In process of installing Livecycle ES2.5 on Linux with WAS 7.0.0.11, I hit a roadblock while configuring Application Server.
Before this step, I created a new instance of Application server and started it successfully after changing the SOAP timeout properties and increasing the heap size for Deployer.
Now on the Livecycle configuration Manger, I filled out all the necessary fields on the Application Server Configuration Screen, but on Verify Server connection,
I get the following errror:
ALC-LCM-100-000
The error message reads " Abnormal termination of WAS JACL script for [ValidateServerCluster].
Couldnt find any helpful information about how to resolove this and proceed ? Any help will be appreciated !!
[ A screenshot of error is attached below ]
If you are using single server instance in ND, go to WAS Admin console.
On the left side, click System Administration > Deployment Manager
At the Deploymnet Manager, open Ports under Additonal Properties
and note down the port for SOAP_CONNECTOR_ADDRESS. This is the port number you should use.
Hope this helps !
