Hey guys,
Trying to get into the pixelFormats here.
I'm adjusting the SDK's Cross Dissolve in order to find out if it's possible to write a transition that only supports PrPixelFormat_BGRA_4444_32f.
This way I can get into making quality plugins without having to write seperated code for different PixelFormats.
"Starting in CS4, plug-ins no longer need to support 8-bit BGRA at a minimum."
- I say: let PP handle the nessesary conversions. Let me focus on just the BGRA4444_32f
So I'm banishing some lines of code:
static prMALError GetPixelFormatsSupported(EffectHandle theData)
prMALError result = esNoErr;
switch((*theData)->pixelFormatIndex)
/* case 0:
(*theData)->pixelFormatSupported = PrPixelFormat_BGRA_4444_8u;
break;
case 1:
(*theData)->pixelFormatSupported = PrPixelFormat_VUYA_4444_8u;
break;
// These pixel formats are only available in Premiere Pro 2.0 and later
case 2:
if ((*theData)->version >= 9)
(*theData)->pixelFormatSupported = PrPixelFormat_BGRA_4444_32f;
else
result = esBadFormatIndex;
break;
/* case 3:
(*theData)->pixelFormatSupported = PrPixelFormat_VUYA_4444_32f;
break;
default:
return result;
So we are down to the one and only PrPixelFormat_BGRA_4444_32f
I wanted to see what happens.
But I didn't got the feeling it wasn't working, because it still showed the YUV sign in the effects tab.
So I messed around with this: Banished some other lines of code so it would only support 8u.
Well, at some point all the signs (32-bits and YUV) where gone in the Effects tab.
Now I want them back. But I can't...
I keep reloading the plug-in by restarting PP - nothing
I'm holding shift at the start of PP to refresh all the plugins. - nothing.
Redownloaded the fresh SDK pack, recompiled the cross dissolve with nothing changed - nothing.
started to get frustrated...
told the plugin not to cache itself, but to reload each time pp is started by adding:
case esCacheOnLoad:
result = esDoNotCacheOnLoad;
break;
to the selector switch: PREMPLUGENTRY DllExport xEffect (short selector, EffectHandle theData)
looked at the ~/library/adobe/premiere pro/5.5/plugin loading.log and found:
Loading /Library/Application Support/Adobe/Common/Plug-ins/CS5.5/MediaCore/Cross_Dissolve.bundle
The registry tells us not to cache so the plugin will be loaded from disk.
Loading from disk...
This plugin was recognized by loader 3dbe9220-aa71-4c9d-9342-4c239a83a825.
- So this is OK. - but then again it doesn't change anything with the recogition for being 32-bits enabled
So the SDK Cross Dissolve transition listed in the Effects tab still isn't showing me the 32bits sign, even with a freshly compiled original that should support both 32-bits color and YUV.
What am I missing here?
Cheers,
Jaap
Getting a step closer:
It seems that deleting the:
~/library/preferences/com.adobe...5.5.plist
wil get PP to update the 32-bits color and YUV icons behind the plugins in the effects tab
Now the code above with only the PrPixelFormat_BGRA_4444_32f as being supported by the plugin doesn't work.
A) PP doesn't show a 32-bits color icon.
B) it acts as if the plugin would still support PrPixelFormat_BGRA_4444_8u (or YUV_8u) and doesn't launch the RenderDissolve32f function.
"Starting in CS4, plug-ins no longer need to support 8-bit BGRA at a minimum. If required, Premiere can make intermediate format conversions in the render pipeline, although these inter- mediate conversions will be avoided if possible."
But It seems PP still requiers me to have my transitions to be 8-bit BGRA supported. True?
Is it time for me to get into ScaleConvert()?
Cheers,
Jaap
The list of supported pixelformats is stored as an array so you have to start with an index of 0.
Simply commenting out the handling cases won’t work – it’ll just fall through for those cases.
You need to modify the PixelFormats[] array that is originally created so that Premiere knows what PixelFormats are supported.
That means that you’ll end up with a
PixelFormats[] = ; only
Once you’ve done that change you can change the handling function too…
if( (theData)->pixelFormatIndex == 0 && (theData)->version >= 9)
else
return result;
Thank you Rallymax,
You have been very helpfull.
This solved my issue.
I keep testing and trying things to improve my skills.
Now stangely the SDK guide says plugins no longer need to support BGRA8 at minimum.
But for a transition to work properly, I found it still needs to handle BGRA8 in order to show the transition in the effect-control-window.
Otherwise PP gives a serious error.
Anyone knows if this is correct?
Cheers.
Unfortunately plugin development isn’t as easy as we all would like but at least it is open for us to develop on.
I suspect that the Editing Mode you’re in has a Player that doesn’t support BGRA_4444_32f and does (because of legacy) support BGRA_4444_8u thus the preview window requires BGRA_8u support to work.
If you do want to support BGRA_4444_8u then you should be able to make common code by converting the 8u to 32f and then continuing your plugin as 32f. (Likewise you should do a YUV_32f to BGRA_32f –although if you don’t know a lot about rec601 and rec709 colorspaces I HIGHLY recommend that you DO NOT start doing this).
Here’s a quick mock up off the top of my head…
float The32fFrame = (float)TheFrame;
int do_32f_to_8u = 0;
switch((*theData)->pixelFormatSupported)
case PrPixelFormat_BGRA_4444_8u:
// Flag to un-convert at the end
do_32f_to_8u = 1;
The32fFrame= malloc(heightrowstride4);
// Convert 0..255 (_8u) buffer to 0.0…1.0 (_32f)
// Change this to SSE|2|3|4 intrinsics for a 4x or 8x speedup!
for(int h=0;h<height;h++) // Height
for(int w=0;w<width;w++) // Width
for(int p=0;w<4;p++) // Plane
The32fFrame[4hrowstride+ 4*w + p] =
(float)TheFrame[4h rowstride + 4*w + p]/(float)255.0);
// Now fall through and process as BGRA_32f
case PrPixelFormat_BGRA_4444_32f:
// IMPLEMENT YOUR FILTER/TRANSITION HERE
break;
default:
return WHATEVER THE ERROR CODE IS FOR UNSUPPORTED;
//Run a loop that un-does the floating point conversion if necessary.
if(do_32f_to_8u)
// Change 32f back to 8u
TheFrame[4h rowstride + 4*w + p] =
(unsigned int)((float)255.0 * The32fFrame[4h rowstride + 4*w + p]);
free(The32fFrame);
return prNOERR;
· Where “rowstride” is the actual stride of the row, not the frame width.
