There are some words in the textArea, now I want to set some paras to be the list, but I failed,does anyone know how to add list dynamically?
<?xml version="1.0" encoding="utf-8"?>
<s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:mx="library://ns.adobe.com/flex/mx"
xmlns:ai="http://ns.adobe.com/ai/2009"
xmlns:d="http://ns.adobe.com/fxg/2008/dt"
xmlns:flm="http://ns.adobe.com/flame/2008"
creationComplete="initApp()">
<fx:Script>
<![CDATA[
import flashx.textLayout.BuildInfo;
import flashx.textLayout.compose.IFlowComposer;
import flashx.textLayout.compose.TextFlowLine;
import flashx.textLayout.conversion.TextConverter;
import flashx.textLayout.edit.IEditManager;
import flashx.textLayout.edit.SelectionFormat;
import flashx.textLayout.edit.SelectionState;
import flashx.textLayout.elements.FlowGroupElement;
import flashx.textLayout.elements.ListElement;
import flashx.textLayout.elements.ListItemElement;
import flashx.textLayout.elements.ParagraphElement;
import flashx.textLayout.elements.SpanElement;
import flashx.textLayout.elements.TextFlow;
import flashx.textLayout.formats.ITextLayoutFormat;
import flashx.textLayout.formats.ListMarkerFormat;
import flashx.textLayout.formats.ListStylePosition;
import flashx.textLayout.formats.ListStyleType;
import flashx.textLayout.operations.SplitParagraphOperation;
import spark.components.TextArea;
import spark.utils.TextFlowUtil;
protected function initApp():void {
var version:String = "";
version += "TLF version: " + BuildInfo.VERSION + "<br/>"+"TLF Build number: " + BuildInfo.kBuildNumber;
var s:String = "";
s += "<TextFlow version='2.0.0' xmlns='http://ns.adobe.com/textLayout/2008'>";
s += "<p>Flex framework"+version+"</p>";
s += "<p>Flex is a free, open source framework for building highly interactive, expressive web applications that dep</p>";
s += "<p>Flex framework</p>";
s += "<p>I am a new paragraph and I'd like to start at the left below the image</p>";
s += "</TextFlow>";
messageTA.textFlow = TextConverter.importToFlow(s, TextConverter.TEXT_LAYOUT_FORMAT);
protected function doSetList():void
var interactionManager:IEditManager = messageTA.textFlow.interactionManager as IEditManager;
var selStart:int=messageTA.selectionAnchorPosition
var selFinish:int=messageTA.selectionActivePosition;
interactionManager.selectRange(selStart,selFinish)
var list:ListElement = new ListElement()
list.tabStops="e20 s24";
list.listStyleType=ListStyleType.CHECK
list.listStylePosition=ListStylePosition.INSIDE;
var lm:ListMarkerFormat=new ListMarkerFormat();
//lm.listStyleType=ListStyleType.DECIMAL;
lm.tabStops="e20 s24";
//lm.listStylePosition=ListStylePosition.INSIDE;
lm.fontSize=14
lm.color="0xff0000"
lm.paragraphEndIndent=5;
list.listMarkerFormat=lm;
var pA:Array=getParaArrAtPoint(messageTA,messageTA.mouseX, messageTA.mouseY);
trace("length==="+pA.length)
for(var j:int=0;j<pA.length;j++){
if(pAis ParagraphElement){
var item:ListItemElement = new ListItemElement();
item.addChild(pA);
list.addChild(item);
messageTA.textFlow.addChild(list);
//interactionManager.applyContainerFormat(lm)
//messageTA.textFlow.interactionManager.setFocus();
messageTA.textFlow.flowComposer.updateAllControllers()
private var charIdxAtPoint:int;
private function getParaArrAtPoint(textArea:Object, x:Number, y:Number):Array {
var fc:IFlowComposer = textArea.textFlow.flowComposer;
var sPoint:Point = textArea.localToGlobal(new Point(x, y));
var paraArray:Array=[]
for (var i:int = 0; i<fc.numLines; i++){
var tfLine:TextFlowLine = fc.getLineAt(i);
trace(i+"="+tfLine.paragraph)
paraArray.push(tfLine.paragraph)
return paraArray;
if (y >= tfLine.y && y <tfLine.height+tfLine.y){
var lineAtomPosition:Number = tfLine.getTextLine().getAtomIndexAtPoint(sPoint.x, sPoint.y);
if(lineAtomPosition==-1){
charIdxAtPoint=-1;
return null;
if (lineAtomPosition>= 0){
charIdxAtPoint=tfLine.absoluteStart+lineAtomPosition+1;
return paraArray;
if (x > tfLine.unjustifiedTextWidth){
charIdxAtPoint=tfLine.absoluteStart+tfLine.textLength-1;
return paraArray;
charIdxAtPoint=tfLine.absoluteStart;
return paraArray;
charIdxAtPoint=textArea.text.length;
return paraArray;
protected function testScroll_clickHandler(event:MouseEvent):void
point.text = '['+event.localX+', '+event.localY+']';
</fx:Script>
<s:VGroup left="5"
right="5"
top="10"
bottom="82">
<s:Button label="Set List At cursor position"
click="doSetList()"/>
<s:TextArea id="messageTA"
width="100%"
height="100%"
click="testScroll_clickHandler(event)"
editable="true"/>
<mx:ApplicationControlBar width="450">
<s:Label text="Click Point:"/>
<s:Label id="point"
width="60"/>
<s:Label text="charIndex:"/>
<s:Label id="index"
width="30"/>
</mx:ApplicationControlBar>
</s:VGroup>
</s:WindowedApplication>
The easiest way is to use the EditManger.createList method. You have this call:
If you add this line right after, it will create a list using that selection:
var list = interactionManager.createList()
You can do it through direct model manipulation, but it would be a bit more complicated than what you have now. The createList method manages this complexity for you.
Thanks.Your help is very useful;
now I can set the list when I select some para
var selStart:int=interactionManager.anchorPosition
var selFinish:int=interactionManager.activePosition
lm.listStyleType=ListStyleType.CHECK;
lm.fontSize=14
lm.color="0xff0000"
interactionManager.createList(null,lm)
At last, thanks again.
After creating a LIST by using EditManager.createList(), how can the LIST be changed back to a paragraph element
Record the listItem returned by createList. Find the paragraph you wanted to convert. Using the following section of codes:
//The following code scrap shows how to convert a list to a normal paragraph
textFlow.removeChild(list);
textFlow.addChild(paragraph);
textFlow.flowComposer.updateAllControllers();
Hi, thank you for the information. The problem is that I may not always have the listitem created by createList as the content may have been imported and converted from HTML.
I'm building a small content editor in which content may be read and converted from HTML and this may already contain list(s). I have a button that creates lists using createList. I would like to be able to allow the user to make a text selectection over some list items and then convet them to paragraphs, with any formatting such as bold etc, by using the same button.
You can also enum your list items with the following codes:
var elem:FlowElement = textFlow.getChildAt(0);
while (elem)
if (elem as ListElement)
var listElement:ListElement = elem as ListElement;
var elem1:ListItemElement = listElement.getChildAt(0) as ListItemElement;
var listMarkerFormat:ListMarkerFormat = new ListMarkerFormat();
listMarkerFormat.textDecoration = TextDecoration.NONE;
elem1.listMarkerFormat = listMarkerFormat;
break;
elem = elem.getNextSibling();
