pixelFormatSupported
Oct 21, 2011 3:43 PM
Tags: #transition_api #pixel_format
Hey guys,
Trying to get into the pixelFormats here.
I'm adjusting the SDK's Cross Dissolve in order to find out if it's possible to write a transition that only supports PrPixelFormat_BGRA_4444_32f.
This way I can get into making quality plugins without having to write seperated code for different PixelFormats.
"Starting in CS4, plug-ins no longer need to support 8-bit BGRA at a minimum."
- I say: let PP handle the nessesary conversions. Let me focus on just the BGRA4444_32f
So I'm banishing some lines of code:
static prMALError GetPixelFormatsSupported(EffectHandle theData)
          prMALError result = esNoErr;
  switch((*theData)->pixelFormatIndex)
/*                    case 0:
                              (*theData)->pixelFormatSupported =  PrPixelFormat_BGRA_4444_8u;
                              break;
                    case 1:
                              (*theData)->pixelFormatSupported =  PrPixelFormat_VUYA_4444_8u;
                              break;
  // These pixel formats are only available in Premiere Pro 2.0 and later
                    case 2:
                              if ((*theData)->version >= 9)
                                        (*theData)->pixelFormatSupportedPrPixelFormat_BGRA_4444_32f;
  else
                                        result = esBadFormatIndex;
  break;
/*                    case 3:
                              (*theData)->pixelFormatSupported =  PrPixelFormat_VUYA_4444_32f;
                              break;
  default:
          return result;
So we are down to the one and only PrPixelFormat_BGRA_4444_32f
I wanted to see what happens.
But I didn't got the feeling it wasn't working, because it still showed the YUV sign in the effects tab.
So I messed around with this: Banished some other lines of code so it would only support 8u.
Well, at some point all the signs (32-bits and YUV) where gone in the Effects tab.
Now I want them back. But I can't...
I keep reloading the plug-in by restarting PP - nothing
I'm holding shift at the start of PP to refresh all the plugins. - nothing.
Redownloaded the fresh SDK pack, recompiled the cross dissolve with nothing changed - nothing.
started to get frustrated...
told the plugin not to cache itself, but to reload each time pp is started by adding:
        case esCacheOnLoad:
            result = esDoNotCacheOnLoad;
            break;
to the selector switch: PREMPLUGENTRY DllExport xEffect (short                               selector,   EffectHandle           theData)
looked at the ~/library/adobe/premiere pro/5.5/plugin loading.log   and found:
Loading /Library/Application Support/Adobe/Common/Plug-ins/CS5.5/MediaCore/Cross_Dissolve.bundle
The registry tells us not to cache so the plugin will be loaded from disk.
Loading from disk...
This plugin was recognized by loader 3dbe9220-aa71-4c9d-9342-4c239a83a825.
- So this is OK. - but then again it doesn't change anything with the recogition for being 32-bits enabled
So the SDK Cross Dissolve transition listed in the Effects tab still isn't showing me the 32bits sign, even with a freshly compiled original that should support both 32-bits color and YUV.
What am I missing here?
Cheers,
Jaap
    Oct 24, 2011 10:32 AM   in reply to Jaap H
    The list of supported pixelformats is stored as an array so you have to start with an index of 0.
    Simply commenting out the handling cases won’t work – it’ll just fall through for those cases.
    You need to modify the PixelFormats[] array that is originally created so that Premiere knows what PixelFormats are supported.
    That means that you’ll end up with a
    PixelFormats[] = ; only
    Once you’ve done that change you can change the handling function too…
    if( (theData)->pixelFormatIndex == 0 && (theData)->version >= 9)
    (*theData)->pixelFormatSupported =  PrPixelFormat_BGRA_4444_32f;
                else
                return result;
    Oct 24, 2011 1:44 PM   in reply to Jaap H
    Unfortunately plugin development isn’t as easy as we all would like but at least it is open for us to develop on.
    I suspect that the Editing Mode you’re in has a Player that doesn’t support BGRA_4444_32f and does (because of legacy) support BGRA_4444_8u thus the preview window requires BGRA_8u support to work.
    If you do want to support BGRA_4444_8u then you should be able to make common code by converting the 8u to 32f and then continuing your plugin as 32f. (Likewise you should do a YUV_32f to BGRA_32f –although if you don’t know a lot about rec601 and rec709 colorspaces I HIGHLY recommend that you DO NOT start doing this).
    Here’s a quick mock up off the top of my head…
    float The32fFrame = (float)TheFrame;
    int do_32f_to_8u = 0;
    switch((*theData)->pixelFormatSupported)
    case PrPixelFormat_BGRA_4444_8u:
    // Flag to un-convert at the end
    do_32f_to_8u = 1;
    The32fFrame= malloc(heightrowstride4);
    // Convert 0..255 (_8u) buffer to 0.0…1.0 (_32f)
    // Change this to SSE|2|3|4 intrinsics for a 4x or 8x speedup!
    for(int h=0;h<height;h++)                     // Height
    for(int w=0;w<width;w++)         // Width
    for(int p=0;w<4;p++)    // Plane
                            The32fFrame[4hrowstride+ 4*w + p] =
    (float)TheFrame[4h rowstride + 4*w + p]/(float)255.0);
    // Now fall through and process as BGRA_32f
    case PrPixelFormat_BGRA_4444_32f:
    // IMPLEMENT YOUR FILTER/TRANSITION HERE
    break;
                default:
                            return WHATEVER THE ERROR CODE IS FOR UNSUPPORTED;
    //Run a loop that un-does the floating point conversion if necessary.
    if(do_32f_to_8u)
    // Change 32f back to 8u
    TheFrame[4h rowstride + 4*w + p] =
    (unsigned int)((float)255.0 * The32fFrame[4h rowstride + 4*w + p]);
                free(The32fFrame);
    return prNOERR;
    ·         Where “rowstride” is the actual stride of the row, not the frame width.
    Oct 24, 2011 1:47 PM   in reply to Jaap H
    Oops a mistake
    Should be
    The32fFrame= malloc(heightrowstride4*sizeof(float));
    Oct 24, 2011 1:50 PM   in reply to Jaap H
    This too…
    new version with “w” to “p” fix…
    for(int p=0;p<4;p++)    // Plane
