I'm having significant trouble trying to get the Adobe AIR Installer to run on my 11-inch MacBook Air, running OS X Lion 10.7.2. I've tried the standard installation which said it completed properly but did not, and also tried installing from the command line.
The Files.zip file at http://cl.ly/1f0C2k3x1R3f1B1j1q0V are the fitlered log file and the crash logs associated with this issue.
Thanks in advance for any help.
—Chris
I wasn't having any problems with Adobe Air until I upgraded to 10.7.2. I tried to open up YNAB and it kept crashing and finally gave me an error that I needed Adobe Air...which I had had so not sure where it went. So I go to download it which is Adobe Air 3 now and it downloads but nothing happens when I click on install. After I try it several times, I have received an error window suggesting that I need Adobe Air to install Adobe Air! Need a fix quick....I need to get into YNAB to figure out what bills need to be paid!
Hi Becqui,
I'm Taylor, YNAB's lead developer. We have a number of customers who are experiencing the same problem with 10.7.2 and YNAB, and we started tracking the issue down yesterday. I started a thread over here: http://forums.adobe.com/message/3970954#3970954
I'm really sorry that this is happening to you! You can learn more in the response I linked to, but here is one weird thing we've learned: If you run Firefox at the same time, users are reporting that they are able to run YNAB! I don't know what that is about yet, but we'll get to the bottom of it soon. I also have a hunch this is related to saving and restoring Windows, so I am about to advice a couple of folks to temporarily disable that feature using these instructions: http://osxdaily.com/2011/07/18/disable-mac-os-x-lion-resume-window-res tore/
You can add me to the list of folks having trouble with this. Thankfully, I found this thread. The problem goes away when Firefox is on.
I was trying to use Rosetta Stone language software (which uses Air) and it wouldn't work with OS 10.7.2. At first I thought the problem was with RS, but now I realize it's Adobe.
Hi Lisa,
I am also experiencing problems with Adobe Air. After updating to Lion 10.7.2, when I turn on my computer, the HughesStatusMeter crashes. While researching the problem on the web, I came across the post on YNAB's forum, mentioned above, that said if you run Firefox then it corrects the problem (at least until you turn your computer off and on again). This workaround worked for me. When I turn on my computer, I close out the two error messages (below), open Firefox, then open the HughesStatusMeter, it again asks if I want to restore windows. Whether I choose to restore windows or not, this time the HughesStatusMeter will work. Then I can close Firefox and the HughesStatusMeter works as normal. Hughes is also looking at this issue for me. Disabling the Restore Windows feature did not fix this issue for me. If it is any help, here are the error messages that I get when I turn the computer:
I just gave this a try, brand new mac book pro I bought last night and I'm in the process of installing apps and whatnot. Couldn't get Air 3.0 installed. I could see the crashes in the console the installer was reporting but couldn't for the life of me figure out why. Sure enough I disabled automatic graphics switching and the Air install worked fine.
I'm not sure if you would need to leave it disabled for Air apps to continue to run though, I think it's just an installation issue.
Yep, I tried installing Adobe Air on 10.7.2 multiple times. Console shows the installer crashing (below).
Go to System Preferences > Energy Saver and uncheck "Automatic graphics switching" and it the install now works.
It's just Adobe trying to get back at Apple - happens all the time.
Process: Adobe AIR Installer [4493]
Path: /var/folders/*/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Identifier: com.adobe.air.Installer
Version: 3.0 (3.0.0.4080)
Code Type: X86 (Native)
Parent Process: updater [4491]
Date/Time: 2011-11-08 07:21:14.844 -0700
OS Version: Mac OS X 10.7.2 (11C74)
Report Version: 9
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000e0000020
VM Regions Near 0xe0000020:
CG shared images 00000000c6496000-00000000c649e000 [ 32K] r--/r-- SM=SHM
Submap 00000000ffff0000-00000000ffff2000 r-x/r-x process-only submap
Application Specific Information:
objc_msgSend() selector name: backingScaleFactor
objc[4493]: garbage collection is OFF
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
If I try to open Vodafone MY190 the same message as sfsavoia is generated by the system. With Firefox open and/or disabling Automatic Graphics Switching all seems to work fine for me too.
You can also resolve this issue by upgrading to 10.7.3. Please see the following post:
http://forums.adobe.com/thread/945589
Chris
I right clicked the AdobeAir Installer package to show the package contents, Then Contents > MacOS > Adobe Air Installer. Double clicked that and it ran a terminal script. And ran through the air install. The adobe air was then in my utilities folder. I had also turned off my automatic graphics switching before hand (but I don’t know if this was related) .
