How to implement a secure authentication model to a Flex 4 / CF9 app?
Oct 26, 2011 7:52 AM
Tags: #flex #authentication #cf9 #token
Hi all
been searching without finding a lot of clarity on the matter
I'm building a flex application that communicates through flash remoting with CF9 cfc methods
I want to make sure my some cfc methods are accessible only by authenticated users
how do I prevent from someone bypassing the flex interface and calling them directly?
I'm looking for the simplest way to implement it
I'd prefer not to use cookies
is then an easy built-in mechanism / tutorial to implement?
it sounds like it make sense to authenticate a user and have cf return an accsess token that would be kept on the server
so does it mean that each flex call to cf should include this token?
what about the cfc's? do I need to construct a central cfc to rout all calls and check the access token before routing & processing any DB query?
I would REALLY appeciate a clean minimal solution
thanks a million
cosmits
    Jan 11, 2012 10:54 AM   in reply to cosmits
    Hi - did you find a solution ? I am on the same way and am interested in that topic.
    Thanks & Regards
