 4:
    0   libsystem_kernel.dylib                  0x91a6783e __psynch_cvwait + 10
    1   libsystem_c.dylib                       0x90268e78 _pthread_cond_wait + 914
    2   libsystem_c.dylib                       0x9021082a pthread_cond_wait + 48
    3   com.adobe.amt.services                  0x06765274 C_AMTUISwitchSuppressUpdates + 16864
    4   com.adobe.amt.services                  0x0675e074 C_EULA_SetState + 2166
    5   com.adobe.amt.services                  0x067652da C_AMTUISwitchSuppressUpdates + 16966
    6   libsystem_c.dylib                       0x90264ed9 _pthread_start + 335
    7   libsystem_c.dylib                       0x902686de thread_start + 34
    Thread 5:
    1   libsystem_c.dylib                       0x90268e21 _pthread_cond_wait + 827
    2   libsystem_c.dylib                       0x9021942c pthread_cond_wait$UNIX2003 + 71
    3   com.apple.CoreServices.CarbonCore          0x95160f36 TSWaitOnCondition + 124
    4   com.apple.CoreServices.CarbonCore          0x950d2579 TSWaitOnConditionTimedRelative + 136
    5   com.apple.CoreServices.CarbonCore          0x95134755 MPWaitOnQueue + 200
    6   com.adobe.dvacore.framework             0x0013fa0a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
    7   com.adobe.dvacore.framework             0x0013b89a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_ t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::thread s::ThreadSafeDelayQueue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
    8   com.adobe.dvacore.framework             0x000c7869 boost::function0<void>::operator()() const + 41
    9   com.adobe.dvacore.framework             0x0013830d dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
    10  com.adobe.dvacore.framework             0x00139200 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
    11  com.adobe.boost_threads.framework          0x000566fd thread_proxy + 141
    12  libsystem_c.dylib                       0x90264ed9 _pthread_start + 335
    13  libsystem_c.dylib                       0x902686de thread_start + 34
    Thread 6:
    Thread 7:
    Thread 8:
    Thread 9:
    Thread 10:
    Thread 11:
    Thread 12:
    Thread 13:
    Thread 14:
    Thread 15:
    2   libsystem_c.dylib                       0x902193e0 pthread_cond_timedwait$UNIX2003 + 70
    3   com.adobe.aubackend.framework           0x022bc600 abe::spectral::SpectralDataManager::Process() + 720
    4   com.adobe.dvacore.framework             0x000c7869 boost::function0<void>::operator()() const + 41
    5   com.adobe.dvacore.framework             0x0013fa9a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 298
    6   com.adobe.dvacore.framework             0x0013b89a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_ t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::thread s::ThreadSafeDelayQueue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
    7   com.adobe.dvacore.framework             0x000c7869 boost::function0<void>::operator()() const + 41
    8   com.adobe.dvacore.framework             0x0013830d dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
    9   com.adobe.dvacore.framework             0x00139200 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
    10  com.adobe.boost_threads.framework          0x000566fd thread_proxy + 141
    11  libsystem_c.dylib                       0x90264ed9 _pthread_start + 335
    12  libsystem_c.dylib                       0x902686de thread_start + 34
    Thread 16:
    2   libsystem_c.dylib                       0x90268f7b pthread_cond_timedwait_relative_np + 47
    3   com.apple.CoreServices.CarbonCore          0x950d25a3 TSWaitOnConditionTimedRelative + 178
    4   com.apple.CoreServices.CarbonCore          0x95134755 MPWaitOnQueue + 200
    5   com.adobe.dvacore.framework             0x0013fa0a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
    Thread 17:: com.apple.audio.IOThread.client
    0   libsystem_kernel.dylib                  0x91a65c22 mach_msg_trap + 10
    1   libsystem_kernel.dylib                  0x91a651f6 mach_msg + 70
    2   com.apple.audio.CoreAudio               0x911d49fe HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned long, unsigned long, mach_msg_header_t*, unsigned int) + 122
    3   com.apple.audio.CoreAudio               0x911d4a6a HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, unsigned int) + 60
    4   com.apple.audio.CoreAudio               0x911cce5f HALC_ProxyIOContext::IOWorkLoop() + 1145
    5   com.apple.audio.CoreAudio               0x911cc926 HALC_ProxyIOContext::IOThreadEntry(void*) + 136
    6   com.apple.audio.CoreAudio               0x911cc898 __HALC_ProxyIOContext_block_invoke_6 + 20
    7   com.apple.audio.CoreAudio               0x911cc81d HALB_IOThread::Entry(void*) + 69
    8   libsystem_c.dylib                       0x90264ed9 _pthread_start + 335
    9   libsystem_c.dylib                       0x902686de thread_start + 34
    Thread 0 crashed with X86 Thread State (32-bit):
      eax: 0x00000000  ebx: 0x00000000  ecx: 0x069b3600  edx: 0x000000ef
      edi: 0x0f2290a7  esi: 0xbfffe1b8  ebp: 0xbfffe178  esp: 0xbfffe15c
       ss: 0x00000023  efl: 0x00010286  eip: 0x0f3686cc   cs: 0x0000001b
       ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
      cr2: 0x00000000
    Logical CPU: 0
    Binary Images:
        0x1000 -     0x2ff7 +com.adobe.Audition.4.0 (4.0x1815 - 4.0) <85E5CFCF-9F35-62E7-FBB0-A9D784065AAA> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/MacOS/Adobe Audition
        0x8000 -     0xcffc +com.adobe.AdobeCrashReporter (2.5 - 3.0.20090403) /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeCrashReporter.framework/Version s/A/AdobeCrashReporter
       0x13000 -    0x2ffd7 +com.adobe.LogTransport (1.0 - 1.0) /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/LogTransport.framework/Versions/A/Lo gTransport
       0x3b000 -    0x41fef +com.adobe.boost_date_time.framework (boost_date_time version 5.5.0 - 5.5.0.11) <65EA5634-E68B-A458-36E5-1CE41C510FE5> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_date_time.framework/Versions/A /boost_date_time
       0x54000 -    0x5bff2 +com.adobe.boost_threads.framework (boost_threads version 5.5.0 - 5.5.0.11) <BA76B8DD-DD46-9677-BC27-2263B3F6C1C2> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_threads.framework/Versions/A/b oost_threads
       0x6c000 -    0x76ffd +com.adobe.boost_signals.framework (boost_signals version 5.5.0 - 5.5.0.11) <BF2FB70C-B5C6-8895-7F49-A958252FE8AD> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_signals.framework/Versions/A/b oost_signals
       0x8a000 -    0x8bffb +com.adobe.boost_system.framework (boost_system version 5.5.0 - 5.5.0.11) <BF82B35F-D3C0-33A9-FEA0-726282D735EA> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_system.framework/Versions/A/bo ost_system
       0x94000 -   0x221fe7 +com.adobe.dvacore.framework (dvacore version 5.5.0 - 5.5.0.11) <B4D76A59-D111-D6BB-5628-4A323BB85052> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
      0x3a5000 -   0x707fe7 +com.adobe.dvaui.framework (dvaui version 5.5.0 - 5.5.0.11) <67D7F0B7-A688-3BEB-F0DA-75C9E4387838> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
      0xab7000 -   0xe34ff3 +com.adobe.dvaadameve.framework (dvaadameve version 5.5.0 - 5.5.0.11) <D61819DB-66CC-348F-3902-BC814A3A4A14> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaa dameve
    0x13b1000 -  0x145efff +com.adobe.dvaworkspace.framework (dvaworkspace version 5.5.0 - 5.5.0.11) <A7558000-BC03-A56D-FB8B-50357B11D002> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dv aworkspace
    0x1534000 -  0x1556ff7 +com.adobe.dvamediatypes.framework (dvamediatypes version 5.5.0 - 5.5.0.11) <BA4829C9-AA08-55B0-0C65-CAABBDE0570E> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/d vamediatypes
    0x1578000 -  0x15d8fff +com.adobe.dvametadata.framework (dvametadata version 5.5.0 - 5.5.0.11) <177F1AC0-7356-003C-3A1B-932D6AFCD109> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvametadata.framework/Versions/A/dva metadata
    0x1664000 -  0x16bcff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.2 -c 3 - 61.141987) <31B045A8-AA5F-AFDF-E2DD-71B418CD1707> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeX MP
    0x16cc000 -  0x1772ff3 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.2 -f 17 - 61.141987) <963C6B68-E97E-A983-A716-6A8FA37E9D2D> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/A dobeXMPFiles
    0x17b0000 -  0x1842fff +com.adobe.dvametadataUI.framework (dvametadataUI version 5.5.0 - 5.5.0.11) <ADF2FFAD-9BB9-D293-6E0F-65D730C1149D> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvametadataui.framework/Versions/A/d vametadataUI
    0x18de000 -  0x1927fff +com.adobe.dvatemporalxmp.framework (dvatemporalxmp version 5.5.0 - 5.5.0.11) <5E7D6AE9-B564-573D-A87E-856AB21CBE72> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/ dvatemporalxmp
    0x194a000 -  0x19f4fff +com.adobe.exo.framework (exo version 5.5.0 - 5.5.0.11) <CD97F7C6-68E8-A72F-9CF3-41875F43B537> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/exo.framework/Versions/A/exo
    0x1af2000 -  0x1b10ff3 +com.adobe.dvaunittesting.framework (dvaunittesting version 5.5.0 - 5.5.0.11) <2A5C3BEA-D80D-1838-0561-5E4167362226> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/ dvaunittesting
    0x1b3c000 -  0x1b47fff +com.adobe.aucore.framework (1.0 - 1.0) <A59255F4-FF8E-6362-0321-66A358A85AC0> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuCore.framework/Versions/A/AuCore
    0x1b55000 -  0x1ccdfe2 +com.adobe.audsp.framework (1.0 - 1.0) <26B5FE57-0462-24C2-A141-50F0A8585AE2> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuDSP.framework/Versions/A/AuDSP
    0x1d3f000 -  0x1ec0fff +com.adobe.auaudiocomponents.framework (1.0 - 1.0) <1E99D19B-F863-7356-1152-AEE3CC79A790> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuAudioComponents.framework/Versions /A/AuAudioComponents
    0x1fcb000 -  0x2359fef +com.adobe.aubackend.framework (1.0 - 1.0) <F772F4E9-DFF6-B6FF-F0FC-D8A58B2D7A2B> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuBackEnd.framework/Versions/A/AuBac kEnd
    0x268c000 -  0x2693fff +com.adobe.dvaundo.framework (dvaundo version 5.5.0 - 5.5.0.11) <EB63E6D5-2B66-B9CE-2537-49F04A2E2546> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
    0x26a0000 -  0x2a04feb +AuApplication (??? - ???) <6EC48FB1-D2E9-C93B-BCDA-56B5E3970DE5> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuApplication.framework/Versions/A/A uApplication
    0x2d00000 -  0x2de8feb +com.adobe.auuitoolkit.framework (1.0 - 1.0) <809291B6-2082-44FB-1FE9-6209B34CB819> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuUIToolkit.framework/Versions/A/AuU IToolkit
    0x2f39000 -  0x2fd8ff7 +com.adobe.AdobeExtendScript (ExtendScript 4.15.1 - 4.15.1.10952) <08C05DF9-BC45-17F2-6797-6E46C1528565> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeExtendScript.framework/Versions /A/AdobeExtendScript
    0x303f000 -  0x30d1fe3 +com.adobe.AdobeScCore (ScCore 4.15.1 - 4.15.1.10952) <393EE4DF-20CE-C83C-F22C-CE5C06DCB858> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/Ado beScCore
    0x311e000 -  0x322effb +com.adobe.auscripting.framework (1.0 - 1.0) <86C73976-B283-7E91-05B9-10F72115B56F> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuScripting.framework/Versions/A/AuS cripting
    0x33bb000 -  0x342afff +com.adobe.auaudiocomponentsui.framework (1.0 - 1.0) <F82A50BC-6CD1-6FAC-642E-C04EB82CD0BF> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuAudioComponentsUI.framework/Versio ns/A/AuAudioComponentsUI
    0x34cb000 -  0x3e5cfef +AuUI (??? - ???) <6A6C3DBD-AADA-8A6C-3C92-FC8E0BD5D796> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuUI.framework/Versions/A/AuUI
    0x47a7000 -  0x47e4fff  com.apple.vmutils (4.2.1 - 107) <43B3BFA5-8362-3EBD-B44B-32DCE9885082> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutil s
    0x47fe000 -  0x486bffb  com.apple.CoreSymbolication (2.1 - 71) <442A5CD4-9820-3BB2-BD68-D8AB94010E34> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Version s/A/CoreSymbolication
    0x48a6000 -  0x490bffb  com.apple.Symbolication (1.2 - 89) <AB71058E-7106-3D01-8EF9-5F9FEF950D6E> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/ Symbolication
    0x4937000 -  0x496efef  com.apple.DebugSymbols (2.1 - 87) <E2E26B90-BC10-304A-AF1B-8E5CCA9776A7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/D ebugSymbols
    0x4987000 -  0x4991ff3 +com.adobe.boost_filesystem.framework (boost_filesystem version 5.5.0 - 5.5.0.11) <0E6191C4-7881-0F74-7118-1E5E94CE884C> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_filesystem.framework/Versions/ A/boost_filesystem
    0x49a6000 -  0x4a23fe2 +com.adobe.boost_regex.framework (boost_regex version 5.5.0 - 5.5.0.11) <0CF74BD7-D9F3-CA91-D6F6-4B56738E4819> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_regex.framework/Versions/A/boo st_regex
    0x4a8a000 -  0x4b5efef +com.adobe.dvaeve.framework (dvaeve version 5.5.0 - 5.5.0.11) <029FE587-C304-DEDB-FC46-6F84D2C75EE4> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
    0x4c5b000 -  0x4c87ff3  com.apple.audio.CoreAudioKit (1.6.2 - 1.6.2) <9376552A-AFDD-368A-AF35-65A2D6F5DF8E> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudi oKit
    0x4c9a000 -  0x4d303a6 +iZotope_Radius (??? - ???) <B6AF5A0A-6CFD-4298-8450-9FD830471654> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/iZotope_Radius.framework/Versions/A/ iZotope_Radius
    0x4d6d000 -  0x4dc3ffb +com.adobe.headlights.LogSessionFramework (??? - 2.1.2.1263) <5B594BC9-5222-651B-6B70-7AD067035B1A> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/LogSession.framework/Versions/A/LogS ession
    0x4e0c000 -  0x509afec +libxerces-c-3.0.dylib (??? - ???) <CDE6FF46-6D9A-55B9-7DF8-CEB48EBB54B9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/libxerces-c-3.0.dylib
    0x521d000 -  0x52caff7  libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <7B6DB792-C9E5-3772-8734-8D0052757B8C> /usr/lib/libcrypto.0.9.7.dylib
    0x530f000 -  0x5432ff7 +AdobeACE (??? - ???) <6B4856DC-3D41-CEF7-CB70-D02EEA97B8D2> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeA CE
    0x5455000 -  0x5b2fff3 +AdobeAGM (??? - ???) <FE943B4D-ED58-F753-8AE8-54E753A773BD> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeA GM
    0x5bf4000 -  0x5c11ff7 +AdobeBIB (??? - ???) <6CC35ACF-5CCD-1509-B4BB-3B48AD140526> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeB IB
    0x5c18000 -  0x5c3effb +AdobeBIBUtils (??? - ???) <B9888BEE-A939-50E3-1CD3-3313AC14A073> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/A dobeBIBUtils
    0x5c45000 -  0x5f74ff3 +com.adobe.CoolType (AdobeCoolType 5.10.7.10201 - 5.10.7.10201) <6810A678-B1DF-F96D-2560-25AE3FDA923A> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/A dobeCoolType
    0x5fc6000 -  0x6034ffb +com.adobe.amtlib (amtlib 4.0.0.21 - 4.0.0.21) <3090D254-587A-A820-DBCD-729C27532FC8> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
    0x604b000 -  0x604ffff +com.adobe.dvaflashview.framework (dvaflashview version 5.5.0 - 5.5.0.11) <98E23B9D-1CF1-E412-FD26-1EDE5BBD3DF9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dv aflashview
    0x605a000 -  0x605dffc +com.adobe.ape.shim (adbeape version 3.1.74.12761 - 3.1.74.12761) <FE2ABE8A-1D3F-7AF5-297C-D22FC3E0FBDA> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
    0x63da000 -  0x63e2fff +com.adobe.asneu.framework (asneu version 1.7.0.1 - 1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
    0x6740000 -  0x67abfe7 +com.adobe.amt.services (AMTServices 4.0.0.21 [BuildVersion: 4.0; BuildDate: Mon Jan 24 2011 21:49:00] - 4.0.0.21) <018F21DE-7E2E-C850-4C32-D4A2131ABF74> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/amtservices.framework/Versions/A/amt services
    0x67e7000 -  0x67ebffb  com.apple.audio.AudioIPCPlugIn (1.2.1 - 1.2.1) <B8333059-00BE-33A6-AEC0-0C8F285E6E07> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/Aud ioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
    0x67f0000 -  0x67f6ffb  com.apple.audio.AppleHDAHALPlugIn (2.1.3 - 2.1.3f7) <C2DD672D-46CE-34BB-8456-129C65DDE583> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
    0x8795000 -  0x8805feb +com.adobe.adobe_caps (adobe_caps 4.0.42.0 - 4.0.42.0) <55D7D2EA-D21E-98B1-77C6-58C0A0E07051> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adob e_caps
    0x8b97000 -  0x8bc0fef +com.adobe.ape (adbeapecore version 3.1.74.12761 - 3.1.74.12761) <21548488-E9C3-4638-D7FC-895EE0F8EE30> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
    0x8e0c000 -  0x8e0dff1  com.apple.textencoding.unicode (2.4 - 2.4) <4E55D4B9-4E67-3FC9-9407-3E99D1D50F15> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
    0xb3d3000 -  0xb3eafff +com.adobe.AmioAiff.bundle (1.0 - 1.0) <8DD42393-CA20-52FD-E73B-735A39AFD2A9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioAiff.bundle/Contents/MacOS/AmioAiff
    0xb404000 -  0xb44dff7 +com.adobe.AmioLSF.bundle (1.0 - 1.0) <DD4C303E-2964-374C-FCE4-B5053A976327> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/MacOS/AmioLSF
    0xb482000 -  0xb4e0ff3 +libsndfile.1.dylib (2.23.0 - compatibility 2.0.0) <832BFA9E-FE6D-3C12-9B61-E8CBC29CD963> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/Libraries/libsndfile.1.dylib
    0xb502000 -  0xb546fef +libFLAC.8.2.0.dylib (11.0.0 - compatibility 11.0.0) <B5EF064F-745D-0D00-2FC4-B31A46971272> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/Libraries/libFLAC.8.2.0.dylib
    0xb55c000 -  0xb6bbfeb +libvorbisenc.2.dylib (3.7.0 - compatibility 3.0.0) <93CE9300-8AB1-83A4-E20D-E7737DB97BA5> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/Libraries/libvorbisenc.2.dylib
    0xb700000 -  0xb726fea +libvorbis.0.dylib (5.4.0 - compatibility 5.0.0) <745A9A7D-4C43-6B9A-FFCF-773BFD318C05> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/Libraries/libvorbis.0.dylib
    0xb72f000 -  0xb731fe8 +libogg.0.dylib (8.0.0 - compatibility 8.0.0) <51B9D3BA-575C-C5A5-CD90-3AF66EB1BDF9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/Libraries/libogg.0.dylib
    0xb737000 -  0xb7e3fe6 +com.adobe.AmioMp3.bundle (1.0 - 1.0) <53405C96-BF4A-93D5-9ECE-3CD999E37DD6> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioMp3.bundle/Contents/MacOS/AmioMp3
    0xb892000 -  0xb8b2ff7 +com.adobe.AmioQT.bundle (1.0 - 1.0) <14050CEE-F059-C990-1515-0F419BBA3F46> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioQT.bundle/Contents/MacOS/AmioQT
    0xb9e5000 -  0xb9eefca +com.cod3r.ac3movieimport (1.7.1 - 1.7.1) /Library/QuickTime/AC3MovieImport.component/Contents/MacOS/AC3MovieIm port
    0xb9f3000 -  0xb9f3fff +com.adobe.SoundboothScoreAudioCodec (1.0 - 1.0) /Library/QuickTime/SoundboothScoreCodec.component/Contents/MacOS/Soun dboothScoreCodec
    0xba5d000 -  0xba5efff  com.apple.DVCPROHDVideoOutputCodec (1.2 - 1.2) /Library/QuickTime/DVCPROHDVideoOutputCodec.component/Contents/MacOS/ DVCPROHDVideoOutputCodec
    0xba62000 -  0xbad3fff +com.DivXInc.DivXDecoder (6.2.5 - 6.2.5) /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
    0xbae1000 -  0xbb31fff +com.DivXInc.DivXDecoder (6.0.5 - 6.0.5) /Library/QuickTime/DivX 6 Decoder.component/Contents/MacOS/DivX 6 Decoder
    0xeb2d000 -  0xed20ff7 +net.telestream.wmv.import (2.1.0.33 - 2.1.0.33) /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
    0xf01d000 -  0xf153ff7  com.apple.QuickTimeStreaming.component (7.7.1 - 2306) <AA9E0B70-CC52-34D7-AF42-1D36708CF31B> /System/Library/QuickTime/QuickTimeStreaming.component/Contents/MacOS /QuickTimeStreaming
    0xf1b7000 -  0xf20affb  com.apple.QuickTimeMPEG.component (7.7.1 - 2306) <29532A45-677C-3381-AC08-919365E64EA9> /System/Library/QuickTime/QuickTimeMPEG.component/Contents/MacOS/Quic kTimeMPEG
    0xf21e000 -  0xf220ffd  com.apple.PDFImporter (2.2 - ???) <4F3BD14A-F40E-3469-81AC-FFBCF5E66F3B> /System/Library/Components/PDFImporter.component/Contents/MacOS/PDFIm porter
    0xf226000 -  0xf37efef +org.perian (??? - 0.5) /Library/QuickTime/Perian.component/Contents/MacOS/Perian
    0x8feba000 - 0x8feec9c7  dyld (195.5 - ???) <134323A7-49DC-3A9D-ACFD-32FAD0FD6BA2> /usr/lib/dyld
    0x90208000 - 0x902d3fff  libsystem_c.dylib (763.12.0 - compatibility 1.0.0) <1B0A12B3-DAFA-31E2-8F82-E98D620E4D72> /usr/lib/system/libsystem_c.dylib
    0x902d4000 - 0x90426fff  com.apple.audio.toolbox.AudioToolbox (1.7.1 - 1.7.1) <7646E131-08EE-3D72-ADA2-4A61C562B36E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
    0x90479000 - 0x90479fff  com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x9047a000 - 0x9050eff7  com.apple.LaunchServices (480.21 - 480.21) <E3621817-B627-3EEC-A7F9-0D45583B7FE8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
    0x9093c000 - 0x90994fff  com.apple.HIServices (1.10 - ???) <76B50B43-6CFD-3067-A085-11420FD4FAA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
    0x90995000 - 0x9099affd  libGFXShared.dylib (??? - ???) <820D744C-C641-3918-A72A-AC2E5276BCB6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
    0x90ee1000 - 0x90f03ff1  com.apple.PerformanceAnalysis (1.10 - 10) <45B10D4C-9B3B-37A6-982D-687A6F9EEA28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versi ons/A/PerformanceAnalysis
    0x90fe1000 - 0x911b7fe3  com.apple.CoreFoundation (6.7.1 - 635.15) <AC9F6462-6315-3D89-8075-D048DB4DBF7E> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
    0x911b8000 - 0x91219ffb  com.apple.audio.CoreAudio (4.0.1 - 4.0.1) <089D78E0-46A6-38DB-9545-7F35CC815939> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x91297000 - 0x9129fff3  liblaunch.dylib (392.18.0 - compatibility 1.0.0) <CD470A1E-0147-3CB1-B44D-0B61F9061826> /usr/lib/system/liblaunch.dylib
    0x912a0000 - 0x912defff  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <0AE59D4F-FFA7-3539-8B86-AD8993894AA0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x91739000 - 0x9173bff7  libdyld.dylib (195.5.0 - compatibility 1.0.0) <637660EA-8D12-3B79-B644-041FEADC9C33> /usr/lib/system/libdyld.dylib
    0x9174c000 - 0x9174dff7  libsystem_sandbox.dylib (??? - ???) <BC0A04E9-4F28-3BC8-AA7B-63C3451E9212> /usr/lib/system/libsystem_sandbox.dylib
    0x9174e000 - 0x919c1fff  com.apple.CoreImage (7.82 - 1.0.1) <6C99F458-E83A-3538-9B71-2C8BD0C9DCD5> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /CoreImage.framework/Versions/A/CoreImage
    0x91a12000 - 0x91a4efff  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <AA56493C-D7C6-3D4F-8DC8-855405AFF57B> /usr/lib/libcups.2.dylib
    0x91a4f000 - 0x91a6dff7  libsystem_kernel.dylib (1699.22.73 - compatibility 1.0.0) <D32C2E9C-8184-3FAF-8694-99FC619FC71B> /usr/lib/system/libsystem_kernel.dylib
    0x91aed000 - 0x91aedfff  libdnsinfo.dylib (395.6.0 - compatibility 1.0.0) <959E5139-EB23-3529-8881-2BCB5724D1A9> /usr/lib/system/libdnsinfo.dylib
    0x91aee000 - 0x91b5dfff  com.apple.Heimdal (2.1 - 2.0) <DE626683-DF32-341B-8997-AE63309590C7> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimda l
    0x91b5f000 - 0x91bc1ffb  com.apple.datadetectorscore (3.0 - 179.4) <12EF80E0-35CC-30A7-942F-2F9E87C4C98C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
    0x91c0d000 - 0x91c23ffe  libxpc.dylib (77.17.0 - compatibility 1.0.0) <E01E0074-0830-3F20-8703-EA7722BFD358> /usr/lib/system/libxpc.dylib
    0x91c24000 - 0x91c25ff0  libunc.dylib (24.0.0 - compatibility 1.0.0) <BCD277D0-4271-3E96-A4A2-85669DBEE2E2> /usr/lib/system/libunc.dylib
    0x91c26000 - 0x91c31fff  libkxld.dylib (??? - ???) <088640F2-429D-3368-AEDA-3C308C4EB80C> /usr/lib/system/libkxld.dylib
    0x91c3c000 - 0x91c58ff5  com.apple.GenerationalStorage (1.0 - 125) <F1D67293-9192-367D-AE74-2732B23E7E77> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versi ons/A/GenerationalStorage
    0x91cab000 - 0x91cadffb  libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x91cae000 - 0x91e0fffb  com.apple.QuartzCore (1.7 - 270.0) <0916DA83-6400-3FEA-BC53-5F4BA4D126EC> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x91e10000 - 0x91e10fff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
    0x91e6b000 - 0x91e73ff3  libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
    0x91e7a000 - 0x91e7bff5  libremovefile.dylib (21.0.0 - compatibility 1.0.0) <9A1E12B7-F822-3544-8E1D-A6DC81E1F2E6> /usr/lib/system/libremovefile.dylib
    0x91eee000 - 0x91ef4ffd  com.apple.CommerceCore (1.0 - 17) <71641C17-1CA7-3AC9-974E-AAC9EB641035> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x91ef5000 - 0x91f24ff7  libsystem_info.dylib (??? - ???) <B86A363D-6EA2-3A69-A6CB-18B7F98FC61A> /usr/lib/system/libsystem_info.dylib
    0x92299000 - 0x9229afff  libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
    0x9229b000 - 0x922a6ffb  com.apple.speech.recognition.framework (4.0.19 - 4.0.19) <17C11291-5B27-3BE2-8614-7A806745EE8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
    0x922a7000 - 0x9233eff3  com.apple.securityfoundation (5.0 - 55005) <F5A98CC2-11C6-34F3-8F72-75B642627630> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
    0x9264c000 - 0x92669ff3  com.apple.openscripting (1.3.3 - ???) <31A51238-0CA1-38C7-9F0E-8A6676EE3241> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
    0x9266a000 - 0x9266dff9  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <B9344DE6-B84D-352C-95AD-EF73A68B8A10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
    0x926b1000 - 0x926bcff3  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <11726E50-E6FC-3AB0-8750-DDDCCF2B8534> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x926df000 - 0x92713ff8  libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <567E922C-E64F-321B-9A47-6B18BF481625> /usr/lib/libssl.0.9.8.dylib
    0x9271a000 - 0x92829ffb  com.apple.DesktopServices (1.6.1 - 1.6.1) <9F02752A-617B-3AC7-BCA1-F040C105EDDE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
    0x9293a000 - 0x92becff7  com.apple.security (7.0 - 55010) <BE0350C5-5221-3BFF-B674-646AB1BA0F2E> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x92bed000 - 0x92bf3ffb  com.apple.print.framework.Print (7.1 - 247.1) <5D7ADC17-D8EF-3958-9C0C-AA45B7717FBA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
    0x92bf4000 - 0x92da8ff3  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib
    0x93580000 - 0x93587ff5  libsystem_dnssd.dylib (??? - ???) <B3217FA8-A7D6-3C90-ABFC-2E54AEF33547> /usr/lib/system/libsystem_dnssd.dylib
    0x93588000 - 0x9360ffff  com.apple.print.framework.PrintCore (7.1 - 366.1) <BD9120A6-BFB0-3796-A903-05F627F696DF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
    0x93621000 - 0x93643ffe  com.apple.framework.familycontrols (3.0 - 300) <F87D87EF-553A-3165-9C9A-6E117C537FE9> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
    0x93644000 - 0x93645fff  liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
    0x93646000 - 0x9373eff7  libFontParser.dylib (??? - ???) <83E7E71E-D217-3DEE-B288-F5BAE7E118C5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x93741000 - 0x937cbffb  com.apple.SearchKit (1.4.0 - 1.4.0) <CF074082-64AB-3A1F-831E-582DF1667827> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
    0x9384d000 - 0x93894fff  com.apple.SystemConfiguration (1.11.1 - 1.11) <CA6CE2B6-DC18-31FF-9668-70BB2FD8D7BB> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
    0x938f2000 - 0x939e2ff1  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
    0x939e3000 - 0x93b03fec  com.apple.vImage (5.1 - 5.1) <008B989F-F080-398E-ACB1-FBF5BA107D6D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
    0x93b04000 - 0x93b0eff2  com.apple.audio.SoundManager (3.9.4 - 3.9.4) <D23C4761-6492-3974-B4D2-495082B8B7A6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
    0x93b14000 - 0x93b16ff9  com.apple.securityhi (4.0 - 1) <BD367302-73C3-32F4-8080-E389AE89E434> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
    0x93e5a000 - 0x93e61ffd  com.apple.NetFS (4.0 - 4.0) <D0D59145-D211-3E7C-9062-35A2833FA99B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x93e62000 - 0x93f22ff3  com.apple.ColorSync (4.7.0 - 4.7.0) <A39EA668-D042-377F-BC81-26748CD57ADC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
    0x93f23000 - 0x9400bfff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <ED3F5E83-8C76-3D46-B2FF-0D5BDF8970C5> /usr/lib/libxml2.2.dylib
    0x94038000 - 0x94074ffd  libGLImage.dylib (??? - ???) <8251242B-E04E-3467-BD0F-834578B18AC0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
    0x94083000 - 0x94094fff  libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
    0x94095000 - 0x94095ffe  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
    0x94096000 - 0x94156fff  com.apple.CoreServices.OSServices (478.29 - 478.29) <EAAAAC1B-2599-3875-9068-DF7E6B5760A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
    0x9418e000 - 0x94232fff  com.apple.QD (3.12 - ???) <68CBE425-43BA-3E6D-8668-A4A67396E20D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
    0x9440f000 - 0x9446cffb  com.apple.htmlrendering (76 - 1.1.4) <743C2943-40BC-36FB-A45C-3421A394F081> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
    0x9446d000 - 0x94490fff  com.apple.CoreVideo (1.7 - 70.1) <3520F013-DF91-364E-88CF-ED252A7BD0AE> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x945a9000 - 0x945b2ff3  com.apple.CommonAuth (2.1 - 2.0) <D49B41B1-A5DD-366A-8C30-49E9B875AA13> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/Com monAuth
    0x945b3000 - 0x945bbff5  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <A1BFC320-616A-30AA-A41E-29D7904FC4C7> /usr/lib/system/libcopyfile.dylib
    0x94678000 - 0x9469dff9  libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x946c7000 - 0x9472bfff  com.apple.framework.IOKit (2.0 - ???) <D14460ED-2B6C-375D-B3A4-B8C82E922666> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x947ba000 - 0x947fbff9  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <975E4F25-7943-3785-849C-244FF4E77602> /usr/lib/libcurl.4.dylib
    0x947fc000 - 0x94824ff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <FCAC685A-724F-3FE7-8416-146108DF75FB> /usr/lib/libxslt.1.dylib
    0x94825000 - 0x94828ff7  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
    0x94829000 - 0x9482affd  libCVMSPluginSupport.dylib (??? - ???) <96F2F2F4-E7A9-36C8-B1CF-D58AA3DB2B44> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC VMSPluginSupport.dylib
    0x9482b000 - 0x9483bfff  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <D6F728DA-990A-32A3-86FA-4A3F4D88E309> /usr/lib/libsasl2.2.dylib
    0x9483c000 - 0x9483fffb  com.apple.help (1.3.2 - 42) <DDCEBA10-5CDE-3ED2-A52F-5CD5A0632CA2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
    0x94cd4000 - 0x94cd4fff  com.apple.Carbon (153 - 153) <6FF98F0F-2CDE-3888-A304-4ED447D24CE3> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x94cd5000 - 0x94d2effb  com.apple.coreui (1.2.1 - 164.1) <890E0BE9-3360-3B56-BE46-5A2421875A40> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x94d2f000 - 0x94e43ff3  com.apple.QuickTimeImporters.component (7.7.1 - 2306) <393FD879-F626-3FB2-9866-9E6B122BD64F> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS /QuickTimeImporters
    0x94e90000 - 0x94fbcff9  com.apple.CFNetwork (520.2.5 - 520.2.5) <02193949-50A8-3CBC-9920-5FCDB8EBE17A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
    0x94fbd000 - 0x95093a5b  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <A0EDB351-4B9D-3AA2-9D1A-0C22204FCCD3> /usr/lib/libobjc.A.dylib
    0x95094000 - 0x95396fff  com.apple.CoreServices.CarbonCore (960.18 - 960.18) <8094724D-591D-3CC2-81DE-4E3029624E11> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
    0x953df000 - 0x953fcfff  libresolv.9.dylib (46.0.0 - compatibility 1.0.0) <95AE43ED-6C52-3B39-89B6-54C81C62F1FF> /usr/lib/libresolv.9.dylib
    0x953fd000 - 0x9544dfff  libFontRegistry.dylib (??? - ???) <81E03B82-1F31-3702-97DC-BE20298E326F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x95604000 - 0x95944ffb  com.apple.HIToolbox (1.8 - ???) <DFED9BD0-E142-397B-BE16-16EBCF3CE1EB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
    0x95a0c000 - 0x95a5dff9  com.apple.ScalableUserInterface (1.0 - 1) <C3FA7E40-0213-3ABC-A006-2CB00B6A7EAB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /ScalableUserInterface.framework/Versions/A/ScalableUserInterface
    0x95a5e000 - 0x95a73ff7  com.apple.ImageCapture (7.0 - 7.0) <116BC0CA-428E-396F-85DF-52793034D2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
    0x95b09000 - 0x95b14ffc  com.apple.NetAuth (1.0 - 3.0) <C07853C0-AF32-3633-9CEF-2480860C12C5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAut h
    0x95b15000 - 0x95b15fff  com.apple.Cocoa (6.6 - ???) <650273EF-1ABC-334E-B745-B75AF028F9F4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x95b5b000 - 0x95b7afff  com.apple.RemoteViewServices (1.2 - 39) <C7B638D2-2F8B-3A45-916A-73103FADC822> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versio ns/A/RemoteViewServices
    0x95b7b000 - 0x95b7effd  libCoreVMClient.dylib (??? - ???) <2D135537-F9A6-33B1-9B01-6ECE7E929C00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
    0x95b7f000 - 0x95b86ff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
    0x95c03000 - 0x95c65ff3  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
    0x95c66000 - 0x95cdbfff  com.apple.Metadata (10.7.0 - 627.20) <1E7C8194-8CE4-3103-A3D1-8913238AF923> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
    0x95d19000 - 0x95d1dfff  com.apple.CommonPanels (1.2.5 - 94) <3A988595-DE53-34ED-9367-C9A737E2AF38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
    0x95d1e000 - 0x95db9ff3  com.apple.ink.framework (1.3.2 - 110) <9F6F37F9-999E-30C5-93D0-E48D4B5E20CD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
    0x95dba000 - 0x95dd3fff  libPng.dylib (??? - ???) <A83B66DC-302C-3A4C-8107-0E5560708024> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x95e79000 - 0x95e8cffb  com.apple.MultitouchSupport.framework (220.62.1 - 220.62.1) <3D94520B-C976-370F-AF56-278002BCF11D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
    0x95f0a000 - 0x95f0eff3  libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
    0x961ca000 - 0x961cbff7  libquarantine.dylib (36.0.0 - compatibility 1.0.0) <70782AEC-8933-3EB4-91CA-E44C0E768C90> /usr/lib/system/libquarantine.dylib
    0x96aa7000 - 0x96aacff7  libmacho.dylib (800.0.0 - compatibility 1.0.0) <56A34E97-518E-307E-8218-C5D43A33EE34> /usr/lib/system/libmacho.dylib
    0x96aad000 - 0x96ab0ff7  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
    0x96ab1000 - 0x96ab1ff0  com.apple.ApplicationServices (41 - 41) <BED33E1D-C95C-3654-9A3A-0CB3607F9F10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
    0x96ab2000 - 0x96ac6ff7  com.apple.CFOpenDirectory (10.7 - 144) <665CDF77-F0C9-3AFF-8CF8-64257268B7DD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x96acd000 - 0x96adbfff  libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
    0x96af4000 - 0x96af4ff2  com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
    0x96af5000 - 0x96afdfff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
    0x96b01000 - 0x96b0afff  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
    0x96b0b000 - 0x96b18fff  libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
    0x96b19000 - 0x97194fe5  com.apple.CoreAUC (6.11.04 - 6.11.04) <B06D52C9-9F59-3EF2-B2BA-11E93C573572> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAU C
    0x97195000 - 0x9719cfff  com.apple.agl (3.1.4 - AGL-3.1.4) <CCCE2A89-026B-3185-ABEA-68D268353164> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x9719d000 - 0x971cbfe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <07D9A827-9567-34C2-9022-AF4BF975C9A7> /usr/lib/libSystem.B.dylib
    0x971cc000 - 0x9720afff  com.apple.NavigationServices (3.6 - 192) <CB7AE807-9292-3EBA-A5F5-D7DCEE28A5B7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
    0x9720b000 - 0x97225fff  com.apple.Kerberos (1.0 - 1) <D7920A1C-FEC4-3460-8DD0-D02491578CBB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x97226000 - 0x97337ff7  libJP2.dylib (??? - ???) <35D120D4-3304-3A02-9259-EB933E74E63A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x97338000 - 0x979e1eeb  com.apple.CoreGraphics (1.600.0 - ???) <322FC806-0B9F-3A58-8C88-D477E32A50F8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x979e2000 - 0x979f2fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x979f3000 - 0x97a29ff4  com.apple.LDAPFramework (3.0 - 120.1) <EA92FCA5-7A7E-328F-8C7F-4250FCC45879> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x97b71000 - 0x97b9affe  com.apple.opencl (1.50.63 - 1.50.63) <C4EC60D6-9A7C-3CE9-AA80-2F81D9BB4465> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x97b9b000 - 0x97c00ff7  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
    0x97fb7000 - 0x97fbbfff  libGIF.dylib (??? - ???) <06E85451-F51C-31C4-B5A6-180819BD9738> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x98045000 - 0x98d95fff  com.apple.QuickTimeComponents.component (7.7.1 - 2306) <B397F658-057A-3D84-ABC7-84AA6256DB88> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacO S/QuickTimeComponents
    0x98d96000 - 0x98dd6ff7  libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
    0x98dd7000 - 0x98e64fe7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <F2A8BBA3-6431-3CED-8CD3-0953410B6F96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
    0x98e65000 - 0x98e9bff7  com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
    0x98e9c000 - 0x98e9dfff  com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
    0x98e9e000 - 0x98eccff7  com.apple.DictionaryServices (1.2.1 - 158.2) <DA16A8B2-F359-345A-BAF7-8E6A5A0741A1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x98ecd000 - 0x991d7ff3  com.apple.Foundation (6.7.1 - 833.20) <B5092554-485A-3A7D-904B-B04B1EE5C50C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x9921a000 - 0x9921afff  com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x9921b000 - 0x992eafff  com.apple.ImageIO.framework (3.1.1 - 3.1.1) <8B8A3DD3-BB3D-33FC-A714-81E1B883B155> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
    0x99478000 - 0x998edff7  FaceCoreLight (1.4.7 - compatibility 1.0.0) <312D0F58-B8E7-3F61-8A83-30C95F2EBEAA> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/ FaceCoreLight
    0x9996b000 - 0x9996bfff  com.apple.audio.units.AudioUnit (1.7.1 - 1.7.1) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x9996c000 - 0x99a7bff7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <90D36793-04A5-3BFF-BE83-EEEDCBEDC756> /usr/lib/libsqlite3.dylib
    0x99a7c000 - 0x99a8cff7  libCRFSuite.dylib (??? - ???) <CE616EF3-756A-355A-95AD-3472A876BEB9> /usr/lib/libCRFSuite.dylib
    0x99bbc000 - 0x99c37ffb  com.apple.ApplicationServices.ATS (317.5.0 - ???) <D5AC5C21-CE1E-333D-94F7-F0F534FD4DC7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
    0x99c38000 - 0x99c60ff0  com.apple.CoreServicesInternal (113.8 - 113.8) <9930695C-1C48-329F-93FD-5AEEE2EF942C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Vers ions/A/CoreServicesInternal
    0x99eab000 - 0x9a387ff6  libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
    0x9a3d5000 - 0x9a3e3fff  com.apple.opengl (1.7.5 - 1.7.5) <81166D23-DE8E-3938-AAD3-29B1FA5E446E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x9a3ef000 - 0x9a3fdfff  libdispatch.dylib (187.7.0 - compatibility 1.0.0) <B50C62AD-0B5B-34C3-A491-ECFD72ED505E> /usr/lib/system/libdispatch.dylib
    0x9a3fe000 - 0x9ae8cffe  com.apple.AppKit (6.7.2 - 1138.23) <ADFA8D70-601E-3B5C-96FD-F45F52055CC8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x9aea6000 - 0x9b12bfe3  com.apple.QuickTime (7.7.1 - 2306) <F8C64DC4-3FE4-3A06-B10B-59E7F3BA6FDD> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x9b12c000 - 0x9b193fff  libc++.1.dylib (19.0.0 - compatibility 1.0.0) <3AFF3CE8-14AE-300F-8F63-8B7FB9D4DA96> /usr/lib/libc++.1.dylib
    0x9b194000 - 0x9b1ddff7  libGLU.dylib (??? - ???) <AEA2AD9A-EEDD-39B8-9B28-4C7C1BACB594> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
    0x9b1de000 - 0x9b2c1ff7  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <BD913D3B-388D-33AE-AA5E-4810C743C28F> /usr/lib/libcrypto.0.9.8.dylib
    0x9b2c2000 - 0x9b305ffd  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <4BA1F5F1-F0A2-3FEB-BB62-F514DCBB3725> /usr/lib/system/libcommonCrypto.dylib
    0x9b446000 - 0x9b447fff  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
    0x9b523000 - 0x9b573ff4  libTIFF.dylib (??? - ???) <E86EA22A-82C0-3E77-9EAF-739F385790D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x9b7d8000 - 0x9b9c1ff7  com.apple.CoreData (104 - 358.12) <F8AD7990-2C30-31A4-8E78-FA8DD5CF03CC> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x9ba3a000 - 0x9ba3effd  IOSurface (??? - ???) <97E875C2-9F1A-3FBA-B80C-594892A02621> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x9ba3f000 - 0x9be41ff6  libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
    0x9bef1000 - 0x9bf7eff7  com.apple.CoreText (220.11.0 - ???) <4F98D709-75AC-35F0-AD88-8F2C4BD744C0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
    0x9bf7f000 - 0x9bf82ffc  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
    0x9bf83000 - 0x9bfaefff  com.apple.GSS (2.1 - 2.0) <05A0171B-76EA-3E4C-8A36-65D1A978AF4B> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x9bfaf000 - 0x9bfb3ffa  libcache.dylib (47.0.0 - compatibility 1.0.0) <98A82BC5-0DD9-3212-9CAE-35A77278EEB6> /usr/lib/system/libcache.dylib
    0x9ca05000 - 0x9ca1afff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x9cafd000 - 0x9cb01ff7  com.apple.OpenDirectory (10.7 - 146) <3D3D30CE-6D82-3681-AA98-4E3AEFFA4229> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
    0xb0000000 - 0xb0011ff8 +com.adobe.ahclientframework (1.6.0.20 - 1.6.0.20) <6FB288F2-45FD-E54A-C9A4-A0D0C374FE37> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclie nt
    External Modification Summary:
      Calls made by other processes targeting this process:
        task_for_pid: 2
        thread_create: 0
        thread_set_state: 0
      Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by all processes on this machine:
        task_for_pid: 6797
        thread_create: 0
        thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=250.8M resident=138.7M(55%) swapped_out_or_unallocated=112.1M(45%)
    Writable regions: Total=131.0M written=7932K(6%) resident=14.4M(11%) swapped_out=0K(0%) unallocated=116.6M(89%)
    REGION TYPE                      VIRTUAL
    (null) (reserved)                    40K        reserved VM address space (unallocated)
    ATS (font support)                 32.2M
    ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
    CG backing stores                   872K
    CG raster data                      860K
    CG shared images                   1256K
    CoreGraphics                          8K
    CoreServices                       4428K
    MALLOC                             26.6M
    MALLOC guard page                    32K
    MALLOC_LARGE (reserved)            33.4M        reserved VM address space (unallocated)
    Memory tag=242                       12K
    Memory tag=243                        4K
    Memory tag=249                      408K
    Stack                              72.6M
    VM_ALLOCATE                        17.0M
    __CI_BITMAP                          80K
    __DATA                             16.1M
    __DATA/__OBJC                       112K
    __IMAGE                            1256K
    __IMPORT                            348K
    __LINKEDIT                         78.1M
    __OBJC                             1636K
    __OBJC/__DATA                        48K
    __PAGEZERO                            4K
    __TEXT                            172.7M
    __UNICODE                           544K
    mapped file                       113.5M
    shared memory                       364K
    shared pmap                        9164K
    TOTAL                             583.1M
    TOTAL, minus reserved VM space    549.7M
    Model: MacBook6,1, BootROM MB61.00C8.B00, 2 processors, Intel Core 2 Duo, 2.26 GHz, 4 GB, SMC 1.51f53
    Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
    Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
    Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.100.98.75.18)
    Bluetooth: Version 4.0.1f4, 2 service, 11 devices, 1 incoming serial ports
    Network Service: AirPort, AirPort, en1
    Serial ATA Device: TOSHIBA MK2555GSXF, 250.06 GB
    Serial ATA Device: MATSHITADVD-R   UJ-898
    USB Device: Built-in iSight, apple_vendor_id, 0x8507, 0x24400000 / 2
    USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0236, 0x04600000 / 2
    USB Device: USB Optical Mouse, 0x046d  (Logitech Inc.), 0xc058, 0x06200000 / 3
    USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x06100000 / 2
    USB Device: Bluetooth Module, apple_vendor_id, 0x8218, 0x06130000 / 4
    please help me, thank you very much
    Oct 24, 2011 1:09 PM   in reply to HarryykC
    By giving the information requested in the FAQ, I can now immediately see the problem:
    Perian is crashing when QuickTime is asking it what it supports.  Please update Perian or uninstall it.   The reason why this is crashing Audition on startup is because on first launch we ask QuickTime which file extensions it supports (e.g. .mov, .aac, .mp4, etc).  In that process, QuickTime is in-turn, calling Perian (since you installed it) and asking Perian.  For some reason, this is crashing.
    If you don't need QuickTime support in Audition, you can remove/rename the AmioQT.bundle from within the Adobe Audition CS5.5.app.
    Oct 24, 2011 8:19 PM   in reply to Charles VW
    thank you very much, it work now
    Oct 25, 2011 7:26 AM   in reply to HarryykC
    For the benefit of others that may come across this thread, what exactly did you do/change to get it to work?
    Oct 25, 2011 8:11 AM   in reply to Charles VW
    I removed perian and then intalled it, but audition not worked, so I renamed the file AmioQT.bundle,while it didnt work, then I removed it,and audition worked. Hope it useful for others
    May 30, 2012 3:49 PM   in reply to Charles VW
    Hey my audition crash when i open up today. it started up did it yesterday as well. please help.
    here a screen shot just before it crashes.
    here the crash report
    Process:         Adobe Audition [3158]
    Parent Process:  launchd [242]
    Date/Time:       2012-05-31 08:09:45.593 +0930
    OS Version:      Mac OS X 10.7.4 (11E53)
    Report Version:  9
    Interval Since Last Report:          2241 sec
    Per-App Interval Since Last Report:  57 sec
    Per-App Crashes Since Last Report:   7
    Anonymous UUID:                      4176F5F7-DB75-41E1-AEDB-0DE4B0F8FEE1
    Exception Type:  EXC_CRASH (SIGABRT)
    Exception Codes: 0x0000000000000000, 0x0000000000000000
    objc[3158]: garbage collection is OFF
    terminate called throwing an exception
    abort() called
    0   libsystem_kernel.dylib                  0x978d89c6 __pthread_kill + 10
    1   libsystem_c.dylib                       0x99159f78 pthread_kill + 106
    2   libsystem_c.dylib                       0x9914abdd abort + 167
    3   libc++abi.dylib                         0x900ee921 abort_message + 94
    4   libc++abi.dylib                         0x900ec1bc default_terminate() + 36
    5   libc++abi.dylib                         0x900ec1fe safe_handler_caller(void (*)()) + 15
    6   libc++abi.dylib                         0x900ec268 std::terminate() + 23
    7   libc++abi.dylib                         0x900ed2a0 __cxa_throw + 112
    8   AuUI                                    0x03550f7f aui::ErrorManager::ThrowError(dvacore::config::ErrorLevel, char const*, unsigned int, int, bool, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&) const + 319
    9   com.adobe.dvacore.framework             0x000c58f8 dvacore::config::ThrowError(dvacore::config::ErrorLevel, char const*, unsigned int, int, bool, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&) + 168
    10  com.adobe.dvacore.framework             0x0011bf89 dvacore::proplist::utils::LoadPropList(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvacore::proplist::PropList&, bool) + 361
    11  AuApplication                           0x026f2f13 app::FavoriteManager::Initialize(bool) + 339
    12  AuApplication                           0x028c59e7 app::Initializer::Initialize(bool, boost::function<void ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >)>) + 6023
    13  AuUI                                    0x03b56440 aui::ApplicationInitializer::Impl::Initialize(dvaworkspace::workspace ::Workspace*) + 2768
    14  AuUI                                    0x03b4bc3c aui::ApplicationInitializer::Initialize(dvaworkspace::workspace::Work space*) + 28
    15  AuUI                                    0x0353d6d7 aui::Application::InitApplication(exo::app::AppInitArgs&) + 3943
    16  com.adobe.exo.framework                 0x0194cdf9 exo::app::AppBase::Initialize(exo::app::AppInitArgs&) + 729
    17  AuUI                                    0x0353243e aui::Application::Initialize(exo::app::AppInitArgs&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 158
    18  AuUI                                    0x03555c0f AudMacMain(int, char**) + 415
    19  com.adobe.Audition.4.0                  0x00002ecd main + 93
    20  com.adobe.Audition.4.0                  0x00002c66 start + 54
    0   libsystem_kernel.dylib                  0x978d990a kevent + 10
    1   libdispatch.dylib                       0x99256e10 _dispatch_mgr_invoke + 969
    2   libdispatch.dylib                       0x9925585f _dispatch_mgr_thread + 53
    Thread 2:
    0   libsystem_kernel.dylib                  0x978d902e __workq_kernreturn + 10
    1   libsystem_c.dylib                       0x99159ccf _pthread_wqthread + 773
    2   libsystem_c.dylib                       0x9915b6fe start_wqthread + 30
    Thread 3:
    Thread 4:
    0   libsystem_kernel.dylib                  0x978d883e __psynch_cvwait + 10
    1   libsystem_c.dylib                       0x9915be78 _pthread_cond_wait + 914
    2   libsystem_c.dylib                       0x9910382a pthread_cond_wait + 48
    3   com.adobe.amt.services                  0x06f25274 C_AMTUISwitchSuppressUpdates + 16864
    4   com.adobe.amt.services                  0x06f1e074 C_EULA_SetState + 2166
    5   com.adobe.amt.services                  0x06f252da C_AMTUISwitchSuppressUpdates + 16966
    6   libsystem_c.dylib                       0x99157ed9 _pthread_start + 335
    7   libsystem_c.dylib                       0x9915b6de thread_start + 34
    Thread 5:
    Thread 6:
    1   libsystem_c.dylib                       0x9915be21 _pthread_cond_wait + 827
    2   libsystem_c.dylib                       0x9910c42c pthread_cond_wait$UNIX2003 + 71
    3   com.apple.CoreServices.CarbonCore          0x90e0ae62 TSWaitOnCondition + 124
    4   com.apple.CoreServices.CarbonCore          0x90d7c37d TSWaitOnConditionTimedRelative + 136
    5   com.apple.CoreServices.CarbonCore          0x90dde67f MPWaitOnQueue + 200
    12  libsystem_c.dylib                       0x99157ed9 _pthread_start + 335
    13  libsystem_c.dylib                       0x9915b6de thread_start + 34
    Thread 7:
    Thread 8:
    Thread 9:
    Thread 10:
    Thread 11:
    Thread 12:
    Thread 13:
    Thread 14:
    Thread 15:
    Thread 16:
    Thread 17:
    Thread 18:
    Thread 19:
    Thread 20:
    Thread 21:
    Thread 22:
    2   libsystem_c.dylib                       0x9910c3e0 pthread_cond_timedwait$UNIX2003 + 70
    11  libsystem_c.dylib                       0x99157ed9 _pthread_start + 335
    12  libsystem_c.dylib                       0x9915b6de thread_start + 34
    Thread 23:
    2   libsystem_c.dylib                       0x9915bf7b pthread_cond_timedwait_relative_np + 47
    3   com.apple.CoreServices.CarbonCore          0x90d7c3a7 TSWaitOnConditionTimedRelative + 178
    4   com.apple.CoreServices.CarbonCore          0x90dde67f MPWaitOnQueue + 200
    Thread 24:: com.apple.audio.IOThread.client
    0   libsystem_kernel.dylib                  0x978d6c22 mach_msg_trap + 10
    1   libsystem_kernel.dylib                  0x978d61f6 mach_msg + 70
    2   com.apple.audio.CoreAudio               0x9920e9fe HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned long, unsigned long, mach_msg_header_t*, unsigned int) + 122
    3   com.apple.audio.CoreAudio               0x9920ea6a HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, unsigned int) + 60
    4   com.apple.audio.CoreAudio               0x99206e5f HALC_ProxyIOContext::IOWorkLoop() + 1145
    5   com.apple.audio.CoreAudio               0x99206926 HALC_ProxyIOContext::IOThreadEntry(void*) + 136
    6   com.apple.audio.CoreAudio               0x99206898 __HALC_ProxyIOContext_block_invoke_6 + 20
    7   com.apple.audio.CoreAudio               0x9920681d HALB_IOThread::Entry(void*) + 69
    8   libsystem_c.dylib                       0x99157ed9 _pthread_start + 335
    9   libsystem_c.dylib                       0x9915b6de thread_start + 34
      eax: 0x00000000  ebx: 0x900ef330  ecx: 0xbfffe91c  edx: 0x978d89c6
      edi: 0xaca2f2c0  esi: 0x00000006  ebp: 0xbfffe938  esp: 0xbfffe91c
       ss: 0x00000023  efl: 0x00000246  eip: 0x978d89c6   cs: 0x0000000b
      cr2: 0x03e952e0
    Logical CPU: 0
    Binary Images:
    0x47fe000 -  0x4808ff3 +com.adobe.boost_filesystem.framework (boost_filesystem version 5.5.0 - 5.5.0.11) <0E6191C4-7881-0F74-7118-1E5E94CE884C> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_filesystem.framework/Versions/ A/boost_filesystem
    0x481d000 -  0x489afe2 +com.adobe.boost_regex.framework (boost_regex version 5.5.0 - 5.5.0.11) <0CF74BD7-D9F3-CA91-D6F6-4B56738E4819> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_regex.framework/Versions/A/boo st_regex
    0x4901000 -  0x49d5fef +com.adobe.dvaeve.framework (dvaeve version 5.5.0 - 5.5.0.11) <029FE587-C304-DEDB-FC46-6F84D2C75EE4> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
    0x4ad2000 -  0x4afeff3  com.apple.audio.CoreAudioKit (1.6.3 - 1.6.3) <7D47B1D3-4410-3524-BC47-FCDF49E48DB5> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudi oKit
    0x4b11000 -  0x4ba73a6 +iZotope_Radius (??? - ???) <B6AF5A0A-6CFD-4298-8450-9FD830471654> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/iZotope_Radius.framework/Versions/A/ iZotope_Radius
    0x4be4000 -  0x4c3affb +com.adobe.headlights.LogSessionFramework (??? - 2.1.2.1263) <5B594BC9-5222-651B-6B70-7AD067035B1A> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/LogSession.framework/Versions/A/LogS ession
    0x4c83000 -  0x4f11fec +libxerces-c-3.0.dylib (??? - ???) <CDE6FF46-6D9A-55B9-7DF8-CEB48EBB54B9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/libxerces-c-3.0.dylib
    0x5094000 -  0x5141ff7  libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <7B6DB792-C9E5-3772-8734-8D0052757B8C> /usr/lib/libcrypto.0.9.7.dylib
    0x5186000 -  0x52a9ff7 +AdobeACE (??? - ???) <6B4856DC-3D41-CEF7-CB70-D02EEA97B8D2> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeA CE
    0x52cc000 -  0x59a6ff3 +AdobeAGM (??? - ???) <FE943B4D-ED58-F753-8AE8-54E753A773BD> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeA GM
    0x5a6b000 -  0x5a88ff7 +AdobeBIB (??? - ???) <6CC35ACF-5CCD-1509-B4BB-3B48AD140526> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeB IB
    0x5a8f000 -  0x5ab5ffb +AdobeBIBUtils (??? - ???) <B9888BEE-A939-50E3-1CD3-3313AC14A073> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/A dobeBIBUtils
    0x5abc000 -  0x5debff3 +com.adobe.CoolType (AdobeCoolType 5.10.7.10201 - 5.10.7.10201) <6810A678-B1DF-F96D-2560-25AE3FDA923A> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/A dobeCoolType
    0x5e3d000 -  0x5eabffb +com.adobe.amtlib (amtlib 4.0.0.21 - 4.0.0.21) <3090D254-587A-A820-DBCD-729C27532FC8> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
    0x5ec2000 -  0x5ec6fff +com.adobe.dvaflashview.framework (dvaflashview version 5.5.0 - 5.5.0.11) <98E23B9D-1CF1-E412-FD26-1EDE5BBD3DF9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dv aflashview
    0x5ed1000 -  0x5ed4ffc +com.adobe.ape.shim (adbeape version 3.1.74.12761 - 3.1.74.12761) <FE2ABE8A-1D3F-7AF5-297C-D22FC3E0FBDA> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
    0x6a8c000 -  0x6a94fff +com.adobe.asneu.framework (asneu version 1.7.0.1 - 1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
    0x6aed000 -  0x6af1ffb  com.apple.audio.AudioIPCPlugIn (1.2.2 - 1.2.2) <E6982BB2-BEC8-3232-989D-B3D5B26AE0DF> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/Aud ioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
    0x6af6000 -  0x6afbfff  com.apple.audio.AppleHDAHALPlugIn (2.2.0 - 2.2.0f3) <BAD1E0E6-10E6-342C-BEB8-B1706F0CE2CF> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
    0x6f00000 -  0x6f6bfe7 +com.adobe.amt.services (AMTServices 4.0.0.21 [BuildVersion: 4.0; BuildDate: Mon Jan 24 2011 21:49:00] - 4.0.0.21) <018F21DE-7E2E-C850-4C32-D4A2131ABF74> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/amtservices.framework/Versions/A/amt services
    0x6f87000 -  0x6fb0fef +com.adobe.ape (adbeapecore version 3.1.74.12761 - 3.1.74.12761) <21548488-E9C3-4638-D7FC-895EE0F8EE30> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
    0x6fc8000 -  0x6fc9ff1  com.apple.textencoding.unicode (2.4 - 2.4) <4E55D4B9-4E67-3FC9-9407-3E99D1D50F15> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
    0x8c00000 -  0x8c70feb +com.adobe.adobe_caps (adobe_caps 4.0.42.0 - 4.0.42.0) <55D7D2EA-D21E-98B1-77C6-58C0A0E07051> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adob e_caps
    0x8feb1000 - 0x8fee3aa7  dyld (195.6 - ???) <3A866A34-4CDD-35A4-B26E-F145B05F3644> /usr/lib/dyld
    0x900de000 - 0x900e6fff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
    0x900e7000 - 0x900f0fff  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
    0x90239000 - 0x90244ff3  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <EDA0F56F-CB2C-30BB-940D-C6A25B73C717> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x90245000 - 0x90246fff  com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
    0x902ef000 - 0x90304fff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x9032f000 - 0x90365ff4  com.apple.LDAPFramework (3.2 - 120.2) <39DF72E3-CDAF-33CC-B2DA-67B8891A5CFF> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x90366000 - 0x9051aff3  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib
    0x90531000 - 0x905d5fff  com.apple.QD (3.40 - ???) <3881BEC6-0908-3073-BA44-346356E1CDF9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
    0x905d6000 - 0x90ab2ff6  libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
    0x90ae7000 - 0x90b15fe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <30189C33-6ADD-3142-83F3-6114B1FC152E> /usr/lib/libSystem.B.dylib
    0x90b16000 - 0x90b36ff7  com.apple.RemoteViewServices (1.4 - 44.1) <1F831750-1E77-3013-B1A6-0DF528623790> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versio ns/A/RemoteViewServices
    0x90b37000 - 0x90b4dffe  libxpc.dylib (77.19.0 - compatibility 1.0.0) <0585AA94-F4FD-32C1-B586-22E7184B781A> /usr/lib/system/libxpc.dylib
    0x90b4e000 - 0x90b4efff  com.apple.Cocoa (6.6 - ???) <5FAFE73E-6AF5-3D09-9191-0BDC8C6875CB> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x90b71000 - 0x90b79ff3  liblaunch.dylib (392.38.0 - compatibility 1.0.0) <D7F6E875-263A-37B5-B403-53F76710538C> /usr/lib/system/liblaunch.dylib
    0x90b7a000 - 0x90b81ff9  libsystem_dnssd.dylib (??? - ???) <D3A766FC-C409-3A57-ADE4-94B7688E1C7E> /usr/lib/system/libsystem_dnssd.dylib
    0x90bb6000 - 0x90bc1ffe  com.apple.NetAuth (3.2 - 3.2) <4377FB18-A550-35C6-BCD2-71C42134EEA6> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAut h
    0x90d23000 - 0x90d3dfff  com.apple.Kerberos (1.0 - 1) <D7920A1C-FEC4-3460-8DD0-D02491578CBB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x90d3e000 - 0x91040fff  com.apple.CoreServices.CarbonCore (960.24 - 960.24) <9692D838-85A5-32C1-B7FB-7C141FFC2557> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
    0x916bd000 - 0x9174aff7  com.apple.CoreText (220.20.0 - ???) <0C3EDD4F-6112-353A-8A3A-8D630182C22A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
    0x9174b000 - 0x9174fff3  libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
    0x91792000 - 0x917c1ff7  libsystem_info.dylib (??? - ???) <37640811-445B-3BB7-9934-A7C99848250D> /usr/lib/system/libsystem_info.dylib
    0x917c2000 - 0x917d2ff7  libCRFSuite.dylib (??? - ???) <94E040D2-2769-359A-A21B-DB85FCB73BDC> /usr/lib/libCRFSuite.dylib
    0x917d3000 - 0x917d4fff  libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
    0x917d5000 - 0x917d6ff7  libsystem_sandbox.dylib (??? - ???) <EBC6ED6B-7D94-32A9-A718-BB9EDA1732C9> /usr/lib/system/libsystem_sandbox.dylib
    0x917d7000 - 0x91939ffb  com.apple.QuartzCore (1.7 - 270.4) <6BC84C60-1003-3008-ABE4-779EF7B4F524> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x919b4000 - 0x91a18fff  com.apple.framework.IOKit (2.0 - ???) <88D60E59-430D-35B8-B1E9-F5138301AEF9> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x91a2a000 - 0x91a6aff7  com.apple.NavigationServices (3.7 - 193) <16A8BCC8-7343-3A90-88B3-AAA334DF615F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
    0x91a6b000 - 0x91a8dffe  com.apple.framework.familycontrols (3.0 - 300) <5BCCDDC2-AFAC-3290-AEEF-23B2664CA11F> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
    0x91a8e000 - 0x91ae9ff3  com.apple.Symbolication (1.3 - 91) <4D12D2EC-5010-3958-A205-9A67E972C76A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/ Symbolication
    0x91aea000 - 0x91b4cffb  com.apple.datadetectorscore (3.0 - 179.4) <3A418498-C189-37A1-9B86-F0ECB33AD91C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
    0x91b50000 - 0x91b72ff8  com.apple.PerformanceAnalysis (1.11 - 11) <453463FF-7C42-3526-8C96-A9971EE07154> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versi ons/A/PerformanceAnalysis
    0x91b73000 - 0x91bb1fff  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <19174EC0-DE0F-38EA-B5F3-7580E84677DD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x91c29000 - 0x91c2dffa  libcache.dylib (47.0.0 - compatibility 1.0.0) <56256537-6538-3522-BCB6-2C79DA6AC8CD> /usr/lib/system/libcache.dylib
    0x92082000 - 0x92345fff  com.apple.security (7.0 - 55148.1) <77754898-4FCD-3CA3-9339-F1058C852806> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x92346000 - 0x92356fff  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <D6F728DA-990A-32A3-86FA-4A3F4D88E309> /usr/lib/libsasl2.2.dylib
    0x9276a000 - 0x92a74ff3  com.apple.Foundation (6.7.2 - 833.25) <4C52ED74-A1FD-3087-A2E1-035AB3CF9610> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x92aba000 - 0x92b18fff  com.apple.coreui (1.2.2 - 165.10) <C6B099D6-7F02-3971-99B9-E415308959CF> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x92b1e000 - 0x92bb4ff7  com.apple.LaunchServices (480.33 - 480.33) <5A4BF529-391E-3987-940E-287ACE56078A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
    0x92bc4000 - 0x92c15ff9  com.apple.ScalableUserInterface (1.0 - 1) <3C39DF4D-5CAE-373A-BE08-8CD16E514337> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /ScalableUserInterface.framework/Versions/A/ScalableUserInterface
    0x92c16000 - 0x92d34fec  com.apple.vImage (5.1 - 5.1) <7757F253-B281-3612-89D4-F2B04061CBE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
    0x92d35000 - 0x92d43fff  com.apple.opengl (1.7.7 - 1.7.7) <2D362F15-5EA6-37B6-9BCB-58F2C599ACDA> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x92e41000 - 0x92e44ffb  com.apple.help (1.3.2 - 42) <B1E6701C-7473-30B2-AB5A-AFC9A4823694> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
    0x92e45000 - 0x92ea7ff3  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
    0x92ef3000 - 0x92f45ff7  libFontRegistry.dylib (??? - ???) <96E9602C-DFD3-3021-8090-60228CC80D26> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x92f46000 - 0x92f83ff7  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <1C757924-4E54-3522-A885-99795EA10228> /usr/lib/libcups.2.dylib
    0x92f84000 - 0x92f8bfff  com.apple.agl (3.2.0 - AGL-3.2.0) <ED5A5B8A-0014-3897-951F-628391333256> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x92f98000 - 0x9307bff7  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <BD913D3B-388D-33AE-AA5E-4810C743C28F> /usr/lib/libcrypto.0.9.8.dylib
    0x93112000 - 0x93135fff  com.apple.CoreVideo (1.7 - 70.3) <4234C11C-E8E9-309A-9465-27D6D7458895> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x93445000 - 0x93446ff0  libunc.dylib (24.0.0 - compatibility 1.0.0) <2F4B35B2-706C-3383-AA86-DABA409FAE45> /usr/lib/system/libunc.dylib
    0x93447000 - 0x93849ff6  libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
    0x9384a000 - 0x9384efff  libGIF.dylib (??? - ???) <A6F1ACAE-7B9B-3B3F-A54A-ED4004EA1D85> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x9384f000 - 0x93850fff  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
    0x939e7000 - 0x93a0cff9  libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x93a0d000 - 0x93a75ff7  libc++.1.dylib (28.1.0 - compatibility 1.0.0) <FE3304C5-C000-3DA0-9E53-0E4CA074B73B> /usr/lib/libc++.1.dylib
    0x93a76000 - 0x93a9eff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <AB530FB2-8BD1-3328-95E8-CF449F0429CA> /usr/lib/libxslt.1.dylib
    0x93a9f000 - 0x93bb0ff7  libJP2.dylib (??? - ???) <845C74F4-1074-3983-945F-EB669538CAA9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x93f6c000 - 0x93f6dffd  libCVMSPluginSupport.dylib (??? - ???) <22B85645-AA98-372B-BB55-55DCCF0EC716> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC VMSPluginSupport.dylib
    0x93f8d000 - 0x93f92ff7  libmacho.dylib (800.0.0 - compatibility 1.0.0) <943213F3-CC9B-328E-8A6F-16D85C4274C7> /usr/lib/system/libmacho.dylib
    0x93fb1000 - 0x93ffaff7  libGLU.dylib (??? - ???) <5EE0B644-FAD6-3E3C-A380-9B0CDA0B6432> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
    0x94001000 - 0x940e9fff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <1841196F-68B5-309F-8ED1-6714B1DFEC83> /usr/lib/libxml2.2.dylib
    0x940ea000 - 0x94120ff7  com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
    0x94385000 - 0x943aeffe  com.apple.opencl (1.50.69 - 1.50.69) <2601993F-F3B3-3737-91AE-4A5795C52CD5> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x94418000 - 0x944b4fef  com.apple.ink.framework (1.4 - 110) <1A3E2916-60C1-3AC1-86BF-202F6567B228> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
    0x944b5000 - 0x944b5fff  com.apple.Carbon (153 - 153) <63603A0C-723B-3968-B302-EBEEE6A14E97> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x944b6000 - 0x944cbff7  com.apple.ImageCapture (7.0.1 - 7.0.1) <1C8933A9-C7C6-36E9-9D8B-0EF08ACA3315> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
    0x944cc000 - 0x94542fff  com.apple.Metadata (10.7.0 - 627.32) <650EE880-1488-3DC6-963B-F3D6E043FFDC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
    0x945d0000 - 0x945d4ff7  com.apple.OpenDirectory (10.7 - 146) <4986A382-8FEF-3392-8CE9-CF6A5EE4E365> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
    0x9485d000 - 0x94860ffc  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
    0x94861000 - 0x948b1ff8  libTIFF.dylib (??? - ???) <4DC2025D-15E7-35CA-B7C5-9F73B26C8B53> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x948bd000 - 0x949ccfff  com.apple.DesktopServices (1.6.3 - 1.6.3) <18CAAA9E-7065-3FF7-ACFE-CDB60E5426A2> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
    0x954b0000 - 0x954c1fff  libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
    0x95514000 - 0x95517ff9  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <1211BEEB-31C9-3A5D-9E71-10FC4A541D1E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
    0x9565b000 - 0x956c0ff7  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
    0x956c1000 - 0x956c4ffd  libCoreVMClient.dylib (??? - ???) <361CCFAF-8565-383F-915F-0B059C793E42> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
    0x9639e000 - 0x963b1ff8  com.apple.MultitouchSupport.framework (231.4 - 231.4) <083F7787-4C3B-31DA-B5BB-1993D9A9723D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
    0x964c4000 - 0x96551fe7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <F2A8BBA3-6431-3CED-8CD3-0953410B6F96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
    0x96552000 - 0x965afffb  com.apple.htmlrendering (76 - 1.1.4) <409EF0CB-2997-369A-9326-BE12436B9EE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
    0x965b0000 - 0x965b4fff  com.apple.CommonPanels (1.2.5 - 94) <EA47550D-7DAF-30D9-91DB-1FB594CC8522> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
    0x968fc000 - 0x9693dff9  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <9FD420FB-7984-3A07-8914-BB19E687D38B> /usr/lib/libcurl.4.dylib
    0x9694c000 - 0x9694cfff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
    0x9694d000 - 0x9694eff7  libquarantine.dylib (36.6.0 - compatibility 1.0.0) <600909D9-BD75-386E-8D3E-7CBD29079DF3> /usr/lib/system/libquarantine.dylib
    0x9694f000 - 0x9696bffc  libPng.dylib (??? - ???) <75F41C08-E187-354C-8115-79387F57FC2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x9696c000 - 0x9729659b  com.apple.CoreGraphics (1.600.0 - ???) <62026E0C-E30F-3FF0-B0F6-6A2D270B20BF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x9760c000 - 0x97654ff7  com.apple.SystemConfiguration (1.11.3 - 1.11) <68B92FEA-F754-3E7E-B5E6-D512E26144E7> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
    0x9767a000 - 0x9767aff0  com.apple.ApplicationServices (41 - 41) <C48EF6B2-ABF9-35BD-A07A-A38EC0008294> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
    0x976a2000 - 0x9772cffb  com.apple.SearchKit (1.4.0 - 1.4.0) <CF074082-64AB-3A1F-831E-582DF1667827> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
    0x9777c000 - 0x9783cffb  com.apple.ColorSync (4.7.4 - 4.7.4) <0A68AF35-15DF-3A0A-9B17-70CE2A106A6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
    0x97885000 - 0x9788dff3  libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
    0x978c0000 - 0x978deff7  libsystem_kernel.dylib (1699.26.8 - compatibility 1.0.0) <3705DE40-E00F-3E37-ADB0-D4AE5F9950F5> /usr/lib/system/libsystem_kernel.dylib
    0x978df000 - 0x978edff7  libxar-nossl.dylib (??? - ???) <5BF4DA8E-C319-354A-967E-A0C725DC8BA3> /usr/lib/libxar-nossl.dylib
    0x978ee000 - 0x978f8ff2  com.apple.audio.SoundManager (3.9.4.1 - 3.9.4.1) <2A089CE8-9760-3F0F-B77D-29A78940EA17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
    0x978f9000 - 0x97939ff7  libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
    0x9793a000 - 0x97a0affb  com.apple.ImageIO.framework (3.1.2 - 3.1.2) <94798A2B-4C7A-30EA-9920-283451BDB9FA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
    0x97a0b000 - 0x984a0ff6  com.apple.AppKit (6.7.3 - 1138.47) <D8CD06D7-F18C-39BE-BC68-B343F87F0469> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x984a1000 - 0x98528fff  com.apple.print.framework.PrintCore (7.1 - 366.3) <EEC03CAB-7F79-3931-87FE-4DF0B767BF47> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
    0x98529000 - 0x98655ff9  com.apple.CFNetwork (520.4.3 - 520.4.3) <E9E315D4-CE22-3715-BED2-BB95AD5E10E8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
    0x98657000 - 0x98747ff1  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
    0x987db000 - 0x9881effd  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <6B35F203-5D72-335A-A4BC-CC89FEC0E14F> /usr/lib/system/libcommonCrypto.dylib
    0x988a2000 - 0x988b2fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x98900000 - 0x9897bffb  com.apple.ApplicationServices.ATS (317.11.0 - ???) <42238C8B-C93F-3369-A500-EC0F10EB2C80> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
    0x9897c000 - 0x9897cffe  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
    0x98c8d000 - 0x98d85ff7  libFontParser.dylib (??? - ???) <1A0DA421-62B2-3AA7-9F62-0E01C1887D09> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x98d86000 - 0x98dbaff8  libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <567E922C-E64F-321B-9A47-6B18BF481625> /usr/lib/libssl.0.9.8.dylib
    0x990eb000 - 0x990f8fff  libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
    0x990fb000 - 0x991c6fff  libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <52421B00-79C8-3727-94DE-62F6820B9C31> /usr/lib/system/libsystem_c.dylib
    0x991c7000 - 0x991f1ff1  com.apple.CoreServicesInternal (113.17 - 113.17) <41979516-2F26-3707-A6CA-7A95A1B0D963> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Vers ions/A/CoreServicesInternal
    0x991f2000 - 0x99253ffb  com.apple.audio.CoreAudio (4.0.2 - 4.0.2) <E617857C-D870-3E2D-BA13-3732DD1BC15E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x99254000 - 0x99262fff  libdispatch.dylib (187.9.0 - compatibility 1.0.0) <2F918480-12C8-3F22-9B1A-9B2D76F6F4F5> /usr/lib/system/libdispatch.dylib
    0x99263000 - 0x99264fff  liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
    0x993d7000 - 0x993dbffd  IOSurface (??? - ???) <EDDBEE65-1EB8-33A7-9972-E361A3508234> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x994bd000 - 0x994c6ff3  com.apple.CommonAuth (2.2 - 2.0) <C3FD6EC2-8EB3-38FB-BBB7-05009CA49024> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/Com monAuth
    0x9973b000 - 0x997fefff  com.apple.CoreServices.OSServices (478.46 - 478.46) <F2063FC8-2BE1-3B97-98AF-8796B0D4BE58> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
    0x99eb7000 - 0x99ebdffd  com.apple.CommerceCore (1.0 - 17) <E59CD307-58E2-35FD-9131-B38978799910> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x99ecd000 - 0x99edbfff  libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
    0x99edf000 - 0x99eeafff  libkxld.dylib (??? - ???) <D8ED88D0-7153-3514-9927-AF15A12261A5> /usr/lib/system/libkxld.dylib
    0x99efc000 - 0x99efcfff  com.apple.audio.units.AudioUnit (1.7.2 - 1.7.2) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x99efd000 - 0x99efeff4  libremovefile.dylib (21.1.0 - compatibility 1.0.0) <6DE3FDC7-0BE0-3791-B6F5-C15422A8AFB8> /usr/lib/system/libremovefile.dylib
    0x99eff000 - 0x99f0affb  com.apple.speech.recognition.framework (4.0.21 - 4.0.21) <A1764D2F-EB84-33DC-9ED5-CDA3B468FF3E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
    0x99f0b000 - 0x9a17effb  com.apple.CoreImage (7.98 - 1.0.1) <EDC91BA1-673D-3B47-BFD5-BBF11C36EE6A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /CoreImage.framework/Versions/A/CoreImage
    0x9a17f000 - 0x9a5f4ff7  FaceCoreLight (1.4.7 - compatibility 1.0.0) <3E2BF587-5168-3FC5-9D8D-183A9C7C1DED> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/ FaceCoreLight
    0x9a5f5000 - 0x9a7edff7  com.apple.CoreData (104.1 - 358.14) <C1730963-F75D-3338-B65F-D50235538B28> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x9a7ee000 - 0x9a9c5fe7  com.apple.CoreFoundation (6.7.2 - 635.21) <4D1D2BAF-1332-32DF-A81B-7E79D4F0A6CB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
    0x9a9cc000 - 0x9ad12ff3  com.apple.HIToolbox (1.9 - ???) <409E6397-0DCB-3431-9CCC-368317C62545> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
    0x9ad50000 - 0x9ad55ffd  libGFXShared.dylib (??? - ???) <1CA9B41B-2C61-38F8-ABAC-1D5511478F5C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
    0x9addc000 - 0x9addcfff  libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <7EFAD88C-AFBC-3D48-BE14-60B8EACC68D7> /usr/lib/system/libdnsinfo.dylib
    0x9addd000 - 0x9addfffb  libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x9b057000 - 0x9b074ff3  com.apple.openscripting (1.3.3 - ???) <33713C0B-B7D5-37AA-87DB-2727FDCC8007> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
    0x9b0ba000 - 0x9b0e8ff7  com.apple.DictionaryServices (1.2.1 - 158.2) <DA16A8B2-F359-345A-BAF7-8E6A5A0741A1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x9b0f1000 - 0x9b0f1fff  com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x9b0f2000 - 0x9b0f4ff9  com.apple.securityhi (4.0 - 1) <ACEEED5F-8D58-377D-B2B8-E4A7F4E5E286> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
    0x9b0f5000 - 0x9b14efff  com.apple.HIServices (1.21 - ???) <5F4D3797-32E2-3709-85F4-4B56515A17D7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
    0x9b14f000 - 0x9b2a1fff  com.apple.audio.toolbox.AudioToolbox (1.7.2 - 1.7.2) <E369AC9E-F548-3DF6-B320-9D09E486070E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
    0x9b2a2000 - 0x9b339ff3  com.apple.securityfoundation (5.0 - 55116) <EB53CEF7-4836-39FD-B012-6BC122ED4CE9> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
    0x9b33a000 - 0x9b345ffe  libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <B63F5D07-93B3-3F02-BFB7-472B4ED3521F> /usr/lib/libbz2.1.0.dylib
    0x9b346000 - 0x9b382ffa  libGLImage.dylib (??? - ???) <504E7865-571E-38B4-A84A-D7B513AC84F5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
    0x9b384000 - 0x9b3a0ff5  com.apple.GenerationalStorage (1.0 - 126.1) <E622F823-7D98-3D13-9C3D-7EA482567394> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versi ons/A/GenerationalStorage
    0x9b3a1000 - 0x9b3b5fff  com.apple.CFOpenDirectory (10.7 - 146) <9149C1FE-865E-3A8D-B9D9-547384F553C8> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x9b50d000 - 0x9b581fff  com.apple.CoreSymbolication (2.2 - 73.2) <FA9305CA-FB9B-3646-8C41-FF8DF15AB2C1> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Version s/A/CoreSymbolication
    0x9b5db000 - 0x9b5deff7  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
    0x9b5df000 - 0x9b64efff  com.apple.Heimdal (2.2 - 2.0) <2E1B8779-36D4-3C62-A67E-0034D77D7707> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimda l
    0x9b64f000 - 0x9b67afff  com.apple.GSS (2.2 - 2.0) <2C468B23-FA87-30B5-B9A6-8C5D1373AA30> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x9b92e000 - 0x9b935ffd  com.apple.NetFS (4.0 - 4.0) <AE731CFE-1B2E-3E46-8759-843F5FB8C24F> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x9b936000 - 0x9b93dff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
    0x9b93e000 - 0x9b95bfff  libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <2870320A-28DA-3B44-9D82-D56E0036F6BB> /usr/lib/libresolv.9.dylib
    0x9b95c000 - 0x9b993fef  com.apple.DebugSymbols (2.1 - 87) <EB951B78-31A5-379F-AFA1-B5C9A7BB3D23> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/D ebugSymbols
    0x9b99c000 - 0x9b99eff7  libdyld.dylib (195.6.0 - compatibility 1.0.0) <1F865C73-5803-3B08-988C-65B8D86CB7BE> /usr/lib/system/libdyld.dylib
    0x9babe000 - 0x9bac1ff7  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
    0x9bb15000 - 0x9bb1dff5  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <BB0C7B49-600F-3551-A460-B7E36CA4C4A4> /usr/lib/system/libcopyfile.dylib
    0x9bdcc000 - 0x9bdccfff  com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x9cb1e000 - 0x9cb24ffb  com.apple.print.framework.Print (7.4 - 247.3) <CB075EEE-FA1F-345C-A1B5-1AB266FC73A1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
    0x9cb9d000 - 0x9ccadfe7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <34E1E3CC-7B6A-3B37-8D07-1258D11E16CB> /usr/lib/libsqlite3.dylib
    0x9ccae000 - 0x9ccaeff2  com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
    0x9ce97000 - 0x9cf6daab  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <2E272DCA-38A0-3530-BBF4-47AE678D20D4> /usr/lib/libobjc.A.dylib
        task_for_pid: 2
        thread_create: 0
        thread_set_state: 0
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
        task_for_pid: 3735
        thread_create: 0
        thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=219.6M resident=105.4M(48%) swapped_out_or_unallocated=114.2M(52%)
    Writable regions: Total=139.4M written=6536K(5%) resident=10.8M(8%) swapped_out=0K(0%) unallocated=128.6M(92%)
    REGION TYPE                      VIRTUAL
    CG raster data                      860K
    CG shared images                   1224K
    CoreGraphics                          8K
    CoreServices                       3724K
    MALLOC                             80.8M
    Memory tag=243                        8K
    Stack                              76.2M
    VM_ALLOCATE                        1004K
    __CI_BITMAP                          80K
    __DATA                             13.3M
    __DATA/__OBJC                       224K
    __IMAGE                             528K
    __IMPORT                            284K
    __LINKEDIT                         76.5M
    __OBJC                             1460K
    __PAGEZERO                            4K
    __TEXT                            143.1M
    __UNICODE                           544K
    mapped file                       145.8M
    shared memory                       364K
    shared pmap                        10.6M
    TOTAL                             590.7M
    TOTAL, minus reserved VM space    557.3M
    Model: MacBookPro8,2, BootROM MBP81.0047.B27, 4 processors, Intel Core i7, 2.2 GHz, 8 GB, SMC 1.69f3
    Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 1024 MB
    Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 512 MB
    Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333531533642465238432D48392020
    Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333531533642465238432D48392020
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.198.4.20)
    Bluetooth: Version 4.0.5f11, 2 service, 18 devices, 1 incoming serial ports
    Network Service: Wi-Fi, AirPort, en1
    Serial ATA Device: Hitachi HTS725050A9A362, 500.11 GB
    Serial ATA Device: MATSHITADVD-R   UJ-8A8
    USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfa100000 / 3
    USB Device: USB Mouse, 0x0d62  (Darfon Electronics Corp.), 0xa100, 0xfa130000 / 6
    USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0245, 0xfa120000 / 5
    USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 4
    USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821a, 0xfa113000 / 7
    USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0xfa200000 / 2
    USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfd100000 / 2
    USB Device: Desktop, 0x0bc2  (Seagate LLC), 0x3300, 0xfd120000 / 4
    USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd110000 / 3
    FireWire Device: GoFlex Desk, Seagate, 800mbit_speed
    Please help thanks
    May 30, 2012 8:10 PM   in reply to ographix
    For this crash report, it looks like the Favorites file is corrupt.  You might want to email that .xml file in the preference folder to audbugs@adobe.com such that the team can investigate.  Otherwise, probably deleting your prefs file might help your crash on startup.
