Installed Flash Player 11 on a 266 Intel Core Duo Mac running OSX 10.6.8 and the plug in is not working on any of my browsers:
Safari 5.1.1
Firefox 7.0.1
Google Chrome 14.0.835.202
I have tried uninstalling and reinstalling Flash 11. Also tried downgrading to 10.3. None of these efforts have solved the problem.
There are no error messages other than "plugin-failure" in Safari and "The Adobe Flash plug-in has failed" in Firefox.
Flash was working fine before the install of Flash 11.
Any help in resolving this issue would be appreciated.
Are you using the Flash Player uninstaller listed below for 10.6?
Yes. Uninstalled using the 10.6 file and reinstalled Flash Player 11. Visited http://www.adobe.com/software/flash/about/ to test the player, and no change.
Still not working.
Have you tried uninstalling and installing a previous version (10.3 preferably) and seeing if that one works? You can get previous versions of the player here...
Yes, tried uninstalling/installing several times. Tried again with the uninstaller/installer you provided in this thread. No change. Flash Player still not working.
Aside from upgrading to Safari 5.1.1 a few days ago, I have not added anything to the system. Besides this problem started upon upgrading to Flash 11, before the Safari upgrade, and affects my other browsers as well.
Stop wasting your time here, you will not get help here, there are few set answers, you will get here. Also if you call Adobe, make sure to call from home phone with free call, cause nobody will answer, I tried twice for 45 mins each on hold than I hang up.
Adobe totally Failure. if it is working do not upgrade. delete, get rid of those upgrade pop ups.
When you go to the following page in each of your browsers, which version is listed (if any)? Specifically try Safari and Chrome.
http://kb2.adobe.com/cps/155/tn_15507.html
Also, do you have any sort of virus software installed? If so, try disabling it. Not permanently, just to see if this is what could be causing the problem.
No anti-virus software installed.
Went to the page, and I see the following:
If Flash Player is installed on your computer, the following box displays the version of Flash Player installed along with the operating system:"
Then just a big blank space. No error message. Nothing.
Seems to me that the page requires Flash Player to be working to determine which version I'm running?
I have been having the EXACT same issue on my computer since I ran some updates last week. I keep getting "Plug-in Failure" when trying to run Flash on any browser. I have tried uninstalling and reinstalling several times and each time I get the same results. Not sure if it's related but I also noticed that many of my fonts had become corrupted following the last set of updates I ran as well. Please let me know if you were able to come up with any solutions.
Unfortunately, I couldn't get an answer which helped with Flash Player 11. Ultimately had to uninstall it and reinstall 10.3.
Sorry.
This is because any nested 3D layers are not longer working on the latest Flash plug-in. The 3D layers have to be on root level.
