Issue with importing effects settings from 3.0 to CS5.5
Oct 29, 2011 12:58 PM
Several times I've attempted to import effects settings from 3.0 into 5.5 using the 5.5 Import>Application Settings function.  Each time it says that it is unable to do it because of some unknown error.  Is there another way to import the settings?  I'm in the middle of an album project in 3.0.1 and would like to try 5.5 with some of these existing sessions.  I've used the SuiteSpot studios Ses2Sesx program to translate the session.  It imports fine, but none of the effects or racks import.  I very much want to be able to do that.
    Oct 30, 2011 7:47 AM   in reply to Eric S 1
    Are these fx or racks native internal fx or external vsts?
    Can you give some example of the fxs you mean?
    Nov 16, 2011 12:24 AM   in reply to Eric S 1
    Sorry Eric - I have moved to Win7 x64 and IE9 and can no longer access this forum unless I use my XP test PC.
    If you want to send one or two of your ses files I will see what I can do regarding converting the settings of the external VSTs.
    What would also be helpful is an sesx file which has these vsts in it and maybe a screen dump of each vsts setting in the fx rack.
    Contact me via the aatranslator web site if you want to pursue this with me
    M
