Hello,
I'm running Audition off a MacBook Pro Version 10.6.6 -- immediately after attempted start-up and I receive a message informing me that the application has quit unexpectedly. I attempt to reopen the application but to no avail. Any suggestions?
Rename the following folder to something else (e.g. "4.0_backup"). This will simulate clearing your preferences
~/Library/Preferences/Adobe/Audition/4.0
Launch Audition, and then post what is in the "Audition Log.txt" file that is created in the new 4.0 folder that will be created the next time you launch Audition.
You also didn't mention if this has always happened since you installed and activated the product, or if it started after something else.
Glad to hear you're up and running again. The method I outlined above is sort of an all or nothing sledgehammer move. In the future, you may wish to hold the [ Shift ] key while starting Audition as that will "ignore" any previous preferences upon startup.
However, if it does happen again, I'd like to work with you to figure out the actual cause, because if we can narrow it down, we can figure out some other behavior in the future than whatever is crashing it right now. Be sure to send in those crash logs with comments...
Hello. My Audition can not start.
Please help me
Here is the log file
Log file created: 10/16/2011 8:24:39 PM
Ticks = 0 <4132> <AuLog.Startup> <5> Application: Audition
Ticks = 0 <4132> <AuLog.Startup> <5> Version 4.0
Ticks = 16 <4132> <AuLog.Startup> <5> Build: 1815
Ticks = 218 <4132> <AuLog.Startup> <5> AuUI initialization sequence started...
Ticks = 218 <4132> <AuLog.Startup> <5> Initializing Crash Recovery
Ticks = 234 <4132> <AuLog.Startup> <5> Initializing AuDSP
Ticks = 250 <4132> <AuLog.Startup> <5> Initializing AuBackEnd
Ticks = 312 <4132> <AuLog.Startup> <5> Initializing AuApplication
Ticks = 312 <4132> <AuLog.Startup> <5> AuApplication initialization sequence started...
Ticks = 312 <4132> <AuLog.Startup> <5> Initializing XML Loader
Ticks = 359 <4132> <AuLog.Startup> <5> Initializing Application Settings
Ticks = 359 <4132> <AuLog.Startup> <5> Intializing dva unit test and console
Ticks = 359 <4132> <AuLog.Startup> <5> Initializing Audio Device
Ticks = 452 <4132> <AuLog.Startup> <5> Initializing XMP System
Ticks = 468 <4132> <AuLog.Startup> <5> Initializing AMIO Host
Ticks = 468 <4132> <AuLog.Startup> <5> AMIO Host initialization sequence started...
Ticks = 484 <4132> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioAiff
Ticks = 515 <4132> <AuLog.Plug-in> <5> Audition AIFF Amio plug-in. ID: 775c126d-5387-4af8-aa44-2209d40b102a
Ticks = 530 <4132> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioLSF
Ticks = 593 <4132> <AuLog.Plug-in.AmioLSF> <5> Loading libsndfile...
Ticks = 640 <4132> <AuLog.Plug-in.AmioLSF> <5> libsndfile version detected: libsndfile-1.0.23
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00020000 AIFF (Apple/SGI) aiff
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020001 Signed 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020003 Signed 24 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020004 Signed 32 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020005 Unsigned 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020006 32 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020007 64 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020010 U-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020011 A-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020012 IMA ADPCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020020 GSM 6.10
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020040 12 bit DWVW
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020041 16 bit DWVW
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020042 24 bit DWVW
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00030000 AU (Sun/NeXT) au
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030001 Signed 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030003 Signed 24 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030004 Signed 32 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030006 32 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030007 64 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030010 U-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030011 A-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030030 32kbs G721 ADPCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030031 24kbs G723 ADPCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00120000 AVR (Audio Visual Research) avr
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00120001 Signed 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00120002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00120005 Unsigned 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00180000 CAF (Apple Core Audio File) caf
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00180001 Signed 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00180002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00180003 Signed 24 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00180004 Signed 32 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00180006 32 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00180007 64 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00180010 U-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00180011 A-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00170000 FLAC (FLAC Lossless Audio Codec) flac
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00170001 Signed 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00170002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00170003 Signed 24 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00100000 HTK (HMM Tool Kit) htk
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00100002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00060000 IFF (Amiga IFF/SVX8/SV16) iff
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00060001 Signed 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00060002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000c0000 MAT4 (GNU Octave 2.0 / Matlab 4.2) mat
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000c0002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000c0004 Signed 32 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000c0006 32 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000c0007 64 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000d0000 MAT5 (GNU Octave 2.1 / Matlab 5.0) mat
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000d0002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000d0004 Signed 32 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000d0005 Unsigned 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000d0006 32 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000d0007 64 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00210000 MPC (Akai MPC 2k) mpc
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00210002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00200000 OGG (OGG Container format) oga
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00200060 Vorbis
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00050000 PAF (Ensoniq PARIS) paf
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00050001 Signed 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00050002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00050003 Signed 24 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00050004 Signed 32 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000e0000 PVF (Portable Voice Format) pvf
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000e0001 Signed 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000e0002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000e0004 Signed 32 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00040000 RAW (header-less) raw
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040001 Signed 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040003 Signed 24 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040004 Signed 32 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040005 Unsigned 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040006 32 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040007 64 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040010 U-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040011 A-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040020 GSM 6.10
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040040 12 bit DWVW
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040041 16 bit DWVW
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040042 24 bit DWVW
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040021 VOX ADPCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00220000 RF64 (RIFF 64) rf64
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00220002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00220003 Signed 24 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00220004 Signed 32 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00220005 Unsigned 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00220006 32 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00220007 64 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00220010 U-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00220011 A-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00160000 SD2 (Sound Designer II) sd2
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00160001 Signed 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00160002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00160003 Signed 24 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00110000 SDS (Midi Sample Dump Standard) sds
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00110001 Signed 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00110002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00110003 Signed 24 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000a0000 SF (Berkeley/IRCAM/CARL) sf
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000a0002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000a0003 Signed 24 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000a0004 Signed 32 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000a0006 32 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000a0010 U-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000a0011 A-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00080000 VOC (Creative Labs) voc
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00080002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00080005 Unsigned 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00080010 U-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00080011 A-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000b0000 W64 (SoundFoundry WAVE 64) w64
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0003 Signed 24 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0004 Signed 32 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0005 Unsigned 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0006 32 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0007 64 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0010 U-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0011 A-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0012 IMA ADPCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0013 Microsoft ADPCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0020 GSM 6.10
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00010000 WAV (Microsoft) wav
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010002 Signed 16 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010003 Signed 24 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010004 Signed 32 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010005 Unsigned 8 bit PCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010006 32 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010007 64 bit float
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010010 U-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010011 A-Law
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010012 IMA ADPCM
Ticks = 655 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010013 Microsoft ADPCM
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010020 GSM 6.10
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010030 32kbs G721 ADPCM
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00070000 WAV (NIST Sphere) wav
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00070001 Signed 8 bit PCM
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00070002 Signed 16 bit PCM
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00070003 Signed 24 bit PCM
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00070004 Signed 32 bit PCM
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00070010 U-Law
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00070011 A-Law
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00130000 WAVEX (Microsoft) wav
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130002 Signed 16 bit PCM
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130003 Signed 24 bit PCM
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130004 Signed 32 bit PCM
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130005 Unsigned 8 bit PCM
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130006 32 bit float
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130007 64 bit float
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130010 U-Law
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130011 A-Law
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130012 IMA ADPCM
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130013 Microsoft ADPCM
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130020 GSM 6.10
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130030 32kbs G721 ADPCM
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00190000 WVE (Psion Series 3) wve
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00190011 A-Law
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000f0000 XI (FastTracker 2) xi
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000f0051 16 bit DPCM
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000f0050 8 bit DPCM
Ticks = 671 <4132> <AuLog.Plug-in.AmioLSF> <5> libsndfile version detected: libsndfile-1.0.23
Ticks = 671 <4132> <AuLog.Plug-in> <5> Audition libsndfile Amio plug-in. ID: caf0f3de-96be-4e2f-85a7-ac6e61310fcb
Ticks = 671 <4132> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioMp3
Ticks = 796 <4132> <AuLog.Plug-in> <5> Audition Mp3 Amio plug-in. ID: ea4740a7-e67e-4070-bed8-3bd3727779db
Ticks = 811 <4132> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioQT
Ticks = 811 <4132> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioWav
Ticks = 827 <4132> <AuLog.Plug-in> <5> Audition Wave Amio plug-in. ID: 60df8553-00c8-4fd7-8a07-6f25e30ab79c
Ticks = 827 <4132> <AuLog.Startup> <5> AMIO Host initialization sequence complete.
Ticks = 842 <4132> <AuLog.Startup> <5> Session Host initialization sequence started...
Ticks = 858 <4132> <AuLog.Plug-in> <5> Loading Session plug-in: FinalCutXML
Ticks = 967 <4132> <AuLog.Plug-in> <5> FCP XML session plug-in. ID: 611577b8-4c4f-4253-a29d-f01516cdeb90
Ticks = 967 <4132> <AuLog.Plug-in> <5> Loading Session plug-in: LegacyXML
Ticks = 1045 <4132> <AuLog.Plug-in> <5> Audition 3.0 XML session plug-in. ID: da4b6774-0370-4c6d-912b-bd0e3a763ef8
Ticks = 1045 <4132> <AuLog.Plug-in> <5> Loading Session plug-in: OmfSession
Ticks = 1154 <4132> <AuLog.Plug-in> <5> DQ OMF PLug-In. ID: 94debb27-326b-4457-92ba-84d6e6f75567
Ticks = 1170 <4132> <AuLog.Plug-in> <5> Loading Session plug-in: PremiereProInterchange
Ticks = 1217 <4132> <AuLog.Plug-in> <5> Adobe Premiere Pro to Audition XML session interchange plug-in. ID: d22d3d0c-2f52-4651-bd94-f73eb80b7e2c
Ticks = 1217 <4132> <AuLog.Plug-in> <5> Loading Session plug-in: SesxNative
Ticks = 1279 <4132> <AuLog.Plug-in> <5> Audition Sesx plug-in. ID: e4fe4447-02d0-44c6-90c8-89d5083fcd26
Ticks = 1279 <4132> <AuLog.Startup> <5> Session Host initialization sequence complete.
Ticks = 1310 <4132> <AuLog.Startup> <5> Initializing Clipboard Manager
Ticks = 1310 <4132> <AuLog.Startup> <5> Initializing Preset Manager
Ticks = 1310 <4132> <AuLog.Startup> <5> Initializing Favorites Manager
Ticks = 1310 <4132> <AuLog.Startup> <5> AuApplication initialization sequence complete.
Ticks = 1310 <4132> <AuLog.Startup> <5> Initializing AsyncQueueManager
Ticks = 1310 <4132> <AuLog.Startup> <5> Initializing AuUI
Ticks = 1732 <4132> <AuLog.Startup> <5> Initializing AuScripting
Ticks = 1747 <4132> <AuLog.Startup> <5> Setting up temp directories
Ticks = 2184 <4132> <AuLog.Startup> <5> AuUI initialization sequence complete.
Did you try the advice given above to ignore or remove your preferences?
%USERPROFILE%\AppData\Roaming\Adobe\Audition\4.0
Alternatively, try the methods in this FAQ to provide more context.
Audition crashes upon startup ever since I installed it. Tried above methods and the alternative FAQ, but nothing has worked.
Here is the log.
Log file created: 10/24/2011 12:32:40 AM
Ticks = 15 <2584> <AuLog.Startup> <5> Application: Audition
Ticks = 15 <2584> <AuLog.Startup> <5> Version 4.0
Ticks = 15 <2584> <AuLog.Startup> <5> Build: 1815
Ticks = 140 <2584> <AuLog.Startup> <5> AuUI initialization sequence started...
Ticks = 140 <2584> <AuLog.Startup> <5> Initializing Crash Recovery
Ticks = 140 <2584> <AuLog.Startup> <5> Initializing AuDSP
Ticks = 140 <2584> <AuLog.Startup> <5> Initializing AuBackEnd
Ticks = 218 <2584> <AuLog.Startup> <5> Initializing AuApplication
Ticks = 218 <2584> <AuLog.Startup> <5> AuApplication initialization sequence started...
Ticks = 218 <2584> <AuLog.Startup> <5> Initializing XML Loader
Ticks = 234 <2584> <AuLog.Startup> <5> Initializing Application Settings
Ticks = 234 <2584> <AuLog.Startup> <5> Intializing dva unit test and console
Ticks = 234 <2584> <AuLog.Startup> <5> Initializing Audio Device
Ticks = 359 <2584> <AuLog.Startup> <5> Initializing XMP System
Ticks = 359 <2584> <AuLog.Startup> <5> Initializing AMIO Host
Ticks = 359 <2584> <AuLog.Startup> <5> AMIO Host initialization sequence started...
Ticks = 374 <2584> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioAiff
Ticks = 374 <2584> <AuLog.Plug-in> <5> Audition AIFF Amio plug-in. ID: 775c126d-5387-4af8-aa44-2209d40b102a
Ticks = 374 <2584> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioLSF
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Loading libsndfile...
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> libsndfile version detected: libsndfile-1.0.23
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00020000 AIFF (Apple/SGI) aiff
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020001 Signed 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020003 Signed 24 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020004 Signed 32 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020005 Unsigned 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020006 32 bit float
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020007 64 bit float
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020010 U-Law
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020011 A-Law
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020012 IMA ADPCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020020 GSM 6.10
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020040 12 bit DWVW
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020041 16 bit DWVW
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00020042 24 bit DWVW
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00030000 AU (Sun/NeXT) au
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030001 Signed 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030003 Signed 24 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030004 Signed 32 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030006 32 bit float
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030007 64 bit float
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030010 U-Law
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030011 A-Law
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030030 32kbs G721 ADPCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00030031 24kbs G723 ADPCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00120000 AVR (Audio Visual Research) avr
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00120001 Signed 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00120002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00120005 Unsigned 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00180000 CAF (Apple Core Audio File) caf
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00180001 Signed 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00180002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00180003 Signed 24 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00180004 Signed 32 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00180006 32 bit float
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00180007 64 bit float
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00180010 U-Law
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00180011 A-Law
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00170000 FLAC (FLAC Lossless Audio Codec) flac
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00170001 Signed 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00170002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00170003 Signed 24 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00100000 HTK (HMM Tool Kit) htk
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00100002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00060000 IFF (Amiga IFF/SVX8/SV16) iff
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00060001 Signed 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00060002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000c0000 MAT4 (GNU Octave 2.0 / Matlab 4.2) mat
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000c0002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000c0004 Signed 32 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000c0006 32 bit float
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000c0007 64 bit float
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000d0000 MAT5 (GNU Octave 2.1 / Matlab 5.0) mat
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000d0002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000d0004 Signed 32 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000d0005 Unsigned 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000d0006 32 bit float
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000d0007 64 bit float
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00210000 MPC (Akai MPC 2k) mpc
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00210002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00200000 OGG (OGG Container format) oga
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00200060 Vorbis
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00050000 PAF (Ensoniq PARIS) paf
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00050001 Signed 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00050002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00050003 Signed 24 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00050004 Signed 32 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000e0000 PVF (Portable Voice Format) pvf
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000e0001 Signed 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000e0002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000e0004 Signed 32 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00040000 RAW (header-less) raw
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040001 Signed 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040003 Signed 24 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040004 Signed 32 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040005 Unsigned 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040006 32 bit float
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040007 64 bit float
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040010 U-Law
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040011 A-Law
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040020 GSM 6.10
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040040 12 bit DWVW
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040041 16 bit DWVW
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040042 24 bit DWVW
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00040021 VOX ADPCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00220000 RF64 (RIFF 64) rf64
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00220002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00220003 Signed 24 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00220004 Signed 32 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00220005 Unsigned 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00220006 32 bit float
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00220007 64 bit float
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00220010 U-Law
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00220011 A-Law
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00160000 SD2 (Sound Designer II) sd2
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00160001 Signed 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00160002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00160003 Signed 24 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00110000 SDS (Midi Sample Dump Standard) sds
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00110001 Signed 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00110002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00110003 Signed 24 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000a0000 SF (Berkeley/IRCAM/CARL) sf
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000a0002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000a0003 Signed 24 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000a0004 Signed 32 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000a0006 32 bit float
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000a0010 U-Law
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000a0011 A-Law
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00080000 VOC (Creative Labs) voc
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00080002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00080005 Unsigned 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00080010 U-Law
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00080011 A-Law
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000b0000 W64 (SoundFoundry WAVE 64) w64
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0002 Signed 16 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0003 Signed 24 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0004 Signed 32 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0005 Unsigned 8 bit PCM
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0006 32 bit float
Ticks = 374 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0007 64 bit float
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0010 U-Law
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0011 A-Law
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0012 IMA ADPCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0013 Microsoft ADPCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000b0020 GSM 6.10
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00010000 WAV (Microsoft) wav
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010002 Signed 16 bit PCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010003 Signed 24 bit PCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010004 Signed 32 bit PCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010005 Unsigned 8 bit PCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010006 32 bit float
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010007 64 bit float
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010010 U-Law
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010011 A-Law
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010012 IMA ADPCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010013 Microsoft ADPCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010020 GSM 6.10
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00010030 32kbs G721 ADPCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00070000 WAV (NIST Sphere) wav
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00070001 Signed 8 bit PCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00070002 Signed 16 bit PCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00070003 Signed 24 bit PCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00070004 Signed 32 bit PCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00070010 U-Law
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00070011 A-Law
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00130000 WAVEX (Microsoft) wav
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130002 Signed 16 bit PCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130003 Signed 24 bit PCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130004 Signed 32 bit PCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130005 Unsigned 8 bit PCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130006 32 bit float
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130007 64 bit float
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130010 U-Law
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130011 A-Law
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130012 IMA ADPCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130013 Microsoft ADPCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130020 GSM 6.10
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00130030 32kbs G721 ADPCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00190000 WVE (Psion Series 3) wve
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 00190011 A-Law
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000f0000 XI (FastTracker 2) xi
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000f0051 16 bit DPCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile subformat: 000f0050 8 bit DPCM
Ticks = 390 <2584> <AuLog.Plug-in.AmioLSF> <5> libsndfile version detected: libsndfile-1.0.23
Ticks = 390 <2584> <AuLog.Plug-in> <5> Audition libsndfile Amio plug-in. ID: caf0f3de-96be-4e2f-85a7-ac6e61310fcb
Ticks = 390 <2584> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioMp3
Ticks = 390 <2584> <AuLog.Plug-in> <5> Audition Mp3 Amio plug-in. ID: ea4740a7-e67e-4070-bed8-3bd3727779db
Ticks = 390 <2584> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioQT
Ticks = 827 <2584> <AuLog.Plug-in> <5> Quicktime version detected: 0x07698000 7.6.9
Ticks = 858 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: smi
Ticks = 858 <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/smil
Ticks = 858 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mpegurl
Ticks = 858 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-mpegurl
Ticks = 858 <2584> <AuLog.Plug-in> <5> Quicktime extension: smi,smil,sml
Ticks = 858 <2584> <AuLog.Plug-in> <5> Quicktime extension: m3u,m3url
Ticks = 858 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: wav
Ticks = 858 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/wav
Ticks = 858 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-wav
Ticks = 873 <2584> <AuLog.Plug-in> <5> Quicktime extension: wav,bwf
Ticks = 873 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: 3gp2
Ticks = 873 <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/3gpp2
Ticks = 873 <2584> <AuLog.Plug-in> <5> Quicktime extension: 3g2
Ticks = 873 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: 3gpp
Ticks = 873 <2584> <AuLog.Plug-in> <5> Quicktime extension: 3gp
Ticks = 889 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: aifc
Ticks = 889 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/aiff
Ticks = 889 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-aiff
Ticks = 889 <2584> <AuLog.Plug-in> <5> Quicktime extension: aiff,aif,aifc,cdda
Ticks = 889 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: aiff
Ticks = 889 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: fli
Ticks = 889 <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/flc
Ticks = 889 <2584> <AuLog.Plug-in> <5> Quicktime extension: flc,fli
Ticks = 889 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: giff
Ticks = 889 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/gif
Ticks = 905 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: gsm
Ticks = 905 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-gsm
Ticks = 905 <2584> <AuLog.Plug-in> <5> Quicktime extension: gsm
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: mpeg
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/mpeg
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/x-mpeg
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mpeg
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-mpeg
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime extension: mpeg,mpg,m1s,m1v,m1a,m75,m15,mpm,mpv,mpa
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime extension: mpeg,mpg,m1s,m1a,mpm,mpa
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: midi
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/midi
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-midi
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime extension: midi,mid,smf,kar
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: mp3
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mp3
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-mp3
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mpeg3
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-mpeg3
Ticks = 920 <2584> <AuLog.Plug-in> <5> Quicktime extension: mp3
Ticks = 936 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: pict
Ticks = 936 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/pict
Ticks = 936 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-pict
Ticks = 936 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: smil
Ticks = 936 <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/smil
Ticks = 936 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mpegurl
Ticks = 936 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-mpegurl
Ticks = 936 <2584> <AuLog.Plug-in> <5> Quicktime extension: smi,smil,sml
Ticks = 936 <2584> <AuLog.Plug-in> <5> Quicktime extension: m3u,m3url
Ticks = 936 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: sd2f
Ticks = 936 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-sd2
Ticks = 936 <2584> <AuLog.Plug-in> <5> Quicktime extension: sd2
Ticks = 951 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: text
Ticks = 951 <2584> <AuLog.Plug-in> <5> Quicktime mime type: text/plain
Ticks = 951 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: ulaw
Ticks = 951 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/basic
Ticks = 951 <2584> <AuLog.Plug-in> <5> Quicktime extension: au,snd,ulw
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: vfw
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/x-msvideo
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/avi
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/msvideo
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime extension: avi,vfw
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: wave
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/wav
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-wav
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime extension: wav,bwf
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: ac3
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/ac3
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-ac3
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime extension: ac3
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: adts
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/aac
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-aac
Ticks = 967 <2584> <AuLog.Plug-in> <5> Quicktime extension: aac
Ticks = 983 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: amc
Ticks = 983 <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/x-mpeg
Ticks = 983 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: amr
Ticks = 983 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/AMR
Ticks = 983 <2584> <AuLog.Plug-in> <5> Quicktime extension: amr
Ticks = 983 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: caff
Ticks = 983 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-caf
Ticks = 983 <2584> <AuLog.Plug-in> <5> Quicktime extension: caf
Ticks = 983 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: cdda
Ticks = 983 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/aiff
Ticks = 983 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-aiff
Ticks = 983 <2584> <AuLog.Plug-in> <5> Quicktime extension: aiff,aif,aifc,cdda
Ticks = 998 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: celp
Ticks = 998 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/vnd.qcelp
Ticks = 998 <2584> <AuLog.Plug-in> <5> Quicktime extension: qcp
Ticks = 998 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: dvc
Ticks = 998 <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/x-dv
Ticks = 998 <2584> <AuLog.Plug-in> <5> Quicktime extension: dv,dif
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: grip
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-sgi
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-photoshop
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-bmp
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/vnd.fpx
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/gif
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/jpeg2000-image
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-jpeg2000-image
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/jp2
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/pjpeg
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-macpaint
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/pict
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-pict
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/png
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-png
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-quicktime
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-targa
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/tiff
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-tiff
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: mpg4
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/mp4
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mp4
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime extension: mp4,mpg4
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: qhtm
Ticks = 1092 <2584> <AuLog.Plug-in> <5> Quicktime mime type: text/x-html-insertion
Ticks = 1107 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: rtsp
Ticks = 1107 <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/x-rtsp
Ticks = 1107 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: sdp
Ticks = 1107 <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/sdp
Ticks = 1107 <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/x-sdp
Ticks = 1107 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: sdv
Ticks = 1107 <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/3gpp
Ticks = 1107 <2584> <AuLog.Plug-in> <5> Quicktime extension: 3gp
Ticks = 1107 <2584> <AuLog.Plug-in> <5> Quicktime component main extension: utxt
Ticks = 1107 <2584> <AuLog.Plug-in> <5> Quicktime mime type: text/plain
Ticks = 1107 <2584> <AuLog.Plug-in> <5> Audition QuickTime Amio plug-in. ID: 01914214-f044-47f7-a43b-5e98267fafd0
Ticks = 1107 <2584> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioWav
Ticks = 1107 <2584> <AuLog.Plug-in> <5> Audition Wave Amio plug-in. ID: 60df8553-00c8-4fd7-8a07-6f25e30ab79c
Ticks = 1107 <2584> <AuLog.Startup> <5> AMIO Host initialization sequence complete.
Ticks = 1123 <2584> <AuLog.Startup> <5> Session Host initialization sequence started...
Ticks = 1139 <2584> <AuLog.Plug-in> <5> Loading Session plug-in: FinalCutXML
Ticks = 1139 <2584> <AuLog.Plug-in> <5> FCP XML session plug-in. ID: 611577b8-4c4f-4253-a29d-f01516cdeb90
Ticks = 1139 <2584> <AuLog.Plug-in> <5> Loading Session plug-in: LegacyXML
Ticks = 1139 <2584> <AuLog.Plug-in> <5> Audition 3.0 XML session plug-in. ID: da4b6774-0370-4c6d-912b-bd0e3a763ef8
Ticks = 1139 <2584> <AuLog.Plug-in> <5> Loading Session plug-in: OmfSession
Ticks = 1139 <2584> <AuLog.Plug-in> <5> DQ OMF PLug-In. ID: 94debb27-326b-4457-92ba-84d6e6f75567
Ticks = 1154 <2584> <AuLog.Plug-in> <5> Loading Session plug-in: PremiereProInterchange
Ticks = 1154 <2584> <AuLog.Plug-in> <5> Adobe Premiere Pro to Audition XML session interchange plug-in. ID: d22d3d0c-2f52-4651-bd94-f73eb80b7e2c
Ticks = 1154 <2584> <AuLog.Plug-in> <5> Loading Session plug-in: SesxNative
Ticks = 1154 <2584> <AuLog.Plug-in> <5> Audition Sesx plug-in. ID: e4fe4447-02d0-44c6-90c8-89d5083fcd26
Ticks = 1154 <2584> <AuLog.Startup> <5> Session Host initialization sequence complete.
Ticks = 1154 <2584> <AuLog.Startup> <5> Initializing Clipboard Manager
Ticks = 1154 <2584> <AuLog.Startup> <5> Initializing Preset Manager
Ticks = 1154 <2584> <AuLog.Startup> <5> Initializing Favorites Manager
Ticks = 1154 <2584> <AuLog.Startup> <5> AuApplication initialization sequence complete.
Ticks = 1154 <2584> <AuLog.Startup> <5> Initializing AsyncQueueManager
Ticks = 1170 <2584> <AuLog.Startup> <5> Initializing AuUI
Ticks = 1388 <2584> <AuLog.Startup> <5> Initializing AuScripting
Ticks = 1388 <2584> <AuLog.Startup> <5> Setting up temp directories
Here is the log.
I don't think you tried what was requested in the FAQ, because you've not posted the crash dump or system information that was requested in the FAQ. Instead, you posted the Audition Log file, which is usually helpful, but not in this situation. Also, the steps mentioned in the FAQ won't stop your crash, it will only help you get us the information we need to figure out what the crash is. I'd first try to delete your preferences folder.
hello, please help me, i dont know how to solve this problem. Audition CS5.5 crashes to after start-up.
system information
Hardware Overview:
Model Name: MacBook
Model Identifier: MacBook6,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.26 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache: 3 MB
Memory: 4 GB
Bus Speed: 1.07 GHz
Boot ROM Version: MB61.00C8.B00
SMC Version (system): 1.51f53
Serial Number (system): 45012Q3H8PW
Hardware UUID: 83B15CC5-50FA-53F9-ABB2-9F4CDF9BE254
Sudden Motion Sensor:
State: Enabled
problem detail and system configration
Process: Adobe Audition [3829]
Path: /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/MacOS/Adobe Audition
Identifier: com.adobe.Audition.4.0
Version: 4.0x1815 (4.0)
Code Type: X86 (Native)
Parent Process: launchd [156]
Date/Time: 2011-10-25 00:28:01.532 +0800
OS Version: Mac OS X 10.7.2 (11C74)
Report Version: 9
Interval Since Last Report: 199872 sec
Crashes Since Last Report: 71
Per-App Interval Since Last Report: 168 sec
Per-App Crashes Since Last Report: 40
Anonymous UUID: 913EA101-2C51-460B-A86C-99F2C6F9883B
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
VM Regions Near 0:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/MacOS/Adobe Audition
__TEXT 0000000000001000-0000000000003000 [ 8K] r-x/rwx SM=COW /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/MacOS/Adobe Audition
Application Specific Information:
objc[3829]: garbage collection is OFF
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 org.perian 0x0f3686cc 0xf226000 + 1320652
1 com.apple.CoreServices.CarbonCore 0x950fb5f5 CallComponent + 223
2 com.apple.CoreServices.CarbonCore 0x950fb63e CallComponentDispatch + 29
3 com.apple.CoreServices.CarbonCore 0x95167898 CallComponentOpen + 43
4 com.apple.CoreServices.CarbonCore 0x950fa2b4 OpenAComponent + 426
5 com.apple.CoreServices.CarbonCore 0x950fa334 OpenComponent + 24
6 com.apple.CoreServices.CarbonCore 0x950fb57c CallComponent + 102
7 com.apple.CoreServices.CarbonCore 0x950fb63e CallComponentDispatch + 29
8 com.apple.QuickTime 0x9af104a0 MovieImportGetMIMETypeList + 43
9 com.adobe.AmioQT.bundle 0x0b8a593b amio::qt::QueryExtensions(std::list<std::string, std::allocator<std::string> >&, std::list<std::string, std::allocator<std::string> > const*, bool, ComponentDescription) + 283
10 com.adobe.AmioQT.bundle 0x0b8a677b amio::qt::QueryImportExtensions(std::list<std::string, std::allocator<std::string> >&, std::list<std::string, std::allocator<std::string> >*, bool) + 107
11 com.adobe.AmioQT.bundle 0x0b89ba0e amio::AmioQTInterface::GetAmioInfo(amio::AmioGetAmioInfoInterface&) + 398
12 com.adobe.AmioQT.bundle 0x0b896b1a amio::AmioInterfaceTemplate<amio::qt::Source, amio::qt::Source>::EntryPoint(int, void*, void*) + 218
13 com.adobe.AmioQT.bundle 0x0b895e69 AmioInterface + 57
14 com.adobe.aubackend.framework 0x01fe2c82 abe::AmioPlugin::LoadModule(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 482
15 com.adobe.aubackend.framework 0x01fdcb40 abe::AmioHost::Impl::LoadModule(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 576
16 com.adobe.aubackend.framework 0x01fe035f abe::AmioHost::Impl::Initialize(std::list<abe::AmioInfo, std::allocator<abe::AmioInfo> > const*, boost::function<void ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >)>&) + 2351
17 com.adobe.aubackend.framework 0x01fda611 abe::AmioHost::Initialize(std::list<abe::AmioInfo, std::allocator<abe::AmioInfo> > const*, boost::function<void ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >)>) + 33
18 AuApplication 0x028c4f4a app::Initializer::Initialize(bool, boost::function<void ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >)>) + 3306
19 AuUI 0x03b56440 aui::ApplicationInitializer::Impl::Initialize(dvaworkspace::workspace ::Workspace*) + 2768
20 AuUI 0x03b4bc3c aui::ApplicationInitializer::Initialize(dvaworkspace::workspace::Work space*) + 28
21 AuUI 0x0353d6d7 aui::Application::InitApplication(exo::app::AppInitArgs&) + 3943
22 com.adobe.exo.framework 0x0194cdf9 exo::app::AppBase::Initialize(exo::app::AppInitArgs&) + 729
23 AuUI 0x0353243e aui::Application::Initialize(exo::app::AppInitArgs&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 158
24 AuUI 0x03555c0f AudMacMain(int, char**) + 415
25 com.adobe.Audition.4.0 0x00002ecd main + 93
26 com.adobe.Audition.4.0 0x00002c66 start + 54
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x91a6890a kevent + 10
1 libdispatch.dylib 0x9a3f1c58 _dispatch_mgr_invoke + 969
2 libdispatch.dylib 0x9a3f06a7 _dispatch_mgr_thread + 53
Thread 2:
0 libsystem_kernel.dylib 0x91a6802e __workq_kernreturn + 10
1 libsystem_c.dylib 0x90266ccf _pthread_wqthread + 773
2 libsystem_c.dylib 0x902686fe start_wqthread + 30
Thread 3:
Thread 4:
0 libsystem_kernel.dylib 0x91a6783e __psynch_cvwait + 10
1 libsystem_c.dylib 0x90268e78 _pthread_cond_wait + 914
2 libsystem_c.dylib 0x9021082a pthread_cond_wait + 48
3 com.adobe.amt.services 0x06765274 C_AMTUISwitchSuppressUpdates + 16864
4 com.adobe.amt.services 0x0675e074 C_EULA_SetState + 2166
5 com.adobe.amt.services 0x067652da C_AMTUISwitchSuppressUpdates + 16966
6 libsystem_c.dylib 0x90264ed9 _pthread_start + 335
7 libsystem_c.dylib 0x902686de thread_start + 34
Thread 5:
1 libsystem_c.dylib 0x90268e21 _pthread_cond_wait + 827
2 libsystem_c.dylib 0x9021942c pthread_cond_wait$UNIX2003 + 71
3 com.apple.CoreServices.CarbonCore 0x95160f36 TSWaitOnCondition + 124
4 com.apple.CoreServices.CarbonCore 0x950d2579 TSWaitOnConditionTimedRelative + 136
5 com.apple.CoreServices.CarbonCore 0x95134755 MPWaitOnQueue + 200
6 com.adobe.dvacore.framework 0x0013fa0a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
7 com.adobe.dvacore.framework 0x0013b89a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_ t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::thread s::ThreadSafeDelayQueue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
8 com.adobe.dvacore.framework 0x000c7869 boost::function0<void>::operator()() const + 41
9 com.adobe.dvacore.framework 0x0013830d dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
10 com.adobe.dvacore.framework 0x00139200 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
11 com.adobe.boost_threads.framework 0x000566fd thread_proxy + 141
12 libsystem_c.dylib 0x90264ed9 _pthread_start + 335
13 libsystem_c.dylib 0x902686de thread_start + 34
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
2 libsystem_c.dylib 0x902193e0 pthread_cond_timedwait$UNIX2003 + 70
3 com.adobe.aubackend.framework 0x022bc600 abe::spectral::SpectralDataManager::Process() + 720
4 com.adobe.dvacore.framework 0x000c7869 boost::function0<void>::operator()() const + 41
5 com.adobe.dvacore.framework 0x0013fa9a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 298
6 com.adobe.dvacore.framework 0x0013b89a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_ t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::thread s::ThreadSafeDelayQueue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
7 com.adobe.dvacore.framework 0x000c7869 boost::function0<void>::operator()() const + 41
8 com.adobe.dvacore.framework 0x0013830d dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
9 com.adobe.dvacore.framework 0x00139200 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
10 com.adobe.boost_threads.framework 0x000566fd thread_proxy + 141
11 libsystem_c.dylib 0x90264ed9 _pthread_start + 335
12 libsystem_c.dylib 0x902686de thread_start + 34
Thread 16:
2 libsystem_c.dylib 0x90268f7b pthread_cond_timedwait_relative_np + 47
3 com.apple.CoreServices.CarbonCore 0x950d25a3 TSWaitOnConditionTimedRelative + 178
4 com.apple.CoreServices.CarbonCore 0x95134755 MPWaitOnQueue + 200
5 com.adobe.dvacore.framework 0x0013fa0a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
Thread 17:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x91a65c22 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x91a651f6 mach_msg + 70
2 com.apple.audio.CoreAudio 0x911d49fe HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned long, unsigned long, mach_msg_header_t*, unsigned int) + 122
3 com.apple.audio.CoreAudio 0x911d4a6a HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, unsigned int) + 60
4 com.apple.audio.CoreAudio 0x911cce5f HALC_ProxyIOContext::IOWorkLoop() + 1145
5 com.apple.audio.CoreAudio 0x911cc926 HALC_ProxyIOContext::IOThreadEntry(void*) + 136
6 com.apple.audio.CoreAudio 0x911cc898 __HALC_ProxyIOContext_block_invoke_6 + 20
7 com.apple.audio.CoreAudio 0x911cc81d HALB_IOThread::Entry(void*) + 69
8 libsystem_c.dylib 0x90264ed9 _pthread_start + 335
9 libsystem_c.dylib 0x902686de thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x00000000 ecx: 0x069b3600 edx: 0x000000ef
edi: 0x0f2290a7 esi: 0xbfffe1b8 ebp: 0xbfffe178 esp: 0xbfffe15c
ss: 0x00000023 efl: 0x00010286 eip: 0x0f3686cc cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x00000000
Logical CPU: 0
Binary Images:
0x1000 - 0x2ff7 +com.adobe.Audition.4.0 (4.0x1815 - 4.0) <85E5CFCF-9F35-62E7-FBB0-A9D784065AAA> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/MacOS/Adobe Audition
0x8000 - 0xcffc +com.adobe.AdobeCrashReporter (2.5 - 3.0.20090403) /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeCrashReporter.framework/Version s/A/AdobeCrashReporter
0x13000 - 0x2ffd7 +com.adobe.LogTransport (1.0 - 1.0) /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/LogTransport.framework/Versions/A/Lo gTransport
0x3b000 - 0x41fef +com.adobe.boost_date_time.framework (boost_date_time version 5.5.0 - 5.5.0.11) <65EA5634-E68B-A458-36E5-1CE41C510FE5> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_date_time.framework/Versions/A /boost_date_time
0x54000 - 0x5bff2 +com.adobe.boost_threads.framework (boost_threads version 5.5.0 - 5.5.0.11) <BA76B8DD-DD46-9677-BC27-2263B3F6C1C2> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_threads.framework/Versions/A/b oost_threads
0x6c000 - 0x76ffd +com.adobe.boost_signals.framework (boost_signals version 5.5.0 - 5.5.0.11) <BF2FB70C-B5C6-8895-7F49-A958252FE8AD> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_signals.framework/Versions/A/b oost_signals
0x8a000 - 0x8bffb +com.adobe.boost_system.framework (boost_system version 5.5.0 - 5.5.0.11) <BF82B35F-D3C0-33A9-FEA0-726282D735EA> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_system.framework/Versions/A/bo ost_system
0x94000 - 0x221fe7 +com.adobe.dvacore.framework (dvacore version 5.5.0 - 5.5.0.11) <B4D76A59-D111-D6BB-5628-4A323BB85052> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x3a5000 - 0x707fe7 +com.adobe.dvaui.framework (dvaui version 5.5.0 - 5.5.0.11) <67D7F0B7-A688-3BEB-F0DA-75C9E4387838> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0xab7000 - 0xe34ff3 +com.adobe.dvaadameve.framework (dvaadameve version 5.5.0 - 5.5.0.11) <D61819DB-66CC-348F-3902-BC814A3A4A14> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaa dameve
0x13b1000 - 0x145efff +com.adobe.dvaworkspace.framework (dvaworkspace version 5.5.0 - 5.5.0.11) <A7558000-BC03-A56D-FB8B-50357B11D002> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dv aworkspace
0x1534000 - 0x1556ff7 +com.adobe.dvamediatypes.framework (dvamediatypes version 5.5.0 - 5.5.0.11) <BA4829C9-AA08-55B0-0C65-CAABBDE0570E> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/d vamediatypes
0x1578000 - 0x15d8fff +com.adobe.dvametadata.framework (dvametadata version 5.5.0 - 5.5.0.11) <177F1AC0-7356-003C-3A1B-932D6AFCD109> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvametadata.framework/Versions/A/dva metadata
0x1664000 - 0x16bcff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.2 -c 3 - 61.141987) <31B045A8-AA5F-AFDF-E2DD-71B418CD1707> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeX MP
0x16cc000 - 0x1772ff3 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.2 -f 17 - 61.141987) <963C6B68-E97E-A983-A716-6A8FA37E9D2D> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/A dobeXMPFiles
0x17b0000 - 0x1842fff +com.adobe.dvametadataUI.framework (dvametadataUI version 5.5.0 - 5.5.0.11) <ADF2FFAD-9BB9-D293-6E0F-65D730C1149D> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvametadataui.framework/Versions/A/d vametadataUI
0x18de000 - 0x1927fff +com.adobe.dvatemporalxmp.framework (dvatemporalxmp version 5.5.0 - 5.5.0.11) <5E7D6AE9-B564-573D-A87E-856AB21CBE72> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/ dvatemporalxmp
0x194a000 - 0x19f4fff +com.adobe.exo.framework (exo version 5.5.0 - 5.5.0.11) <CD97F7C6-68E8-A72F-9CF3-41875F43B537> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/exo.framework/Versions/A/exo
0x1af2000 - 0x1b10ff3 +com.adobe.dvaunittesting.framework (dvaunittesting version 5.5.0 - 5.5.0.11) <2A5C3BEA-D80D-1838-0561-5E4167362226> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/ dvaunittesting
0x1b3c000 - 0x1b47fff +com.adobe.aucore.framework (1.0 - 1.0) <A59255F4-FF8E-6362-0321-66A358A85AC0> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuCore.framework/Versions/A/AuCore
0x1b55000 - 0x1ccdfe2 +com.adobe.audsp.framework (1.0 - 1.0) <26B5FE57-0462-24C2-A141-50F0A8585AE2> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuDSP.framework/Versions/A/AuDSP
0x1d3f000 - 0x1ec0fff +com.adobe.auaudiocomponents.framework (1.0 - 1.0) <1E99D19B-F863-7356-1152-AEE3CC79A790> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuAudioComponents.framework/Versions /A/AuAudioComponents
0x1fcb000 - 0x2359fef +com.adobe.aubackend.framework (1.0 - 1.0) <F772F4E9-DFF6-B6FF-F0FC-D8A58B2D7A2B> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuBackEnd.framework/Versions/A/AuBac kEnd
0x268c000 - 0x2693fff +com.adobe.dvaundo.framework (dvaundo version 5.5.0 - 5.5.0.11) <EB63E6D5-2B66-B9CE-2537-49F04A2E2546> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
0x26a0000 - 0x2a04feb +AuApplication (??? - ???) <6EC48FB1-D2E9-C93B-BCDA-56B5E3970DE5> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuApplication.framework/Versions/A/A uApplication
0x2d00000 - 0x2de8feb +com.adobe.auuitoolkit.framework (1.0 - 1.0) <809291B6-2082-44FB-1FE9-6209B34CB819> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuUIToolkit.framework/Versions/A/AuU IToolkit
0x2f39000 - 0x2fd8ff7 +com.adobe.AdobeExtendScript (ExtendScript 4.15.1 - 4.15.1.10952) <08C05DF9-BC45-17F2-6797-6E46C1528565> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeExtendScript.framework/Versions /A/AdobeExtendScript
0x303f000 - 0x30d1fe3 +com.adobe.AdobeScCore (ScCore 4.15.1 - 4.15.1.10952) <393EE4DF-20CE-C83C-F22C-CE5C06DCB858> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/Ado beScCore
0x311e000 - 0x322effb +com.adobe.auscripting.framework (1.0 - 1.0) <86C73976-B283-7E91-05B9-10F72115B56F> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuScripting.framework/Versions/A/AuS cripting
0x33bb000 - 0x342afff +com.adobe.auaudiocomponentsui.framework (1.0 - 1.0) <F82A50BC-6CD1-6FAC-642E-C04EB82CD0BF> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuAudioComponentsUI.framework/Versio ns/A/AuAudioComponentsUI
0x34cb000 - 0x3e5cfef +AuUI (??? - ???) <6A6C3DBD-AADA-8A6C-3C92-FC8E0BD5D796> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuUI.framework/Versions/A/AuUI
0x47a7000 - 0x47e4fff com.apple.vmutils (4.2.1 - 107) <43B3BFA5-8362-3EBD-B44B-32DCE9885082> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutil s
0x47fe000 - 0x486bffb com.apple.CoreSymbolication (2.1 - 71) <442A5CD4-9820-3BB2-BD68-D8AB94010E34> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Version s/A/CoreSymbolication
0x48a6000 - 0x490bffb com.apple.Symbolication (1.2 - 89) <AB71058E-7106-3D01-8EF9-5F9FEF950D6E> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/ Symbolication
0x4937000 - 0x496efef com.apple.DebugSymbols (2.1 - 87) <E2E26B90-BC10-304A-AF1B-8E5CCA9776A7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/D ebugSymbols
0x4987000 - 0x4991ff3 +com.adobe.boost_filesystem.framework (boost_filesystem version 5.5.0 - 5.5.0.11) <0E6191C4-7881-0F74-7118-1E5E94CE884C> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_filesystem.framework/Versions/ A/boost_filesystem
0x49a6000 - 0x4a23fe2 +com.adobe.boost_regex.framework (boost_regex version 5.5.0 - 5.5.0.11) <0CF74BD7-D9F3-CA91-D6F6-4B56738E4819> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_regex.framework/Versions/A/boo st_regex
0x4a8a000 - 0x4b5efef +com.adobe.dvaeve.framework (dvaeve version 5.5.0 - 5.5.0.11) <029FE587-C304-DEDB-FC46-6F84D2C75EE4> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
0x4c5b000 - 0x4c87ff3 com.apple.audio.CoreAudioKit (1.6.2 - 1.6.2) <9376552A-AFDD-368A-AF35-65A2D6F5DF8E> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudi oKit
0x4c9a000 - 0x4d303a6 +iZotope_Radius (??? - ???) <B6AF5A0A-6CFD-4298-8450-9FD830471654> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/iZotope_Radius.framework/Versions/A/ iZotope_Radius
0x4d6d000 - 0x4dc3ffb +com.adobe.headlights.LogSessionFramework (??? - 2.1.2.1263) <5B594BC9-5222-651B-6B70-7AD067035B1A> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/LogSession.framework/Versions/A/LogS ession
0x4e0c000 - 0x509afec +libxerces-c-3.0.dylib (??? - ???) <CDE6FF46-6D9A-55B9-7DF8-CEB48EBB54B9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/libxerces-c-3.0.dylib
0x521d000 - 0x52caff7 libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <7B6DB792-C9E5-3772-8734-8D0052757B8C> /usr/lib/libcrypto.0.9.7.dylib
0x530f000 - 0x5432ff7 +AdobeACE (??? - ???) <6B4856DC-3D41-CEF7-CB70-D02EEA97B8D2> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeA CE
0x5455000 - 0x5b2fff3 +AdobeAGM (??? - ???) <FE943B4D-ED58-F753-8AE8-54E753A773BD> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeA GM
0x5bf4000 - 0x5c11ff7 +AdobeBIB (??? - ???) <6CC35ACF-5CCD-1509-B4BB-3B48AD140526> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeB IB
0x5c18000 - 0x5c3effb +AdobeBIBUtils (??? - ???) <B9888BEE-A939-50E3-1CD3-3313AC14A073> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/A dobeBIBUtils
0x5c45000 - 0x5f74ff3 +com.adobe.CoolType (AdobeCoolType 5.10.7.10201 - 5.10.7.10201) <6810A678-B1DF-F96D-2560-25AE3FDA923A> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/A dobeCoolType
0x5fc6000 - 0x6034ffb +com.adobe.amtlib (amtlib 4.0.0.21 - 4.0.0.21) <3090D254-587A-A820-DBCD-729C27532FC8> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x604b000 - 0x604ffff +com.adobe.dvaflashview.framework (dvaflashview version 5.5.0 - 5.5.0.11) <98E23B9D-1CF1-E412-FD26-1EDE5BBD3DF9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dv aflashview
0x605a000 - 0x605dffc +com.adobe.ape.shim (adbeape version 3.1.74.12761 - 3.1.74.12761) <FE2ABE8A-1D3F-7AF5-297C-D22FC3E0FBDA> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
0x63da000 - 0x63e2fff +com.adobe.asneu.framework (asneu version 1.7.0.1 - 1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
0x6740000 - 0x67abfe7 +com.adobe.amt.services (AMTServices 4.0.0.21 [BuildVersion: 4.0; BuildDate: Mon Jan 24 2011 21:49:00] - 4.0.0.21) <018F21DE-7E2E-C850-4C32-D4A2131ABF74> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/amtservices.framework/Versions/A/amt services
0x67e7000 - 0x67ebffb com.apple.audio.AudioIPCPlugIn (1.2.1 - 1.2.1) <B8333059-00BE-33A6-AEC0-0C8F285E6E07> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/Aud ioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x67f0000 - 0x67f6ffb com.apple.audio.AppleHDAHALPlugIn (2.1.3 - 2.1.3f7) <C2DD672D-46CE-34BB-8456-129C65DDE583> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x8795000 - 0x8805feb +com.adobe.adobe_caps (adobe_caps 4.0.42.0 - 4.0.42.0) <55D7D2EA-D21E-98B1-77C6-58C0A0E07051> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adob e_caps
0x8b97000 - 0x8bc0fef +com.adobe.ape (adbeapecore version 3.1.74.12761 - 3.1.74.12761) <21548488-E9C3-4638-D7FC-895EE0F8EE30> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
0x8e0c000 - 0x8e0dff1 com.apple.textencoding.unicode (2.4 - 2.4) <4E55D4B9-4E67-3FC9-9407-3E99D1D50F15> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0xb3d3000 - 0xb3eafff +com.adobe.AmioAiff.bundle (1.0 - 1.0) <8DD42393-CA20-52FD-E73B-735A39AFD2A9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioAiff.bundle/Contents/MacOS/AmioAiff
0xb404000 - 0xb44dff7 +com.adobe.AmioLSF.bundle (1.0 - 1.0) <DD4C303E-2964-374C-FCE4-B5053A976327> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/MacOS/AmioLSF
0xb482000 - 0xb4e0ff3 +libsndfile.1.dylib (2.23.0 - compatibility 2.0.0) <832BFA9E-FE6D-3C12-9B61-E8CBC29CD963> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/Libraries/libsndfile.1.dylib
0xb502000 - 0xb546fef +libFLAC.8.2.0.dylib (11.0.0 - compatibility 11.0.0) <B5EF064F-745D-0D00-2FC4-B31A46971272> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/Libraries/libFLAC.8.2.0.dylib
0xb55c000 - 0xb6bbfeb +libvorbisenc.2.dylib (3.7.0 - compatibility 3.0.0) <93CE9300-8AB1-83A4-E20D-E7737DB97BA5> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/Libraries/libvorbisenc.2.dylib
0xb700000 - 0xb726fea +libvorbis.0.dylib (5.4.0 - compatibility 5.0.0) <745A9A7D-4C43-6B9A-FFCF-773BFD318C05> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/Libraries/libvorbis.0.dylib
0xb72f000 - 0xb731fe8 +libogg.0.dylib (8.0.0 - compatibility 8.0.0) <51B9D3BA-575C-C5A5-CD90-3AF66EB1BDF9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/Libraries/libogg.0.dylib
0xb737000 - 0xb7e3fe6 +com.adobe.AmioMp3.bundle (1.0 - 1.0) <53405C96-BF4A-93D5-9ECE-3CD999E37DD6> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioMp3.bundle/Contents/MacOS/AmioMp3
0xb892000 - 0xb8b2ff7 +com.adobe.AmioQT.bundle (1.0 - 1.0) <14050CEE-F059-C990-1515-0F419BBA3F46> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioQT.bundle/Contents/MacOS/AmioQT
0xb9e5000 - 0xb9eefca +com.cod3r.ac3movieimport (1.7.1 - 1.7.1) /Library/QuickTime/AC3MovieImport.component/Contents/MacOS/AC3MovieIm port
0xb9f3000 - 0xb9f3fff +com.adobe.SoundboothScoreAudioCodec (1.0 - 1.0) /Library/QuickTime/SoundboothScoreCodec.component/Contents/MacOS/Soun dboothScoreCodec
0xba5d000 - 0xba5efff com.apple.DVCPROHDVideoOutputCodec (1.2 - 1.2) /Library/QuickTime/DVCPROHDVideoOutputCodec.component/Contents/MacOS/ DVCPROHDVideoOutputCodec
0xba62000 - 0xbad3fff +com.DivXInc.DivXDecoder (6.2.5 - 6.2.5) /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
0xbae1000 - 0xbb31fff +com.DivXInc.DivXDecoder (6.0.5 - 6.0.5) /Library/QuickTime/DivX 6 Decoder.component/Contents/MacOS/DivX 6 Decoder
0xeb2d000 - 0xed20ff7 +net.telestream.wmv.import (2.1.0.33 - 2.1.0.33) /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
0xf01d000 - 0xf153ff7 com.apple.QuickTimeStreaming.component (7.7.1 - 2306) <AA9E0B70-CC52-34D7-AF42-1D36708CF31B> /System/Library/QuickTime/QuickTimeStreaming.component/Contents/MacOS /QuickTimeStreaming
0xf1b7000 - 0xf20affb com.apple.QuickTimeMPEG.component (7.7.1 - 2306) <29532A45-677C-3381-AC08-919365E64EA9> /System/Library/QuickTime/QuickTimeMPEG.component/Contents/MacOS/Quic kTimeMPEG
0xf21e000 - 0xf220ffd com.apple.PDFImporter (2.2 - ???) <4F3BD14A-F40E-3469-81AC-FFBCF5E66F3B> /System/Library/Components/PDFImporter.component/Contents/MacOS/PDFIm porter
0xf226000 - 0xf37efef +org.perian (??? - 0.5) /Library/QuickTime/Perian.component/Contents/MacOS/Perian
0x8feba000 - 0x8feec9c7 dyld (195.5 - ???) <134323A7-49DC-3A9D-ACFD-32FAD0FD6BA2> /usr/lib/dyld
0x90208000 - 0x902d3fff libsystem_c.dylib (763.12.0 - compatibility 1.0.0) <1B0A12B3-DAFA-31E2-8F82-E98D620E4D72> /usr/lib/system/libsystem_c.dylib
0x902d4000 - 0x90426fff com.apple.audio.toolbox.AudioToolbox (1.7.1 - 1.7.1) <7646E131-08EE-3D72-ADA2-4A61C562B36E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
0x90479000 - 0x90479fff com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9047a000 - 0x9050eff7 com.apple.LaunchServices (480.21 - 480.21) <E3621817-B627-3EEC-A7F9-0D45583B7FE8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
0x9093c000 - 0x90994fff com.apple.HIServices (1.10 - ???) <76B50B43-6CFD-3067-A085-11420FD4FAA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
0x90995000 - 0x9099affd libGFXShared.dylib (??? - ???) <820D744C-C641-3918-A72A-AC2E5276BCB6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
0x90ee1000 - 0x90f03ff1 com.apple.PerformanceAnalysis (1.10 - 10) <45B10D4C-9B3B-37A6-982D-687A6F9EEA28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versi ons/A/PerformanceAnalysis
0x90fe1000 - 0x911b7fe3 com.apple.CoreFoundation (6.7.1 - 635.15) <AC9F6462-6315-3D89-8075-D048DB4DBF7E> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
0x911b8000 - 0x91219ffb com.apple.audio.CoreAudio (4.0.1 - 4.0.1) <089D78E0-46A6-38DB-9545-7F35CC815939> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x91297000 - 0x9129fff3 liblaunch.dylib (392.18.0 - compatibility 1.0.0) <CD470A1E-0147-3CB1-B44D-0B61F9061826> /usr/lib/system/liblaunch.dylib
0x912a0000 - 0x912defff libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <0AE59D4F-FFA7-3539-8B86-AD8993894AA0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x91739000 - 0x9173bff7 libdyld.dylib (195.5.0 - compatibility 1.0.0) <637660EA-8D12-3B79-B644-041FEADC9C33> /usr/lib/system/libdyld.dylib
0x9174c000 - 0x9174dff7 libsystem_sandbox.dylib (??? - ???) <BC0A04E9-4F28-3BC8-AA7B-63C3451E9212> /usr/lib/system/libsystem_sandbox.dylib
0x9174e000 - 0x919c1fff com.apple.CoreImage (7.82 - 1.0.1) <6C99F458-E83A-3538-9B71-2C8BD0C9DCD5> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /CoreImage.framework/Versions/A/CoreImage
0x91a12000 - 0x91a4efff libcups.2.dylib (2.9.0 - compatibility 2.0.0) <AA56493C-D7C6-3D4F-8DC8-855405AFF57B> /usr/lib/libcups.2.dylib
0x91a4f000 - 0x91a6dff7 libsystem_kernel.dylib (1699.22.73 - compatibility 1.0.0) <D32C2E9C-8184-3FAF-8694-99FC619FC71B> /usr/lib/system/libsystem_kernel.dylib
0x91aed000 - 0x91aedfff libdnsinfo.dylib (395.6.0 - compatibility 1.0.0) <959E5139-EB23-3529-8881-2BCB5724D1A9> /usr/lib/system/libdnsinfo.dylib
0x91aee000 - 0x91b5dfff com.apple.Heimdal (2.1 - 2.0) <DE626683-DF32-341B-8997-AE63309590C7> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimda l
0x91b5f000 - 0x91bc1ffb com.apple.datadetectorscore (3.0 - 179.4) <12EF80E0-35CC-30A7-942F-2F9E87C4C98C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
0x91c0d000 - 0x91c23ffe libxpc.dylib (77.17.0 - compatibility 1.0.0) <E01E0074-0830-3F20-8703-EA7722BFD358> /usr/lib/system/libxpc.dylib
0x91c24000 - 0x91c25ff0 libunc.dylib (24.0.0 - compatibility 1.0.0) <BCD277D0-4271-3E96-A4A2-85669DBEE2E2> /usr/lib/system/libunc.dylib
0x91c26000 - 0x91c31fff libkxld.dylib (??? - ???) <088640F2-429D-3368-AEDA-3C308C4EB80C> /usr/lib/system/libkxld.dylib
0x91c3c000 - 0x91c58ff5 com.apple.GenerationalStorage (1.0 - 125) <F1D67293-9192-367D-AE74-2732B23E7E77> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versi ons/A/GenerationalStorage
0x91cab000 - 0x91cadffb libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91cae000 - 0x91e0fffb com.apple.QuartzCore (1.7 - 270.0) <0916DA83-6400-3FEA-BC53-5F4BA4D126EC> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x91e10000 - 0x91e10fff com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
0x91e6b000 - 0x91e73ff3 libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
0x91e7a000 - 0x91e7bff5 libremovefile.dylib (21.0.0 - compatibility 1.0.0) <9A1E12B7-F822-3544-8E1D-A6DC81E1F2E6> /usr/lib/system/libremovefile.dylib
0x91eee000 - 0x91ef4ffd com.apple.CommerceCore (1.0 - 17) <71641C17-1CA7-3AC9-974E-AAC9EB641035> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
0x91ef5000 - 0x91f24ff7 libsystem_info.dylib (??? - ???) <B86A363D-6EA2-3A69-A6CB-18B7F98FC61A> /usr/lib/system/libsystem_info.dylib
0x92299000 - 0x9229afff libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
0x9229b000 - 0x922a6ffb com.apple.speech.recognition.framework (4.0.19 - 4.0.19) <17C11291-5B27-3BE2-8614-7A806745EE8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
0x922a7000 - 0x9233eff3 com.apple.securityfoundation (5.0 - 55005) <F5A98CC2-11C6-34F3-8F72-75B642627630> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
0x9264c000 - 0x92669ff3 com.apple.openscripting (1.3.3 - ???) <31A51238-0CA1-38C7-9F0E-8A6676EE3241> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
0x9266a000 - 0x9266dff9 libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <B9344DE6-B84D-352C-95AD-EF73A68B8A10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
0x926b1000 - 0x926bcff3 libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <11726E50-E6FC-3AB0-8750-DDDCCF2B8534> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x926df000 - 0x92713ff8 libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <567E922C-E64F-321B-9A47-6B18BF481625> /usr/lib/libssl.0.9.8.dylib
0x9271a000 - 0x92829ffb com.apple.DesktopServices (1.6.1 - 1.6.1) <9F02752A-617B-3AC7-BCA1-F040C105EDDE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
0x9293a000 - 0x92becff7 com.apple.security (7.0 - 55010) <BE0350C5-5221-3BFF-B674-646AB1BA0F2E> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x92bed000 - 0x92bf3ffb com.apple.print.framework.Print (7.1 - 247.1) <5D7ADC17-D8EF-3958-9C0C-AA45B7717FBA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
0x92bf4000 - 0x92da8ff3 libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib
0x93580000 - 0x93587ff5 libsystem_dnssd.dylib (??? - ???) <B3217FA8-A7D6-3C90-ABFC-2E54AEF33547> /usr/lib/system/libsystem_dnssd.dylib
0x93588000 - 0x9360ffff com.apple.print.framework.PrintCore (7.1 - 366.1) <BD9120A6-BFB0-3796-A903-05F627F696DF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
0x93621000 - 0x93643ffe com.apple.framework.familycontrols (3.0 - 300) <F87D87EF-553A-3165-9C9A-6E117C537FE9> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
0x93644000 - 0x93645fff liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
0x93646000 - 0x9373eff7 libFontParser.dylib (??? - ???) <83E7E71E-D217-3DEE-B288-F5BAE7E118C5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x93741000 - 0x937cbffb com.apple.SearchKit (1.4.0 - 1.4.0) <CF074082-64AB-3A1F-831E-582DF1667827> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
0x9384d000 - 0x93894fff com.apple.SystemConfiguration (1.11.1 - 1.11) <CA6CE2B6-DC18-31FF-9668-70BB2FD8D7BB> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
0x938f2000 - 0x939e2ff1 libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
0x939e3000 - 0x93b03fec com.apple.vImage (5.1 - 5.1) <008B989F-F080-398E-ACB1-FBF5BA107D6D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
0x93b04000 - 0x93b0eff2 com.apple.audio.SoundManager (3.9.4 - 3.9.4) <D23C4761-6492-3974-B4D2-495082B8B7A6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
0x93b14000 - 0x93b16ff9 com.apple.securityhi (4.0 - 1) <BD367302-73C3-32F4-8080-E389AE89E434> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
0x93e5a000 - 0x93e61ffd com.apple.NetFS (4.0 - 4.0) <D0D59145-D211-3E7C-9062-35A2833FA99B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x93e62000 - 0x93f22ff3 com.apple.ColorSync (4.7.0 - 4.7.0) <A39EA668-D042-377F-BC81-26748CD57ADC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
0x93f23000 - 0x9400bfff libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <ED3F5E83-8C76-3D46-B2FF-0D5BDF8970C5> /usr/lib/libxml2.2.dylib
0x94038000 - 0x94074ffd libGLImage.dylib (??? - ???) <8251242B-E04E-3467-BD0F-834578B18AC0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
0x94083000 - 0x94094fff libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
0x94095000 - 0x94095ffe libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
0x94096000 - 0x94156fff com.apple.CoreServices.OSServices (478.29 - 478.29) <EAAAAC1B-2599-3875-9068-DF7E6B5760A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
0x9418e000 - 0x94232fff com.apple.QD (3.12 - ???) <68CBE425-43BA-3E6D-8668-A4A67396E20D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
0x9440f000 - 0x9446cffb com.apple.htmlrendering (76 - 1.1.4) <743C2943-40BC-36FB-A45C-3421A394F081> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
0x9446d000 - 0x94490fff com.apple.CoreVideo (1.7 - 70.1) <3520F013-DF91-364E-88CF-ED252A7BD0AE> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x945a9000 - 0x945b2ff3 com.apple.CommonAuth (2.1 - 2.0) <D49B41B1-A5DD-366A-8C30-49E9B875AA13> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/Com monAuth
0x945b3000 - 0x945bbff5 libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <A1BFC320-616A-30AA-A41E-29D7904FC4C7> /usr/lib/system/libcopyfile.dylib
0x94678000 - 0x9469dff9 libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x946c7000 - 0x9472bfff com.apple.framework.IOKit (2.0 - ???) <D14460ED-2B6C-375D-B3A4-B8C82E922666> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x947ba000 - 0x947fbff9 libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <975E4F25-7943-3785-849C-244FF4E77602> /usr/lib/libcurl.4.dylib
0x947fc000 - 0x94824ff7 libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <FCAC685A-724F-3FE7-8416-146108DF75FB> /usr/lib/libxslt.1.dylib
0x94825000 - 0x94828ff7 libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
0x94829000 - 0x9482affd libCVMSPluginSupport.dylib (??? - ???) <96F2F2F4-E7A9-36C8-B1CF-D58AA3DB2B44> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC VMSPluginSupport.dylib
0x9482b000 - 0x9483bfff libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <D6F728DA-990A-32A3-86FA-4A3F4D88E309> /usr/lib/libsasl2.2.dylib
0x9483c000 - 0x9483fffb com.apple.help (1.3.2 - 42) <DDCEBA10-5CDE-3ED2-A52F-5CD5A0632CA2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
0x94cd4000 - 0x94cd4fff com.apple.Carbon (153 - 153) <6FF98F0F-2CDE-3888-A304-4ED447D24CE3> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x94cd5000 - 0x94d2effb com.apple.coreui (1.2.1 - 164.1) <890E0BE9-3360-3B56-BE46-5A2421875A40> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x94d2f000 - 0x94e43ff3 com.apple.QuickTimeImporters.component (7.7.1 - 2306) <393FD879-F626-3FB2-9866-9E6B122BD64F> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS /QuickTimeImporters
0x94e90000 - 0x94fbcff9 com.apple.CFNetwork (520.2.5 - 520.2.5) <02193949-50A8-3CBC-9920-5FCDB8EBE17A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
0x94fbd000 - 0x95093a5b libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <A0EDB351-4B9D-3AA2-9D1A-0C22204FCCD3> /usr/lib/libobjc.A.dylib
0x95094000 - 0x95396fff com.apple.CoreServices.CarbonCore (960.18 - 960.18) <8094724D-591D-3CC2-81DE-4E3029624E11> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
0x953df000 - 0x953fcfff libresolv.9.dylib (46.0.0 - compatibility 1.0.0) <95AE43ED-6C52-3B39-89B6-54C81C62F1FF> /usr/lib/libresolv.9.dylib
0x953fd000 - 0x9544dfff libFontRegistry.dylib (??? - ???) <81E03B82-1F31-3702-97DC-BE20298E326F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x95604000 - 0x95944ffb com.apple.HIToolbox (1.8 - ???) <DFED9BD0-E142-397B-BE16-16EBCF3CE1EB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
0x95a0c000 - 0x95a5dff9 com.apple.ScalableUserInterface (1.0 - 1) <C3FA7E40-0213-3ABC-A006-2CB00B6A7EAB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x95a5e000 - 0x95a73ff7 com.apple.ImageCapture (7.0 - 7.0) <116BC0CA-428E-396F-85DF-52793034D2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
0x95b09000 - 0x95b14ffc com.apple.NetAuth (1.0 - 3.0) <C07853C0-AF32-3633-9CEF-2480860C12C5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAut h
0x95b15000 - 0x95b15fff com.apple.Cocoa (6.6 - ???) <650273EF-1ABC-334E-B745-B75AF028F9F4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x95b5b000 - 0x95b7afff com.apple.RemoteViewServices (1.2 - 39) <C7B638D2-2F8B-3A45-916A-73103FADC822> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versio ns/A/RemoteViewServices
0x95b7b000 - 0x95b7effd libCoreVMClient.dylib (??? - ???) <2D135537-F9A6-33B1-9B01-6ECE7E929C00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
0x95b7f000 - 0x95b86ff7 libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
0x95c03000 - 0x95c65ff3 libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
0x95c66000 - 0x95cdbfff com.apple.Metadata (10.7.0 - 627.20) <1E7C8194-8CE4-3103-A3D1-8913238AF923> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
0x95d19000 - 0x95d1dfff com.apple.CommonPanels (1.2.5 - 94) <3A988595-DE53-34ED-9367-C9A737E2AF38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
0x95d1e000 - 0x95db9ff3 com.apple.ink.framework (1.3.2 - 110) <9F6F37F9-999E-30C5-93D0-E48D4B5E20CD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
0x95dba000 - 0x95dd3fff libPng.dylib (??? - ???) <A83B66DC-302C-3A4C-8107-0E5560708024> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x95e79000 - 0x95e8cffb com.apple.MultitouchSupport.framework (220.62.1 - 220.62.1) <3D94520B-C976-370F-AF56-278002BCF11D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
0x95f0a000 - 0x95f0eff3 libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
0x961ca000 - 0x961cbff7 libquarantine.dylib (36.0.0 - compatibility 1.0.0) <70782AEC-8933-3EB4-91CA-E44C0E768C90> /usr/lib/system/libquarantine.dylib
0x96aa7000 - 0x96aacff7 libmacho.dylib (800.0.0 - compatibility 1.0.0) <56A34E97-518E-307E-8218-C5D43A33EE34> /usr/lib/system/libmacho.dylib
0x96aad000 - 0x96ab0ff7 libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
0x96ab1000 - 0x96ab1ff0 com.apple.ApplicationServices (41 - 41) <BED33E1D-C95C-3654-9A3A-0CB3607F9F10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
0x96ab2000 - 0x96ac6ff7 com.apple.CFOpenDirectory (10.7 - 144) <665CDF77-F0C9-3AFF-8CF8-64257268B7DD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x96acd000 - 0x96adbfff libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
0x96af4000 - 0x96af4ff2 com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
0x96af5000 - 0x96afdfff com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
0x96b01000 - 0x96b0afff libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
0x96b0b000 - 0x96b18fff libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
0x96b19000 - 0x97194fe5 com.apple.CoreAUC (6.11.04 - 6.11.04) <B06D52C9-9F59-3EF2-B2BA-11E93C573572> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAU C
0x97195000 - 0x9719cfff com.apple.agl (3.1.4 - AGL-3.1.4) <CCCE2A89-026B-3185-ABEA-68D268353164> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x9719d000 - 0x971cbfe7 libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <07D9A827-9567-34C2-9022-AF4BF975C9A7> /usr/lib/libSystem.B.dylib
0x971cc000 - 0x9720afff com.apple.NavigationServices (3.6 - 192) <CB7AE807-9292-3EBA-A5F5-D7DCEE28A5B7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
0x9720b000 - 0x97225fff com.apple.Kerberos (1.0 - 1) <D7920A1C-FEC4-3460-8DD0-D02491578CBB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x97226000 - 0x97337ff7 libJP2.dylib (??? - ???) <35D120D4-3304-3A02-9259-EB933E74E63A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x97338000 - 0x979e1eeb com.apple.CoreGraphics (1.600.0 - ???) <322FC806-0B9F-3A58-8C88-D477E32A50F8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x979e2000 - 0x979f2fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x979f3000 - 0x97a29ff4 com.apple.LDAPFramework (3.0 - 120.1) <EA92FCA5-7A7E-328F-8C7F-4250FCC45879> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x97b71000 - 0x97b9affe com.apple.opencl (1.50.63 - 1.50.63) <C4EC60D6-9A7C-3CE9-AA80-2F81D9BB4465> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x97b9b000 - 0x97c00ff7 libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
0x97fb7000 - 0x97fbbfff libGIF.dylib (??? - ???) <06E85451-F51C-31C4-B5A6-180819BD9738> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x98045000 - 0x98d95fff com.apple.QuickTimeComponents.component (7.7.1 - 2306) <B397F658-057A-3D84-ABC7-84AA6256DB88> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacO S/QuickTimeComponents
0x98d96000 - 0x98dd6ff7 libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
0x98dd7000 - 0x98e64fe7 libvMisc.dylib (325.4.0 - compatibility 1.0.0) <F2A8BBA3-6431-3CED-8CD3-0953410B6F96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
0x98e65000 - 0x98e9bff7 com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
0x98e9c000 - 0x98e9dfff com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
0x98e9e000 - 0x98eccff7 com.apple.DictionaryServices (1.2.1 - 158.2) <DA16A8B2-F359-345A-BAF7-8E6A5A0741A1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
0x98ecd000 - 0x991d7ff3 com.apple.Foundation (6.7.1 - 833.20) <B5092554-485A-3A7D-904B-B04B1EE5C50C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9921a000 - 0x9921afff com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9921b000 - 0x992eafff com.apple.ImageIO.framework (3.1.1 - 3.1.1) <8B8A3DD3-BB3D-33FC-A714-81E1B883B155> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
0x99478000 - 0x998edff7 FaceCoreLight (1.4.7 - compatibility 1.0.0) <312D0F58-B8E7-3F61-8A83-30C95F2EBEAA> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/ FaceCoreLight
0x9996b000 - 0x9996bfff com.apple.audio.units.AudioUnit (1.7.1 - 1.7.1) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9996c000 - 0x99a7bff7 libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <90D36793-04A5-3BFF-BE83-EEEDCBEDC756> /usr/lib/libsqlite3.dylib
0x99a7c000 - 0x99a8cff7 libCRFSuite.dylib (??? - ???) <CE616EF3-756A-355A-95AD-3472A876BEB9> /usr/lib/libCRFSuite.dylib
0x99bbc000 - 0x99c37ffb com.apple.ApplicationServices.ATS (317.5.0 - ???) <D5AC5C21-CE1E-333D-94F7-F0F534FD4DC7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
0x99c38000 - 0x99c60ff0 com.apple.CoreServicesInternal (113.8 - 113.8) <9930695C-1C48-329F-93FD-5AEEE2EF942C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Vers ions/A/CoreServicesInternal
0x99eab000 - 0x9a387ff6 libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
0x9a3d5000 - 0x9a3e3fff com.apple.opengl (1.7.5 - 1.7.5) <81166D23-DE8E-3938-AAD3-29B1FA5E446E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9a3ef000 - 0x9a3fdfff libdispatch.dylib (187.7.0 - compatibility 1.0.0) <B50C62AD-0B5B-34C3-A491-ECFD72ED505E> /usr/lib/system/libdispatch.dylib
0x9a3fe000 - 0x9ae8cffe com.apple.AppKit (6.7.2 - 1138.23) <ADFA8D70-601E-3B5C-96FD-F45F52055CC8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x9aea6000 - 0x9b12bfe3 com.apple.QuickTime (7.7.1 - 2306) <F8C64DC4-3FE4-3A06-B10B-59E7F3BA6FDD> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x9b12c000 - 0x9b193fff libc++.1.dylib (19.0.0 - compatibility 1.0.0) <3AFF3CE8-14AE-300F-8F63-8B7FB9D4DA96> /usr/lib/libc++.1.dylib
0x9b194000 - 0x9b1ddff7 libGLU.dylib (??? - ???) <AEA2AD9A-EEDD-39B8-9B28-4C7C1BACB594> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
0x9b1de000 - 0x9b2c1ff7 libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <BD913D3B-388D-33AE-AA5E-4810C743C28F> /usr/lib/libcrypto.0.9.8.dylib
0x9b2c2000 - 0x9b305ffd libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <4BA1F5F1-F0A2-3FEB-BB62-F514DCBB3725> /usr/lib/system/libcommonCrypto.dylib
0x9b446000 - 0x9b447fff libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
0x9b523000 - 0x9b573ff4 libTIFF.dylib (??? - ???) <E86EA22A-82C0-3E77-9EAF-739F385790D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x9b7d8000 - 0x9b9c1ff7 com.apple.CoreData (104 - 358.12) <F8AD7990-2C30-31A4-8E78-FA8DD5CF03CC> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9ba3a000 - 0x9ba3effd IOSurface (??? - ???) <97E875C2-9F1A-3FBA-B80C-594892A02621> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x9ba3f000 - 0x9be41ff6 libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
0x9bef1000 - 0x9bf7eff7 com.apple.CoreText (220.11.0 - ???) <4F98D709-75AC-35F0-AD88-8F2C4BD744C0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
0x9bf7f000 - 0x9bf82ffc libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
0x9bf83000 - 0x9bfaefff com.apple.GSS (2.1 - 2.0) <05A0171B-76EA-3E4C-8A36-65D1A978AF4B> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x9bfaf000 - 0x9bfb3ffa libcache.dylib (47.0.0 - compatibility 1.0.0) <98A82BC5-0DD9-3212-9CAE-35A77278EEB6> /usr/lib/system/libcache.dylib
0x9ca05000 - 0x9ca1afff com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x9cafd000 - 0x9cb01ff7 com.apple.OpenDirectory (10.7 - 146) <3D3D30CE-6D82-3681-AA98-4E3AEFFA4229> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
0xb0000000 - 0xb0011ff8 +com.adobe.ahclientframework (1.6.0.20 - 1.6.0.20) <6FB288F2-45FD-E54A-C9A4-A0D0C374FE37> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclie nt
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 2
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 6797
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=250.8M resident=138.7M(55%) swapped_out_or_unallocated=112.1M(45%)
Writable regions: Total=131.0M written=7932K(6%) resident=14.4M(11%) swapped_out=0K(0%) unallocated=116.6M(89%)
REGION TYPE VIRTUAL
(null) (reserved) 40K reserved VM address space (unallocated)
ATS (font support) 32.2M
ATS (font support) (reserved) 4K reserved VM address space (unallocated)
CG backing stores 872K
CG raster data 860K
CG shared images 1256K
CoreGraphics 8K
CoreServices 4428K
MALLOC 26.6M
MALLOC guard page 32K
MALLOC_LARGE (reserved) 33.4M reserved VM address space (unallocated)
Memory tag=242 12K
Memory tag=243 4K
Memory tag=249 408K
Stack 72.6M
VM_ALLOCATE 17.0M
__CI_BITMAP 80K
__DATA 16.1M
__DATA/__OBJC 112K
__IMAGE 1256K
__IMPORT 348K
__LINKEDIT 78.1M
__OBJC 1636K
__OBJC/__DATA 48K
__PAGEZERO 4K
__TEXT 172.7M
__UNICODE 544K
mapped file 113.5M
shared memory 364K
shared pmap 9164K
TOTAL 583.1M
TOTAL, minus reserved VM space 549.7M
Model: MacBook6,1, BootROM MB61.00C8.B00, 2 processors, Intel Core 2 Duo, 2.26 GHz, 4 GB, SMC 1.51f53
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.100.98.75.18)
Bluetooth: Version 4.0.1f4, 2 service, 11 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: TOSHIBA MK2555GSXF, 250.06 GB
Serial ATA Device: MATSHITADVD-R UJ-898
USB Device: Built-in iSight, apple_vendor_id, 0x8507, 0x24400000 / 2
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0236, 0x04600000 / 2
USB Device: USB Optical Mouse, 0x046d (Logitech Inc.), 0xc058, 0x06200000 / 3
USB Device: BRCM2070 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x06100000 / 2
USB Device: Bluetooth Module, apple_vendor_id, 0x8218, 0x06130000 / 4
please help me, thank you very much
By giving the information requested in the FAQ, I can now immediately see the problem:
Perian is crashing when QuickTime is asking it what it supports. Please update Perian or uninstall it. The reason why this is crashing Audition on startup is because on first launch we ask QuickTime which file extensions it supports (e.g. .mov, .aac, .mp4, etc). In that process, QuickTime is in-turn, calling Perian (since you installed it) and asking Perian. For some reason, this is crashing.
If you don't need QuickTime support in Audition, you can remove/rename the AmioQT.bundle from within the Adobe Audition CS5.5.app.
Hey my audition crash when i open up today. it started up did it yesterday as well. please help.
here a screen shot just before it crashes.
here the crash report
Process: Adobe Audition [3158]
Parent Process: launchd [242]
Date/Time: 2012-05-31 08:09:45.593 +0930
OS Version: Mac OS X 10.7.4 (11E53)
Report Version: 9
Interval Since Last Report: 2241 sec
Per-App Interval Since Last Report: 57 sec
Per-App Crashes Since Last Report: 7
Anonymous UUID: 4176F5F7-DB75-41E1-AEDB-0DE4B0F8FEE1
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
objc[3158]: garbage collection is OFF
terminate called throwing an exception
abort() called
0 libsystem_kernel.dylib 0x978d89c6 __pthread_kill + 10
1 libsystem_c.dylib 0x99159f78 pthread_kill + 106
2 libsystem_c.dylib 0x9914abdd abort + 167
3 libc++abi.dylib 0x900ee921 abort_message + 94
4 libc++abi.dylib 0x900ec1bc default_terminate() + 36
5 libc++abi.dylib 0x900ec1fe safe_handler_caller(void (*)()) + 15
6 libc++abi.dylib 0x900ec268 std::terminate() + 23
7 libc++abi.dylib 0x900ed2a0 __cxa_throw + 112
8 AuUI 0x03550f7f aui::ErrorManager::ThrowError(dvacore::config::ErrorLevel, char const*, unsigned int, int, bool, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&) const + 319
9 com.adobe.dvacore.framework 0x000c58f8 dvacore::config::ThrowError(dvacore::config::ErrorLevel, char const*, unsigned int, int, bool, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&) + 168
10 com.adobe.dvacore.framework 0x0011bf89 dvacore::proplist::utils::LoadPropList(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvacore::proplist::PropList&, bool) + 361
11 AuApplication 0x026f2f13 app::FavoriteManager::Initialize(bool) + 339
12 AuApplication 0x028c59e7 app::Initializer::Initialize(bool, boost::function<void ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >)>) + 6023
13 AuUI 0x03b56440 aui::ApplicationInitializer::Impl::Initialize(dvaworkspace::workspace ::Workspace*) + 2768
14 AuUI 0x03b4bc3c aui::ApplicationInitializer::Initialize(dvaworkspace::workspace::Work space*) + 28
15 AuUI 0x0353d6d7 aui::Application::InitApplication(exo::app::AppInitArgs&) + 3943
16 com.adobe.exo.framework 0x0194cdf9 exo::app::AppBase::Initialize(exo::app::AppInitArgs&) + 729
17 AuUI 0x0353243e aui::Application::Initialize(exo::app::AppInitArgs&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 158
18 AuUI 0x03555c0f AudMacMain(int, char**) + 415
19 com.adobe.Audition.4.0 0x00002ecd main + 93
20 com.adobe.Audition.4.0 0x00002c66 start + 54
0 libsystem_kernel.dylib 0x978d990a kevent + 10
1 libdispatch.dylib 0x99256e10 _dispatch_mgr_invoke + 969
2 libdispatch.dylib 0x9925585f _dispatch_mgr_thread + 53
Thread 2:
0 libsystem_kernel.dylib 0x978d902e __workq_kernreturn + 10
1 libsystem_c.dylib 0x99159ccf _pthread_wqthread + 773
2 libsystem_c.dylib 0x9915b6fe start_wqthread + 30
Thread 3:
Thread 4:
0 libsystem_kernel.dylib 0x978d883e __psynch_cvwait + 10
1 libsystem_c.dylib 0x9915be78 _pthread_cond_wait + 914
2 libsystem_c.dylib 0x9910382a pthread_cond_wait + 48
3 com.adobe.amt.services 0x06f25274 C_AMTUISwitchSuppressUpdates + 16864
4 com.adobe.amt.services 0x06f1e074 C_EULA_SetState + 2166
5 com.adobe.amt.services 0x06f252da C_AMTUISwitchSuppressUpdates + 16966
6 libsystem_c.dylib 0x99157ed9 _pthread_start + 335
7 libsystem_c.dylib 0x9915b6de thread_start + 34
Thread 5:
Thread 6:
1 libsystem_c.dylib 0x9915be21 _pthread_cond_wait + 827
2 libsystem_c.dylib 0x9910c42c pthread_cond_wait$UNIX2003 + 71
3 com.apple.CoreServices.CarbonCore 0x90e0ae62 TSWaitOnCondition + 124
4 com.apple.CoreServices.CarbonCore 0x90d7c37d TSWaitOnConditionTimedRelative + 136
5 com.apple.CoreServices.CarbonCore 0x90dde67f MPWaitOnQueue + 200
12 libsystem_c.dylib 0x99157ed9 _pthread_start + 335
13 libsystem_c.dylib 0x9915b6de thread_start + 34
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
2 libsystem_c.dylib 0x9910c3e0 pthread_cond_timedwait$UNIX2003 + 70
11 libsystem_c.dylib 0x99157ed9 _pthread_start + 335
12 libsystem_c.dylib 0x9915b6de thread_start + 34
Thread 23:
2 libsystem_c.dylib 0x9915bf7b pthread_cond_timedwait_relative_np + 47
3 com.apple.CoreServices.CarbonCore 0x90d7c3a7 TSWaitOnConditionTimedRelative + 178
4 com.apple.CoreServices.CarbonCore 0x90dde67f MPWaitOnQueue + 200
Thread 24:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x978d6c22 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x978d61f6 mach_msg + 70
2 com.apple.audio.CoreAudio 0x9920e9fe HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned long, unsigned long, mach_msg_header_t*, unsigned int) + 122
3 com.apple.audio.CoreAudio 0x9920ea6a HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, unsigned int) + 60
4 com.apple.audio.CoreAudio 0x99206e5f HALC_ProxyIOContext::IOWorkLoop() + 1145
5 com.apple.audio.CoreAudio 0x99206926 HALC_ProxyIOContext::IOThreadEntry(void*) + 136
6 com.apple.audio.CoreAudio 0x99206898 __HALC_ProxyIOContext_block_invoke_6 + 20
7 com.apple.audio.CoreAudio 0x9920681d HALB_IOThread::Entry(void*) + 69
8 libsystem_c.dylib 0x99157ed9 _pthread_start + 335
9 libsystem_c.dylib 0x9915b6de thread_start + 34
eax: 0x00000000 ebx: 0x900ef330 ecx: 0xbfffe91c edx: 0x978d89c6
edi: 0xaca2f2c0 esi: 0x00000006 ebp: 0xbfffe938 esp: 0xbfffe91c
ss: 0x00000023 efl: 0x00000246 eip: 0x978d89c6 cs: 0x0000000b
cr2: 0x03e952e0
Logical CPU: 0
Binary Images:
0x47fe000 - 0x4808ff3 +com.adobe.boost_filesystem.framework (boost_filesystem version 5.5.0 - 5.5.0.11) <0E6191C4-7881-0F74-7118-1E5E94CE884C> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_filesystem.framework/Versions/ A/boost_filesystem
0x481d000 - 0x489afe2 +com.adobe.boost_regex.framework (boost_regex version 5.5.0 - 5.5.0.11) <0CF74BD7-D9F3-CA91-D6F6-4B56738E4819> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_regex.framework/Versions/A/boo st_regex
0x4901000 - 0x49d5fef +com.adobe.dvaeve.framework (dvaeve version 5.5.0 - 5.5.0.11) <029FE587-C304-DEDB-FC46-6F84D2C75EE4> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
0x4ad2000 - 0x4afeff3 com.apple.audio.CoreAudioKit (1.6.3 - 1.6.3) <7D47B1D3-4410-3524-BC47-FCDF49E48DB5> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudi oKit
0x4b11000 - 0x4ba73a6 +iZotope_Radius (??? - ???) <B6AF5A0A-6CFD-4298-8450-9FD830471654> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/iZotope_Radius.framework/Versions/A/ iZotope_Radius
0x4be4000 - 0x4c3affb +com.adobe.headlights.LogSessionFramework (??? - 2.1.2.1263) <5B594BC9-5222-651B-6B70-7AD067035B1A> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/LogSession.framework/Versions/A/LogS ession
0x4c83000 - 0x4f11fec +libxerces-c-3.0.dylib (??? - ???) <CDE6FF46-6D9A-55B9-7DF8-CEB48EBB54B9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/libxerces-c-3.0.dylib
0x5094000 - 0x5141ff7 libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <7B6DB792-C9E5-3772-8734-8D0052757B8C> /usr/lib/libcrypto.0.9.7.dylib
0x5186000 - 0x52a9ff7 +AdobeACE (??? - ???) <6B4856DC-3D41-CEF7-CB70-D02EEA97B8D2> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeA CE
0x52cc000 - 0x59a6ff3 +AdobeAGM (??? - ???) <FE943B4D-ED58-F753-8AE8-54E753A773BD> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeA GM
0x5a6b000 - 0x5a88ff7 +AdobeBIB (??? - ???) <6CC35ACF-5CCD-1509-B4BB-3B48AD140526> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeB IB
0x5a8f000 - 0x5ab5ffb +AdobeBIBUtils (??? - ???) <B9888BEE-A939-50E3-1CD3-3313AC14A073> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/A dobeBIBUtils
0x5abc000 - 0x5debff3 +com.adobe.CoolType (AdobeCoolType 5.10.7.10201 - 5.10.7.10201) <6810A678-B1DF-F96D-2560-25AE3FDA923A> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/A dobeCoolType
0x5e3d000 - 0x5eabffb +com.adobe.amtlib (amtlib 4.0.0.21 - 4.0.0.21) <3090D254-587A-A820-DBCD-729C27532FC8> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x5ec2000 - 0x5ec6fff +com.adobe.dvaflashview.framework (dvaflashview version 5.5.0 - 5.5.0.11) <98E23B9D-1CF1-E412-FD26-1EDE5BBD3DF9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dv aflashview
0x5ed1000 - 0x5ed4ffc +com.adobe.ape.shim (adbeape version 3.1.74.12761 - 3.1.74.12761) <FE2ABE8A-1D3F-7AF5-297C-D22FC3E0FBDA> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
0x6a8c000 - 0x6a94fff +com.adobe.asneu.framework (asneu version 1.7.0.1 - 1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
0x6aed000 - 0x6af1ffb com.apple.audio.AudioIPCPlugIn (1.2.2 - 1.2.2) <E6982BB2-BEC8-3232-989D-B3D5B26AE0DF> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/Aud ioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x6af6000 - 0x6afbfff com.apple.audio.AppleHDAHALPlugIn (2.2.0 - 2.2.0f3) <BAD1E0E6-10E6-342C-BEB8-B1706F0CE2CF> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x6f00000 - 0x6f6bfe7 +com.adobe.amt.services (AMTServices 4.0.0.21 [BuildVersion: 4.0; BuildDate: Mon Jan 24 2011 21:49:00] - 4.0.0.21) <018F21DE-7E2E-C850-4C32-D4A2131ABF74> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/amtservices.framework/Versions/A/amt services
0x6f87000 - 0x6fb0fef +com.adobe.ape (adbeapecore version 3.1.74.12761 - 3.1.74.12761) <21548488-E9C3-4638-D7FC-895EE0F8EE30> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
0x6fc8000 - 0x6fc9ff1 com.apple.textencoding.unicode (2.4 - 2.4) <4E55D4B9-4E67-3FC9-9407-3E99D1D50F15> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x8c00000 - 0x8c70feb +com.adobe.adobe_caps (adobe_caps 4.0.42.0 - 4.0.42.0) <55D7D2EA-D21E-98B1-77C6-58C0A0E07051> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adob e_caps
0x8feb1000 - 0x8fee3aa7 dyld (195.6 - ???) <3A866A34-4CDD-35A4-B26E-F145B05F3644> /usr/lib/dyld
0x900de000 - 0x900e6fff com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
0x900e7000 - 0x900f0fff libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
0x90239000 - 0x90244ff3 libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <EDA0F56F-CB2C-30BB-940D-C6A25B73C717> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x90245000 - 0x90246fff com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
0x902ef000 - 0x90304fff com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x9032f000 - 0x90365ff4 com.apple.LDAPFramework (3.2 - 120.2) <39DF72E3-CDAF-33CC-B2DA-67B8891A5CFF> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x90366000 - 0x9051aff3 libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib
0x90531000 - 0x905d5fff com.apple.QD (3.40 - ???) <3881BEC6-0908-3073-BA44-346356E1CDF9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
0x905d6000 - 0x90ab2ff6 libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
0x90ae7000 - 0x90b15fe7 libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <30189C33-6ADD-3142-83F3-6114B1FC152E> /usr/lib/libSystem.B.dylib
0x90b16000 - 0x90b36ff7 com.apple.RemoteViewServices (1.4 - 44.1) <1F831750-1E77-3013-B1A6-0DF528623790> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versio ns/A/RemoteViewServices
0x90b37000 - 0x90b4dffe libxpc.dylib (77.19.0 - compatibility 1.0.0) <0585AA94-F4FD-32C1-B586-22E7184B781A> /usr/lib/system/libxpc.dylib
0x90b4e000 - 0x90b4efff com.apple.Cocoa (6.6 - ???) <5FAFE73E-6AF5-3D09-9191-0BDC8C6875CB> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x90b71000 - 0x90b79ff3 liblaunch.dylib (392.38.0 - compatibility 1.0.0) <D7F6E875-263A-37B5-B403-53F76710538C> /usr/lib/system/liblaunch.dylib
0x90b7a000 - 0x90b81ff9 libsystem_dnssd.dylib (??? - ???) <D3A766FC-C409-3A57-ADE4-94B7688E1C7E> /usr/lib/system/libsystem_dnssd.dylib
0x90bb6000 - 0x90bc1ffe com.apple.NetAuth (3.2 - 3.2) <4377FB18-A550-35C6-BCD2-71C42134EEA6> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAut h
0x90d23000 - 0x90d3dfff com.apple.Kerberos (1.0 - 1) <D7920A1C-FEC4-3460-8DD0-D02491578CBB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x90d3e000 - 0x91040fff com.apple.CoreServices.CarbonCore (960.24 - 960.24) <9692D838-85A5-32C1-B7FB-7C141FFC2557> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
0x916bd000 - 0x9174aff7 com.apple.CoreText (220.20.0 - ???) <0C3EDD4F-6112-353A-8A3A-8D630182C22A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
0x9174b000 - 0x9174fff3 libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
0x91792000 - 0x917c1ff7 libsystem_info.dylib (??? - ???) <37640811-445B-3BB7-9934-A7C99848250D> /usr/lib/system/libsystem_info.dylib
0x917c2000 - 0x917d2ff7 libCRFSuite.dylib (??? - ???) <94E040D2-2769-359A-A21B-DB85FCB73BDC> /usr/lib/libCRFSuite.dylib
0x917d3000 - 0x917d4fff libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
0x917d5000 - 0x917d6ff7 libsystem_sandbox.dylib (??? - ???) <EBC6ED6B-7D94-32A9-A718-BB9EDA1732C9> /usr/lib/system/libsystem_sandbox.dylib
0x917d7000 - 0x91939ffb com.apple.QuartzCore (1.7 - 270.4) <6BC84C60-1003-3008-ABE4-779EF7B4F524> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x919b4000 - 0x91a18fff com.apple.framework.IOKit (2.0 - ???) <88D60E59-430D-35B8-B1E9-F5138301AEF9> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x91a2a000 - 0x91a6aff7 com.apple.NavigationServices (3.7 - 193) <16A8BCC8-7343-3A90-88B3-AAA334DF615F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
0x91a6b000 - 0x91a8dffe com.apple.framework.familycontrols (3.0 - 300) <5BCCDDC2-AFAC-3290-AEEF-23B2664CA11F> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
0x91a8e000 - 0x91ae9ff3 com.apple.Symbolication (1.3 - 91) <4D12D2EC-5010-3958-A205-9A67E972C76A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/ Symbolication
0x91aea000 - 0x91b4cffb com.apple.datadetectorscore (3.0 - 179.4) <3A418498-C189-37A1-9B86-F0ECB33AD91C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
0x91b50000 - 0x91b72ff8 com.apple.PerformanceAnalysis (1.11 - 11) <453463FF-7C42-3526-8C96-A9971EE07154> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versi ons/A/PerformanceAnalysis
0x91b73000 - 0x91bb1fff libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <19174EC0-DE0F-38EA-B5F3-7580E84677DD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x91c29000 - 0x91c2dffa libcache.dylib (47.0.0 - compatibility 1.0.0) <56256537-6538-3522-BCB6-2C79DA6AC8CD> /usr/lib/system/libcache.dylib
0x92082000 - 0x92345fff com.apple.security (7.0 - 55148.1) <77754898-4FCD-3CA3-9339-F1058C852806> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x92346000 - 0x92356fff libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <D6F728DA-990A-32A3-86FA-4A3F4D88E309> /usr/lib/libsasl2.2.dylib
0x9276a000 - 0x92a74ff3 com.apple.Foundation (6.7.2 - 833.25) <4C52ED74-A1FD-3087-A2E1-035AB3CF9610> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92aba000 - 0x92b18fff com.apple.coreui (1.2.2 - 165.10) <C6B099D6-7F02-3971-99B9-E415308959CF> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x92b1e000 - 0x92bb4ff7 com.apple.LaunchServices (480.33 - 480.33) <5A4BF529-391E-3987-940E-287ACE56078A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
0x92bc4000 - 0x92c15ff9 com.apple.ScalableUserInterface (1.0 - 1) <3C39DF4D-5CAE-373A-BE08-8CD16E514337> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x92c16000 - 0x92d34fec com.apple.vImage (5.1 - 5.1) <7757F253-B281-3612-89D4-F2B04061CBE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
0x92d35000 - 0x92d43fff com.apple.opengl (1.7.7 - 1.7.7) <2D362F15-5EA6-37B6-9BCB-58F2C599ACDA> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x92e41000 - 0x92e44ffb com.apple.help (1.3.2 - 42) <B1E6701C-7473-30B2-AB5A-AFC9A4823694> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
0x92e45000 - 0x92ea7ff3 libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
0x92ef3000 - 0x92f45ff7 libFontRegistry.dylib (??? - ???) <96E9602C-DFD3-3021-8090-60228CC80D26> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x92f46000 - 0x92f83ff7 libcups.2.dylib (2.9.0 - compatibility 2.0.0) <1C757924-4E54-3522-A885-99795EA10228> /usr/lib/libcups.2.dylib
0x92f84000 - 0x92f8bfff com.apple.agl (3.2.0 - AGL-3.2.0) <ED5A5B8A-0014-3897-951F-628391333256> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x92f98000 - 0x9307bff7 libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <BD913D3B-388D-33AE-AA5E-4810C743C28F> /usr/lib/libcrypto.0.9.8.dylib
0x93112000 - 0x93135fff com.apple.CoreVideo (1.7 - 70.3) <4234C11C-E8E9-309A-9465-27D6D7458895> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x93445000 - 0x93446ff0 libunc.dylib (24.0.0 - compatibility 1.0.0) <2F4B35B2-706C-3383-AA86-DABA409FAE45> /usr/lib/system/libunc.dylib
0x93447000 - 0x93849ff6 libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
0x9384a000 - 0x9384efff libGIF.dylib (??? - ???) <A6F1ACAE-7B9B-3B3F-A54A-ED4004EA1D85> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x9384f000 - 0x93850fff libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
0x939e7000 - 0x93a0cff9 libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x93a0d000 - 0x93a75ff7 libc++.1.dylib (28.1.0 - compatibility 1.0.0) <FE3304C5-C000-3DA0-9E53-0E4CA074B73B> /usr/lib/libc++.1.dylib
0x93a76000 - 0x93a9eff7 libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <AB530FB2-8BD1-3328-95E8-CF449F0429CA> /usr/lib/libxslt.1.dylib
0x93a9f000 - 0x93bb0ff7 libJP2.dylib (??? - ???) <845C74F4-1074-3983-945F-EB669538CAA9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x93f6c000 - 0x93f6dffd libCVMSPluginSupport.dylib (??? - ???) <22B85645-AA98-372B-BB55-55DCCF0EC716> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC VMSPluginSupport.dylib
0x93f8d000 - 0x93f92ff7 libmacho.dylib (800.0.0 - compatibility 1.0.0) <943213F3-CC9B-328E-8A6F-16D85C4274C7> /usr/lib/system/libmacho.dylib
0x93fb1000 - 0x93ffaff7 libGLU.dylib (??? - ???) <5EE0B644-FAD6-3E3C-A380-9B0CDA0B6432> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
0x94001000 - 0x940e9fff libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <1841196F-68B5-309F-8ED1-6714B1DFEC83> /usr/lib/libxml2.2.dylib
0x940ea000 - 0x94120ff7 com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
0x94385000 - 0x943aeffe com.apple.opencl (1.50.69 - 1.50.69) <2601993F-F3B3-3737-91AE-4A5795C52CD5> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x94418000 - 0x944b4fef com.apple.ink.framework (1.4 - 110) <1A3E2916-60C1-3AC1-86BF-202F6567B228> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
0x944b5000 - 0x944b5fff com.apple.Carbon (153 - 153) <63603A0C-723B-3968-B302-EBEEE6A14E97> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x944b6000 - 0x944cbff7 com.apple.ImageCapture (7.0.1 - 7.0.1) <1C8933A9-C7C6-36E9-9D8B-0EF08ACA3315> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
0x944cc000 - 0x94542fff com.apple.Metadata (10.7.0 - 627.32) <650EE880-1488-3DC6-963B-F3D6E043FFDC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
0x945d0000 - 0x945d4ff7 com.apple.OpenDirectory (10.7 - 146) <4986A382-8FEF-3392-8CE9-CF6A5EE4E365> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
0x9485d000 - 0x94860ffc libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
0x94861000 - 0x948b1ff8 libTIFF.dylib (??? - ???) <4DC2025D-15E7-35CA-B7C5-9F73B26C8B53> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x948bd000 - 0x949ccfff com.apple.DesktopServices (1.6.3 - 1.6.3) <18CAAA9E-7065-3FF7-ACFE-CDB60E5426A2> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
0x954b0000 - 0x954c1fff libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
0x95514000 - 0x95517ff9 libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <1211BEEB-31C9-3A5D-9E71-10FC4A541D1E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
0x9565b000 - 0x956c0ff7 libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
0x956c1000 - 0x956c4ffd libCoreVMClient.dylib (??? - ???) <361CCFAF-8565-383F-915F-0B059C793E42> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
0x9639e000 - 0x963b1ff8 com.apple.MultitouchSupport.framework (231.4 - 231.4) <083F7787-4C3B-31DA-B5BB-1993D9A9723D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
0x964c4000 - 0x96551fe7 libvMisc.dylib (325.4.0 - compatibility 1.0.0) <F2A8BBA3-6431-3CED-8CD3-0953410B6F96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
0x96552000 - 0x965afffb com.apple.htmlrendering (76 - 1.1.4) <409EF0CB-2997-369A-9326-BE12436B9EE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
0x965b0000 - 0x965b4fff com.apple.CommonPanels (1.2.5 - 94) <EA47550D-7DAF-30D9-91DB-1FB594CC8522> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
0x968fc000 - 0x9693dff9 libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <9FD420FB-7984-3A07-8914-BB19E687D38B> /usr/lib/libcurl.4.dylib
0x9694c000 - 0x9694cfff com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
0x9694d000 - 0x9694eff7 libquarantine.dylib (36.6.0 - compatibility 1.0.0) <600909D9-BD75-386E-8D3E-7CBD29079DF3> /usr/lib/system/libquarantine.dylib
0x9694f000 - 0x9696bffc libPng.dylib (??? - ???) <75F41C08-E187-354C-8115-79387F57FC2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x9696c000 - 0x9729659b com.apple.CoreGraphics (1.600.0 - ???) <62026E0C-E30F-3FF0-B0F6-6A2D270B20BF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9760c000 - 0x97654ff7 com.apple.SystemConfiguration (1.11.3 - 1.11) <68B92FEA-F754-3E7E-B5E6-D512E26144E7> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
0x9767a000 - 0x9767aff0 com.apple.ApplicationServices (41 - 41) <C48EF6B2-ABF9-35BD-A07A-A38EC0008294> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
0x976a2000 - 0x9772cffb com.apple.SearchKit (1.4.0 - 1.4.0) <CF074082-64AB-3A1F-831E-582DF1667827> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
0x9777c000 - 0x9783cffb com.apple.ColorSync (4.7.4 - 4.7.4) <0A68AF35-15DF-3A0A-9B17-70CE2A106A6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
0x97885000 - 0x9788dff3 libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
0x978c0000 - 0x978deff7 libsystem_kernel.dylib (1699.26.8 - compatibility 1.0.0) <3705DE40-E00F-3E37-ADB0-D4AE5F9950F5> /usr/lib/system/libsystem_kernel.dylib
0x978df000 - 0x978edff7 libxar-nossl.dylib (??? - ???) <5BF4DA8E-C319-354A-967E-A0C725DC8BA3> /usr/lib/libxar-nossl.dylib
0x978ee000 - 0x978f8ff2 com.apple.audio.SoundManager (3.9.4.1 - 3.9.4.1) <2A089CE8-9760-3F0F-B77D-29A78940EA17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
0x978f9000 - 0x97939ff7 libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
0x9793a000 - 0x97a0affb com.apple.ImageIO.framework (3.1.2 - 3.1.2) <94798A2B-4C7A-30EA-9920-283451BDB9FA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
0x97a0b000 - 0x984a0ff6 com.apple.AppKit (6.7.3 - 1138.47) <D8CD06D7-F18C-39BE-BC68-B343F87F0469> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x984a1000 - 0x98528fff com.apple.print.framework.PrintCore (7.1 - 366.3) <EEC03CAB-7F79-3931-87FE-4DF0B767BF47> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
0x98529000 - 0x98655ff9 com.apple.CFNetwork (520.4.3 - 520.4.3) <E9E315D4-CE22-3715-BED2-BB95AD5E10E8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
0x98657000 - 0x98747ff1 libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
0x987db000 - 0x9881effd libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <6B35F203-5D72-335A-A4BC-CC89FEC0E14F> /usr/lib/system/libcommonCrypto.dylib
0x988a2000 - 0x988b2fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x98900000 - 0x9897bffb com.apple.ApplicationServices.ATS (317.11.0 - ???) <42238C8B-C93F-3369-A500-EC0F10EB2C80> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
0x9897c000 - 0x9897cffe libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
0x98c8d000 - 0x98d85ff7 libFontParser.dylib (??? - ???) <1A0DA421-62B2-3AA7-9F62-0E01C1887D09> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x98d86000 - 0x98dbaff8 libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <567E922C-E64F-321B-9A47-6B18BF481625> /usr/lib/libssl.0.9.8.dylib
0x990eb000 - 0x990f8fff libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
0x990fb000 - 0x991c6fff libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <52421B00-79C8-3727-94DE-62F6820B9C31> /usr/lib/system/libsystem_c.dylib
0x991c7000 - 0x991f1ff1 com.apple.CoreServicesInternal (113.17 - 113.17) <41979516-2F26-3707-A6CA-7A95A1B0D963> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Vers ions/A/CoreServicesInternal
0x991f2000 - 0x99253ffb com.apple.audio.CoreAudio (4.0.2 - 4.0.2) <E617857C-D870-3E2D-BA13-3732DD1BC15E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x99254000 - 0x99262fff libdispatch.dylib (187.9.0 - compatibility 1.0.0) <2F918480-12C8-3F22-9B1A-9B2D76F6F4F5> /usr/lib/system/libdispatch.dylib
0x99263000 - 0x99264fff liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
0x993d7000 - 0x993dbffd IOSurface (??? - ???) <EDDBEE65-1EB8-33A7-9972-E361A3508234> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x994bd000 - 0x994c6ff3 com.apple.CommonAuth (2.2 - 2.0) <C3FD6EC2-8EB3-38FB-BBB7-05009CA49024> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/Com monAuth
0x9973b000 - 0x997fefff com.apple.CoreServices.OSServices (478.46 - 478.46) <F2063FC8-2BE1-3B97-98AF-8796B0D4BE58> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
0x99eb7000 - 0x99ebdffd com.apple.CommerceCore (1.0 - 17) <E59CD307-58E2-35FD-9131-B38978799910> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
0x99ecd000 - 0x99edbfff libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
0x99edf000 - 0x99eeafff libkxld.dylib (??? - ???) <D8ED88D0-7153-3514-9927-AF15A12261A5> /usr/lib/system/libkxld.dylib
0x99efc000 - 0x99efcfff com.apple.audio.units.AudioUnit (1.7.2 - 1.7.2) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x99efd000 - 0x99efeff4 libremovefile.dylib (21.1.0 - compatibility 1.0.0) <6DE3FDC7-0BE0-3791-B6F5-C15422A8AFB8> /usr/lib/system/libremovefile.dylib
0x99eff000 - 0x99f0affb com.apple.speech.recognition.framework (4.0.21 - 4.0.21) <A1764D2F-EB84-33DC-9ED5-CDA3B468FF3E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
0x99f0b000 - 0x9a17effb com.apple.CoreImage (7.98 - 1.0.1) <EDC91BA1-673D-3B47-BFD5-BBF11C36EE6A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /CoreImage.framework/Versions/A/CoreImage
0x9a17f000 - 0x9a5f4ff7 FaceCoreLight (1.4.7 - compatibility 1.0.0) <3E2BF587-5168-3FC5-9D8D-183A9C7C1DED> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/ FaceCoreLight
0x9a5f5000 - 0x9a7edff7 com.apple.CoreData (104.1 - 358.14) <C1730963-F75D-3338-B65F-D50235538B28> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9a7ee000 - 0x9a9c5fe7 com.apple.CoreFoundation (6.7.2 - 635.21) <4D1D2BAF-1332-32DF-A81B-7E79D4F0A6CB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
0x9a9cc000 - 0x9ad12ff3 com.apple.HIToolbox (1.9 - ???) <409E6397-0DCB-3431-9CCC-368317C62545> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
0x9ad50000 - 0x9ad55ffd libGFXShared.dylib (??? - ???) <1CA9B41B-2C61-38F8-ABAC-1D5511478F5C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
0x9addc000 - 0x9addcfff libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <7EFAD88C-AFBC-3D48-BE14-60B8EACC68D7> /usr/lib/system/libdnsinfo.dylib
0x9addd000 - 0x9addfffb libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x9b057000 - 0x9b074ff3 com.apple.openscripting (1.3.3 - ???) <33713C0B-B7D5-37AA-87DB-2727FDCC8007> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
0x9b0ba000 - 0x9b0e8ff7 com.apple.DictionaryServices (1.2.1 - 158.2) <DA16A8B2-F359-345A-BAF7-8E6A5A0741A1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9b0f1000 - 0x9b0f1fff com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9b0f2000 - 0x9b0f4ff9 com.apple.securityhi (4.0 - 1) <ACEEED5F-8D58-377D-B2B8-E4A7F4E5E286> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
0x9b0f5000 - 0x9b14efff com.apple.HIServices (1.21 - ???) <5F4D3797-32E2-3709-85F4-4B56515A17D7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
0x9b14f000 - 0x9b2a1fff com.apple.audio.toolbox.AudioToolbox (1.7.2 - 1.7.2) <E369AC9E-F548-3DF6-B320-9D09E486070E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
0x9b2a2000 - 0x9b339ff3 com.apple.securityfoundation (5.0 - 55116) <EB53CEF7-4836-39FD-B012-6BC122ED4CE9> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
0x9b33a000 - 0x9b345ffe libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <B63F5D07-93B3-3F02-BFB7-472B4ED3521F> /usr/lib/libbz2.1.0.dylib
0x9b346000 - 0x9b382ffa libGLImage.dylib (??? - ???) <504E7865-571E-38B4-A84A-D7B513AC84F5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
0x9b384000 - 0x9b3a0ff5 com.apple.GenerationalStorage (1.0 - 126.1) <E622F823-7D98-3D13-9C3D-7EA482567394> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versi ons/A/GenerationalStorage
0x9b3a1000 - 0x9b3b5fff com.apple.CFOpenDirectory (10.7 - 146) <9149C1FE-865E-3A8D-B9D9-547384F553C8> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x9b50d000 - 0x9b581fff com.apple.CoreSymbolication (2.2 - 73.2) <FA9305CA-FB9B-3646-8C41-FF8DF15AB2C1> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Version s/A/CoreSymbolication
0x9b5db000 - 0x9b5deff7 libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
0x9b5df000 - 0x9b64efff com.apple.Heimdal (2.2 - 2.0) <2E1B8779-36D4-3C62-A67E-0034D77D7707> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimda l
0x9b64f000 - 0x9b67afff com.apple.GSS (2.2 - 2.0) <2C468B23-FA87-30B5-B9A6-8C5D1373AA30> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x9b92e000 - 0x9b935ffd com.apple.NetFS (4.0 - 4.0) <AE731CFE-1B2E-3E46-8759-843F5FB8C24F> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x9b936000 - 0x9b93dff7 libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
0x9b93e000 - 0x9b95bfff libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <2870320A-28DA-3B44-9D82-D56E0036F6BB> /usr/lib/libresolv.9.dylib
0x9b95c000 - 0x9b993fef com.apple.DebugSymbols (2.1 - 87) <EB951B78-31A5-379F-AFA1-B5C9A7BB3D23> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/D ebugSymbols
0x9b99c000 - 0x9b99eff7 libdyld.dylib (195.6.0 - compatibility 1.0.0) <1F865C73-5803-3B08-988C-65B8D86CB7BE> /usr/lib/system/libdyld.dylib
0x9babe000 - 0x9bac1ff7 libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
0x9bb15000 - 0x9bb1dff5 libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <BB0C7B49-600F-3551-A460-B7E36CA4C4A4> /usr/lib/system/libcopyfile.dylib
0x9bdcc000 - 0x9bdccfff com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9cb1e000 - 0x9cb24ffb com.apple.print.framework.Print (7.4 - 247.3) <CB075EEE-FA1F-345C-A1B5-1AB266FC73A1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
0x9cb9d000 - 0x9ccadfe7 libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <34E1E3CC-7B6A-3B37-8D07-1258D11E16CB> /usr/lib/libsqlite3.dylib
0x9ccae000 - 0x9ccaeff2 com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
0x9ce97000 - 0x9cf6daab libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <2E272DCA-38A0-3530-BBF4-47AE678D20D4> /usr/lib/libobjc.A.dylib
task_for_pid: 2
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 3735
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=219.6M resident=105.4M(48%) swapped_out_or_unallocated=114.2M(52%)
Writable regions: Total=139.4M written=6536K(5%) resident=10.8M(8%) swapped_out=0K(0%) unallocated=128.6M(92%)
REGION TYPE VIRTUAL
CG raster data 860K
CG shared images 1224K
CoreGraphics 8K
CoreServices 3724K
MALLOC 80.8M
Memory tag=243 8K
Stack 76.2M
VM_ALLOCATE 1004K
__CI_BITMAP 80K
__DATA 13.3M
__DATA/__OBJC 224K
__IMAGE 528K
__IMPORT 284K
__LINKEDIT 76.5M
__OBJC 1460K
__PAGEZERO 4K
__TEXT 143.1M
__UNICODE 544K
mapped file 145.8M
shared memory 364K
shared pmap 10.6M
TOTAL 590.7M
TOTAL, minus reserved VM space 557.3M
Model: MacBookPro8,2, BootROM MBP81.0047.B27, 4 processors, Intel Core i7, 2.2 GHz, 8 GB, SMC 1.69f3
Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 1024 MB
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 512 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333531533642465238432D48392020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333531533642465238432D48392020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.198.4.20)
Bluetooth: Version 4.0.5f11, 2 service, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: Hitachi HTS725050A9A362, 500.11 GB
Serial ATA Device: MATSHITADVD-R UJ-8A8
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfa100000 / 3
USB Device: USB Mouse, 0x0d62 (Darfon Electronics Corp.), 0xa100, 0xfa130000 / 6
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0245, 0xfa120000 / 5
USB Device: BRCM2070 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 4
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821a, 0xfa113000 / 7
USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0xfa200000 / 2
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfd100000 / 2
USB Device: Desktop, 0x0bc2 (Seagate LLC), 0x3300, 0xfd120000 / 4
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd110000 / 3
FireWire Device: GoFlex Desk, Seagate, 800mbit_speed
Please help thanks
For this crash report, it looks like the Favorites file is corrupt. You might want to email that .xml file in the preference folder to audbugs@adobe.com such that the team can investigate. Otherwise, probably deleting your prefs file might help your crash on startup.
