Frame duplication during 2vuy (in .avi) import on Premiere CS4
Oct 20, 2011 7:20 PM
Tags: #avi #import #2vuy #aja #kona
Hello:
I am currently trying to import a complete Premiere CS4 (version 4.2.1) project on my laptop, Windows 7 - 64bit, which doesn't have an AJA Kona 3 card installed. The detailed file specification of the source file is given further below and had been created on a system with AJA's Kona card. The source files are in an AVI wrapper, in OpenDML, with 2vuy and had been created by the AJA Kona card on a different system.
The file gets imported into Premiere, and it displays the correct file length, here of about 56mn 24s. However, I can only access the first few seconds. If I drag the video file to the timeline, I realized that every frame is present for about 2 minutes and 40 seconds, which results in about 18 seconds of the original file length. To explain it in different words - I have the same frame at position 00:00:00, 00:00:01, 00:00:02 until 02:39:24.
The original files can be properly displayed within the windows media player, which utilizes a YCbCr Codec from Drastic Technology Inc. Therefore, I strongly believe that the source files aren't corrupted. What should I do now?
BR
Filmemacher
General
Complete name :
H:\PZ05\116_PZ05\pz05\Captured Video\main 03.avi
Format :
AVI
Format/Info :
Audio Video Interleave
Format profile :
OpenDML
File size :
  1. 65.4 GiB
Duration :
56mn 24s
Overall bit rate :
166 Mbps
Video
ID :
Format :
2vuy
Codec ID :
2vuy
Duration :
56mn 24s
Bit rate :
2 539 Kbps
Width :
720 pixels
Height :
576 pixels
Display aspect ratio :
5:4
Frame rate :
  1. 25.000 fps
Standard :
PAL
Bits/(Pixel*Frame) :
  1. 0.245
Stream size :
  1. 1.00 GiB (2%)
    Oct 21, 2011 7:18 AM   in reply to Filmemacher
    I believe you'll need the AJA hardware to work on this project.
    Oct 21, 2011 11:59 AM   in reply to Filmemacher
    I am looking for a solution, which doesn't require the AJA hardware
    I get that.  I just don't know if it's possible.
    You could check with AJA, see what they say about it.
