dan_x3_
How to know if i'm a extended form?
Oct 27, 2011 1:33 PM
Hi, i'm developing some forms with Designer 9 sp2 and have Reader Extensions license.
Some forms are extended on a process point (non process management and start process as non-extended forms ) but have a "save as" button who i wanna hide if no extensions appli yet.
There is a way to know with javascript or formcalc lenguages if i'm "running" in a extended form?
TIA
    Oct 27, 2011 2:12 PM   in reply to dan_x3_
    I thought you might be able to test it with this:
    var testRE = event.target.appRightsValidate({}, 2, false);
    app.alert(testRE);
    See discussion here: http://forums.adobe.com/message/3987180#3987180.
    However it appears that it may be restricted in the security model.
    Or, I may have the syntax wrong.
    Someone else may have a better handle on this,
    Niall
    Oct 27, 2011 2:54 PM   in reply to dan_x3_
    Try
    var test=this.appRightsValidate();
    if the PDF is Reader Extended Form it will return true, otherwise will return false.
    Oct 27, 2011 4:47 PM   in reply to dan_x3_
    Can you send me test file so I can find out why the script is not working on your test file? My email is syen@adobe.com
