Export to IOS5
Oct 25, 2011 4:31 PM
Tags: #dreamweaver #export #ios #ipad #phonegap
I'm trying to export a Dreamweaver built website to an Ipad that has IOS 5. I have the latest version of Dreamweaver CS5.5, XCode, and PhoneGap, but am unable to get a working copy of the webpage. Even a simple, "Hello World" site in HTML5 doesn't work.
After setting up the /Developer path, Instructions say to click Site > Mobile Applications > Build > IPad, however I get an error message that says, "The build of "Hello World" failed to complete successfully. Please consult the build log at Users/UserProfile/Desktop/com.performance.hello_world_ios/buildlog.lo g for additional details. What could go wrong in such a simple export?
    Oct 26, 2011 4:16 AM   in reply to DFerri916
    I know absolutely nothing about this operation, but I'm just curious if you have consulted that mentioned log file?
    Nov 1, 2011 8:52 PM   in reply to DFerri916
    I had two problems with my PhoneGap, one for IOS5 and one for Android
    The fix for the IOS5 problem that worked for me was in the Camera.h file
    Although I found many on my system (leading me to believe that a base Camera.h is copied for each project), The one I found to modify for my project was in:
    Users/london1a1/Documents/DW_NAF/PhoneGapLib/PhoneGapLib/Classes/Camera.h
    Find this code in the file:
    @interface CameraPicker : UIImagePickerController
         NSString* successCallback;
         NSString* errorCallback;
         NSInteger quality;
         NSString* postUrl;
        enum DestinationType returnType;
    and change it to this  (note the lines that change are bolded):
         NSInteger quality;
         NSString* postUrl;
         enum DestinationType;
         enum returnType;
    The original reference where I found the fix can be found here:
    http://osdir.com/ml/phonegap/2011-10/msg00918.html
    Although it's not part of your question, but more in the hope that someone else who is experiencing both issues with the IOS and Android find this response:
    The error I got for the PhoneGap / Android environment was:
    Dreamweaver is unable to open X in the emulator. Please consult the build log at /Users/.../buildlog.log for additional details.
    The answer I found was here:
    http://forums.adobe.com/message/3997853?tstart=0
    and involves tweaking the build.xml file and adding just two elements.
    I hope this helps.
    Nov 5, 2011 6:23 AM   in reply to DFerri916
    I've been having the same problem (build failed to complete successfully). I have a complex jquery mobile site--with several videos included--that I was trying to convert to an app now that I've upgraded to DW 5.5. I thought maybe I was overwhelming the DW PhoneGap feature, so I built a basic jquery mobile page in which I only changed the wording of the Page One, Page Two, etc. text. Then I tried using the app feature. Same error. I wish these things always worked as smoothly as they seem to on the Adobe Greg Rewis tutorials.
    Nov 13, 2011 4:24 PM   in reply to london1a1
    I made the change. However, Camera.h changes back to its original every time I build the app. How can I avoid that? Thanks in advance.
    Nov 14, 2011 4:38 PM   in reply to DFerri916
    I also have the same problem. If I save Camera.h and then publish through Dreamweaver again, Camera.h resets back to the original state.
    Nov 14, 2011 4:57 PM   in reply to djr328
    Don't forget to end each line with ';' (semi-column). Then it will stick.
    Dec 9, 2011 3:55 PM   in reply to DFerri916
    I'm having the very same problem.
    When I first installed Dreamweaver CS5.5, I was running OSX Snow Leopard, and I never had a problem building & emulating the Phonegap apps that I wrote.
    Since that time, I've updated to OSX Lion, and I haven't been able to build & emulate without getting the "failed to complete successfully" error message.
    I just called Adobe tech support, and the best they could offer was to suggest I post my problem to this site.  It sounded like they had never heard of this problem.
    FWIW, I tried modifying the Camera.h file as suggested on this thread, to no avail.
    Dec 11, 2011 6:49 AM   in reply to The German
    Hey,
    You may copy the Camera.h into another folder, make the changes then paste it back in the /Documents/DW_NAF/PhoneGapLib/PhoneGapLib/Classes/ folder replacing the original file, this way you can keep your changes.
    But even making the changes:
    to
    enum returnType;
    I still get the same problem.
    Running Snow Leopard.
    Waiting solutions...
    Dec 17, 2011 12:49 PM   in reply to london1a1
    Thank you so much! yes I was also having the exact same two problems, I had to edit the build file for Android and seperate the two enums in the camera header file for IOS, and now im up and running.
    Dec 30, 2011 8:22 PM   in reply to DFerri916
    If you have done the phonegap update to the current 1.3 version then go through all your camera.h files and make sure they all have
    @proprerty (nonatomic) enum destinationType returnType;
    with the camerapicker block then everything should work great I upgraded my phonegap to 1.3 and my dreamweaver to the 11.5 5344 version as well as i always run the latest Xcode and I hade the same error that you were getting and this is what I came upi with after countless hours of research and trial and error.
    Jan 3, 2012 1:58 AM   in reply to DFerri916
    london1a1's workaround seems to work fine. I've been having the same problems. Changed the Camera.h file, now everything works. I had to do the same type of workaround to get Android to also work.
    Jan 11, 2012 9:41 PM   in reply to london1a1
    Hello everyone.
    Wll it's January 11 2012, and has anyone found an answer to the non building problems.
    Jan 25, 2012 1:52 PM   in reply to DFerri916
    Hello!
    I just finally got it working.
    Here is how:
    Go to  /Applications/Adobe Dreamweaver CS5.5/Configuration/NativeAppFramework/DWPhoneGap/iphone/PhoneGapLib/ Classes/
    Open Camera.h and modify from
    to
    enum returnType;
    Then go to  YourUsername/Documents/DW_NAF/PhoneGapLib/PhoneGapLib/Classes/
    and modify it there too.
    Hope this helps!
    Best Regards,
    Cerpow.
    Mar 14, 2012 9:25 AM   in reply to london1a1
    Thank you so much, it works perfectly.
