Encore: what does it take to get an input legal?
Apr 22, 2010 10:36 AM
I know this is a bit off topic from Premiere SDK but since there is no Encore (highly technical) forum I thought it best to post here instead of emailing Zac directly (so that others may learn the answer).
My question is this:
     Specifically, what does it take for Encore to NOT transcode an input video file for DVD (mpeg2) or BluRay (mpeg4) destination?
thx.
    Apr 22, 2010 11:23 AM   in reply to Rallymax
    Encore uses the Sonic HDMV SDK for Blu-Ray support. Below are the video formats supported by Encore:
    Resolution
    Display Aspect Ratio
    FPS
    Scan Mode
    TV Standard
    1920 × 1080
    16x9
    29.97
    Interlaced
    NTSC
    1920 × 1080
    16x9
    25
    Interlaced
    PAL
    1920 × 1080
    16x9
    24
    Progressive
    NTSC, PAL
    1920 × 1080
    16x9
    23.976
    Progressive
    NTSC, PAL
    1440 × 1080
    16x9
    29.97
    Interlaced
    NTSC
    1440 × 1080
    16x9
    25
    Interlaced
    PAL
    1440 × 1080
    16x9
    24
    Progressive
    NTSC, PAL
    1440 × 1080
    16x9
    23.976
    Progressive
    NTSC, PAL
    1280 × 720
    16x9
    59.94
    Progressive
    NTSC
    1280 × 720
    16x9
    50
    Progressive
    PAL
    1280 × 720
    16x9
    24
    Progressive
    NTSC, PAL
    1280 × 720
    16x9
    23.976
    Progressive
    NTSC, PAL
    720 × 576
    16x9
    25
    Interlaced
    PAL
    720 × 576
    4x3
    25
    Interlaced
    PAL
    720 × 480
    16x9
    29.97
    Interlaced
    NTSC
    720 × 480
    4x3
    29.97
    Interlaced
    NTSC
    And here are the audio formats supported:
    Codec
    File Format
    Sample Rate
    Sample Size
    Channels
    Max Bitrate
    LPCM
    .wav
    48 kHz
    16, 20, 24
    2, 4, 6, 8
    n/a
    LPCM
    .wav
    96 kHz
    16, 20, 24
    2, 4, 6, 8
    n/a
    LPCM
    .wav
    192 kHz
    16, 20, 24
    2, 4, 6
    n/a
    Dolby Digital
    .ac3
    48 kHz
    n/a
    up to 6
    640 kbps
    Dolby Digital Plus
    .ec3
    48 kHz
    n/a
    up to 8
    4736 kbps
    DTS
    .dts, .cpt
    48 kHz
    n/a
    up to 5
    1509 kbps
    DTS-HD
    .dts-hd
    48 kHz
    n/a
    up to 8
    24500 kbps
    DTS-HD
    .dts-hd
    96 kHz
    n/a
    up to 8
    24500 kbps
    DTS-HD
    .dts-hd
    192 kHz
    n/a
    up to 6
    24500 kbps
    Let me know if you have any specific questions on the specs, or any files that are getting transcoded, and I can take a look.
    Apr 22, 2010 1:13 PM   in reply to Rallymax
    The Encore forum has a FAQ on troubleshooting m2v files that are being transcoded by Encore: http://forums.adobe.com/thread/398763?tstart=0
    This tutorial might also help: http://blogs.adobe.com/davtechtable/2008/04/apples_compressor_encore_b lura.html
    Apr 22, 2010 6:01 PM   in reply to Zac Lam
    Hi Zac-san
    Though I might be wrong...
    You should prepare AC3 or Dts for audio of channels that are more than two.
    For example, it is mixed with two channels even in case of WAVE of six channels if you prepare LPCM.
    Kengo Mikoshiba.
    ----- from my notes -----
    The syntax of MPEG-2 and the H.264 data depends on the encoder.
    And Encore does not check the syntax of these streams. I guess.
    It is not guarantee even if Encore doesn't transcode your prepared data is fit for DVD or Blu-ray.
    I expect it is no problem if you use a standard plug-in of Premiere.
    Oct 18, 2011 12:19 AM   in reply to Zac Lam
    Hi Zak,
    I have a couple technical questions about AVCHD, Blu-ray pass-through.
    1) The Help files notes that "Encore does not transcode Blu-ray legal AVCHD files. The table of legal frame sizes does not include 1920x1080 30 progressive. Yet, when I use Adobe Dynamic Link in Encore CS5 to import a P Pro CS5 AVCHD 1080 30p sequence, and then convert that to a Timeline, the listing under Blu-ray Transcode Status is "--" and under Blu-ray Transcode Settings is "N/A." Can you or someone on the Encore team explain that?
    2) If a P Pro sequence has non-AVCHD items in it (AVI files or still images, for example), how does Encore handle them such that they do not have to be transcoded for Blu-ray?
    Jeff Sengstack
    Oct 18, 2011 4:13 PM   in reply to Rallymax
    Hi Rallymax,
    Thanks for your response. I have two follow-up questions:
    1) Regarding Dynamic Linking: What is AVC smart rendering? I don't know that that is an option in P Pro or Encore.
    2) You said uing Dynamic Linking means "there is very little chance that [Encore] will get the video stream blu-ray legal." What workflow does passthrough AVCHD clips to Blu-ray without rendering?
    Jeff
    Oct 19, 2011 10:57 AM   in reply to Rallymax
    The Blu-ray disk format does not include the possibility of 30p.  This is not an Encore specific limitation, but a Blu-ray disk limitation.  (Though admittedly I can't explain the Transcode values using Dynamic Link.  My own suggestion here would be to not shoot 30p when going to Blu-ray, and to just not use Dynamic Link.  Export out of Premiere Pro first.)
    Oct 19, 2011 10:58 AM   in reply to Rallymax
    Everything in a PP sequence will need transcoding.  There's no way around that.
    Oct 19, 2011 12:50 PM   in reply to Rallymax
    Hi Rallymax, Sengstack,
    2) You said using Dynamic Linking means "there is very little chance that Re: Encore: what does it take to get an input legal? will get the video stream blu-ray legal." What workflow does passthrough AVCHD clips to Blu-ray without rendering?
    Zac, if you have a Premiere Project Dynamically Linked into an Encore project is Encore going to always decide that it needs transcoding?
    If the sequence is configured at Blu-ray legal dimensions AND it can provide the custom FourCC = “AVC “ theoretically it meets the condition check right?
    I would agree with Jim Simon.  If you're using Dynamic Link in Encore, it won't be bringing in compressed AVC, and you'll need to transcode.
    So rather than importing PPro projects, importing pre-encoded Blu-ray compliant files is going to be the way to skip the transcode in Encore.
    Also, has Encore CS5.5 been upgraded to support Blu-ray 3D with its use of the MVC codec extension to the AVC codec
    Not yet.  Good feature request!
    Cheers,
    Zac
    Oct 19, 2011 5:33 PM   in reply to Rallymax
    Rallymax,
    Thanks for the smart rendering tour and the other explanations. I think I've got a handle on this now.
    Jeff
    Jun 23, 2012 3:04 PM   in reply to Zac Lam
    My file format for my DTS-HD MA files from the DTS-HD Master Audio Suite (on my mac) results in the extension .dtshd & not .dts-hd, is there going to be any problems for Encore CS6?
    Jun 25, 2012 2:44 PM   in reply to m2425
    Hi m2425,
    I think the original question on this thread has been answered.  Can you start a new thread with your new question, and if you want, post the link in this one?
    Zac
    Jun 25, 2012 11:30 PM   in reply to Zac Lam
    Ok
    Jun 30, 2012 7:19 AM   in reply to m2425
    That's correct. extension for these file types is .dtshd, and the stream will also contain the hidden core audio stream (this should have been set up at the encoding stage). You will not be able to preview these streams.
Bookmarked By (1)
