Xavier Beautoir 12 posts
Sep 23, 2011
Error while loading services: Failure in Loader: VerifyError: Error #1014
Oct 19, 2011 7:08 PM
I have a library that, after it loads, I see this error in the console:
Failure in Loader: VerifyError: Error #1014: Class mx.collections::ArrayCollection could not be found.
I had the same problem with another library, except it had a problem with IToken. I got around this problem by changing the default linkage of libraries in build path from external to merge into code. That did not work this time.
Merging Flex libraries into service libraries does not seem to be anything close to the correct way to deal with this. Besides, it didn't some the problem every time.
What is the best way to keep these sorts of dependency errors from arising? The RSLs are included with Web apps, but not with libraries.
    Oct 19, 2011 8:30 PM   in reply to Xavier Beautoir
    Hi Xavier,
    Is the library that fails to load an interface library? There are restrictions on classes that can be in interface libraries. See the section titled “Limitations on classes used in a service interface library” on this help page: http://help.adobe.com/en_US/enterpriseplatform/10.0/AEPDeveloperGuide/ WSabb771403789c7a3-31e63d5312fb7375fac-8000.html#WSabb771403789c7a3-37 c95b1412fb7245fd9-8000 Service libraries can use Flex classes that are specific to a flex version, but cannot render any UI elements.
    Don
