Hi I need help with adobe lightbox gallery.I am building a website using dreamweaver cs5.
My problem is that the gallery works perfect in "live view" but when I check it in the browsers the pictures do not show at all.
What am I doing wrong .Please help.
Thanks for answering! I removed the other folders (the css, scripts and images) to try them in another folder, but when I tried to install again from within Dreamweaver, it wouldn't add those. I finally got it to work by using the Save Files option from within Widget Browser. But it didn't put all of the code into the page, I had to copy and paste the missing portions from the code view in Widget Browser. Finally it worked!
I appreciate your response!
I have come across this problem.
In the lightbox.js file you have a navigation script which reads images/lightbox/lightbox-ico-loading.gif etc etc
make sure your folder spelling and case is the same.
i.e capital 'I' for images will not work if your folder is spelt with a lower case
Hope this makes it clear and helps.
Jerry
I am having the same problem.
My webpage works fine on my computer, but the website I uploaded is not displaying pre/next & close button. All the images are where they are supposed to be.
I've verified the links on the html on the page and CSS files... what else do I need to check to make this work??
Hi All:
From my experience with other people having problems with the widget, here are some things you can check when it doesn't work:
I hope this helps.
