Expression needed!! Any help appreciated. Using audio converted keyframes
Oct 22, 2011 4:39 AM
Hi all,
I'm hoping this isn't to much of a complicated issue. I use after effects regularly but the expression stuff does have me baffled. I can convert the audio to keyframes with out an issue. What I'm trying to achieve is this - I have a talking head with the bottom mouth part cut on a sperate layer. i'd like the mouth layer to move up and down being driven by the audio. I can pick whip to the audio no problem but then I need to ensure it only effects one of the position values and also 'fine tune' how the audio effects that value.
Please help!!
Thanks!!
    Oct 22, 2011 9:07 AM   in reply to Shaun Phillips
    I'm not sure what you're doing with the slider, but I think this is all you need for the mouth:
    aud = thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider);
    y = linear(aud,0,36,1492,1547);
    [1001.5,y]
    If you already have the mouth positioned at [1001.5,1492], you could just do this:
    y = linear(aud,0,36,0,55);
    value + [0,y]
    Dan
    Oct 22, 2011 12:26 PM   in reply to Shaun Phillips
    I'm sure you figured out that there's a typo in the expression I posted. I left out the closing quote on "Slider".
    Dan
