Hi everyone!
I am creating an exporter plug-in. It works fine when I open Premiere, open a project and choose to export using my plug-in. But when i open a project directly by double clicking the project file (like untitled.prproj), my plug-in always show up a "Error compiling movie" message.
I use log4cxx to help track the plug-in, but no log was created, so my guess is that the plug-in has not even been loaded.
Could anyone tell be the differences between starting Premiere -> open a project and open a project directly by double clicking its .prproj file. In both case, which file is loaded and which file is not?
I'm very appreciated if anyone would have the same problem and tell me how to fix this. I'm really stuck here ![]()
The version is CS5.5.
And my steps are:
1. open the project by double clicking the .prproj file
2. select a file in the project
3. Choose File -> Export -> Media
4. Select my plug-in in the drop down list and choose Export
=> Error
But if take these step:
1. Open Premiere Pro
2. select a project
3. select a file in the project
4. Choose File -> Export -> Media
5. Select my plug-in in the drop down list and choose Export
the plug-in run just fine.
So I think that there are something different between opening a project directly and open Premiere and choose a project. Could you verify this for me? Thanks.
Thank you very much for your answer. That's true.
My plug-in loads an ini file to read some parameters. That file is put in the install folder (same folder with the .exe). So when I click on the .prproj file, the current directory would be the project directory, that makes the ini file not to be read and causes errors. I have fixed it now. Thanks again, man.
