i've found a solution!!!
i'm sure is not the best but at least do the trick to compile and install in emulator. Just follow this steps:
- on your Android SDK folder, locate the file "build.xml" inside /tools/ant
- open the file and search the string
<target name="install"
- right after the closing of <target> and before <do-only-if-not-library>
insert this code:
<property name="out.packaged.file" location="${out.absolute.dir}/${ant.project.name}-debug-unaligned.apk" />
<property name="out.final.file" location="${out.absolute.dir}/${ant.project.name}-debug.apk" />
it should look something like this
that will let you "build and emulate" as usual (at least it worked on my iMac and Macbook). The problem with this approach is when Adroid gets updated it will overwrite build.xml and i must re-edit the file in order to have dreamweaver working :S
hope someone here with a deeper knowledge of android/dreamweaver find a better way to fix this problem ![]()
THANK YOU!!!! ![]()
I just purchased Dreamweaver 5.5. I've never paid so much money for a program, but I wanted easy mobile app development. Dreamweaver is well known and I've used older versons years ago. I'm no rich person. I saved a long time to get this program. The mobile integration with both Android and iOS has been a nightmare. NOTHING worked as stated by Adobe. For this kind of money, the program should "just work".
You solved half of my problem with the Android sdk and emulator. Had to install the sdk manually. The so called Dreamweaver automatic set up never worked for me. How is anyone without programming knowledge of xml or other languages supposed to know to dig deeply into the developer files and do this?
After installing your fix, I saw my first actual application running on an android emulator. I've had Dreamweaver for almost two weeks. I've been continually fighting to try get it to recognize the two development environments. This has been a nightmare. I've seen so many other posts that are stating the same problems.
Now, if only I can find a way to get iOS recognized.
You have my gratitude for your post.
Thanks again.
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
