The ActiveX control for Flash Player could not be registered
Oct 6, 2011 1:14 PM
Tags: #failed #activex #install_failed #register #registered
Here we go again with a failed Flash Player install.
Runing Windows 7 64bit with IE9
Install gets to 50% and stalls with Failed to register.
I have downloaded the small install, run as Admin. Same error.
Uninstalled and Rebooted...
Downloaded the direct install, run as Admin. Same error.
Reduced IE9 Security to lowest setting. Same error.
Uninstalled, rebooted, reinstalled. Same error.
Run Task Manager shut down all processes (except criticals). Same error.
Ran reset_fp10.cmd through subinalc.exe. Same error. Might there be a reset_fp11.cmd?
Not sure what else to do here...Ideas?
    Oct 6, 2011 4:09 PM   in reply to ChipM
    some people have found that there are multiple iexplore.exe processes running, but it sounds like you covered this.  if you did not, make sure to force quit those.  also, some IM clients and other apps can possibly load the player.  check the system tray to see if any programs are running there.
    Oct 6, 2011 6:15 PM   in reply to ChipM
    Sorry, I have just a few minutes before I have to leave...
    Can you download & install Process Monitor, then start the installer and note the process ID.
    Start Process Monitor and filter only the FP installer.  Next click INSTALL (on the FP installer) and watch it with Process Monitor.  It should show you what registry entry is blocking the installer from registering the ActiveX.
    Oct 7, 2011 6:53 PM   in reply to ChipM
    Is the ProcMon output very large, or just one page?  Could you take a screenshot of that output?
    I also don't know what we will get from ProcMon, but I am hoping that we can see what is causing that registration error.  (I also don't understand why the Firefox plugin [dll] can be registered, but the IE ActiveX [ocx] cannot.)
    Oct 10, 2011 7:42 PM   in reply to ChipM
    Can you try to save the output, then attach it to a reply in this forum?
    (I see that I have a 8.9MB limit to attached files; do you see a similar limit? Is the file larger than that? Could you possibly zip it if it is larger?)
    Oct 24, 2011 2:44 PM   in reply to ChipM
    I am ready to throw my computer out the window at this point. My Flashplayer worked fine until the 11 upgrade. Windows XP, Service Pack 3, 32bit, Internet Explorer. Home computer, nothing special but all that happens is it gets through 50% then says Active X can't be registered. Exact same error has here???
    Oct 24, 2011 6:22 PM   in reply to WDY73
    I FINALLY got it to work by using the solution offered here: http://kb2.adobe.com/cps/494/cpsid_49419.html
    Oct 24, 2011 7:21 PM   in reply to ChipM
    ChipM wrote:
    Can't figure out how to attach the log file.
    Click on "Use advanced editor" on the upper-right corner of the forum editor.
    Now click on the "Browse" button under "Attach Files" on the lower-left corner.
    (I have just attached a little PDF to test attachments.)
    Oct 25, 2011 6:10 PM   in reply to ChipM
    Can you send it to me by email?  (I'll send you my address via PM.)
    Oct 26, 2011 10:11 PM   in reply to ChipM
    Thank you; I have received your Procmon logfile.  It is indeed very long, and it may take me a while to analyze it.  (I also have just reinstalled the FP 11 ActiveX with Procmon, so I will have something to compare it with.)
    If any of the Adobe engineers want to have a look at it as well, I will try to attach it to this post.
    Oct 26, 2011 10:37 PM   in reply to ChipM
    Have you ever used the registry editor (regedit.exe)?
    I would like you to check some few things for me (do not edit anything!).
    Using regedit, can you find the following key: {D27CDB6E-AE6D-11cf-96B8-444553540000}
    This key should exist at HKEY_CLASSES_ROOT\CLSID and other locations.  I am only insterested in the one at HKEY_CLASSES_ROOT\CLSID.
    Does it exist in your registry?
    Does it have any subkeys, like InprocServer32 and others?
    If the InprocServer32 subkey exists, what does it contain?
    Please feel free to ask if you are unsure about what to do.  (But I feel you have good technical skills, the way you handled Procmon.)
    Oct 27, 2011 5:52 PM   in reply to ChipM
    The reason I asked about that key is that I saw in your log several dozen times NAME NOT FOUND for that key.
    In my own Procmon log I see that the Flash OCX is registered in that key, but I do not see that in your log file.
    I need to look deeper into these logs, i.e. where that key is created, and where it potentially fails in your case.  Unfortunately I have not much time today.
    Attaching the log file to my earlier post failed.  (The virus scanner rejected it as malware.)  I will try to forward it by email to the engineering team.
    Oct 28, 2011 8:16 PM   in reply to ChipM
    Well done!
    To everyone trying this solution, be sure to create a System Restore Point before editing the registry.
    Nov 14, 2011 2:22 AM   in reply to ChipM
    Hello!
    I've the same issue since a month... everything was fine with version 10. after needed to update for V.11 i got that activex error. trying all solutions but so far I couldnt solve it.... even I gave those permissions on registry. it s not helping... what am I suppose to do? am I missing something.... any other idea?
    kinda regards
    Nov 14, 2011 6:33 PM   in reply to freevision
    I am still collecting data from other similar reports; maybe I can come up with a general solution.
    If you want to help, send me your ProcMon logfile.
    Nov 15, 2011 12:27 AM   in reply to Pat Willener
    hi,
    here s my log file. http://dl.dropbox.com/u/2478367/Logfile2.PML
    I hope we can find a permanent solution for this ridicilous .... I contacted with Macromedia and also microsoft about this issue. Both of them blaming eachother but no solutions. what kind of customer care is that ))
    ps: my chrome and firefox perfectly works with flash player 11
    Nov 15, 2011 4:09 PM   in reply to freevision
    Thank you for the logfile; I will have a look at it when I find some time.
    Actually, it is neither Microsoft's nor Adobe's fault; it is a permission issue within your Windows registry.  From the few logfiles I have analyzed so far, each user had a different problem (different registry key with insufficient permissions).
    Nov 16, 2011 12:01 AM   in reply to Pat Willener
    I followed almost every solutions, including permit whole HKEY_CLASSES_ROOT and specifically to CLSID. is there any other folders I need to permit?
    the thing is this issue came up with player 11. all was fine before that. isn't that weird?  I believe Adobe and Microsoft must consider these issues.
    kinda regards
    Nov 23, 2011 7:55 AM   in reply to Pat Willener
    hi,
    did ever have a chance to look at my log file? still I'm stuck with this issue....
    Nov 23, 2011 9:07 PM   in reply to freevision
    Sorry, I haven't found anything so far.  I have (today) asked the Adobe team to have a look at it.
    Nov 29, 2011 12:02 AM   in reply to Pat Willener
    hello! is there any response from adobe team. this non-sense issue s affecting all my workflow ((((
    Nov 29, 2011 4:28 PM   in reply to freevision
    Yes, the Adobe team is looking into it.
    Meanwhile, another user has discovered a tool that seems to fix many installation problems: http://support.microsoft.com/mats/Program_Install_and_Uninstall
    Can you give it a try?
  • Chris Campbell
    May 4, 2010
    Nov 30, 2011 4:11 PM   in reply to Pat Willener
    Freevision,
    Thanks for the log file.  In addition to that, can you also post your Flash Player installer log?
    Chris
    Dec 1, 2011 2:13 AM   in reply to Chris Campbell
    hello Chris, )) here s my log file ...
    http://dl.dropbox.com/u/2478367/FlashInstall.log
    Ozy
    Dec 1, 2011 1:09 AM   in reply to Pat Willener
    hi,
    I did it... I assume u know already how it works. at the end Adobe Flash Player wasnt on the list. so it couldnt find any problem to fix. but there was Adobe AIR, Adobe Community Help, Adobe media Player and Adobe reader.. dont think it s related with my issue.
    still there s no progress...
    Dec 6, 2011 12:17 AM   in reply to Chris Campbell
    hi guys, I'm sorry but anything new with this issue?
    Dec 15, 2011 6:33 AM   in reply to freevision
    FINALLY I FIXED THIS PROBLEM....
    it was all about permissions of Flash directory under WINDOWS folder.
    1- Permissions must be set manually on
    C:\Windows\System32\Macromed\Flash  ( as Administrator -- right click on folder's name then launch Properties, switch SECURITY section and select your user. REMEMBER: your account must be administrator rights. check under Allow boxes there, then Apply all changes)
    2-  Same process must be done also for C:\Windows\SysWOW64\Macromed\Flash
    3- Download latest http://fpdownload.macromedia.com/get/flashplayer/installers/archive/fp _11.1.102.55_archive.zip  it s an installer archive.
    4- try to install fp_11.1.102.55_archive\11_1r102_55_64bit\flashplayer11_1r102_55_winax _64bit.msi   do not try to install EXE versions. it doesnt work. MSI installer worked for me...
    I tried many solutions to fix it. non of them worked. this research took me 2 months but I fixed finally... Adobe Team MUST CONSIDER this solution next time I believe.
    thanks
    Apr 11, 2012 6:20 PM   in reply to ChipM
    THANKS FREEVISION, YOU ARE THE BEST
    After 6 months I FINALLY fixed this problem, following your instructions, as for what ChipM said, in the next page you can find the LAST install via .MSI
    http://www.adobe.com/products/flashplayer/distribution3.html
    Thank you!!!!!!!!! for posting it, i'm so happy i just cant believe it's already fixed
    Apr 11, 2012 8:39 PM   in reply to Anzo07
    Failed. I always use the MSI, now what did adobe do?  All permissions were good; registry and both macro folders. Ripped ALL adobe from system and registry, checked permissions, MSI again. Fail. Extracted the exe from the MSI, failed again. Why does updating flash have to be such a hassle?
    Apr 12, 2012 3:31 AM   in reply to UnFlash
    Here is thelog. I did all the permisisoning to where I even gave Everyone and Users full on the folders.
    === Verbose logging started: 4/12/2012  05:25:33  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Windows\System32\msiexec.exe ===
    MSI (c) (F4:A0) [05:25:33:647]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
    MSI (c) (F4:64) [05:25:33:678]: Resetting cached policy values
    MSI (c) (F4:64) [05:25:33:678]: Machine policy value 'Debug' is 0
    MSI (c) (F4:64) [05:25:33:678]: ******* RunEngine:
               ******* Product: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
               ******* Action:
               ******* CommandLine: **********
    MSI (c) (F4:64) [05:25:33:678]: Machine policy value 'DisableUserInstalls' is 0
    MSI (c) (F4:64) [05:25:33:678]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi' against software restriction policy
    MSI (c) (F4:64) [05:25:33:678]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi has a digital signature
    MSI (c) (F4:64) [05:25:33:991]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi is permitted to run at the 'unrestricted' authorization level.
    MSI (c) (F4:64) [05:25:34:053]: Cloaking enabled.
    MSI (c) (F4:64) [05:25:34:053]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (F4:64) [05:25:34:069]: End dialog not enabled
    MSI (c) (F4:64) [05:25:34:069]: Original package ==> C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
    MSI (c) (F4:64) [05:25:34:069]: Package we're running from ==> C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
    MSI (c) (F4:64) [05:25:34:069]: APPCOMPAT: Compatibility mode property overrides found.
    MSI (c) (F4:64) [05:25:34:069]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (c) (F4:64) [05:25:34:069]: APPCOMPAT: no matching ProductCode found in database.
    MSI (c) (F4:64) [05:25:34:069]: MSCOREE not loaded loading copy from system32
    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'TransformsSecure' is 0
    MSI (c) (F4:64) [05:25:34:084]: User policy value 'TransformsAtSource' is 0
    MSI (c) (F4:64) [05:25:34:084]: Note: 1: 2205 2:  3: MsiFileHash
    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisablePatch' is 0
    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'AllowLockdownPatch' is 0
    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisableLUAPatching' is 0
    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisableFlyWeightPatching' is 0
    MSI (c) (F4:64) [05:25:34:084]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
    MSI (c) (F4:64) [05:25:34:084]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (c) (F4:64) [05:25:34:084]: APPCOMPAT: no matching ProductCode found in database.
    MSI (c) (F4:64) [05:25:34:084]: Transforms are not secure.
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG'.
    MSI (c) (F4:64) [05:25:34:084]: Command Line: CURRENTDIRECTORY=C:\Users\Admin\Desktop CLIENTUILEVEL=0 CLIENTPROCESSID=4596
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{56994055-C101-488E-A9CB-CF207652B759}'.
    MSI (c) (F4:64) [05:25:34:084]: Product Code passed to Engine.Initialize:           ''
    MSI (c) (F4:64) [05:25:34:084]: Product Code from property table before transforms: '{5C804EBB-475F-4555-A225-1D6573F158BD}'
    MSI (c) (F4:64) [05:25:34:084]: Product Code from property table after transforms:  '{5C804EBB-475F-4555-A225-1D6573F158BD}'
    MSI (c) (F4:64) [05:25:34:084]: Product not registered: beginning first-time install
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
    MSI (c) (F4:64) [05:25:34:084]: Entering CMsiConfigurationManager::SetLastUsedSource.
    MSI (c) (F4:64) [05:25:34:084]: User policy value 'SearchOrder' is 'nmu'
    MSI (c) (F4:64) [05:25:34:084]: Adding new sources is allowed.
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
    MSI (c) (F4:64) [05:25:34:084]: Package name extracted from package path: 'install_flash_player_11_active_x_64bit.msi'
    MSI (c) (F4:64) [05:25:34:084]: Package to be registered: 'install_flash_player_11_active_x_64bit.msi'
    MSI (c) (F4:64) [05:25:34:084]: Note: 1: 2262 2: AdminProperties 3: -2147287038
    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisableMsi' is 0
    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (c) (F4:64) [05:25:34:084]: User policy value 'AlwaysInstallElevated' is 0
    MSI (c) (F4:64) [05:25:34:084]: Product installation will be elevated because user is admin and product is being installed per-machine.
    MSI (c) (F4:64) [05:25:34:084]: Running product '{5C804EBB-475F-4555-A225-1D6573F158BD}' with elevated privileges: Product is assigned.
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Admin\Desktop'.
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '4596'.
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
    MSI (c) (F4:64) [05:25:34:084]: TRANSFORMS property is now:
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Favorites
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Documents
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Templates
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Local
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Pictures
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Desktop
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
    MSI (c) (F4:64) [05:25:34:084]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
    MSI (c) (F4:64) [05:25:34:100]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
    MSI (c) (F4:64) [05:25:34:100]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
    MSI (c) (F4:64) [05:25:34:100]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Viking'.
    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi'.
    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi'.
    MSI (c) (F4:64) [05:25:34:100]: Machine policy value 'MsiDisableEmbeddedUI' is 0
    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\Admin\Desktop\'.
    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\'.
    MSI (c) (F4:A0) [05:25:34:100]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
    === Logging started: 4/12/2012  05:25:34 ===
    MSI (c) (F4:64) [05:25:34:100]: Note: 1: 2205 2:  3: PatchPackage
    MSI (c) (F4:64) [05:25:34:100]: Machine policy value 'DisableRollback' is 0
    MSI (c) (F4:64) [05:25:34:100]: User policy value 'DisableRollback' is 0
    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
    MSI (c) (F4:64) [05:25:34:116]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
    MSI (c) (F4:64) [05:25:34:116]: Doing action: INSTALL
    Action 05:25:34: INSTALL.
    Action start 05:25:34: INSTALL.
    MSI (c) (F4:64) [05:25:34:116]: UI Sequence table 'InstallUISequence' is present and populated.
    MSI (c) (F4:64) [05:25:34:116]: Running UISequence
    MSI (c) (F4:64) [05:25:34:116]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
    MSI (c) (F4:64) [05:25:34:116]: Doing action: ISSetAllUsers
    Action 05:25:34: ISSetAllUsers.
    Action start 05:25:34: ISSetAllUsers.
    MSI (c) (F4:64) [05:25:34:147]: Creating MSIHANDLE (1) of type 790542 for thread 1380
    MSI (c) (F4:78) [05:25:34:147]: Invoking remote custom action. DLL: C:\Users\Ad~1\AppData\Local\Temp\MSIEDE8.tmp, Entrypoint: SetAllUsers
    MSI (c) (F4:DC) [05:25:34:147]: Cloaking enabled.
    MSI (c) (F4:DC) [05:25:34:147]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (F4:DC) [05:25:34:147]: Connected to service for CA interface.
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (2) of type 790531 for thread 2532
    InstallShield 05:25:34: Begin SetAllUsers()
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (2) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (3) of type 790541 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (4) of type 790531 for thread 2532
    InstallShield 05:25:34: Getting records from Upgrade table
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (4) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (5) of type 790540 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (6) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (7) of type 790531 for thread 2532
    InstallShield 05:25:34: UpgradeCode: {42463807-970B-4257-BC95-5C348D61DF1C} MinVersion: 6.0.0.0 MaxVersion: 11.2.202.228 Language:  Attributes: 769
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (7) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (8) of type 790531 for thread 2532
    InstallShield 05:25:34: No related products for UpgradeCode {42463807-970B-4257-BC95-5C348D61DF1C} found
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (8) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (6) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (9) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (10) of type 790531 for thread 2532
    InstallShield 05:25:34: UpgradeCode: {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} MinVersion:  MaxVersion: 11.2.202.228 Language:  Attributes: 257
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (10) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (11) of type 790531 for thread 2532
    InstallShield 05:25:34: No related products for UpgradeCode {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} found
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (11) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (9) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (12) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (13) of type 790531 for thread 2532
    InstallShield 05:25:34: UpgradeCode: {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} MinVersion:  MaxVersion: 11.2.202.228 Language:  Attributes: 257
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (13) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (14) of type 790531 for thread 2532
    InstallShield 05:25:34: No related products for UpgradeCode {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} found
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (14) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (12) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (15) of type 790531 for thread 2532
    InstallShield 05:25:34: End SetAllUsers()
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (15) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (5) of type 790540 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (3) of type 790541 for thread 2532
    MSI (c) (F4:78) [05:25:34:256]: Closing MSIHANDLE (1) of type 790542 for thread 1380
    Action ended 05:25:34: ISSetAllUsers. Return value 1.
    MSI (c) (F4:64) [05:25:34:256]: Doing action: AppSearch
    Action 05:25:34: AppSearch. Searching for installed applications
    Action start 05:25:34: AppSearch.
    MSI (c) (F4:64) [05:25:34:256]: Note: 1: 2205 2:  3: AppSearch
    MSI (c) (F4:64) [05:25:34:256]: Note: 1: 2228 2:  3: AppSearch 4: SELECT `Property`, `Signature_` FROM `AppSearch`
    Action ended 05:25:34: AppSearch. Return value 0.
    MSI (c) (F4:64) [05:25:34:256]: Doing action: LaunchConditions
    Action 05:25:34: LaunchConditions. Evaluating launch conditions
    Action start 05:25:34: LaunchConditions.
    Action ended 05:25:34: LaunchConditions. Return value 1.
    MSI (c) (F4:64) [05:25:34:272]: Doing action: SetupInitialization
    Action 05:25:34: SetupInitialization.
    Action start 05:25:34: SetupInitialization.
    Info 2898.For Tahoma8 textstyle, the system created a 'Tahoma' font, in 0 character set.
    Info 2898.For TahomaBold10 textstyle, the system created a 'Tahoma' font, in 0 character set.
    Action 05:25:34: SetupInitialization. Dialog created
    Action ended 05:25:34: SetupInitialization. Return value 1.
    MSI (c) (F4:64) [05:25:34:288]: Doing action: FindRelatedProducts
    Action 05:25:34: FindRelatedProducts. Searching for related applications
    Action start 05:25:34: FindRelatedProducts.
    Action ended 05:25:34: FindRelatedProducts. Return value 1.
    MSI (c) (F4:64) [05:25:34:288]: Skipping action: CCPSearch (condition is false)
    MSI (c) (F4:64) [05:25:34:288]: Skipping action: RMCCPSearch (condition is false)
    MSI (c) (F4:64) [05:25:34:288]: Doing action: ValidateProductID
    Action 05:25:34: ValidateProductID.
    Action start 05:25:34: ValidateProductID.
    Action ended 05:25:34: ValidateProductID. Return value 1.
    MSI (c) (F4:64) [05:25:34:303]: Doing action: CostInitialize
    Action 05:25:34: CostInitialize. Computing space requirements
    Action start 05:25:34: CostInitialize.
    MSI (c) (F4:64) [05:25:34:303]: Machine policy value 'MaxPatchCacheSize' is 10
    MSI (c) (F4:64) [05:25:34:303]: Baseline: Sorting baselines for {5C804EBB-475F-4555-A225-1D6573F158BD}.
    MSI (c) (F4:64) [05:25:34:303]: Baseline: New baseline 11.2.202 from transaction.
    MSI (c) (F4:64) [05:25:34:303]: Baseline: Sorted order Native: Order 0.
    MSI (c) (F4:64) [05:25:34:303]: Baseline Data Table:
    MSI (c) (F4:64) [05:25:34:303]: ProductCode: {5C804EBB-475F-4555-A225-1D6573F158BD} Version: 11.2.202 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
    MSI (c) (F4:64) [05:25:34:303]: Baseline File Table:
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
    Action ended 05:25:34: CostInitialize. Return value 1.
    MSI (c) (F4:64) [05:25:34:303]: Doing action: FileCost
    Action 05:25:34: FileCost. Computing space requirements
    Action start 05:25:34: FileCost.
    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: Class
    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: Extension
    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: TypeLib
    Action ended 05:25:34: FileCost. Return value 1.
    MSI (c) (F4:64) [05:25:34:303]: Doing action: IsolateComponents
    Action 05:25:34: IsolateComponents.
    Action start 05:25:34: IsolateComponents.
    Action ended 05:25:34: IsolateComponents. Return value 0.
    MSI (c) (F4:64) [05:25:34:303]: Doing action: setUserProfileNT
    Action 05:25:34: setUserProfileNT.
    Action start 05:25:34: setUserProfileNT.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Admin'.
    Action ended 05:25:34: setUserProfileNT. Return value 1.
    MSI (c) (F4:64) [05:25:34:303]: Skipping action: SetAllUsersProfileNT (condition is false)
    MSI (c) (F4:64) [05:25:34:303]: Doing action: setAllUsersProfile2K
    Action 05:25:34: setAllUsersProfile2K.
    Action start 05:25:34: setAllUsersProfile2K.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData'.
    Action ended 05:25:34: setAllUsersProfile2K. Return value 1.
    MSI (c) (F4:64) [05:25:34:303]: Doing action: ResolveSource
    Action 05:25:34: ResolveSource.
    Action start 05:25:34: ResolveSource.
    MSI (c) (F4:64) [05:25:34:303]: Resolving source.
    MSI (c) (F4:64) [05:25:34:303]: Resolving source to launched-from source.
    MSI (c) (F4:64) [05:25:34:303]: Setting launched-from source as last-used.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (c) (F4:64) [05:25:34:303]: SOURCEDIR ==> C:\Users\Admin\Desktop\
    MSI (c) (F4:64) [05:25:34:303]: SOURCEDIR product ==> {5C804EBB-475F-4555-A225-1D6573F158BD}
    MSI (c) (F4:64) [05:25:34:303]: Determining source type
    MSI (c) (F4:64) [05:25:34:303]: Source type from package 'install_flash_player_11_active_x_64bit.msi': 0
    MSI (c) (F4:64) [05:25:34:303]: Source path resolution complete. Dumping Directory table...
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: TARGETDIR , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: WindowsFolder , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: USERPROFILE , Object: C:\Users\Admin\Desktop\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: TempFolder , Object: C:\Users\Admin\Desktop\Temp\ , LongSubPath: Temp\ , ShortSubPath:
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: System64Folder , Object: C:\Users\Admin\Desktop\System64\ , LongSubPath: System64\ , ShortSubPath:
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: MACROMED , Object: C:\Users\Admin\Desktop\System64\Macromed\ , LongSubPath: System64\Macromed\ , ShortSubPath:
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: FLASH , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: INSTALLDIR , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: CommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\ , LongSubPath: Common\ , ShortSubPath:
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: ISCommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Users\Admin\Desktop\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
    Action ended 05:25:34: ResolveSource. Return value 1.
    MSI (c) (F4:64) [05:25:34:303]: Doing action: CostFinalize
    Action 05:25:34: CostFinalize. Computing space requirements
    Action start 05:25:34: CostFinalize.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2262 2: Patch 3: -2147287038
    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: Condition
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Modifying USERPROFILE property. Its current value is 'C:\Users\Admin'. Its new value: 'C:\Users\Admin\'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\system32\Macromed\'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Modifying ALLUSERSPROFILE property. Its current value is 'C:\ProgramData'. Its new value: 'C:\ProgramData\'.
    MSI (c) (F4:64) [05:25:34:303]: Target path resolution complete. Dumping Directory table...
    MSI (c) (F4:64) [05:25:34:303]: Note: target paths subject to change (via custom actions or browsing)
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: TARGETDIR , Object: E:\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: USERPROFILE , Object: C:\Users\Admin\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: TempFolder , Object: C:\Users\Ad~1\AppData\Local\Temp\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: MACROMED , Object: C:\Windows\system32\Macromed\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: FLASH , Object: C:\Windows\system32\Macromed\Flash\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\system32\Macromed\Flash\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
    Action ended 05:25:34: CostFinalize. Return value 1.
    MSI (c) (F4:64) [05:25:34:303]: Doing action: MigrateFeatureStates
    Action 05:25:34: MigrateFeatureStates. Migrating feature states from related applications
    Action start 05:25:34: MigrateFeatureStates.
    Action ended 05:25:34: MigrateFeatureStates. Return value 0.
    MSI (c) (F4:64) [05:25:34:303]: Skipping action: PatchWelcome (condition is false)
    MSI (c) (F4:64) [05:25:34:303]: Doing action: InstallWelcome
    Action 05:25:34: InstallWelcome.
    Action start 05:25:34: InstallWelcome.
    Action 05:25:34: InstallWelcome. Dialog created
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: _RemoveFilePath
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: MsiFileHash
    MSI (c) (F4:9C) [05:25:34:319]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: BindImage
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: ProgId
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: PublishComponent
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: SelfReg
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Extension
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Font
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Shortcut
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Class
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: TypeLib
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2727 2:
    Action ended 05:25:36: InstallWelcome. Return value 1.
    MSI (c) (F4:64) [05:25:36:022]: Skipping action: SetupResume (condition is false)
    MSI (c) (F4:64) [05:25:36:022]: Skipping action: MaintenanceWelcome (condition is false)
    MSI (c) (F4:64) [05:25:36:022]: Doing action: SetupProgress
    Action 05:25:36: SetupProgress.
    Action start 05:25:36: SetupProgress.
    Info 2898.For MSSansBold8 textstyle, the system created a 'Tahoma' font, in 0 character set.
    Info 2898.For MSSWhiteSerif8 textstyle, the system created a 'Tahoma' font, in 0 character set.
    Action 05:25:36: SetupProgress. Dialog created
    Action ended 05:25:36: SetupProgress. Return value 1.
    MSI (c) (F4:64) [05:25:36:038]: Doing action: ExecuteAction
    Action 05:25:36: ExecuteAction.
    Action start 05:25:36: ExecuteAction.
    MSI (c) (F4:64) [05:25:36:053]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
    MSI (c) (F4:64) [05:25:36:053]: Grabbed execution mutex.
    MSI (c) (F4:64) [05:25:36:053]: Incrementing counter to disable shutdown. Counter after increment: 0
    MSI (c) (F4:64) [05:25:36:053]: Switching to server: SECONDSEQUENCE="1" TARGETDIR="E:\" ALLUSERSPROFILE="C:\ProgramData\" MACROMED="C:\Windows\system32\Macromed\" FLASH="C:\Windows\system32\Macromed\Flash\" INSTALLDIR="C:\Windows\system32\Macromed\Flash\" ROOTDRIVE="E:\" USERPROFILE="C:\Users\Admin\" EXECUTEACTION="INSTALL" ACTION="INSTALL" SOURCEDIR="C:\Users\Admin\Desktop\" USERNAME="Viking" CLIENTPROCESSID="4596" CLIENTUILEVEL="0" CURRENTDIRECTORY="C:\Users\Admin\Desktop"  ADDLOCAL=FlashPlayerAXInstaller
    MSI (s) (28:94) [05:25:36:069]: Running installation inside multi-package transaction C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
    MSI (s) (28:94) [05:25:36:069]: Grabbed execution mutex.
    MSI (s) (28:78) [05:25:36:069]: Resetting cached policy values
    MSI (s) (28:78) [05:25:36:069]: Machine policy value 'Debug' is 0
    MSI (s) (28:78) [05:25:36:069]: ******* RunEngine:
               ******* Action: INSTALL
    MSI (s) (28:78) [05:25:36:069]: Machine policy value 'DisableUserInstalls' is 0
    MSI (s) (28:78) [05:25:36:069]: Setting cached product context: User non-assigned for product: 13E07932B849E664386721423DF2FDC0
    MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: 13E07932B849E664386721423DF2FDC0
    MSI (s) (28:78) [05:25:36:084]: Setting cached product context: User non-assigned for product: 8B17357F59074B5F87FBCDE4D112027B
    MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: 8B17357F59074B5F87FBCDE4D112027B
    MSI (s) (28:78) [05:25:36:084]: Setting cached product context: User non-assigned for product: 9F268D25182F5B148860854DBA8B51E9
    MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: 9F268D25182F5B148860854DBA8B51E9
    MSI (s) (28:78) [05:25:36:084]: Setting cached product context: User non-assigned for product: BB6F3BEED8135EC489F91819CFFB5B87
    MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: BB6F3BEED8135EC489F91819CFFB5B87
    MSI (s) (28:78) [05:25:36:084]: Setting cached product context: machine assigned for product: D430EE3D29B555A4AA20E2D6A0A669EE
    MSI (s) (28:78) [05:25:36:084]: Using cached product context: machine assigned for product: D430EE3D29B555A4AA20E2D6A0A669EE
    MSI (s) (28:78) [05:25:36:084]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
    MSI (s) (28:78) [05:25:36:084]: Note: 1: 1715 2: Adobe Flash Player 11 ActiveX (x64)
    MSI (s) (28:78) [05:25:36:084]: Calling SRSetRestorePoint API. dwRestorePtType: 0, dwEventType: 102, llSequenceNumber: 0, szDescription: "Installed Adobe Flash Player 11 ActiveX (x64).".
    MSI (s) (28:78) [05:25:46:319]: The call to SRSetRestorePoint API succeeded. Returned status: 0, llSequenceNumber: 390.
    MSI (s) (28:78) [05:25:46:319]: File will have security applied from OpCode.
    MSI (s) (28:78) [05:25:46:366]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi' against software restriction policy
    MSI (s) (28:78) [05:25:46:366]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi has a digital signature
    MSI (s) (28:78) [05:25:46:538]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi is permitted to run at the 'unrestricted' authorization level.
    MSI (s) (28:78) [05:25:46:538]: End dialog not enabled
    MSI (s) (28:78) [05:25:46:538]: Original package ==> C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
    MSI (s) (28:78) [05:25:46:538]: Package we're running from ==> C:\Windows\Installer\1201d91.msi
    MSI (s) (28:78) [05:25:46:538]: APPCOMPAT: Compatibility mode property overrides found.
    MSI (s) (28:78) [05:25:46:538]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (s) (28:78) [05:25:46:538]: APPCOMPAT: no matching ProductCode found in database.
    MSI (s) (28:78) [05:25:46:553]: MSCOREE not loaded loading copy from system32
    MSI (s) (28:78) [05:25:46:553]: Machine policy value 'TransformsSecure' is 0
    MSI (s) (28:78) [05:25:46:553]: User policy value 'TransformsAtSource' is 0
    MSI (s) (28:78) [05:25:46:553]: Note: 1: 2205 2:  3: MsiFileHash
    MSI (s) (28:78) [05:25:46:553]: Machine policy value 'DisablePatch' is 0
    MSI (s) (28:78) [05:25:46:553]: Machine policy value 'AllowLockdownPatch' is 0
    MSI (s) (28:78) [05:25:46:553]: Machine policy value 'DisableLUAPatching' is 0
    MSI (s) (28:78) [05:25:46:553]: Machine policy value 'DisableFlyWeightPatching' is 0
    MSI (s) (28:78) [05:25:46:553]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
    MSI (s) (28:78) [05:25:46:553]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (s) (28:78) [05:25:46:553]: APPCOMPAT: no matching ProductCode found in database.
    MSI (s) (28:78) [05:25:46:553]: Transforms are not secure.
    MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG'.
    MSI (s) (28:78) [05:25:46:553]: Command Line: SECONDSEQUENCE=1 TARGETDIR=E:\ ALLUSERSPROFILE=C:\ProgramData\ MACROMED=C:\Windows\system32\Macromed\ FLASH=C:\Windows\system32\Macromed\Flash\ INSTALLDIR=C:\Windows\system32\Macromed\Flash\ ROOTDRIVE=E:\ USERPROFILE=C:\Users\Admin\ EXECUTEACTION=INSTALL ACTION=INSTALL SOURCEDIR=C:\Users\Admin\Desktop\ USERNAME=Viking CLIENTPROCESSID=4596 CLIENTUILEVEL=0 CURRENTDIRECTORY=C:\Users\Admin\Desktop ADDLOCAL=FlashPlayerAXInstaller ACTION=INSTALL
    MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{56994055-C101-488E-A9CB-CF207652B759}'.
    MSI (s) (28:78) [05:25:46:553]: Product Code passed to Engine.Initialize:           ''
    MSI (s) (28:78) [05:25:46:553]: Product Code from property table before transforms: '{5C804EBB-475F-4555-A225-1D6573F158BD}'
    MSI (s) (28:78) [05:25:46:553]: Product Code from property table after transforms:  '{5C804EBB-475F-4555-A225-1D6573F158BD}'
    MSI (s) (28:78) [05:25:46:553]: Product not registered: beginning first-time install
    MSI (s) (28:78) [05:25:46:553]: Product {5C804EBB-475F-4555-A225-1D6573F158BD} is not managed.
    MSI (s) (28:78) [05:25:46:553]: MSI_LUA: Credential prompt not required, user is an admin
    MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
    MSI (s) (28:78) [05:25:46:553]: Entering CMsiConfigurationManager::SetLastUsedSource.
    MSI (s) (28:78) [05:25:46:553]: User policy value 'SearchOrder' is 'nmu'
    MSI (s) (28:78) [05:25:46:553]: Adding new sources is allowed.
    MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
    MSI (s) (28:78) [05:25:46:569]: Package name extracted from package path: 'install_flash_player_11_active_x_64bit.msi'
    MSI (s) (28:78) [05:25:46:569]: Package to be registered: 'install_flash_player_11_active_x_64bit.msi'
    MSI (s) (28:78) [05:25:46:569]: Note: 1: 2262 2: AdminProperties 3: -2147287038
    MSI (s) (28:78) [05:25:46:569]: Machine policy value 'DisableMsi' is 0
    MSI (s) (28:78) [05:25:46:569]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (s) (28:78) [05:25:46:569]: User policy value 'AlwaysInstallElevated' is 0
    MSI (s) (28:78) [05:25:46:569]: Product installation will be elevated because user is admin and product is being installed per-machine.
    MSI (s) (28:78) [05:25:46:569]: Running product '{5C804EBB-475F-4555-A225-1D6573F158BD}' with elevated privileges: Product is assigned.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\system32\Macromed\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Admin\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Viking'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '4596'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Admin\Desktop'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ADDLOCAL property. Its value is 'FlashPlayerAXInstaller'.
    MSI (s) (28:78) [05:25:46:569]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is 'ffdbe6677a09a542b5e6559f7939deaf'.
    MSI (s) (28:78) [05:25:46:569]: RESTART MANAGER: Session opened.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
    MSI (s) (28:78) [05:25:46:569]: Engine has iefSecondSequence set to true.
    MSI (s) (28:78) [05:25:46:569]: TRANSFORMS property is now:
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Deleting SOURCEDIR property. Its current value is 'C:\Users\Admin\Desktop\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
    MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming
    MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Favorites
    MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
    MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Documents
    MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent
    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo
    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Templates
    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\ProgramData
    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Local
    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Pictures
    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
    MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (s) (28:78) [05:25:46:616]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Desktop
    MSI (s) (28:78) [05:25:46:616]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
    MSI (s) (28:78) [05:25:46:616]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
    MSI (s) (28:78) [05:25:46:616]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
    MSI (s) (28:78) [05:25:46:616]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
    MSI (s) (28:78) [05:25:46:616]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\1201d91.msi'.
    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi'.
    MSI (s) (28:78) [05:25:46:616]: Machine policy value 'MsiDisableEmbeddedUI' is 0
    MSI (s) (28:78) [05:25:46:616]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install
    MSI (s) (28:78) [05:25:46:616]: Note: 1: 2205 2:  3: PatchPackage
    MSI (s) (28:78) [05:25:46:616]: Machine policy value 'DisableRollback' is 0
    MSI (s) (28:78) [05:25:46:616]: User policy value 'DisableRollback' is 0
    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
    MSI (s) (28:78) [05:25:46:616]: Doing action: INSTALL
    Action 05:25:46: INSTALL.
    Action start 05:25:46: INSTALL.
    MSI (s) (28:78) [05:25:46:616]: Running ExecuteSequence
    MSI (s) (28:78) [05:25:46:616]: Doing action: ISSetAllUsers
    Action 05:25:46: ISSetAllUsers.
    Action start 05:25:46: ISSetAllUsers.
    MSI (s) (28:78) [05:25:46:616]: Skipping action due to msidbCustomActionTypeFirstSequence option.
    Action ended 05:25:46: ISSetAllUsers. Return value 0.
    MSI (s) (28:78) [05:25:46:616]: Doing action: AppSearch
    Action 05:25:46: AppSearch. Searching for installed applications
    Action start 05:25:46: AppSearch.
    MSI (s) (28:78) [05:25:46:616]: Skipping AppSearch action: already done on client side
    Action ended 05:25:46: AppSearch. Return value 0.
    MSI (s) (28:78) [05:25:46:616]: Doing action: LaunchConditions
    Action 05:25:46: LaunchConditions. Evaluating launch conditions
    Action start 05:25:46: LaunchConditions.
    Action ended 05:25:46: LaunchConditions. Return value 1.
    MSI (s) (28:78) [05:25:46:616]: Doing action: FindRelatedProducts
    Action 05:25:46: FindRelatedProducts. Searching for related applications
    Action start 05:25:46: FindRelatedProducts.
    MSI (s) (28:78) [05:25:46:616]: Skipping FindRelatedProducts action: already done on client side
    Action ended 05:25:46: FindRelatedProducts. Return value 0.
    MSI (s) (28:78) [05:25:46:616]: Skipping action: CCPSearch (condition is false)
    MSI (s) (28:78) [05:25:46:616]: Skipping action: RMCCPSearch (condition is false)
    MSI (s) (28:78) [05:25:46:616]: Doing action: ValidateProductID
    Action 05:25:46: ValidateProductID.
    Action start 05:25:46: ValidateProductID.
    Action ended 05:25:46: ValidateProductID. Return value 1.
    MSI (s) (28:78) [05:25:46:616]: Doing action: CostInitialize
    Action 05:25:46: CostInitialize. Computing space requirements
    Action start 05:25:46: CostInitialize.
    MSI (s) (28:78) [05:25:46:616]: Machine policy value 'MaxPatchCacheSize' is 10
    MSI (s) (28:78) [05:25:46:616]: Baseline: Sorting baselines for {5C804EBB-475F-4555-A225-1D6573F158BD}.
    MSI (s) (28:78) [05:25:46:616]: Baseline: New baseline 11.2.202 from transaction.
    MSI (s) (28:78) [05:25:46:616]: Baseline: Sorted order Native: Order 0.
    MSI (s) (28:78) [05:25:46:616]: Baseline Data Table:
    MSI (s) (28:78) [05:25:46:616]: ProductCode: {5C804EBB-475F-4555-A225-1D6573F158BD} Version: 11.2.202 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
    MSI (s) (28:78) [05:25:46:616]: Baseline File Table:
    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
    MSI (s) (28:78) [05:25:46:616]: Note: 1: 2262 2: Patch 3: -2147287038
    MSI (s) (28:78) [05:25:46:616]: Note: 1: 2205 2:  3: MsiPatchHeaders
    MSI (s) (28:78) [05:25:46:616]: Note: 1: 2205 2:  3: __MsiPatchFileList
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: PatchPackage
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
    MSI (s) (28:78) [05:25:46:631]: Delta compression fallback method for this product transaction is 'MSI 2.0 legacy obsolescence'
    Action ended 05:25:46: CostInitialize. Return value 1.
    MSI (s) (28:78) [05:25:46:631]: Doing action: FileCost
    Action 05:25:46: FileCost. Computing space requirements
    Action start 05:25:46: FileCost.
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Class
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Extension
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: TypeLib
    Action ended 05:25:46: FileCost. Return value 1.
    MSI (s) (28:78) [05:25:46:631]: Doing action: IsolateComponents
    Action 05:25:46: IsolateComponents.
    Action start 05:25:46: IsolateComponents.
    Action ended 05:25:46: IsolateComponents. Return value 0.
    MSI (s) (28:78) [05:25:46:631]: Doing action: CostFinalize
    Action 05:25:46: CostFinalize. Computing space requirements
    Action start 05:25:46: CostFinalize.
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Condition
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
    MSI (s) (28:78) [05:25:46:631]: Target path resolution complete. Dumping Directory table...
    MSI (s) (28:78) [05:25:46:631]: Note: target paths subject to change (via custom actions or browsing)
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: TARGETDIR , Object: E:\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: USERPROFILE , Object: C:\Users\Admin\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: TempFolder , Object: C:\Users\Ad~1\AppData\Local\Temp\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: MACROMED , Object: C:\Windows\system32\Macromed\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: FLASH , Object: C:\Windows\system32\Macromed\Flash\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\system32\Macromed\Flash\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
    Action ended 05:25:46: CostFinalize. Return value 1.
    MSI (s) (28:78) [05:25:46:631]: Doing action: SetARPINSTALLLOCATION
    Action 05:25:46: SetARPINSTALLLOCATION.
    Action start 05:25:46: SetARPINSTALLLOCATION.
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding ARPINSTALLLOCATION property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    Action ended 05:25:46: SetARPINSTALLLOCATION. Return value 1.
    MSI (s) (28:78) [05:25:46:631]: Doing action: SetODBCFolders
    Action 05:25:46: SetODBCFolders. Initializing ODBC directories
    Action start 05:25:46: SetODBCFolders.
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: ODBCDriver
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: ODBCTranslator
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
    Action ended 05:25:46: SetODBCFolders. Return value 0.
    MSI (s) (28:78) [05:25:46:631]: Doing action: MigrateFeatureStates
    Action 05:25:46: MigrateFeatureStates. Migrating feature states from related applications
    Action start 05:25:46: MigrateFeatureStates.
    MSI (s) (28:78) [05:25:46:631]: Skipping MigrateFeatureStates action: already done on client side
    Action ended 05:25:46: MigrateFeatureStates. Return value 0.
    MSI (s) (28:78) [05:25:46:631]: Doing action: InstallValidate
    Action 05:25:46: InstallValidate. Validating install
    Action start 05:25:46: InstallValidate.
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is 'ffdbe6677a09a542b5e6559f7939deaf'.
    MSI (s) (28:78) [05:25:46:631]: Feature: FlashPlayerAXInstaller; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (28:78) [05:25:46:631]: Component: __ISRegistryComponent65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
    MSI (s) (28:78) [05:25:46:631]: Component: ISRegistryComponent; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
    MSI (s) (28:78) [05:25:46:631]: Component: InstallAX64.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: BindImage
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: ProgId
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: PublishComponent
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: SelfReg
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Font
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Shortcut
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: _RemoveFilePath
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: MsiFileHash
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2727 2:
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: FilesInUse
    MSI (s) (28:78) [05:25:46:647]: Note: 1: 2727 2:
    Action ended 05:25:46: InstallValidate. Return value 1.
    MSI (s) (28:78) [05:25:46:647]: Doing action: RemoveExistingProducts
    Action 05:25:46: RemoveExistingProducts. Removing applications
    Action start 05:25:46: RemoveExistingProducts.
    Action ended 05:25:46: RemoveExistingProducts. Return value 1.
    MSI (s) (28:78) [05:25:46:663]: Doing action: InstallInitialize
    Action 05:25:46: InstallInitialize.
    Action start 05:25:46: InstallInitialize.
    MSI (s) (28:78) [05:25:46:663]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (s) (28:78) [05:25:46:663]: User policy value 'AlwaysInstallElevated' is 0
    MSI (s) (28:78) [05:25:46:663]: BeginTransaction: Locking Server
    MSI (s) (28:78) [05:25:46:663]: Server not locked: locking for product {5C804EBB-475F-4555-A225-1D6573F158BD}
    Action ended 05:25:50: InstallInitialize. Return value 1.
    MSI (s) (28:78) [05:25:50:538]: Skipping action: CallExeUninstaller (condition is false)
    MSI (s) (28:78) [05:25:50:538]: Doing action: MakePropsAvailable
    Action 05:25:50: MakePropsAvailable.
    Action start 05:25:50: MakePropsAvailable.
    MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding RemoveFilesCA property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    Action ended 05:25:50: MakePropsAvailable. Return value 1.
    MSI (s) (28:78) [05:25:50:538]: Doing action: AllocateRegistrySpace
    Action 05:25:50: AllocateRegistrySpace. Allocating registry space
    Action start 05:25:50: AllocateRegistrySpace.
    Action ended 05:25:50: AllocateRegistrySpace. Return value 1.
    MSI (s) (28:78) [05:25:50:538]: Doing action: ProcessComponents
    Action 05:25:50: ProcessComponents. Updating component registration
    Action start 05:25:50: ProcessComponents.
    MSI (s) (28:78) [05:25:50:538]: Note: 1: 2205 2:  3: MsiPatchCertificate
    MSI (s) (28:78) [05:25:50:538]: LUA patching is disabled: missing MsiPatchCertificate table
    MSI (s) (28:78) [05:25:50:538]: Resolving source.
    MSI (s) (28:78) [05:25:50:538]: Resolving source to launched-from source.
    MSI (s) (28:78) [05:25:50:538]: Setting launched-from source as last-used.
    MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\Admin\Desktop\'.
    MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\'.
    MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (s) (28:78) [05:25:50:538]: SOURCEDIR ==> C:\Users\Admin\Desktop\
    MSI (s) (28:78) [05:25:50:538]: SOURCEDIR product ==> {5C804EBB-475F-4555-A225-1D6573F158BD}
    MSI (s) (28:78) [05:25:50:538]: Determining source type
    MSI (s) (28:78) [05:25:50:553]: Source type from package 'install_flash_player_11_active_x_64bit.msi': 0
    MSI (s) (28:78) [05:25:50:553]: Source path resolution complete. Dumping Directory table...
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: TARGETDIR , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: WindowsFolder , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: USERPROFILE , Object: C:\Users\Admin\Desktop\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: TempFolder , Object: C:\Users\Admin\Desktop\Temp\ , LongSubPath: Temp\ , ShortSubPath:
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: System64Folder , Object: C:\Users\Admin\Desktop\System64\ , LongSubPath: System64\ , ShortSubPath:
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: MACROMED , Object: C:\Users\Admin\Desktop\System64\Macromed\ , LongSubPath: System64\Macromed\ , ShortSubPath:
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: FLASH , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: INSTALLDIR , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: CommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\ , LongSubPath: Common\ , ShortSubPath:
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: ISCommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Users\Admin\Desktop\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
    Action 05:25:50: GenerateScript. Generating script operations for action:
    GenerateScript: Updating component registration
    Action ended 05:25:50: ProcessComponents. Return value 1.
    MSI (s) (28:78) [05:25:50:553]: Doing action: UnpublishComponents
    Action 05:25:50: UnpublishComponents. Unpublishing Qualified Components
    Action start 05:25:50: UnpublishComponents.
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: PublishComponent
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 05:25:50: UnpublishComponents. Return value 0.
    MSI (s) (28:78) [05:25:50:569]: Doing action: MsiUnpublishAssemblies
    Action 05:25:50: MsiUnpublishAssemblies. Unpublishing assembly information
    Action start 05:25:50: MsiUnpublishAssemblies.
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 05:25:50: MsiUnpublishAssemblies. Return value 0.
    MSI (s) (28:78) [05:25:50:569]: Doing action: UnpublishFeatures
    Action 05:25:50: UnpublishFeatures. Unpublishing product features
    Action start 05:25:50: UnpublishFeatures.
    Action ended 05:25:50: UnpublishFeatures. Return value 1.
    MSI (s) (28:78) [05:25:50:569]: Doing action: StopServices
    Action 05:25:50: StopServices. Stopping services
    Action start 05:25:50: StopServices.
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: ServiceControl
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
    Action ended 05:25:50: StopServices. Return value 1.
    MSI (s) (28:78) [05:25:50:569]: Doing action: DeleteServices
    Action 05:25:50: DeleteServices. Deleting services
    Action start 05:25:50: DeleteServices.
    Action ended 05:25:50: DeleteServices. Return value 1.
    MSI (s) (28:78) [05:25:50:569]: Doing action: UnregisterComPlus
    Action 05:25:50: UnregisterComPlus. Unregistering COM+ Applications and Components
    Action start 05:25:50: UnregisterComPlus.
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: Complus
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
    Action ended 05:25:50: UnregisterComPlus. Return value 0.
    MSI (s) (28:78) [05:25:50:569]: Doing action: SelfUnregModules
    Action 05:25:50: SelfUnregModules. Unregistering modules
    Action start 05:25:50: SelfUnregModules.
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: SelfReg
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: SelfReg 4: Select `File`.`FileName`,`Component`.`Directory_`,`Component`.`Installed`, `File`.`Component_`,`SelfReg`.`File_`  From `SelfReg`, `File`, `Component` Where `SelfReg`.`File_` = `File`.`File` And `File`.`Component_` = `Component`.`Component` And `Component`.`Action` = 0
    Action ended 05:25:50: SelfUnregModules. Return value 1.
    MSI (s) (28:78) [05:25:50:569]: Doing action: UnregisterTypeLibraries
    Action 05:25:50: UnregisterTypeLibraries. Unregistering type libraries
    Action start 05:25:50: UnregisterTypeLibraries.
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: TypeLib
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Component`.`Action`=0)
    Action ended 05:25:50: UnregisterTypeLibraries. Return value 0.
    MSI (s) (28:78) [05:25:50:569]: Doing action: RemoveODBC
    Action 05:25:50: RemoveODBC. Removing ODBC components
    Action start 05:25:50: RemoveODBC.
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: ODBCDataSource
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registr ation` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: ODBCTranslator
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: ODBCDriver
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2711 2: ODBCDriverManager
    1: Removing ODBC components
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2711 2: ODBCDriverManager64
    Action ended 05:25:50: RemoveODBC. Return value 1.
    MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterFonts
    Action 05:25:50: UnregisterFonts. Unregistering fonts
    Action start 05:25:50: UnregisterFonts.
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: Font
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
    Action ended 05:25:50: UnregisterFonts. Return value 1.
    MSI (s) (28:78) [05:25:50:584]: Doing action: RemoveRegistryValues
    Action 05:25:50: RemoveRegistryValues. Removing system registry values
    Action start 05:25:50: RemoveRegistryValues.
    Action ended 05:25:50: RemoveRegistryValues. Return value 1.
    MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterClassInfo
    Action 05:25:50: UnregisterClassInfo. Unregister class servers
    Action start 05:25:50: UnregisterClassInfo.
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: Class
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 05:25:50: UnregisterClassInfo. Return value 0.
    MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterExtensionInfo
    Action 05:25:50: UnregisterExtensionInfo. Unregistering extension servers
    Action start 05:25:50: UnregisterExtensionInfo.
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: Extension
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 05:25:50: UnregisterExtensionInfo. Return value 0.
    MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterProgIdInfo
    Action 05:25:50: UnregisterProgIdInfo. Unregistering program identifiers
    Action start 05:25:50: UnregisterProgIdInfo.
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: ProgId
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags` , `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 05:25:50: UnregisterProgIdInfo. Return value 0.
    MSI (s) (28:78) [05:25:50:600]: Doing action: UnregisterMIMEInfo
    Action 05:25:50: UnregisterMIMEInfo. Unregistering MIME info
    Action start 05:25:50: UnregisterMIMEInfo.
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: MIME
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 05:25:50: UnregisterMIMEInfo. Return value 0.
    MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveIniValues
    Action 05:25:50: RemoveIniValues. Removing INI file entries
    Action start 05:25:50: RemoveIniValues.
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: IniFile
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile `.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
    Action ended 05:25:50: RemoveIniValues. Return value 1.
    MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveShortcuts
    Action 05:25:50: RemoveShortcuts. Removing shortcuts
    Action start 05:25:50: RemoveShortcuts.
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: Shortcut
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, null, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Feature`.`Action`, `Component`.`Action` From  `Shortcut`, `Feature`, `Component` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 05:25:50: RemoveShortcuts. Return value 0.
    MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveEnvironmentStrings
    Action 05:25:50: RemoveEnvironmentStrings. Updating environment strings
    Action start 05:25:50: RemoveEnvironmentStrings.
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: Environment
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
    Action ended 05:25:50: RemoveEnvironmentStrings. Return value 1.
    MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveDuplicateFiles
    Action 05:25:50: RemoveDuplicateFiles. Removing duplicated files
    Action start 05:25:50: RemoveDuplicateFiles.
    Action ended 05:25:50: RemoveDuplicateFiles. Return value 1.
    MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveFolders
    Action 05:25:50: RemoveFolders. Removing folders
    Action start 05:25:50: RemoveFolders.
    Action ended 05:25:50: RemoveFolders. Return value 1.
    MSI (s) (28:78) [05:25:50:600]: Doing action: CreateFolders
    Action 05:25:50: CreateFolders. Creating folders
    Action start 05:25:50: CreateFolders.
    CreateFolders: Folder: Creating folders
    Action ended 05:25:50: CreateFolders. Return value 1.
    MSI (s) (28:78) [05:25:50:600]: Doing action: MoveFiles
    Action 05:25:50: MoveFiles. Moving files
    Action start 05:25:50: MoveFiles.
    Action ended 05:25:50: MoveFiles. Return value 1.
    MSI (s) (28:78) [05:25:50:600]: Doing action: InstallFiles
    Action 05:25:50: InstallFiles. Copying new files
    Action start 05:25:50: InstallFiles.
    MSI (s) (28:78) [05:25:50:616]: Dumping binary patch manager data...
    MSI (s) (28:78) [05:25:50:616]: The file represented by File table key 'InstallAX64.exe' has no eligible binary patches
    InstallFiles: File: Copying new files,  Directory: ,  Size:
    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: MsiPatchOldAssemblyFile
    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2228 2:  3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE  `MsiPatchOldAssemblyFile`.`File_` = ?
    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: MsiSFCBypass
    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: MsiPatchHeaders
    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: PatchPackage
    Action ended 05:25:50: InstallFiles. Return value 1.
    MSI (s) (28:78) [05:25:50:616]: Doing action: NewCustomAction1
    Action 05:25:50: NewCustomAction1.
    Action start 05:25:50: NewCustomAction1.
    NewCustomAction1:
    Action ended 05:25:50: NewCustomAction1. Return value 1.
    MSI (s) (28:78) [05:25:50:616]: Doing action: PatchFiles
    Action 05:25:50: PatchFiles. Patching files
    Action start 05:25:50: PatchFiles.
    Action ended 05:25:50: PatchFiles. Return value 1.
    MSI (s) (28:78) [05:25:50:616]: Doing action: DuplicateFiles
    Action 05:25:50: DuplicateFiles. Creating duplicate files
    Action start 05:25:50: DuplicateFiles.
    Action ended 05:25:50: DuplicateFiles. Return value 1.
    MSI (s) (28:78) [05:25:50:616]: Doing action: BindImage
    Action 05:25:50: BindImage. Binding executables
    Action start 05:25:50: BindImage.
    Action ended 05:25:50: BindImage. Return value 1.
    MSI (s) (28:78) [05:25:50:631]: Doing action: CreateShortcuts
    Action 05:25:50: CreateShortcuts. Creating shortcuts
    Action start 05:25:50: CreateShortcuts.
    CreateShortcuts: Shortcut: Creating shortcuts
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Shortcut
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, `FileName`, `Component`.`Directory_`, `Arguments`, `WkDir`, `Icon_`, `IconIndex`, `Hotkey`, `ShowCmd`, `Shortcut`.`Description`, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Component`.`Action`, `Target`, `ComponentId`, `Feature`.`Action`, `Component`.`Installed`, `DisplayResourceDLL`, `DisplayResourceId`, `DescriptionResourceDLL`, `DescriptionResourceId` From `Shortcut`, `Feature`, `Component`, `File` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
    Action ended 05:25:50: CreateShortcuts. Return value 0.
    MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterClassInfo
    Action 05:25:50: RegisterClassInfo. Registering class servers
    Action start 05:25:50: RegisterClassInfo.
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Class
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
    Action ended 05:25:50: RegisterClassInfo. Return value 0.
    MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterExtensionInfo
    Action 05:25:50: RegisterExtensionInfo. Registering extension servers
    Action start 05:25:50: RegisterExtensionInfo.
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Extension
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
    Action ended 05:25:50: RegisterExtensionInfo. Return value 0.
    MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterProgIdInfo
    Action 05:25:50: RegisterProgIdInfo. Registering program identifiers
    Action start 05:25:50: RegisterProgIdInfo.
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: ProgId
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
    Action ended 05:25:50: RegisterProgIdInfo. Return value 0.
    MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterMIMEInfo
    Action 05:25:50: RegisterMIMEInfo. Registering MIME info
    Action start 05:25:50: RegisterMIMEInfo.
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: MIME
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
    Action ended 05:25:50: RegisterMIMEInfo. Return value 0.
    MSI (s) (28:78) [05:25:50:631]: Doing action: WriteRegistryValues
    Action 05:25:50: WriteRegistryValues. Writing system registry values
    Action start 05:25:50: WriteRegistryValues.
    WriteRegistryValues: Key: Writing system registry values, Name: , Value:
    Action ended 05:25:50: WriteRegistryValues. Return value 1.
    MSI (s) (28:78) [05:25:50:631]: Doing action: WriteIniValues
    Action 05:25:50: WriteIniValues. Writing INI file values
    Action start 05:25:50: WriteIniValues.
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: IniFile
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile `.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
    Action ended 05:25:50: WriteIniValues. Return value 1.
    MSI (s) (28:78) [05:25:50:631]: Doing action: WriteEnvironmentStrings
    Action 05:25:50: WriteEnvironmentStrings. Updating environment strings
    Action start 05:25:50: WriteEnvironmentStrings.
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Environment
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
    Action ended 05:25:50: WriteEnvironmentStrings. Return value 1.
    MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterFonts
    Action 05:25:50: RegisterFonts. Registering fonts
    Action start 05:25:50: RegisterFonts.
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: Font
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
    Action ended 05:25:50: RegisterFonts. Return value 1.
    MSI (s) (28:78) [05:25:50:647]: Doing action: InstallODBC
    Action 05:25:50: InstallODBC. Installing ODBC components
    Action start 05:25:50: InstallODBC.
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2711 2: ODBCDriverManager
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2711 2: ODBCDriverManager64
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ODBCDriver
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`Fil eName`,`File_Setup`,`Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ODBCTranslator
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`,`RuntimeFlags`,` Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ODBCDataSource
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registr ation` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
    Action ended 05:25:50: InstallODBC. Return value 0.
    MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterTypeLibraries
    Action 05:25:50: RegisterTypeLibraries. Registering type libraries
    Action start 05:25:50: RegisterTypeLibraries.
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: TypeLib
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes`, `Component`.`RuntimeFlags` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Component`.`Action`=1 OR `Component`.`Action`=2) OR (`Component`.`Action` = null AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2)))
    Action ended 05:25:50: RegisterTypeLibraries. Return value 0.
    MSI (s) (28:78) [05:25:50:647]: Doing action: SelfRegModules
    Action 05:25:50: SelfRegModules. Registering modules
    Action start 05:25:50: SelfRegModules.
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: SelfReg
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: SelfReg 4: Select `FileAction`.`FileName`,`FileAction`.`Directory_`,`FileAction`.`Actio n`, `FileAction`.`Component_`,`SelfReg`.`File_` From `SelfReg`, `FileAction` Where `SelfReg`.`File_` = `FileAction`.`File`  And (`FileAction`.`Action` = 1 OR `FileAction`.`Action` = 2)
    Action ended 05:25:50: SelfRegModules. Return value 1.
    MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterComPlus
    Action 05:25:50: RegisterComPlus. Registering COM+ Applications and Components
    Action start 05:25:50: RegisterComPlus.
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: Complus
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
    Action ended 05:25:50: RegisterComPlus. Return value 0.
    MSI (s) (28:78) [05:25:50:647]: Doing action: InstallServices
    Action 05:25:50: InstallServices. Installing new services
    Action start 05:25:50: InstallServices.
    MSI (s) (28:78) [05:25:50:647]: Detected older ServiceInstall table schema
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ServiceInstall
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ServiceInstall 4: SELECT `ServiceInstall`,`Name`,`DisplayName`,`ServiceType`,`StartType`,`Erro rControl`,`LoadOrderGroup`,`Dependencies`,`StartName`,`Password`,`Comp onentId`,`Directory_`,`FileName`,`Arguments` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
    Action ended 05:25:50: InstallServices. Return value 1.
    MSI (s) (28:78) [05:25:50:647]: Doing action: StartServices
    Action 05:25:50: StartServices. Starting services
    Action start 05:25:50: StartServices.
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ServiceControl
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
    Action ended 05:25:50: StartServices. Return value 1.
    MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterUser
    Action 05:25:50: RegisterUser. Registering user
    Action start 05:25:50: RegisterUser.
    RegisterUser: Registering user
    Action ended 05:25:50: RegisterUser. Return value 1.
    MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterProduct
    Action 05:25:50: RegisterProduct. Registering product
    Action start 05:25:50: RegisterProduct.
    RegisterProduct: Registering product
    MSI (s) (28:78) [05:25:50:647]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
    Action ended 05:25:50: RegisterProduct. Return value 1.
    MSI (s) (28:78) [05:25:50:647]: Doing action: PublishComponents
    Action 05:25:50: PublishComponents. Publishing qualified components
    Action start 05:25:50: PublishComponents.
    MSI (s) (28:78) [05:25:50:663]: Note: 1: 2205 2:  3: PublishComponent
    MSI (s) (28:78) [05:25:50:663]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
    Action ended 05:25:50: PublishComponents. Return value 0.
    MSI (s) (28:78) [05:25:50:663]: Doing action: MsiPublishAssemblies
    Action 05:25:50: MsiPublishAssemblies. Publishing assembly information
    Action start 05:25:50: MsiPublishAssemblies.
    MSI (s) (28:78) [05:25:50:663]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (s) (28:78) [05:25:50:663]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
    Action ended 05:25:50: MsiPublishAssemblies. Return value 0.
    MSI (s) (28:78) [05:25:50:663]: Doing action: PublishFeatures
    Action 05:25:50: PublishFeatures. Publishing product features
    Action start 05:25:50: PublishFeatures.
    PublishFeatures: Feature: Publishing product features
    Action ended 05:25:50: PublishFeatures. Return value 1.
    MSI (s) (28:78) [05:25:50:663]: Doing action: PublishProduct
    Action 05:25:50: PublishProduct. Publishing product information
    Action start 05:25:50: PublishProduct.
    1: Publishing product information
    Action ended 05:25:50: PublishProduct. Return value 1.
    MSI (s) (28:78) [05:25:50:663]: Skipping action: ScheduleReboot (condition is false)
    MSI (s) (28:78) [05:25:50:663]: Doing action: InstallFinalize
    Action 05:25:50: InstallFinalize.
    Action start 05:25:50: InstallFinalize.
    MSI (s) (28:78) [05:25:50:663]: Running Script: C:\Windows\Installer\MSI2E1D.tmp
    MSI (s) (28:78) [05:25:50:663]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
    MSI (s) (28:78) [05:25:50:663]: Machine policy value 'DisableRollback' is 0
    MSI (s) (28:78) [05:25:50:663]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installe r\Rollback\Scripts 3: 2
    MSI (s) (28:78) [05:25:50:678]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1082927930,LangId=1 033,Platform=589824,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVers ion=4,ScriptAttributes=1)
    MSI (s) (28:78) [05:25:50:678]: Executing op: ProductInfo(ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},Product Name=Adobe Flash Player 11 ActiveX (x64),PackageName=install_flash_player_11_active_x_64bit.msi,Language =1033,Version=184680650,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPROD UCTICON.exe,,PackageCode={56994055-C101-488E-A9CB-CF207652B759},,,Inst anceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags=3)
    MSI (s) (28:78) [05:25:50:678]: Executing op: DialogInfo(Type=0,Argument=1033)
    MSI (s) (28:78) [05:25:50:678]: Executing op: DialogInfo(Type=1,Argument=Adobe Flash Player 11 ActiveX (x64))
    MSI (s) (28:78) [05:25:50:678]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDes cription=Removing backup files,CleanupTemplate=File: [1])
    MSI (s) (28:78) [05:25:50:678]: Executing op: SetBaseline(Baseline=0,)
    MSI (s) (28:78) [05:25:50:678]: Executing op: SetBaseline(Baseline=1,)
    MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
    Action 5:25:50: ProcessComponents. Updating component registration
    MSI (s) (28:78) [05:25:50:678]: Executing op: ProgressTotal(Total=2,Type=1,ByteEquivalent=24000)
    MSI (s) (28:78) [05:25:50:678]: Executing op: ComponentRegister(ComponentId={6EF6969F-DD13-4E22-AA5B-47F75A5D7633}, KeyPath=C:\Windows\system32\Macromed\Flash\,State=3,,Disk=1,SharedDllR efCount=0,BinaryType=1)
    1: {5C804EBB-475F-4555-A225-1D6573F158BD} 2: {6EF6969F-DD13-4E22-AA5B-47F75A5D7633} 3: C:\Windows\system32\Macromed\Flash\
    MSI (s) (28:78) [05:25:50:678]: Executing op: ComponentRegister(ComponentId={6962420C-65FE-4F17-8BAF-8E36FC85EF6F}, KeyPath=C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe,State=3,,Disk =1,SharedDllRefCount=1,BinaryType=1)
    1: {5C804EBB-475F-4555-A225-1D6573F158BD} 2: {6962420C-65FE-4F17-8BAF-8E36FC85EF6F} 3: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe
    MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
    Action 5:25:50: RemoveODBC. Removing ODBC components
    MSI (s) (28:78) [05:25:50:678]: Executing op: ODBCDriverManager(,BinaryType=0)
    MSI (s) (28:78) [05:25:50:678]: Executing op: ODBCDriverManager(,BinaryType=1)
    MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
    Action 5:25:50: CreateFolders. Creating folders
    MSI (s) (28:78) [05:25:50:678]: Executing op: FolderCreate(Folder=C:\Windows\system32\Macromed\Flash\,Foreign=0,,)
    CreateFolders: Folder: C:\Windows\system32\Macromed\Flash\
    MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
    Action 5:25:50: InstallFiles. Copying new files
    MSI (s) (28:78) [05:25:50:678]: Executing op: ProgressTotal(Total=8767136,Type=0,ByteEquivalent=1)
    MSI (s) (28:78) [05:25:50:678]: Executing op: SetTargetFolder(Folder=C:\Users\Ad~1\AppData\Local\Temp\)
    MSI (s) (28:78) [05:25:50:678]: Executing op: SetSourceFolder(Folder=1\Temp\)
    MSI (s) (28:78) [05:25:50:678]: Executing op: ChangeMedia(MediaVolumeLabel=DISK1,MediaPrompt=Please insert the disk: 1,MediaCabinet=Data1.cab,BytesPerTick=65536,CopierType=2,ModuleFileNa me=C:\Windows\Installer\1201d91.msi,,,,,IsFirstPhysicalMedia=1)
    MSI (s) (28:78) [05:25:50:678]: Executing op: FileCopy(SourceName=INSTAL~1.EXE|InstallAX64.exe,SourceCabKey=Install AX64.exe,DestName=InstallAX64.exe,Attributes=16384,FileSize=8767136,Pe rTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,Version=11.2.202.228,Languag e=1033,InstallMode=58982400,,,,,,,)
    MSI (s) (28:78) [05:25:50:678]: File: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe; To be installed; Won't patch; No existing file
    MSI (s) (28:78) [05:25:50:678]: Source for file 'InstallAX64.exe' is compressed
    InstallFiles: File: InstallAX64.exe,  Directory: C:\Users\Ad~1\AppData\Local\Temp\,  Size: 8767136
    MSI (s) (28:78) [05:25:50:772]: Executing op: CacheSizeFlush(,)
    MSI (s) (28:78) [05:25:50:772]: Executing op: ActionStart(Name=NewCustomAction1,,)
    Action 5:25:50: NewCustomAction1.
    MSI (s) (28:78) [05:25:50:772]: Executing op: CustomActionSchedule(Action=NewCustomAction1,ActionType=3090,Source=C :\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe,Target=-install -msi,)
    CustomAction NewCustomAction1 returned actual error code 1032 (note this may not be 100% accurate if translation happened inside sandbox)
    MSI (s) (28:78) [05:25:53:788]: Note: 1: 1722 2: NewCustomAction1 3: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe 4: -install -msi
    Info 2835.The control ErrorIcon was not found on dialog SetupError.
    Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe, command: -install -msi
    MSI (s) (28:78) [05:25:58:694]: Product: Adobe Flash Player 11 ActiveX (x64) -- Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe, command: -install -msi
    Action ended 05:25:58: InstallFinalize. Return value 3.
    MSI (s) (28:78) [05:25:58:694]: User policy value 'DisableRollback' is 0
    MSI (s) (28:78) [05:25:58:694]: Machine policy value 'DisableRollback' is 0
    MSI (s) (28:78) [05:25:58:694]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1082927930,LangId=1 033,Platform=589824,ScriptType=2,ScriptMajorVersion=21,ScriptMinorVers ion=4,ScriptAttributes=1)
    MSI (s) (28:78) [05:25:58:694]: Executing op: DialogInfo(Type=0,Argument=1033)
    MSI (s) (28:78) [05:25:58:694]: Executing op: DialogInfo(Type=1,Argument=Adobe Flash Player 11 ActiveX (x64))
    MSI (s) (28:78) [05:25:58:694]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDes cription=Removing backup files,CleanupTemplate=File: [1])
    Action 5:25:58: Rollback. Rolling back action:
    Rollback: NewCustomAction1
    MSI (s) (28:78) [05:25:58:694]: Executing op: ActionStart(Name=NewCustomAction1,,)
    MSI (s) (28:78) [05:25:58:694]: Executing op: ProductInfo(ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},Product Name=Adobe Flash Player 11 ActiveX (x64),PackageName=install_flash_player_11_active_x_64bit.msi,Language =1033,Version=184680650,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPROD UCTICON.exe,,PackageCode={56994055-C101-488E-A9CB-CF207652B759},,,Inst anceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags=3)
    Rollback: Copying new files
    MSI (s) (28:78) [05:25:58:694]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
    MSI (s) (28:78) [05:25:58:694]: Executing op: SetTargetFolder(Folder=C:\Users\Ad~1\AppData\Local\Temp\)
    MSI (s) (28:78) [05:25:58:694]: Executing op: FileRemove(,FileName=C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe ,,)
    Rollback: Creating folders
    MSI (s) (28:78) [05:25:58:709]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
    MSI (s) (28:78) [05:25:58:709]: Executing op: FolderCreate(Folder=C:\Windows\system32\Macromed\Flash\,Foreign=0,Sec urityDescriptor=BinaryData,)
    Rollback: Removing ODBC components
    MSI (s) (28:78) [05:25:58:709]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
    Rollback: Updating component registration
    MSI (s) (28:78) [05:25:58:709]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
    MSI (s) (28:78) [05:25:58:709]: Executing op: ComponentUnregister(ComponentId={6962420C-65FE-4F17-8BAF-8E36FC85EF6F },ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},BinaryType=1,)
    MSI (s) (28:78) [05:25:58:709]: Executing op: ComponentUnregister(ComponentId={6EF6969F-DD13-4E22-AA5B-47F75A5D7633 },ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},BinaryType=1,)
    MSI (s) (28:78) [05:25:58:709]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=0)
    MSI (s) (28:78) [05:25:58:709]: Error in rollback skipped. Return: 5
    MSI (s) (28:78) [05:25:58:709]: Note: 1: 2318 2:
    MSI (s) (28:78) [05:25:58:709]: Calling SRSetRestorePoint API. dwRestorePtType: 13, dwEventType: 103, llSequenceNumber: 390, szDescription: "".
    MSI (s) (28:78) [05:25:58:709]: The call to SRSetRestorePoint API succeeded. Returned status: 0.
    MSI (s) (28:78) [05:25:58:709]: Unlocking Server
    MSI (s) (28:78) [05:25:59:350]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
    Action ended 05:25:59: INSTALL. Return value 3.
    Property(S): DiskPrompt = [1]
    Property(S): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
    Property(S): ProductCode = {5C804EBB-475F-4555-A225-1D6573F158BD}
    Property(S): ProductToBeRegistered = 1
    Property(S): SourcedirProduct = {5C804EBB-475F-4555-A225-1D6573F158BD}
    Property(S): SOURCEDIR = C:\Users\Admin\Desktop\
    Property(S): VersionNT = 601
    Property(S): TARGETDIR = E:\
    Property(S): ALLUSERSPROFILE = C:\ProgramData\
    Property(S): PrimaryVolumeSpaceRemaining = 0
    Property(S): PrimaryVolumeSpaceRequired = 0
    Property(S): PrimaryVolumeSpaceAvailable = 0
    Property(S): OutOfNoRbDiskSpace = 0
    Property(S): OutOfDiskSpace = 0
    Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
    Property(S): MACROMED = C:\Windows\system32\Macromed\
    Property(S): FLASH = C:\Windows\system32\Macromed\Flash\
    Property(S): INSTALLDIR = C:\Windows\system32\Macromed\Flash\
    Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
    Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
    Property(S): System64Folder = C:\Windows\system32\
    Property(S): CostingComplete = 1
    Property(S): SourceDir = C:\Users\Admin\Desktop\
    Property(S): TempFolder = C:\Users\Ad~1\AppData\Local\Temp\
    Property(S): USERPROFILE = C:\Users\Admin\
    Property(S): Preselected = 1
    Property(S): UILevel = 5
    Property(S): OriginalDatabase = C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
    Property(S): DATABASE = C:\Windows\Installer\1201d91.msi
    Property(S): Privileged = 1
    Property(S): MsiRunningElevated = 1
    Property(S): RedirectedDllSupport = 2
    Property(S): MsiWin32AssemblySupport = 6.1.7601.17514
    Property(S): MsiNetAssemblySupport = 4.0.30319.1
    Property(S): Date = 4/12/2012
    Property(S): Time = 5:25:59
    Property(S): TTCSupport = 1
    Property(S): ColorBits = 32
    Property(S): TextInternalLeading = 3
    Property(S): TextHeight = 16
    Property(S): BorderSide = 1
    Property(S): BorderTop = 1
    Property(S): CaptionHeight = 22
    Property(S): ScreenY = 768
    Property(S): ISCHECKFORPRODUCTUPDATES = 1
    Property(S): ApplicationUsers = AllUsers
    Property(S): AgreeToLicense = No
    Property(S): _IsMaintenance = Change
    Property(S): RestartManagerOption = CloseRestart
    Property(S): IS_SQLSERVER_USERNAME = sa
    Property(S): IS_SQLSERVER_AUTHENTICATION = 0
    Property(S): SetupType = Typical
    Property(S): _IsSetupTypeMin = Typical
    Property(S): Display_IsBitmapDlg = 1
    Property(S): ScreenX = 1024
    Property(S): ProductName = Adobe Flash Player 11 ActiveX (x64)
    Property(S): ALLUSERS = 1
    Property(S): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
    Property(S): ARPNOMODIFY = 1
    Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
    Property(S): ARPURLINFOABOUT = http://www.adobe.com
    Property(S): SystemLanguageID = 1033
    Property(S): ARPURLUPDATEINFO = http://www.adobe.com/go/getflashplayer
    Property(S): DWUSINTERVAL = 30
    Property(S): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE 08FD9AC
    Property(S): DefaultUIFont = Tahoma8
    Property(S): DialogCaption = InstallShield for Windows Installer
    Property(S): DisplayNameCustom = Custom
    Property(S): DisplayNameMinimal = Minimal
    Property(S): DisplayNameTypical = Typical
    Property(S): ErrorDialog = SetupError
    Property(S): INSTALLLEVEL = 100
    Property(S): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine.  If available, please run ISScript.msi, or contact your support personnel for further assistance.
    Property(S): ISVROOT_PORT_NO = 0
    Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
    Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
    Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
    Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
    Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
    Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
    Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
    Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
    Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
    Property(S): InstallChoice = AR
    Property(S): Manufacturer = Adobe Systems Incorporated
    Property(S): MsiLogging = voicewarmupx
    Property(S): NewProperty2 = 0
    Property(S): NewProperty3 = 0
    Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
    Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
    Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
    Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
    Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
    Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
    Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
    Property(S): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
    Property(S): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
    Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
    Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
    Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
    Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
    Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
    Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
    Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
    Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
    Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
    Property(S): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
    Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
    Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
    Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
    Property(S): ProductID = none
    Property(S): ProductLanguage = 1033
    Property(S): ProductVersion = 11.2.202.228
    Property(S): ProgressType0 = install
    Property(S): ProgressType1 = Installing
    Property(S): ProgressType2 = installed
    Property(S): ProgressType3 = installs
    Property(S): RebootYesNo = Yes
    Property(S): ReinstallModeText = omus
    Property(S): SHOWLAUNCHPROGRAM = 0
    Property(S): SecureCustomProperties = ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;SUPPORTDIR
    Property(S): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
    Property(S): RemoveFilesCA = C:\Windows\system32\Macromed\Flash\
    Property(S): ARPINSTALLLOCATION = C:\Windows\system32\Macromed\Flash\
    Property(S): ComputerName = NSDQ01
    Property(S): UserLanguageID = 1033
    Property(S): UserSID = S-1-5-21-2660183097-2710711284-1203379116-500
    Property(S): LogonUser = Admin
    Property(S): AdminUser = 1
    Property(S): MsiTrueAdminUser = 1
    Property(S): VirtualMemory = 6406
    Property(S): PhysicalMemory = 4094
    Property(S): Intel = 6
    Property(S): Msix64 = 6
    Property(S): MsiAMD64 = 6
    Property(S): ShellAdvtSupport = 1
    Property(S): OLEAdvtSupport = 1
    Property(S): GPTSupport = 1
    Property(S): FontsFolder = C:\Windows\Fonts\
    Property(S): DesktopFolder = C:\Users\Public\Desktop\
    Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
    Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
    Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
    Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
    Property(S): MyPicturesFolder = C:\Users\Admin\Pictures\
    Property(S): LocalAppDataFolder = C:\Users\Admin\AppData\Local\
    Property(S): CommonAppDataFolder = C:\ProgramData\
    Property(S): USERNAME = Viking
    Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
    Property(S): SendToFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo\
    Property(S): RecentFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent\
    Property(S): PrintHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
    Property(S): PersonalFolder = C:\Users\Admin\Documents\
    Property(S): NetHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
    Property(S): FavoritesFolder = C:\Users\Admin\Favorites\
    Property(S): AppDataFolder = C:\Users\Admin\AppData\Roaming\
    Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
    Property(S): ProgramFiles64Folder = C:\Program Files\
    Property(S): ProgramFilesFolder = C:\Program Files (x86)\
    Property(S): RemoteAdminTS = 1
    Property(S): SystemFolder = C:\Windows\SysWOW64\
    Property(S): WindowsVolume = C:\
    Property(S): WindowsFolder = C:\Windows\
    Property(S): MsiNTProductType = 1
    Property(S): ServicePackLevelMinor = 0
    Property(S): ServicePackLevel = 1
    Property(S): WindowsBuild = 7601
    Property(S): VersionNT64 = 601
    Property(S): VersionMsi = 5.00
    Property(S): MsiSystemRebootPending = 1
    Property(S): ADDLOCAL = FlashPlayerAXInstaller
    Property(S): CURRENTDIRECTORY = C:\Users\Admin\Desktop
    Property(S): CLIENTUILEVEL = 0
    Property(S): CLIENTPROCESSID = 4596
    Property(S): VersionDatabase = 200
    Property(S): ACTION = INSTALL
    Property(S): EXECUTEACTION = INSTALL
    Property(S): ROOTDRIVE = E:\
    Property(S): SECONDSEQUENCE = 1
    Property(S): PackagecodeChanging = 1
    Property(S): ProductState = -1
    Property(S): PackageCode = {56994055-C101-488E-A9CB-CF207652B759}
    Property(S): MsiLogFileLocation = C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG
    MSI (s) (28:78) [05:25:59:366]: MainEngineThread is returning 1603
    MSI (s) (28:94) [05:25:59:366]: RESTART MANAGER: Session closed.
    MSI (s) (28:94) [05:25:59:366]: User policy value 'DisableRollback' is 0
    MSI (s) (28:94) [05:25:59:366]: Machine policy value 'DisableRollback' is 0
    MSI (s) (28:94) [05:25:59:366]: Incrementing counter to disable shutdown. Counter after increment: 0
    MSI (s) (28:94) [05:25:59:366]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installe r\Rollback\Scripts 3: 2
    MSI (s) (28:94) [05:25:59:381]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
    MSI (s) (28:94) [05:25:59:381]: Restoring environment variables
    MSI (c) (F4:64) [05:25:59:381]: Back from server. Return value: 1603
    MSI (c) (F4:64) [05:25:59:381]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
    MSI (c) (F4:64) [05:25:59:381]: PROPERTY CHANGE: Deleting SECONDSEQUENCE property. Its current value is '1'.
    Action ended 05:25:59: ExecuteAction. Return value 3.
    MSI (c) (F4:64) [05:25:59:381]: Doing action: SetupCompleteError
    Action 05:25:59: SetupCompleteError.
    Action start 05:25:59: SetupCompleteError.
    Action 05:25:59: SetupCompleteError. Dialog created
    Action ended 05:26:00: SetupCompleteError. Return value 2.
    Action ended 05:26:00: INSTALL. Return value 3.
    MSI (c) (F4:64) [05:26:00:694]: Destroying RemoteAPI object.
    MSI (c) (F4:DC) [05:26:00:709]: Custom Action Manager thread ending.
    Property(C): DiskPrompt = [1]
    Property(C): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
    Property(C): ProductCode = {5C804EBB-475F-4555-A225-1D6573F158BD}
    Property(C): PrimaryVolumeSpaceRemaining = 0
    Property(C): PrimaryVolumeSpaceRequired = 0
    Property(C): PrimaryVolumeSpaceAvailable = 0
    Property(C): OutOfNoRbDiskSpace = 0
    Property(C): OutOfDiskSpace = 0
    Property(C): VersionNT = 601
    Property(C): TARGETDIR = E:\
    Property(C): ALLUSERSPROFILE = C:\ProgramData\
    Property(C): SourcedirProduct = {5C804EBB-475F-4555-A225-1D6573F158BD}
    Property(C): CommonFilesFolder = C:\Program Files (x86)\Common Files\
    Property(C): MACROMED = C:\Windows\system32\Macromed\
    Property(C): FLASH = C:\Windows\system32\Macromed\Flash\
    Property(C): INSTALLDIR = C:\Windows\system32\Macromed\Flash\
    Property(C): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
    Property(C): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
    Property(C): System64Folder = C:\Windows\system32\
    Property(C): CostingComplete = 1
    Property(C): ROOTDRIVE = E:\
    Property(C): SourceDir = C:\Users\Admin\Desktop\
    Property(C): TempFolder = C:\Users\Ad~1\AppData\Local\Temp\
    Property(C): USERPROFILE = C:\Users\Admin\
    Property(C): EXECUTEACTION = INSTALL
    Property(C): ACTION = INSTALL
    Property(C): UILevel = 5
    Property(C): VersionHandler = 5.00
    Property(C): SOURCEDIR = C:\Users\Admin\Desktop\
    Property(C): OriginalDatabase = C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
    Property(C): DATABASE = C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
    Property(C): Privileged = 1
    Property(C): MsiRunningElevated = 1
    Property(C): RedirectedDllSupport = 2
    Property(C): MsiWin32AssemblySupport = 6.1.7601.17514
    Property(C): MsiNetAssemblySupport = 4.0.30319.1
    Property(C): Date = 4/12/2012
    Property(C): Time = 05:26:00
    Property(C): TTCSupport = 1
    Property(C): ISCHECKFORPRODUCTUPDATES = 1
    Property(C): ApplicationUsers = AllUsers
    Property(C): AgreeToLicense = No
    Property(C): _IsMaintenance = Change
    Property(C): RestartManagerOption = CloseRestart
    Property(C): IS_SQLSERVER_USERNAME = sa
    Property(C): IS_SQLSERVER_AUTHENTICATION = 0
    Property(C): SetupType = Typical
    Property(C): _IsSetupTypeMin = Typical
    Property(C): Display_IsBitmapDlg = 1
    Property(C): ProductName = Adobe Flash Player 11 ActiveX (x64)
    Property(C): ALLUSERS = 1
    Property(C): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
    Property(C): ARPNOMODIFY = 1
    Property(C): ARPPRODUCTICON = ARPPRODUCTICON.exe
    Property(C): ARPURLINFOABOUT = http://www.adobe.com
    Property(C): ColorBits = 32
    Property(C): ARPURLUPDATEINFO = http://www.adobe.com/go/getflashplayer
    Property(C): DWUSINTERVAL = 30
    Property(C): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE 08FD9AC
    Property(C): DefaultUIFont = Tahoma8
    Property(C): DialogCaption = InstallShield for Windows Installer
    Property(C): DisplayNameCustom = Custom
    Property(C): DisplayNameMinimal = Minimal
    Property(C): DisplayNameTypical = Typical
    Property(C): ErrorDialog = SetupError
    Property(C): INSTALLLEVEL = 100
    Property(C): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine.  If available, please run ISScript.msi, or contact your support personnel for further assistance.
    Property(C): ISVROOT_PORT_NO = 0
    Property(C): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
    Property(C): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
    Property(C): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
    Property(C): IS_PROGMSG_XML_COSTING = Costing XML files...
    Property(C): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
    Property(C): IS_PROGMSG_XML_FILES = Performing XML file changes...
    Property(C): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
    Property(C): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
    Property(C): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
    Property(C): InstallChoice = AR
    Property(C): Manufacturer = Adobe Systems Incorporated
    Property(C): MsiLogging = voicewarmupx
    Property(C): NewProperty2 = 0
    Property(C): NewProperty3 = 0
    Property(C): PIDTemplate = 12345<###-%%%%%%%>@@@@@
    Property(C): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
    Property(C): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
    Property(C): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
    Property(C): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
    Property(C): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
    Property(C): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
    Property(C): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
    Property(C): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
    Property(C): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
    Property(C): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
    Property(C): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
    Property(C): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
    Property(C): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
    Property(C): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
    Property(C): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
    Property(C): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
    Property(C): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
    Property(C): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
    Property(C): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
    Property(C): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
    Property(C): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
    Property(C): ProductID = none
    Property(C): ProductLanguage = 1033
    Property(C): ProductVersion = 11.2.202.228
    Property(C): ProgressType0 = install
    Property(C): ProgressType1 = Installing
    Property(C): ProgressType2 = installed
    Property(C): ProgressType3 = installs
    Property(C): RebootYesNo = Yes
    Property(C): ReinstallModeText = omus
    Property(C): SHOWLAUNCHPROGRAM = 0
    Property(C): SecureCustomProperties = ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;SUPPORTDIR
    Property(C): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
    Property(C): TextInternalLeading = 3
    Property(C): TextHeight = 16
    Property(C): BorderSide = 1
    Property(C): BorderTop = 1
    Property(C): AdminUser = 1
    Property(C): CaptionHeight = 22
    Property(C): ScreenY = 1080
    Property(C): ScreenX = 1920
    Property(C): SystemLanguageID = 1033
    Property(C): ComputerName = NSDQ01
    Property(C): UserLanguageID = 1033
    Property(C): UserSID = S-1-5-21-2660183097-2710711284-1203379116-500
    Property(C): LogonUser = Admin
    Property(C): MsiTrueAdminUser = 1
    Property(C): VirtualMemory = 6439
    Property(C): PhysicalMemory = 4094
    Property(C): Intel = 6
    Property(C): Msix64 = 6
    Property(C): MsiAMD64 = 6
    Property(C): ShellAdvtSupport = 1
    Property(C): OLEAdvtSupport = 1
    Property(C): GPTSupport = 1
    Property(C): FontsFolder = C:\Windows\Fonts\
    Property(C): DesktopFolder = C:\Users\Public\Desktop\
    Property(C): USERNAME = Viking
    Property(C): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
    Property(C): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
    Property(C): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
    Property(C): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
    Property(C): MyPicturesFolder = C:\Users\Admin\Pictures\
    Property(C): LocalAppDataFolder = C:\Users\Admin\AppData\Local\
    Property(C): CommonAppDataFolder = C:\ProgramData\
    Property(C): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
    Property(C): SendToFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo\
    Property(C): RecentFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent\
    Property(C): PrintHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
    Property(C): PersonalFolder = C:\Users\Admin\Documents\
    Property(C): NetHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
    Property(C): FavoritesFolder = C:\Users\Admin\Favorites\
    Property(C): AppDataFolder = C:\Users\Admin\AppData\Roaming\
    Property(C): CommonFiles64Folder = C:\Program Files\Common Files\
    Property(C): ProgramFiles64Folder = C:\Program Files\
    Property(C): ProgramFilesFolder = C:\Program Files (x86)\
    Property(C): RemoteAdminTS = 1
    Property(C): SystemFolder = C:\Windows\SysWOW64\
    Property(C): WindowsVolume = C:\
    Property(C): WindowsFolder = C:\Windows\
    Property(C): MsiNTProductType = 1
    Property(C): ServicePackLevelMinor = 0
    Property(C): ServicePackLevel = 1
    Property(C): WindowsBuild = 7601
    Property(C): VersionNT64 = 601
    Property(C): VersionMsi = 5.00
    Property(C): VersionDatabase = 200
    Property(C): MsiSystemRebootPending = 1
    Property(C): CLIENTPROCESSID = 4596
    Property(C): CLIENTUILEVEL = 0
    Property(C): CURRENTDIRECTORY = C:\Users\Admin\Desktop
    Property(C): PackagecodeChanging = 1
    Property(C): ProductState = -1
    Property(C): PackageCode = {56994055-C101-488E-A9CB-CF207652B759}
    Property(C): MsiLogFileLocation = C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG
    === Logging stopped: 4/12/2012  05:26:00 ===
    MSI (c) (F4:64) [05:26:00:709]: Note: 1: 1708
    MSI (c) (F4:64) [05:26:00:709]: Product: Adobe Flash Player 11 ActiveX (x64) -- Installation operation failed.
    MSI (c) (F4:64) [05:26:00:709]: Windows Installer installed the product. Product Name: Adobe Flash Player 11 ActiveX (x64). Product Version: 11.2.202.228. Product Language: 1033. Manufacturer: Adobe Systems Incorporated. Installation success or error status: 1603.
    MSI (c) (F4:64) [05:26:00:709]: Grabbed execution mutex.
    MSI (c) (F4:64) [05:26:00:709]: Cleaning up uninstalled install packages, if any exist
    MSI (c) (F4:64) [05:26:00:709]: MainEngineThread is returning 1603
    === Verbose logging stopped: 4/12/2012  05:26:00 ===
