Part of my job is to teach routined InDesign users how to build Folio's. Most of them do quite well, after their initial confusion with the Interaction panels ("which do and which don't work with ADPS"). But the panel they fear most, is definitely the Folio Builder. Not even because of its casual malfunctioning (that's my nightmare as a trainer), but mainly because of its design and cosmetics. The panel sports a well-know and trusted appearance, but it's a devil in disguise.
It begins with logging-in. "No, you can't click the bull's-eye, it's just a mysterious indicator." It would be much more obvious if it looked like a led (red or green) or if it had some useful interaction to it - letting you log in/out perhaps...
Next, the three-tiered views are not clear enough. When I show them the image below, and tell them how their workflow moves from left to right and from right to left (from "Account" to "Folio" to "Article" to "Layout" and v.v.) they immediately 'get it'. And after warning them that the navigational elements on top of the panel are quite clueless (what to hit, to go where to), and that you're often thrown back from Layout to Folio (skipping Article), they're in charge and on guard. Finally, I tell them that the "New" button magically changes its functionality in each level ("wait for the pop-up!"). It is highly unusual that a side menu shows and hides certain commands in each level. It should list ALL associated commands, and show momentarily unavailable ones grayed out.
This all wouldn't be necessary if the panel would be a bit more self-explanatory. I hope this rant helps to improve its design.
very good. these all need to be addressed. the experience of the folio
builder panel is bad... I have so many ideas of a redesign in my mind, but
I'm not in charge. maybe this thread can turn into a design ideaas for the
Panel.
good start, Peter!
(mobil gesendet)
Am 23.10.2011 00:30 schrieb "Peter Villevoye" <forums@adobe.com>:
Re: The Folio Builder panel, design-wise... created by Peter Villevoye<http://forums.adobe.com/people/Peter+Villevoye>in
Digital Publishing Suite - View the full discussion<http://forums.adobe.com/message/3985568#3985568>
Thanks to you both,
I do have an account (I can log into the DigitalPublishing site, as well as the general Adobe site)
I am running CS5 and have updated with:
AdobeDigitalPublishing-All.dmg as well as
AdobeDigitalPublishing-Tools.dmg
All of the DP panels open and the features work, still trouble loggin in.
Maybe there's another patch or update that I'm needing?
Thanks again,
Ev
Don't trust the "Update" button in the Folio Builder panel (another buggy and therefore useless feature...) It points to a page where only 'fresh' and not 100% up-to-date complete installs can be found. For now, use, trust, and refer to this URL and especially the "Update" section (halfway the page):
http://help.adobe.com/en_US/digitalpubsuite/using/WS67cb9e293e2f1f60-2 1ba9a4512e5e5e0b8d-7ffe.html
This separate/modular installing and updating of extensions, tools and apps is necessary. It prevents that users who already work with ADPS, inadvertedly produce folio's that don't run on older viewers (which they need to update first, before updating all tools inside of InDesign).
Getting it to work can be Rocket Science...
Feel free to openly discuss any improvements or behavior changes you'd like to see made to the folio builder panel. We value comments and suggestions from people actively using the products in the field. I have several usability improvements I'd like to see made to the panel, it just becomes a tradeoff between increasing stability, usability and new features. Input on these forums does get listened to and acted on.
I think one very tiny change might already help (both new and routined) users to distinguish quickly between the several states of the panel: make the article bars less high. There are not only more than enough articles in a regular pub to be happy with more entries in the panel's view size, it also helps to instantly see that you're in the 'other' state. And maybe the Layout state might sport a different ordering of the two obvious thumbnails, leaving a tinted gap in the pane for the missing layout(s). In that way all states are easier to distinguish and understand.
It also frees up some space to design a bit more explanantory and helpful navigational bar at the top of the panel. It's clumsy, having to navigate so often and carefully through such a cryptic interface.
