Locked
Cannot install Adobe Air on Windows 7 (64 bit)
Guest
Nov 04, 2011 Nov 04, 2011
After an apparently succesfully installation of Adobe Air on a new PC with 64 bit Windows 7 operating system, it doesn't works at all. When I'm trying tu run an Adobe Air application or even the uninstaller of Adobe Air I get the message "This application requires a version of Adobe AIR which cannot be found. Please download..." . I've tried to remove all the registry entries and reinstall Adobe AIR but it didn't solve the problem.
The content of the log file is the following
[2011-11-04:07:59:52] Runtime Installer begin with version 2.5.0.16600 on Windows 7 x86
[2011-11-04:07:59:52] Commandline is:
[2011-11-04:07:59:52] No installed runtime detected
[2011-11-04:07:59:55] Relaunching with elevation
[2011-11-04:07:59:55] Launching subprocess with commandline c:\users\tibi\appdata\local\temp\airc74d.tmp\adobe air installer.exe -ei
[2011-11-04:07:59:59] Runtime Installer begin with version 2.5.0.16600 on Windows 7 x86
[2011-11-04:07:59:59] Commandline is: -stdio \\.\pipe\AIR_3156_0 -ei
[2011-11-04:07:59:59] No installed runtime detected
[2011-11-04:07:59:59] Starting silent runtime install. Installing runtime version 2.5.0.16600
[2011-11-04:07:59:59] Installing msi at c:\users\tibi\appdata\local\temp\airc74d.tmp\setup.msi with guid {46C045BF-2B3F-4BC4-8E4C-00E0CF8BD9DB}
[2011-11-04:08:00:02] Runtime Installer end with exit code 0
[2011-11-04:08:00:02] Elevated install completed
[2011-11-04:08:00:05] Got an unexpected fatal error while quitting: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception TypeError: Error #1009" errorID=1009]
[2011-11-04:08:00:05] Runtime Installer end with exit code 5
[2011-11-04:09:33:26] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-11-04:09:33:26] Commandline is:
[2011-11-04:09:33:26] No installed runtime detected
[2011-11-04:09:33:30] Runtime Installer end with exit code 6
[2011-11-04:09:33:55] Runtime Installer begin with version 3.0.0.4080 on Windows XP x86
[2011-11-04:09:33:55] Commandline is:
[2011-11-04:09:33:55] No installed runtime detected
[2011-11-04:09:34:05] Starting runtime install. Installing runtime version 3.0.0.4080
[2011-11-04:09:34:05] Installing msi at c:\users\tibi\appdata\local\temp\aire2bb.tmp\setup.msi with guid {ACEB2BAF-96DF-48FD-ADD5-43842D4C443D}
[2011-11-04:09:34:10] Got an unexpected fatal error while quitting: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception TypeError: Error #1009" errorID=1009]
[2011-11-04:09:34:10] Runtime Installer end with exit code 5
I have no ideea what could be the problem
Installation
24.2K
Guest
Nov 06, 2011 Nov 06, 2011
I'm sorry you're running into installation issues with AIR. Microsoft has just released a new utility that can help resolve installation problems. Would you mind giving this a try and let us know how it works for you? When running the Fix it, go through the uninstall process and try to remove Adobe AIR from your system. Once finished, download the latest version of AIR and install again.
Microsoft Install and Uninstall Fix It
If you still encounter problems, you can try the AIR zapper tool. You can find it on this post: http://forums.adobe.com/message/3737276#3737276
Guest
Hello
No this fix was also not working along with others I found on the net. I've spent a 3 days already on this. I'll attach the msi installer log maybe that will help you.
Can we see a debug output of the  executable(Adobe AIR Application Installer.exe)?
Regards
Guest
Nov 07, 2011 Nov 07, 2011
So this time can you try Windows Install Cleanup tool mentioned in this thread http://forums.adobe.com/thread/771325?tstart=0 to remove AIR Runtime and then install the latest AIR Runtime again?
To install this tool on 64bit Windows, you need to run this program in compatibility mode for WinXP SP3 (right click the exe file, Properties -> Compatibility)
Guest
Nov 14, 2011 Nov 14, 2011
Hello
Finally good news. The Compatibility mode it seems that solves the  issue, but it has to be used for the AdobeAIRInstaller.exe or whatever you try to run to install the adobe AIR.
The steps I followed are below:
1. Used the Windows Installer Cleanup and removed the Adobe AIR. (This could not be removed earlier from control Panel because the same error was shown)
2. Run the AdobeAIRInstaller.exe in Compatibility mode Windows XP SP3.
3. Install the Adobe AIR application. (This might also need the Compatibility mode set to XP SP3 if it's an EXE file)
Note: I also tried a variant with compatibility mode set to Windows XP SP3 to the C:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Adobe AIR Application Installer.exe and that also worked but only after the reinstallation of Adobe AIR.
As I see, if all exe's are set to Compatibility mode XP SP3 it is pretty much possible to solve the problem. I can do a few tests and come back since I cloned the PC to vmWare so I can work with the nonworking version of the app endlessly.
Regards
Guest
Glad to hear that!
