Hey all,
I'd like to use a SWF file as a persistent background animation. The problem I'm running into is that it stops playing when the playhead stops. I've tried all the timimg options and no luck. In fact, when I choose the Play for rest of project option, my animation is played ON TOP of all objects, not in the background. I'm on Cap5.5 Windows7. Any help is greatly appreciated!
Cheers!
I highly doubt that the Captivate team put in the effort necessary to dig through your movie and stop anything that could be looping. So you might want to try just converting everything that's at the top level of your Flash movie into a symbol. That way, if they stop() your main timeline, the nested timeline might continue.
Good luck!
Ran into the same problem. Here's my work-around:
1. Create your background design (including the swf) in powerpoint.
2. Import the powerpoint slide to captivate.
The downside to it is that you will not have the ease of selecting it as a background. But it'll be relatively easy to paste it to every slide.
Hope it helps.
-Vic-
Thanks for the speedy response. Unfortunately, it didn't work. The PPT file failed to play in in the slide. The PPT played automatically within PPT but not once I imported it. I might be doing something wrong and, if I am, I'm open to further instruction. Thank you for your help so far.
My apologies... I was thinking gif files. Not sure how I confused it with swf. I'll test and let you know if I find something.
It would seem the challenge still stands. I still can't seem to get a persistent animation that continues independent of the playhead. Any additional thoughts are appreciated!
Cheers all!
Good luck!
That did it! So, what I ended up doing was the following:
Thank you for all your responses! I couldn't have figured this out without all your help! Hopefully this will help someone else!
have you tried adding the swf to a master slide? I tested it just now and seemed to work OK.
