@mito
Kuler search not working?
Aug 2, 2011 11:00 AM
having problems searching for tags. Nothing shows up for any of the words...anyone else having the same problem?
    Aug 2, 2011 3:04 PM   in reply to @mito
    Yep, I am having exactly the same problem. I have spent the last hour trying to work it out and have found no solution. I will let you know if I have any luck.
    Aug 2, 2011 7:46 PM   in reply to @mito
    Thanks for reporting this issue.
    I tried on searching for tags (using tag:sixties in search box) and was getting some results for it. Can you please share how were you searching for tags?
    You may have a look into the kuler help for searching theme -
    http://kuler.adobe.com/links/kuler_help.html#Start
    Please let us know if you still face this issue.
    kuler Team
    Aug 8, 2011 12:36 PM   in reply to Ankur__Gupta
    I can also not use the search function. Has anyone found a work around or solution?
    Aug 8, 2011 12:39 PM   in reply to Poinciana123
    Just realized that search is working in Firefox but not in Safari.
    Oct 17, 2011 1:01 PM   in reply to Ankur__Gupta
    I haven't been able to get search to work for months now (on the web using FireFox nor in Photoshop). I used to be able to just type in a name (i.e. chocolate) and get results. Now, I consistently get "No results found". I've tried entering just chocolate, or tag:chocolate, or theme:chocolate, but still can't get any search results. Also tried searching chocolate* and *chocolate* - still doesn't work!
    Update: I should say it does not work with FireFox 7.0.1, but it will work in Chrome.
    Oct 18, 2011 1:25 AM   in reply to Moncoeur
    Hello Moncoeur,
    I tried in Firefox 7.0.1 . For keyword "chocolate", kuler search returned the following results (see attached snapshot) . Are you searching for any particular theme ?
    Neha
    Oct 18, 2011 3:03 PM   in reply to @mito
    This is exactly what I'm getting!
    Oct 18, 2011 3:04 PM   in reply to Neha Sirohi
    Are you on a Mac or PC? I'm on a PC and getting the same results as the screenshot in the reply from mito.
    Oct 20, 2011 9:00 AM   in reply to @mito
    It's the same issue for me. The search doesn't throw up any results.
    I've tried multiple different browsers, but no go.
    Nov 2, 2011 10:37 AM   in reply to @mito
    I'm having the same problem, using Firefox 7.0.1 on a MAC. Hasn't worked for months. Get it together Adobe. this is basic function of a website.
    Nov 2, 2011 10:58 AM   in reply to @mito
    having the same problem. yesterday it worked though! Firefox 7.0.1. and Mac
    Nov 3, 2011 8:56 AM   in reply to @mito
    I'm getting about the same issue. I first opened Kuler and was able to find the Johnny Cash Tribute, but after downloading the swatch and loading into photoshop, I wasn't able to retrieve any results either with kuler or the kuler tab in photoshop.
    Win Vista PC
    Used both Chrome and Windows
    Photoshop 5.1
    Nov 3, 2011 8:57 AM   in reply to @mito
    Having the same problem - worked a couple of days ago, but even then it was flackly at best (sometimes it would work, other times it didn't - didn't seem to be any rhyme or reason to it). Am follownig steps in a textbook. If this is what is to be expected from a company like Adobe, I don't think I want to use their products.
    Nov 10, 2011 1:52 PM   in reply to @mito
    I have been having the search problem as well.It worked just now for three searches, then quit working. I even tested it by trying the same phrase that had worked moments before.
    Nov 11, 2011 10:22 AM   in reply to @mito
    I'm having a similar problem. When accessing Kuler through CS5 extension the search is stuck on an old search for "winter" themes. When I try to type in new search term and hit enter nothing happens, it will only display the results for the winter search. I don't know if it's related but my CSreview in Indesign also won't work. It jdisplays the must sign in prompt but when I type in my login info it tells me I'm already signed in, I click ok and it goes back to the must sign in prompt. Great ideas for services adobe, too bad they're too buggy to use.
    Nov 14, 2011 8:35 PM   in reply to MichelTallichet
    Hello everyone,
    The amount of traffic on Kuler has been growing so fast in the recent past that we need to move to new search servers. This will happen in the next few weeks. In the meantime, some users may experience intermittent issues while searching for themes. Thanks for your patience and support.
    Kuler team
    Dec 20, 2011 7:45 PM   in reply to VikramSethi
    When is the work expected to be completed?  It's still not working, and we're getting compliaints via other forums/channels.
    Jan 23, 2012 2:05 AM   in reply to Chris Cox
    Hello Everyone,
    The Kuler search issue was resolved just before Christmas. We have been tracking it ever since and it seems to be stable now. The good news is that we have improved the search performance multi-fold as well.
    Our apologies for all the inconvenience that this issue has caused in the past. Please let us know if you have been running into this issue in the recent past.
    Kuler team
