Keyword hierarchy corrupted with every export
Nov 5, 2011 5:20 PM
Tags: #lightroom #problem #error #export #keyword #lightroom3.5 #lr3.5
Why oh why when I export any image from one folder to another do I end up with most keywords applied to that image written to my hierarchical keyword list as a new 1st level keyword and not under the parent keyword as they should be?  I've tried everything. I'm using Windows 7 64 bit, with the latest LR 3.  Export Synonyms, Include on Export, Export containing keywords are all checked with all the keywords and I've unchecked the Write Keywords as Hierarchy in the Export dialogue. With every export I have to clean up my keyword list and I'm at wits end with wasted hours. Any ideas ANYONE? Thanks in advance!
    Nov 5, 2011 7:27 PM   in reply to BarbLM
    Nov 5, 2011 9:45 PM   in reply to BarbLM
    Since 2007 Windows has been using "/" as the hierarchical keyword separator/delimiter. Lightroom doesn't have the option of inserting "/" between hierarchical keywords on export so the keywords show up in Windows file properties separated by "," indicating they are top level/not in a hierarchy. If you put a checkmark in "Write Keywords as a Lightroom Hierarchy", Lightroom itself,  Bridge, Expression Media 2 and a few other apps will pick up the hierarchy.
    Nov 6, 2011 8:15 AM   in reply to BarbLM
    By " export any image from one folder to another", I assume you mean you're using the File > Export command with the option Add To This Catalog?
    If so, here's what's happening: When you export with the option Add To This Catalog, that's the same as exporting to a file and then importing the file.  When you uncheck the export option Write Keywords as Hierarchy, the files get exported without the hierarchy -- their metadata contains the original leaf keywords as top-level keywords. So when the files get reimported, their keywords get read as top-level keywords.  (Note that LR treats the keyword People > John as a different keyword from the top-level keyword John.)
    To avoid this problem, you'll need to select the option Write Keywords as Hierarchy.
    But are you sure you want to export into the catalog? If you're converting a raw file into a JPEG and keeping the raw file in the catalog, then perhaps you should just use LR to move the file into the desired folder and not create a JPEG at all until you need it. If you're converting a raw file into a JPEG and discarding the raw file, then exporting into the catalog is the right thing to do. Or is there another reason you're exporting into the catalog?
    See this feedback topic for a related discussion:
    http://feedback.photoshop.com/photoshop_family/topics/tag_duplication_ in_lightroom_3
    Nov 7, 2011 2:32 PM   in reply to BarbLM
    Would it be better in order to keep a scientific name in the hierarchy
    to instead insert that name under the parent tag in the hierarchy rather
    than as a synonym?
    You're faced with a tradeoff: Make the scientific names synonyms and have them re-imported as top-level keywords.  Or make the scientific names separate keywords and sometimes forget to apply them along with their common name.
    Overall, I think LR's handling of synonyms is lacking, with other problems including: You can't search for synonyms in the Keyword List pane; and LR doesn't auto-complete synonyms when you type them in the Keyword Tags box. The Any Tag plugin provides workarounds for those latter two problems.
