No Filters in AIR for iOS?
Oct 26, 2011 7:44 PM
Tags: #air #flash #for #cs5.5 #3.0 #ios #overlay #fail #filters
Using the AIR 3.0 overlay and exporting to iOS from CS5.5.  All is well (super cool actually) however the drop shadow filter is failing to work.  Is fine if I publish as swf or projector.
Any tips?
Thnaks,
Dave
CODE
__________
import flash.net.SharedObject;
import flash.filters.DropShadowFilter;
var path = MovieClip(this.root).main;
var gap:Number = 20;
var hostName:String = "theHost";
var username:String;
var fadeBackAmount:Number = .4;
var myFont = new ExpoDFont();
var myFormat:TextFormat = new TextFormat();
myFormat.size = 15;
myFormat.align = TextFormatAlign.CENTER;
myFormat.bold = true;
myFormat.font = myFont.fontName;
doneBut.addEventListener(MouseEvent.CLICK, finishedEditing);
/*saveBut.addEventListener(MouseEvent.CLICK, saveIt);
clearBut.addEventListener(MouseEvent.CLICK, clearIt);
loadBut.addEventListener(MouseEvent.CLICK, loadIt);
saveBut.buttonMode = true;
clearBut.buttonMode = true;
loadBut.buttonMode = true;*/
var dropShadow:DropShadowFilter = new DropShadowFilter();
dropShadow.distance = 0;
dropShadow.angle = 45;
dropShadow.color = 0x333333;
dropShadow.alpha = 1;
dropShadow.blurX = 10;
dropShadow.blurY = 10;
dropShadow.strength = 2;
dropShadow.quality = 15;
dropShadow.inner = false;
dropShadow.knockout = false;
dropShadow.hideObject = false;
makeThumbs();
function makeThumbs() {
          for (var i:uint=0; i<path.pagesFlow1.length; i++) {
                    var th = new MovieClip();
                    var bitmap:Bitmap = new Bitmap();
                    var mc = new(path.pagesFlow1[i]);
                    var bData:BitmapData = new BitmapData(1024,768);
                    th.tBmap = bitmap;
                    bData.draw( mc );
                    bitmap.bitmapData = bData;
                    bitmap.filters = new Array(dropShadow);
                    th.addChild(bitmap);
                    th.scaleX = .1;
                    th.scaleY = th.scaleX;
                    th.x = th.width * i + gap * i;
                    th.buttonMode = true;
                    th.name = getQualifiedClassName((path.pagesFlow1[i]));
                    var myText:TextField = new TextField();
                    myText.defaultTextFormat = myFormat;
                    myText.text = th.name;
                    myText.selectable = false;
                    myText.mouseEnabled = false;
                    myText.wordWrap = true;
                    myText.textColor = 0xCCCCCC;
                    //myText.scaleX = 1;
                    //myText.scaleY = myText.scaleX;
                    myText.width = th.width;
                    myText.height = 40;
                    myText.x = th.width * i + gap * i;
                    myText.y = th.y + th.height / 4;
                    addChild(th);
                    addChild(myText);
                    th.addEventListener(MouseEvent.CLICK,doThumbClick);
                    if (isThumbExcluded(th)) {
                              bitmap.alpha = fadeBackAmount;
                              path.excludePages.push(th.name);
                    } else {
                              bitmap.alpha = 1;
//test to see if thumb is already excluded
function isThumbExcluded(t) {
          var mySo:SharedObject = SharedObject.getLocal(hostName);
          for (var prop in mySo.data.soExcludedArray) {
                    if (mySo.data.soExcludedArray[prop] == t.name) {
                              //trace(" mySo.data.soExcludedArray[prop] "+mySo.data.soExcludedArray[prop]);
                              return true;
function doThumbClick(e:MouseEvent) {
          //trace(e.currentTarget.name);
          //if already excluded, let it back in else exclude it
          if (isThumbExcluded(e.currentTarget)) {
                    //trace("e.currentTarget "+e.currentTarget.name);
                    e.currentTarget.tBmap.alpha = 1;
                    //e.currentTarget.isExcluded = false;
                    spliceExcluded(e.currentTarget);
          } else {
                    e.currentTarget.tBmap.alpha = fadeBackAmount;
                    //e.currentTarget.isExcluded = true;
                    path.excludePages.push(e.currentTarget.name);
          saveIt();
function spliceExcluded(t) {
                    if (path.excludePages[i] == t.name) {
                              //trace("zapped "+path.excludePages[i]);
                              path.excludePages.splice(i,1);
function finishedEditing(e:Event):void {
          hideMenu();
          MovieClip(this.parent).menu_mc.visible = false;
function hideMenu() {
          this.visible = false;
          path.menu.visible = false;
///////SharedOpject Helpers
function saveIt() {
          var theExcluded:Array = path.excludePages;
          //trace("theExcluded "+theExcluded);
          mySo.data.soExcludedArray = theExcluded;
          trace("set: " + mySo.data.soExcludedArray);// theExcluded
//readout.appendText("set: " + mySo.data.soExcludedArray +"\n");
function clearIt(e:MouseEvent) {
          mySo.clear();
function loadIt(e:MouseEvent) {
          //trace(mySo.data.soExcludedArray);// yourUsername
                    trace(prop+": "+mySo.data.soExcludedArray[prop]);
                    trace("path.excludePages[prop] "+path.excludePages[prop]);
//readout.appendText(mySo.data.soExcludedArray[prop] +"\n");
function SharedObject_clear() {
          mySo.clear();
}//trace("cleared: " + mySo.data.soExcludedArray);// undefined
