Hi all
I would like AME (5.5.1.12, under Windows 7) to overwrite the source files that it is encoding, or if that's not possible, save the exported files to a different folder with the same file names as the sources.
However I can see no way to do this without manually specifying a file name for every file. I need to process 400 files so this is not practical.
Currently AME automatically adds a "-1" suffix to the exported file name, whether it's saved in the same folder as the source or a different folder.
Can anyone advise, please?
Hi Jim,
Thanks for the reply. However, overwriting source files during a batch process is a common feature in audio/video software. It's possible in Audition, for instance, as well as in third-party programs such as Sound Forge, Wavelab and Samplitude.
Presumably in these cases the software writes to a temporary file, either in RAM or on the hard drive, before deleting the original and replacing it with the new one.
I'm surprised to hear that AME can't do this for conversions that stay within the same file format (such as the bit depth of a wave file).
Thanks for the response. I understand what you mean about NLEs, but the batch processing features I'm describing aren't non-linear, and can be used "destructively" if needed. (FWIW, Sound Forge and Wavelab aren't NLEs.)
Anyway, that aside, is there a way to stop AME from renaming outputted files with a numerical suffix, without having to specify the name for each file?
Hello,
Sorry but I don't understand what you mean by "If you want the same file name delete the previous file first" - if I am not overwriting the previous file (if by previous file you mean the source file), then how would I do what you describe?
Apologies if I'm misunderstanding something obvious.
