Adding xtras in Dir 11.5.9
Oct 21, 2011 10:55 AM
In previous versions of Director, all I had to do to "install" a new xtra was copy and paste it into the Director application's Xtras folder.  I'm currently attempting to "add" an xtra that way to a project.  Yet, when I click Add, the xtra doesn't show up in the list, even though it is in the Director application's Xtras folder.  Am I missing something?
I have tried just copying and pasting the xtra into the Xtras folder in my project folder.  But the projector can't find it.  This also happens to be an xtra that needs to be included in the projector, and I published the projector with the "Include in Projector" box checked.  Nevertheless, it can't find it.
Thanks for whatever info you can provide.
Dewey
    Oct 21, 2011 7:11 PM   in reply to MECS
    What's the xtra - is it updated for D11.5 and can your authoring environment find and use it?
    Oct 22, 2011 8:18 AM   in reply to MECS
    MECS wrote:
    The Xtra is resolution.x32  v1.3.5
    How do you update an xtra for D11.5?
    That xtra is not v11.5 compatible.
    And Mark Andrade (AndradeArts) dropped his xtras development a few years ago.
    But what are you trying to achieve there?
    There is always a workaround.
    Oct 22, 2011 9:58 AM   in reply to MECS
    There is a list of screen resolution xtras here:
    http://www.deansdirectortutorials.com/MileHighTable/#ScreenResolution
    DisplayMode Xtra is probably your best bet; it is Director 11.5 compatible and can do precisely what you want ... the only downside is that you have to buy a license:
    http://www.xtras.starsoftmultimedia.com/xtras/DisplayMode/index.php
    Buddy API is another possibility:
    http://www.mods.com.au/budapi_docs/baSetDisplay.htm
    You get two free method calls with the unregistered version, which might not be enough in your case (because you have get and store the original setting in order to turn the monitor back when exiting, which adds up to a  total of three).
    Oct 23, 2011 4:43 PM   in reply to MECS
    I have a similar problem. I copied all the xtras in the mac xtra folder and put them next to the projector.
    On mac using Lion and from Director 1.5, the projector can not find the Fileio xtra. I get an error
    What do I need to do to have it read the fileio xtra. Do I have to change the way is it is called? Did it change from Director MX?
    Thans for your help.
    Clang
    Oct 24, 2011 5:14 PM   in reply to MECS
    Actually the error says, Projector error: FileIO xtra is missing. That is all.
    I took all the xtras that were in cross-platform folder of my 11.5 Director and put them in the same folder as projector I want to run.
    But it does not seem to like what is there. Has Adobe not provided the correct xtra in that folder? My Director BTW is uptodate.
    Dont know where to go from here?
    Thanks.
    char
    Oct 25, 2011 3:45 AM   in reply to clangton
    You should put the xtras into a folder called "xtras", not into the same folder as the executable
    Oct 25, 2011 8:18 AM   in reply to MECS
    No.  sounds like you have it correct.  You can try embedding the xtras into the executable by going to Modify, Movie, Xtras, then Add every xtra you need for the projector.  Then republish.  Once you do that, you will not need the external xtras folder at all.
    Oct 25, 2011 8:48 AM   in reply to Mike Blaustein
    Yes, I have the fileio xtra and all the other xtras, all in one folder called xtras. This folder "xtras" sits in an another folder which also contains the executable.
    So they are side by side.
    The configuration of folders etc. is same as what I have on the PC version and this has always workd fine for me.
    This is an old working program that I trying to make work on the Mac Lion OS. So m idea was to create a new projector and replace the oldone with new one
    that will run on Mac Lion. I also upgraded the Xtra folder at the same time with the Mac Xtras that came with the Director 11.5.
    So al I have done to a program that was working on the Mac Snow Leopard, is to chage the director and the xtas folder. The program does rin okay, except it gives an error
    that the fleio is missing. Then it goes on the run okay.
    I dont think it is the configuation. Its just that the
    xtra itself ( has ppc in the name.) is not being accepted by the executable.
    Char
    Oct 26, 2011 2:09 AM   in reply to MECS
    One thing I never have been quite clear on, however; is there a way I can find out what xtras my project actually require so I don’t dump in a bunch of xtras that I don’t need?  The program will let me know if I left one out that it needs, but it doesn’t tell me if I throw some in that are required.
    The only way to do this is to go to the dialog Mike suggested (Modify -> Movie -> Xtras...) and delete everything there (select them one-by-one and hit the Remove button, or select the top one and just keep hitting Remove until the dialog is empty). Any cast members that require asset xtras will automatically add them back (close and re-open the dialog to see what they are). However, any scripting xtras won't be auto-added and you'll need to remember which ones your movie/s rely on (like FileIO) and Add them manually.
